SketchUcation Premium Membership
[Plugin] Projections version 2 UPDATED 03.07.09
Re: [plugin] Projections version 2
Postby mitcorb » Thu Jun 25, 2009 9:06 pm
could it be camera position relative to horizon when selection is done? probably not, just wondering.
mitcorb
Top SketchUcator
Operating system: Windows
SketchUp version: 8
License type: Free/Make
SketchUp use: architecture
Postby massimo » Thu Jun 25, 2009 9:11 pm
Unfortunately nothing to do with camera position, Mitcorb. Don't understand why but it simply doesn't work for me.
massimo
Global Moderator
SketchUp version: 7
License type: Pro
SketchUp use: other
Postby Pilou » Thu Jun 25, 2009 9:58 pm
Any chance to integrate an "Offset" or similar in the "Extrude line along a vector"?
Speedy Galerie
Pilou
Top SketchUcator
SketchUp version: 6
SketchUp use: hobby
Level of SketchUp: Advanced
Postby massimo » Fri Jun 26, 2009 7:37 am
Didier Bur wrote:
The same happens (never works) if you try to do that on a single face in order to have a grid (horizontally + vertically).
Maybe it's only my problem?
Unfortunately I think it is your problem, because what you describe always work on my side...
Hi Didier and thanks for your patience. When i use for the second time "insert guides at divisions" some lines are missed (very often the middle line) but i've noticed that if i click a little bit below the edge of the solid it works fine. Maybe this makes some sense to you?
massimo
Global Moderator
SketchUp version: 7
License type: Pro
SketchUp use: other
Postby urgen » Fri Jun 26, 2009 9:13 am
... hi Dider! ....is it possible to add old function "create lines at intersection of selected faces" in a script?...It's very useful function :? ....I do not want come back to old script "ClineAtFaceIntersection.rb" :roll:
--pupil forever...------
urgen
Postby Didier Bur » Fri Jun 26, 2009 3:50 pm
OK, no problem, I was thinking this one were not so useful. I'll put it in next update.
Didier Bur (Bytes Farmer)
Ecole Nationale Supérieure d'Architecture de Nancy (F)
http://rld.crai.archi.fr/rubylibrarydepot/
Didier Bur
SketchUp version: 8
License type: Pro
Postby urgen » Fri Jun 26, 2009 4:26 pm
....thanks,Didier! :P
...For drawing of difficult roofs this function is very necessary ;)
urgen
Postby Didier Bur » Fri Jun 26, 2009 5:16 pm
Yes, it is due to the "automatic cleaner" bug. Bug was corrected yesterday, that's why this didn't happen here ;)
Didier Bur
SketchUp version: 8
License type: Pro
Postby rv1974 » Sun Jun 28, 2009 7:53 am
Hi Didier!
I can't make your new commands work.
Some quotations from console:
Error: #<NameError: uninitialized constant ProjectCpointTool>
C:/Program Files/Google/Google SketchUp 7/Plugins/projection_extension.rb:47
C:/Program Files/Google/Google SketchUp 7/Plugins/projection_extension.rb:47:in `call'
Error: #<NameError: uninitialized constant XLinesThrougLinesTool>
C:/Program Files/Google/Google SketchUp 7/Plugins/projection_extension.rb:23
C:/Program Files/Google/Google SketchUp 7/Plugins/projection_extension.rb:23:in `call'
Any ideas what's wrong in my case?
And thank you again and again for your contributions.
rv1974
SketchUp version: 8
License type: Pro
Postby Didier Bur » Sun Jun 28, 2009 8:10 pm
hi rv1974,
your installation is incorrect. You must have a sub-folder "projections" under plugins after unzipping the archive. Check for it, i'm almost sure this is not the case ;)
Didier Bur
SketchUp version: 8
License type: Pro
Postby DIEGO-RODRIGUEZ » Sun Jun 28, 2009 10:31 pm
Didier, thank you for this fantastic tool.
But I have the same problem massimo, with guide lines
DIEGO-RODRIGUEZ
Banned
Postby rv1974 » Mon Jun 29, 2009 9:10 am
Didier Bur wrote:hi rv1974,
For a 1st sight everything is OK. In fact I have your toolbar and the point tool working (one single click though)
rv1974
SketchUp version: 8
License type: Pro
Postby Didier Bur » Mon Jun 29, 2009 11:40 am
Yes but I also see that you have another 'projection.rb' file which is the previous version. Do a clean install, removing ALL previous files in the Projections folder, and everything will go OK.
Regards,
Didier Bur
SketchUp version: 8
License type: Pro
Re: [plugin] Projections version 2 UPDATED 29.06.09
Postby massimo » Mon Jun 29, 2009 12:37 pm
Thanks Didier, now it works very well. :thumb:
massimo
Global Moderator
SketchUp version: 7
License type: Pro
SketchUp use: other
Postby OTB Designworks » Mon Jun 29, 2009 1:48 pm
I am using a MAC pro, and this version 2 has no functionality on my computer.
Choosing any function has no effect whatsoever.
I am attaching the errors indicated in the Ruby console.
I have deleted all previous versions from my plug in folder.
Thanks and help! I use these all the time, especially extrude lines, which is a god send sometimes.
Cheers, Chuck
Cheers, Chuck
MY BLOG
Become a fan of OTB Designworks on Facebook, we'd love to have you!
3.2ghz 8 core Mac Pro. 10 gig RAM, 8800 GT GPU, dual monitors
OTB Designworks
Postby DIEGO-RODRIGUEZ » Mon Jun 29, 2009 2:54 pm
Thank you very much for update Didier.
Three suggestion.
a - be possible to customize the toolbar?for example Plugins 1001bit 1.1.6
Leaving active in the toolbar only the tools I'm interested
b - Erase guides, Could have an option to delete all guides of the drawing?
c - Insert Insert guides and guides at intervals at divisions, after using them, are active at the same starting point.
the tool could be active. But choose a new edge?
and a question.
