SketchUcation Plugin Store
[Request] Testing on a Mac
Postby chrisglasier » Wed Jun 17, 2009 9:59 am
Could some kind person(s) have a look at this plugin code? I'm told it does not work on a Mac (I only have a PC). I have gone through all the javascript and transformed all IE only syntax. Perhaps a cursory look at the attached files is enough to expose the cause.
Many thanks
Chris
chrisglasier
Operating system: Windows
SketchUp version: 8
License type: Free
SketchUp use: other
Re: [Request] Testing on a Mac
Postby tbd » Fri Jun 19, 2009 10:13 am
you can always download Safari for Windows and try things out.
on a quick look it seems that count variable is not defined in start() function and screws things out.
SketchUp Ruby Consultant | Podium 1.x developer
http://plugins.ro
tbd
Postby chrisglasier » Fri Jun 19, 2009 10:25 am
TBD wrote:you can always download Safari for Windows and try things out.
Thanks TBD.
Yes I have downloaded Safari but the code is so mixed up with Sketchup, I would need to make a whole lot of fake SU returns - maybe I will just have to do that.
The count variable is received from the ruby callback further down the page. I moved it up to make the code easier to read. Everything seems to work in a PC so I think it must be syntax related or possibly something to do with entities at the beginning (I saw something about that but I cannot remember where).
Any further help gratefully received!
My regards
Chris
chrisglasier
SketchUp version: 8
License type: Free
SketchUp use: other
Postby chrisglasier » Fri Jun 19, 2009 10:49 am
OK found it
Finally, there is a difference in the way that the Mac boots up SketchUp that you should be cautious about: there is no Sketchup.active_model when the Ruby scripts are first loaded. So if your script is making changes to the active_model at load time, it will not work on the Mac. The answer? Ensure code that references the active model is part of a UI event handler, responding to the user selecting a tool or a menu item. You can also use an AppObserver to get a callback whenever a new model is opened, at which point it's safe to talk to the active_model.
Anyone kind enough to help with the observer code?
Chris
chrisglasier
SketchUp version: 8
License type: Free
SketchUp use: other
Postby tbd » Fri Jun 19, 2009 11:01 am
I always do me coding outside of Sketchup using a proxy function for Sketchup related functions. This way I can do the testing easily,without waiting for Sketchup and with proper debug tools.
I would do some refactoring and add a proxy Sketchup function to test things in Safari.
if you need some small code to be tested on Mac - post it and I try it.
http://plugins.ro
tbd
Postby chrisglasier » Fri Jun 19, 2009 11:23 am
TBD wrote:if you need some small code to be tested on Mac - post it and I try it.
Thanks I can make a small example (thanks for the offer); but if you don't test it with Sketchup (but a proxy) how does the active model business fit in?
Chris
chrisglasier
SketchUp version: 8
License type: Free
SketchUp use: other
Postby chrisglasier » Fri Jun 19, 2009 12:32 pm
Here are html and rb files that open three scenes onloading. They work on a PC.
Chris
chrisglasier
SketchUp version: 8
License type: Free
SketchUp use: other
Postby tbd » Fri Jun 19, 2009 9:40 pm
ok, this is weird.
if I don't add the alerts the code doesn't get run. looks like some synchronization problems from HTML world to SketchUp world.
need to debug this further.
http://plugins.ro
tbd
Postby chrisglasier » Sat Jun 20, 2009 1:27 am
TBD wrote:ok, this is weird.
Sorry to have lumbered you with this.
The thing works on my PC with or without the alerts (but I expect you would have guessed that).
Do you think I should try and get the Sketchup team to look at it. CMD showed an interest in cgScenes so maybe he (or she) could help. Please let me know what you think.
And thanks again of course.
Chris
chrisglasier
SketchUp version: 8
License type: Free
SketchUp use: other
Postby Jim » Sat Jun 20, 2009 3:53 pm
Unless I misunderstand the problem, SketchUp always uses Internet Explorer no matter what other browser is installed.
