SketchUcation Premium Membership
[Plugin] Projections version 2 UPDATED 03.07.09
Re: [plugin] Projections version 2 UPDATED 29.06.09
Postby DIEGO-RODRIGUEZ » Mon Jun 29, 2009 2:54 pm
Thank you very much for update Didier.
Three suggestion.
a - be possible to customize the toolbar?for example Plugins 1001bit 1.1.6
Leaving active in the toolbar only the tools I'm interested
b - Erase guides, Could have an option to delete all guides of the drawing?
c - Insert Insert guides and guides at intervals at divisions, after using them, are active at the same starting point.
the tool could be active. But choose a new edge?
and a question.
Achieve as the result of this picture?
Last edited by DIEGO-RODRIGUEZ on Mon Jun 29, 2009 3:11 pm, edited 1 time in total.
DIEGO-RODRIGUEZ
Banned
Postby rv1974 » Mon Jun 29, 2009 3:04 pm
Didier Bur wrote:Yes but I also see that you have another 'projection.rb' file which is the previous version. Do a clean install, removing ALL previous files in the Projections folder, and everything will go OK.
Regards,
Indeed it goes OK :P
Another thing: Could you add multiple not connected edges extrusion? It'd really add a lot
rv1974
Operating system: Windows
SketchUp version: 8
License type: Pro
SketchUp use: architecture
Level of SketchUp: Advanced
Postby Ken » Mon Jun 29, 2009 5:36 pm
Didier
Would it be possible to have a choice for Tools #6 and #7 to place either points or guide lines?
Thanks for me a very useful plugin
Ken
Government rushes to help the irresponsible and does little for the responsible.
Ken
Premium Member
Premium Member
SketchUp version: 8
License type: Pro
SketchUp use: engineering and mechanical design
Postby Didier Bur » Mon Jun 29, 2009 6:50 pm
Hi Chuck,
It seems you have the same problem than rv1974. An "uninitialized constant" error message means that the script within the "Projection" folder is not loaded, and an "undefined method" error message too. Check for the file "projection.rbs" in the Projection" sub-folder of plugins. Please tell me if it is there. :bounce:
Didier Bur (Bytes Farmer)
Ecole Nationale Supérieure d'Architecture de Nancy (F)
http://rld.crai.archi.fr/rubylibrarydepot/
Didier Bur
SketchUp version: 8
License type: Pro
Postby Didier Bur » Mon Jun 29, 2009 8:40 pm
You can do that already. Select unconnected edges as you would do with connected edges !
You can do that already too. After a first guides insertion, hit Enter to select a new edge (watch your status bar). Please read the doc folks ! :D
Didier Bur
SketchUp version: 8
License type: Pro
Postby urgen » Mon Jun 29, 2009 9:18 pm
...Thanks for update Didier,very useful. :thumb:
--pupil forever...------
urgen
Postby Ben Ritter » Mon Jun 29, 2009 9:55 pm
Didier,
Fantastic tools! Thank you very much.
Ben Ritter
Postby OTB Designworks » Tue Jun 30, 2009 2:34 am
Didier Bur wrote:Hi Chuck,
Hi Didier, thanks for the quick response.
Yes, the projection.rbs is in the projection folder.
I trashed the file and still no functionality. I have nothing but png's and the projection.pdf filesin the projection folder and still the same error messages. I tried placing the rbs file back in and still nothing works.
thanks for the help
Cheers, Chuck
Cheers, Chuck
MY BLOG
Become a fan of OTB Designworks on Facebook, we'd love to have you!
3.2ghz 8 core Mac Pro. 10 gig RAM, 8800 GT GPU, dual monitors
OTB Designworks
Postby takesh h » Tue Jun 30, 2009 6:40 am
Hi Didier, this looks like another sweeeet update, however with my iMac nothing so far works.
My situation is just like Chuck's, they don't seem like doing anything whatsoever upon my clicking icons.
I've been using Projection tools for the longest time and am very familiar with how they work.
They have been doing beautifully until I updated to ver.2.
I clean-installed them as well.
I just noticed that if I install them in [HD]-[user]-[username]-[library]-[Application Support]-[Google SketchUp6]-[SketchUp]-[plugin],
instead of usual [HD]-[library]-[Application Support]-[Google SketchUp6]-[SketchUp]-[plugin], everything works.
Hope this will be fixed... Thanks in advance!
takesh h
Postby Bob James » Tue Jun 30, 2009 8:05 am
I can verify the results of takesh h: It doesn't work if you put the necessary files in the usual place, but does work if you put them in the User Library.
The same is true for Profile Builder (for me, at least)
"If you don't plan ahead you'll be at the mercy of those that do" - Ashleigh Brilliant
"Bad is not good until worse happens" - Bob James
Bob James
Premium Member
Premium Member
SketchUp version: 8
License type: Pro
SketchUp use: other
Postby rv1974 » Tue Jun 30, 2009 8:34 am
You simply turned me into francophil :ecstatic:
http://www.youtube.com/watch?v=ye0_QCUgwO4&eurl=http%3A%2F%2Fdirty.ru%2Fcomments%2F255512&feature=player_embedded
rv1974
SketchUp version: 8
License type: Pro
Postby Pilou » Tue Jun 30, 2009 9:03 am
:mrgreen:
Speedy Galerie
Pilou
Top SketchUcator
SketchUp version: 6
License type: Free
SketchUp use: hobby
Postby OTB Designworks » Tue Jun 30, 2009 1:04 pm
bob.james5 wrote:I can verify the results of takesh h: It doesn't work if you put the necessary files in the usual place, but does work if you put them in the User Library.