Achieve as the result of this picture?
Last edited by DIEGO-RODRIGUEZ on Mon Jun 29, 2009 3:11 pm, edited 1 time in total.
DIEGO-RODRIGUEZ
Banned
Postby rv1974 » Mon Jun 29, 2009 3:04 pm
Didier Bur wrote:Yes but I also see that you have another 'projection.rb' file which is the previous version. Do a clean install, removing ALL previous files in the Projections folder, and everything will go OK.
Regards,
Indeed it goes OK :P
Another thing: Could you add multiple not connected edges extrusion? It'd really add a lot
rv1974
SketchUp version: 8
License type: Pro
Postby Ken » Mon Jun 29, 2009 5:36 pm
Didier
Would it be possible to have a choice for Tools #6 and #7 to place either points or guide lines?
Thanks for me a very useful plugin
Ken
Government rushes to help the irresponsible and does little for the responsible.
Ken
Premium Member
Premium Member
SketchUp version: 8
License type: Pro
SketchUp use: engineering and mechanical design
Postby Didier Bur » Mon Jun 29, 2009 6:50 pm
Hi Chuck,
It seems you have the same problem than rv1974. An "uninitialized constant" error message means that the script within the "Projection" folder is not loaded, and an "undefined method" error message too. Check for the file "projection.rbs" in the Projection" sub-folder of plugins. Please tell me if it is there. :bounce:
Didier Bur
SketchUp version: 8
License type: Pro
Postby Didier Bur » Mon Jun 29, 2009 8:40 pm
You can do that already. Select unconnected edges as you would do with connected edges !
You can do that already too. After a first guides insertion, hit Enter to select a new edge (watch your status bar). Please read the doc folks ! :D
Didier Bur
SketchUp version: 8
License type: Pro
Postby urgen » Mon Jun 29, 2009 9:18 pm
...Thanks for update Didier,very useful. :thumb:
urgen
Postby Ben Ritter » Mon Jun 29, 2009 9:55 pm
Didier,
Fantastic tools! Thank you very much.
Ben Ritter
Postby OTB Designworks » Tue Jun 30, 2009 2:34 am
Didier Bur wrote:Hi Chuck,
Hi Didier, thanks for the quick response.
Yes, the projection.rbs is in the projection folder.
I trashed the file and still no functionality. I have nothing but png's and the projection.pdf filesin the projection folder and still the same error messages. I tried placing the rbs file back in and still nothing works.
thanks for the help
Cheers, Chuck
Cheers, Chuck
MY BLOG
OTB Designworks
Postby takesh h » Tue Jun 30, 2009 6:40 am
Hi Didier, this looks like another sweeeet update, however with my iMac nothing so far works.
My situation is just like Chuck's, they don't seem like doing anything whatsoever upon my clicking icons.
I've been using Projection tools for the longest time and am very familiar with how they work.
They have been doing beautifully until I updated to ver.2.
I clean-installed them as well.
I just noticed that if I install them in [HD]-[user]-[username]-[library]-[Application Support]-[Google SketchUp6]-[SketchUp]-[plugin],
instead of usual [HD]-[library]-[Application Support]-[Google SketchUp6]-[SketchUp]-[plugin], everything works.
Hope this will be fixed... Thanks in advance!
takesh h
Postby Bob James » Tue Jun 30, 2009 8:05 am
I can verify the results of takesh h: It doesn't work if you put the necessary files in the usual place, but does work if you put them in the User Library.
The same is true for Profile Builder (for me, at least)
"If you don't plan ahead you'll be at the mercy of those that do" - Ashleigh Brilliant
"Bad is not good until worse happens" - Bob James
Bob James
Premium Member
Premium Member
SketchUp version: 8
License type: Pro
SketchUp use: other
Postby rv1974 » Tue Jun 30, 2009 8:34 am
You simply turned me into francophil :ecstatic:
http://www.youtube.com/watch?v=ye0_QCUgwO4&eurl=http%3A%2F%2Fdirty.ru%2Fcomments%2F255512&feature=player_embedded
rv1974
SketchUp version: 8
License type: Pro
Postby Pilou » Tue Jun 30, 2009 9:03 am
:mrgreen:
Speedy Galerie
Pilou
Top SketchUcator
SketchUp version: 6
SketchUp use: hobby
Postby OTB Designworks » Tue Jun 30, 2009 1:04 pm
bob.james5 wrote:I can verify the results of takesh h: It doesn't work if you put the necessary files in the usual place, but does work if you put them in the User Library.
This works for me as well! Thanks guys, I had forgotten that some scripts just don't like the "regular" library location.
Cheers, chuck
Cheers, Chuck
MY BLOG
OTB Designworks
Postby Didier Bur » Tue Jun 30, 2009 8:01 pm
Were you francophobe ??? :roflmao:
I'm far from an expert in MacOs, but this sounds to me to be like when on Windows you install some software for "all users" or for just one user.
I'll put that in the doc. Thanks for the tip !
Didier Bur
SketchUp version: 8
License type: Pro
Postby Edson » Tue Jun 30, 2009 8:23 pm
thanks, didier. a great plugin has become even better!
edson mahfuz, architect
http://www.mahfuz.arq.br
Anyone can get you more for more, but it takes genius to get you more for less.
Edson
Global Moderator
Operating system: Mac
SketchUp version: 8
License type: Pro
Vertex Tools for SketchUp. Take control over each vertex with this vertex editor for SketchUp.
Next
Return to Plugins
Users browsing this forum: borislf, Hortax, littlecoles, mehdiZ, OmarSun, TMLEE, tobi and 8 guests