Jim
Global Moderator
SketchUp version: 8
License type: Pro
SketchUp use: other
Postby thomthom » Sat Jun 20, 2009 4:01 pm
Jim wrote:Unless I misunderstand the problem, SketchUp always uses Internet Explorer no matter what other browser is installed.
On PC, yes. But on Mac it uses the Safari engine.
So when you're on PC developing a plugin - with no Mac to test on you can try your code on Safari to do some basic testing.
If you're on Mac it's worse though as IE hasn't been available on Mac since IE5 - and even then it was a completely different browser than the PC version.
Global Moderator
SketchUp version: 8
License type: Pro
SketchUp use: architecture
Level of SketchUp: Advanced
Postby thomthom » Sat Jun 20, 2009 4:04 pm
If this Mac testing isn't too urgent I could have a look at it. But I don't have much spare time as I'm working on an architectural project besides work which is due on ~2 weeks. +pluss my involvement in other projects and various beta testings.
But I do have a Mac Mini at home that I've used to debug ruby plugins.
Global Moderator
SketchUp version: 8
License type: Pro
Postby AdamB » Sat Jun 20, 2009 5:33 pm
[First off, thanks to TBD for forwarding the link to me..]
I never did really understand what it is you're trying to do, Chris, but the example TBD posted can be made to work by editing line 16 of sceneTest.rb to be:
cmd = "receiveSceneCount('#{count}')"
Guess they're not handling the (admittedly spurious) terminator correctly.
Adam
Developer of LightUp http://www.light-up.co.uk
AdamB
LightUp
Postby chrisglasier » Sat Jun 20, 2009 5:50 pm
Thanks all!
It is pretty late here, and I have only the energy to copy post my reply to Jim's PM ...
Thanks Jim, this Mac business is very troublesome. I found the following in the API documentation:
I looked at the AppObserver class, but as I have no experience of observers and I will have limited time with the Mac tomorrow, I thought if someone could help with the observer mentioned, I might just have a chance.
I'll post this in the topic as well.
My regards
Chris
chrisglasier
SketchUp version: 8
License type: Free
SketchUp use: other
Postby tbd » Sat Jun 20, 2009 6:05 pm
that code will never work race condition - JS code will run before the Ruby thing so you will get wrong values. that's why it works only when alert commands are inserted (which is not a solution imho)
you need to refactor the code and take that in account (or push Google to open their implementation of JS bridge from DC)
http://plugins.ro
tbd
Postby Jim » Sat Jun 20, 2009 6:36 pm
viewtopic.php?f=315&t=19831&st=0&sk=t&sd=a&start=45#p165464
ScottLininger wrote:On the WebDialog topic...
We wrote a somewhat generic bridge between JS and Ruby that we used for Dynamic Components. I learned a lot from that and would have some thoughts on how to build a new one that's truly generic and easy to use. That's almost worthy of its own big thread. ;)
One note: I think it would be work for the JS code side of a bridge to be stored in the ruby and then dumped into the WebDialog via execute_script, so JS code side of things would call something like this:
Code: Select all
window.location.href='skp:initialize_bridge';
...and then from there would have access to whatever JS methods we implement.
It doesn't sound like Google wants to open their code, but Scott says he is willing to help design a better bridge.
Jim
Global Moderator
SketchUp version: 8
License type: Pro
SketchUp use: other
Postby chrisglasier » Sun Jun 21, 2009 1:43 am
Thanks for all your help. In the end with the constraints of machinery and time, I decided to resort to the good old 1995 solution:
Code: Select all
function start(){
if(navigator.appName == 'Microsoft Internet Explorer') browserStart()
else{
confirmPanel = document.getElementById("confirm")
confirmPanel.innerHTML = "START"  }   }
function receiveSceneCount(x){
count = x    }
function browserStart(){
//TO FIND IF ANY SCENES EXIST
function confirmDown(){
switch(confirmPanel.innerHTML){
case "START": browserStart();  break
I hope it works but it really doesn't seem right.
