Didier Bur wrote:Didier Bur wrote:You simply turned me into francophil
Were you francophobe ???![]()
Nope I was francophag
[Plugin] Projections version 2 UPDATED 03.07.09
• Page 2 of 4 • 1, 2, 3, 4
Re: [plugin] Projections version 2 UPDATED 29.06.09
-- Nope I was francophag
Re: [plugin] Projections version 2 UPDATED 29.06.09Didier
It occurs to me that my recent tool cpointAtLineFaceIntersection.rb viewtopic.php?p=168853#p168853 might also be incorporated into your projection toolset - please feel free to reuse the code / ideas as you see fit... TIG
Re: [plugin] Projections version 2 UPDATED 29.06.09Didier:
Your last icon creates faces from a curve (a continuous curve), but the faces are not smoothed (like those created when push-pulling a circle or "welded" segments). Wondering if you can incorporate this into another or the same tool? What do others think. Good, bad, or unecessary? John
Illustrator Beaverton, Oregon
That's just what I was going to ask you for ! Thanks for contributing
This feature is incorporated in the code actually, but apparently doesn't work every time I'll check that asap. Regards, Didier Bur (Bytes Farmer)
Ecole Nationale Supérieure d'Architecture de Nancy (F) http://rld.crai.archi.fr/rubylibrarydepot/
Re: [plugin] Projections version 2 UPDATED 29.06.09THANK YOU!, will definitely try this updated plugin!
Re: [plugin] Projections version 2 UPDATED 03.07.09thank you very much Didier Bur
but you have probably forgotten to add the new images for the new buttons of the latest update. they are missing...
Re: [plugin] Projections version 2 UPDATED 03.07.09Am I missing something? There are 4 items you show on your first post that are blank on my toolbar. The icons for them are not even in the projection folder inside the zip file. I am confused.
Yes agree - I was just about to send the very same screenshot, since I'm also missing 4 icons. anyway - thx a lot for your good work on this - absolutely amazing!
Re: [plugin] Projections version 2 UPDATED 03.07.09I am also not seeing buttons 1, 5, 8, 9. If I mouse over these buttons their descriptions show up. I have not fully tested the functions yet. At first I thought the update would overwrite the previous. And then I reviewed the first post where you say to delete the previous, so I did that. However, the four mentioned buttons do not get their png's, which I believe are in the auxiliary folder.
Re: [plugin] Projections version 2 UPDATED 03.07.09I see all the buttons, but agree that the surface is not smoothed
Please, register (free) to access all the attachments on the forums. "If you don't plan ahead you'll be at the mercy of those that do" - Ashleigh Brilliant
"Bad is not good until worse happens" - Bob James
Here, all the buttons, change the folder from the archive of "Projection" Please, register (free) to access all the attachments on the forums.
What you have is not the latest version...so you can get or the buttons loaded. The latest version updated on 3. July is missing buttons. So waiting for Didier Bur.
No they are still not "all the buttons" compared to the latest update in first page. There are at least three buttons missing. It seems Didier Bur has updated the .rb but forgotten to change the folder. You can get all the buttons loaded because your .rb is not the latest one.
Re: [plugin] Projections version 2 UPDATED 03.07.09Sorry for the missing icons. Zip updated.
Re: [plugin] Projections version 2 UPDATED 03.07.09Hi Didier, regarding your smooth problem - have a look at Matt's script here
http://forums.sketchucation.com/viewtopic.php?f=180&t=11317&hilit=plugin
Re: [plugin] Projections version 2 UPDATED 03.07.09Hi Cadfathher,
Thanks a million. I knew that smoothing was possible, but the ruby doc is REALLY bad, it doesn't mention that an edge can be smoothed only when it shares 2 faces. It works now. Patch published. Didier Bur (Bytes Farmer)
Re: [plugin] Projections version 2 UPDATED 03.07.09wonder if anyone has the same thing - when i use extrude lines, i cannot draw the vector easily - it stop/starts or disappears.
only with difficulty i can align it along an axis.. will keep an eye if there's a clash somewhere
The Projection folder I have is dated 6 July 2009 and I downloaded the "Projection Patch" but I don't see any difference. What am I missing? Please, register (free) to access all the attachments on the forums. "If you don't plan ahead you'll be at the mercy of those that do" - Ashleigh Brilliant
this is what's happening - the inferencing works well when you have faces behind the cursor. it snaps strangely when in empty space thought i'd cheer you up for the day... Please, register (free) to access all the attachments on the forums.
Re: [plugin] Projections version 2 UPDATED 03.07.09It's me or when using undo with for exemple the Extrude line along a vector all the lines are killed
It's some annoying when you have made 10 extrude lines successive all is to remake Does not possible to have a real undo successive? Please, register (free) to access all the attachments on the forums.
Re: [plugin] Projections version 2 UPDATED 03.07.09Hi Pilou,
Someone asked me (a long time ago I confess) to have a global undo instead of a step by step undo. How to satisfy everybody ? In french: on m'a demandé il y a longtemps de faire un annuler global plutôt que par étape. c'est l'un ou l'autre, c'est difficile de contenter tout le monde... Didier Bur (Bytes Farmer)
Nothing. The new RBS is an update of the "extrude lines tool" to have smoothed surfaces when extruding curves, arcs, and circles. Regards, Didier Bur (Bytes Farmer)
Hem hem, Inference when there's no face behind cursor snaps to the Red-Green plane as I see Must look into it... Didier Bur (Bytes Farmer)
Re: [plugin] Projections version 2 UPDATED 03.07.09Damned!
It's very more subtle to have a partial Undo than a global Undo for this sort of function (just 10 clicks than a painful remake It's even absurd! As the drawing of the vector is not so evident, an error is speedy arrived! I am very disappointed
Re: [plugin] Projections version 2 UPDATED 03.07.09TIG's extrudeEdgesByRails.rb... NOT yet on general release...
Re: [plugin] Projections version 2 UPDATED 03.07.09Look forward to it's release TIG
SketchUcation One-Liner AdvertsNeed SketchUp Books, Models, Styles or Textures? Check out our One Stop Shop for SketchUp.
