[Plugin] Simple Loft alpha 0.1b -- UPDATED May-15-09Re: [Plugin] Simple Loft alpha 0.1b -- UPDATED May-15-09Chris, You are A GENIUS!!!
Re: [Plugin] Simple Loft alpha 0.1b -- UPDATED May-15-09I just downloaded the loft plugin and I'm finding that once I select the loft tool
I can't select any of the curves in my model. Any suggestions?
Re: [Plugin] Simple Loft alpha 0.1b -- UPDATED May-15-09Jacqueline, could you post either the model or a screen shot so we can see what you're doing?
Out of curiosity, is there any chance your curves are inside components or groups that are not open for editing? Inspecting mirrors is a job I could easily see myself doing.
Re: [Plugin] Simple Loft alpha 0.1b -- UPDATED May-15-09Thank you so much for sharing this use full
Re: [Plugin] Simple Loft alpha 0.1b -- UPDATED May-15-09You're welcome. There are better tools for lofting now. This was the first one, but TIG and FREDO in particular have done lots of amazing work with lofting plugins. I'd recommend looking at theirs.
Re: [Plugin] Simple Loft alpha 0.1b -- UPDATED May-15-09Hi,
one simple question, I downloaded the rb script for the loft tool but it doesn't appear in my sketchup. Neither in my plugins menu even if i click and drag it into the plugins folder of my sketchup. If you could help, i would really like to use it, seems to work like a charm to creat super smooth surfaces. Thanks
Re: [Plugin] Simple Loft alpha 0.1b -- UPDATED May-15-09Almost always when a user reports that a plugin doesn't work, the reason turns out to be that it was installed incorrectly. Since I know for a fact that the plugin does work, I'll assume the your problem is the same. It appears you have Win7. In that OS you must have administrator privileges to install files into the Plugins folder. Do you? If not, you'll need to change that so you do.
Second, you say you dragged it into your Plugins folder. Did you extract the contents of the ZIP file? When you open the ZIP file you'll see there is a file whose extension is .rb and a folder. The folder has some icon and other files. Those contents must remain in that folder inside the Plugins folder. There's a sticky post about installing plugins in this forum. Read it. After you've made sure you have administrative rights to add files to the Plugins folder and you've installed it correctly, check to see if it works. If you still have problems, let us know. Include screen shots that show the plugin installed correctly in the Plugins folder. Also, this plugin contains a single button toolbar. You'll want to turn that on under View>Toolbars. Inspecting mirrors is a job I could easily see myself doing.