Also I think it is wrong to start off a major new excursion into automated interfaces with workarounds! I would really like to find a proper solution. Perhaps the evolution of SKX will help expose it - but I wonder how.
Anyway thanks again for your time; I will let you know what happened tonight tomorrow; I foresee some grief!
Kind regards
Chris
chrisglasier
SketchUp version: 8
License type: Free
SketchUp use: other
Postby thomthom » Sun Jun 21, 2009 9:05 am
hmm... It might be that you try to do changes to the webpage before the DOM is ready. If you do things immediately as the webdialog is loaded you need to wait until all the HTML elements are built.
http://www.javascriptkit.com/dhtmltutors/domready.shtml
Global Moderator
SketchUp version: 8
License type: Pro
Postby chrisglasier » Sun Jun 21, 2009 9:44 am
I think I will look at that deeply if the thing fails tonight because everything now seems to work with a PC; and I have loaded the page into Safari and there are no syntax errors (tested with FF as well) just complaints about skp of course. So I don't want to mess with what exists.
It seems to me this is much the same as loading the active_model business. Anyway thanks for the info. I just hope I don't need to re-jig everything!
Cheers
Chris
chrisglasier
SketchUp version: 8
License type: Free
SketchUp use: other
Postby fredo6 » Sun Jun 21, 2009 12:58 pm
chrisglasier wrote:Could some kind person(s) have a look at this plugin code? I'm told it does not work on a Mac (I only have a PC). I have gone through all the javascript and transformed all IE only syntax. Perhaps a cursory look at the attached files is enough to expose the cause.
Many thanks
Chris
Chris,
You may just be facing a well-known synchronization issue with web dialogs on Mac. Unlike in Windows/IE, the windows.location callback verb called from HTML does NOT block, so that you continue execute JavaScript. Furthermore, most callbacks will be 'lost', as Sketchup uses only one buffer to communicate with Ruby, not a queue.
See that post: http://forums.sketchucation.com/viewtopic.php?f=180&t=13394&p=101428&hilit=+safari#p98793
You have to do the synchronization manually, which, I agree, is not a piece of cake.
Fredo
fredo6
Top SketchUcator
Postby chrisglasier » Mon Jun 22, 2009 5:47 am
Fredo6 wrote:You may just be facing a well-known synchronization issue with web dialogs on Mac. Unlike in Windows/IE, the windows.location callback verb called from HTML does NOT block, so that you continue execute JavaScript. Furthermore, most callbacks will be 'lost', as Sketchup uses only one buffer to communicate with Ruby, not a queue.
Thanks for replying Fredo. I am afraid I am quite new to Ruby, generally just using the callbacks to instruct SU to do things - "move component[x]" type of thing. I expected some hassle with Mac/PC compatibility but from the post you quoted it seems it is way beyond my ken, and the problems getting access to a Mac are fraught with frustration (as I predicted). I don't even know if the current version doesn't work but I suspect it won't.
Does this mean I have to make chains of javascript/ruby functions, viz
JS01 call ruby01; ruby01 call JS 02; JS02 call ruby 02 ... until the play is complete.
I have done something like this before with setInterval functions that control a number of different objects with different timing and paths, so if I have interpreted what you say correctly, I feel I would be still in with a chance (British stoicism and all that).
But there is still the problem, common on the forum I now know, of finding Mac owners willing to test. If anyone reading this will volunteer, I promise a mention in dispatches. Here, opportunistically, is the current "best chance" set of files.
cgScenes R1.033(white version with start).zip
Incidentally, Fredo, I did try to press for resolution of this well-known synchronization issue again in this reply to CMD - over optimistically perhaps.