This works for me as well! Thanks guys, I had forgotten that some scripts just don't like the "regular" library location.
Cheers, chuck
Cheers, Chuck
MY BLOG
OTB Designworks
Postby Didier Bur » Tue Jun 30, 2009 8:01 pm
Were you francophobe ??? :roflmao:
I'm far from an expert in MacOs, but this sounds to me to be like when on Windows you install some software for "all users" or for just one user.
I'll put that in the doc. Thanks for the tip !
Didier Bur
SketchUp version: 8
License type: Pro
Postby Edson » Tue Jun 30, 2009 8:23 pm
thanks, didier. a great plugin has become even better!
edson mahfuz, architect
http://www.mahfuz.arq.br
Anyone can get you more for more, but it takes genius to get you more for less.
Edson
Global Moderator
Operating system: Mac
SketchUp version: 8
License type: Pro
Postby rv1974 » Wed Jul 01, 2009 9:59 am
Nope I was francophag :D
rv1974
SketchUp version: 8
License type: Pro
Postby TIG » Wed Jul 01, 2009 10:24 am
Didier
It occurs to me that my recent tool cpointAtLineFaceIntersection.rb viewtopic.php?p=168853#p168853 might also be incorporated into your projection toolset - please feel free to reuse the code / ideas as you see fit...
Global Moderator
SketchUp version: 8
License type: Pro
Postby JClements » Wed Jul 01, 2009 3:21 pm
Didier:
Your last icon creates faces from a curve (a continuous curve), but the faces are not smoothed (like those created when push-pulling a circle or "welded" segments).
Wondering if you can incorporate this into another or the same tool?
What do others think. Good, bad, or unecessary?
John
Illustrator
Beaverton, Oregon
JClements
Premium Member
Premium Member
SketchUp version: 8
License type: Pro
SketchUp use: illustration, cartoons
Postby Didier Bur » Wed Jul 01, 2009 8:43 pm
That's just what I was going to ask you for ! Thanks for contributing :thumb:
This feature is incorporated in the code actually, but apparently doesn't work every time :oops:
I'll check that asap.
Regards,
Didier Bur
SketchUp version: 8
License type: Pro
Postby cyan.archnet » Fri Jul 03, 2009 2:01 am
THANK YOU!, will definitely try this updated plugin!
cyan.archnet
Postby accabrera » Fri Jul 03, 2009 5:30 am
:thumb: Thanks !!!
accabrera
Re: [plugin] Projections version 2 UPDATED 03.07.09
Postby boilingsnow » Sat Jul 04, 2009 3:28 am
thank you very much Didier Bur
but you have probably forgotten to add the new images for the new buttons of the latest update. they are missing...
boilingsnow
Postby boofredlay » Sun Jul 05, 2009 12:05 am
Am I missing something? There are 4 items you show on your first post that are blank on my toolbar. The icons for them are not even in the projection folder inside the zip file. I am confused.
boofredlay
Global Moderator
SketchUp version: 8
License type: Pro
Postby define » Sun Jul 05, 2009 1:29 am
Boofredlay wrote:Am I missing something? There are 4 items you show on your first post that are blank on my toolbar. The icons for them are not even in the projection folder inside the zip file. I am confused.
Yes agree - I was just about to send the very same screenshot, since I'm also missing 4 icons.
anyway - thx a lot for your good work on this - absolutely amazing!
define
Postby mitcorb » Sun Jul 05, 2009 4:06 am
I am also not seeing buttons 1, 5, 8, 9. If I mouse over these buttons their descriptions show up. I have not fully tested the functions yet. At first I thought the update would overwrite the previous. And then I reviewed the first post where you say to delete the previous, so I did that. However, the four mentioned buttons do not get their png's, which I believe are in the auxiliary folder.
mitcorb
Top SketchUcator
SketchUp version: 8
License type: Free
Postby Bob James » Sun Jul 05, 2009 8:02 am
I see all the buttons, but agree that the surface is not smoothed
Bob James
Premium Member
Premium Member
SketchUp version: 8
License type: Pro
SketchUp use: other
Postby blajnov » Sun Jul 05, 2009 8:15 am
Here, all the buttons, change the folder from the archive of "Projection"
blajnov
Postby boilingsnow » Sun Jul 05, 2009 10:03 am
bob.james5 wrote:I see all the buttons, but agree that the surface is not smoothed
What you have is not the latest version...so you can get or the buttons loaded.
The latest version updated on 3. July is missing buttons.
So waiting for Didier Bur.
boilingsnow
Postby boilingsnow » Sun Jul 05, 2009 10:09 am
No they are still not "all the buttons" compared to the latest update in first page. There are at least three buttons missing.
It seems Didier Bur has updated the .rb but forgotten to change the folder. You can get all the buttons loaded because your .rb is not the latest one.
boilingsnow
Postby Didier Bur » Mon Jul 06, 2009 7:49 pm
Sorry for the missing icons. Zip updated.
Didier Bur
SketchUp version: 8
License type: Pro
Need SketchUp Books, Models, Styles or Textures? Check out our One Stop Shop for SketchUp.
PreviousNext
Return to Plugins
Users browsing this forum: edmon05, lenreed, MSN Bot, nutbase, OzModiar, patriarch, Vichingo and 30 guests