My thanks and regards
Chris
chrisglasier
SketchUp version: 8
License type: Free
SketchUp use: other
Postby chrisglasier » Thu Jun 25, 2009 6:01 am
thomthom wrote:If this Mac testing isn't too urgent I could have a look at it. But I don't have much spare time as I'm working on an architectural project besides work which is due on ~2 weeks. +pluss my involvement in other projects and various beta testings.
That's kind of you to offer. Considering the obstacles bought up here and in the SFX Bridge topic, I think time becomes subservient to finding some solution (even if temporary). Perhaps it could be lodged in the repository for the benefit of anyone else attempting such similar lunacy with web dialogs and Macs.
Two sets of files are attached. Any original files and directories should be deleted. For the Mac version, I have:
... introduced a START control to deal with the fact there is no Sketchup.active_model when the Ruby scripts are first loaded. This is not a tool or a menu item but I think the effect should be the same.
... rewritten the code so that no window.location call is followed by any javascript statements.
... opened the MAC files in FF and Safari to see if either reported syntax errors.
Opportunistically, I included the PC version which includes the makings of a javascript call - initiated by user action in SU's display and selection observer - as described here. A solution to this too might be a good addition to the SFX web dialog section.
Whilst there is hope I am very willing to rejig things, provided I have guidance, so please let me know what you think.
Double tak*
Chris
* Norwegian for thank you if I remember correctly from my time working with Snohetta
chrisglasier
SketchUp version: 8
License type: Free
SketchUp use: other
Postby thomthom » Thu Jun 25, 2009 7:30 am
Close! :D
Tak = Roof
Takk = Thanks
OT (sorry but you got me curious) what work did you do with Snøhetta?
Global Moderator
SketchUp version: 8
License type: Pro
Postby chrisglasier » Thu Jun 25, 2009 7:46 am
thomthom wrote:Close! :D
Tak = Roof
Takk = Thanks
Alexandria Library (design time schedule and monitoring); also co-authored Atomic Architecture with Craig Dykers, one of the founders ... a long time ago!
Chris
Edit added AA link - now Google is working
chrisglasier
SketchUp version: 8
License type: Free
SketchUp use: other
Postby TIG » Fri Jun 26, 2009 8:58 am
Can some one with a Mac tell me what they get returned when they use this snippet in the Ruby Console...
Code: Select all
ENV["TEMP"]
Is it 'nil' or a 'path_to_the_temp_folder' ?
Also with
Code: Select all
ENV["TMP"]
ditto ...
Also a Mac whole ENV listing, got thus...
Code: Select all
ENV.sort
would be helpful.
Global Moderator
SketchUp version: 8
License type: Pro
Postby tbd » Fri Jun 26, 2009 9:55 am
Code: Select all
ENV["TEMP"]
=> nil
Code: Select all
ENV["TMP"]
=>nil
Code: Select all
ENV.sort
=> [["COMMAND_MODE", "legacy"], ["DISPLAY", "/tmp/launch-jGxAIU/:0"], ["HOME", "/Users/TBD"], ["LOGNAME", "TBD"], ["PATH", "/usr/bin:/bin:/usr/sbin:/sbin"], ["PYTHONPATH", "/Applications/Quick Search Box.app/Contents/Frameworks/Vermilion.framework/Resources"], ["SHELL", "/bin/bash"], ["SSH_AUTH_SOCK", "/tmp/launch-4hMGhW/Listeners"], ["TMPDIR", "/var/folders/oo/oofmaDN7HfGByvhOdkcyck+++TI/-Tmp-/"], ["USER", "TBD"], ["__CF_USER_TEXT_ENCODING", "0x1F5:0:0"]]
http://plugins.ro
tbd
Postby TIG » Fri Jun 26, 2009 9:58 am
Thanks TBD, so your temp folder is called "TMPDIR" :D
Global Moderator
SketchUp version: 8
License type: Pro
Are you a Premium Member? Get your freebies here. Are you not a Premium Member yet? Upgrade your account to grab these freebies instantly.
Return to Plugins
