by thomthom » Fri Dec 31, 2010 6:22 pm
Gaieus wrote:One question before downloading. I saw that you had it as UV Toolkit 2 in the menu - along with the original one (???). Do I need to remove the previous version or will I (also) end up with two toolsets?
You'll have to remove v1 as v2 doesn't overwrite v1. Both can co-exist - but there'd be no point.
- PluginStore Author
- Name: Thomas Thomassen
- Operating system: Windows
- SketchUp version: 2019
- License type: Pro
- SketchUp use: other
- Level of SketchUp: Advanced
by thomthom » Fri Dec 31, 2010 6:24 pm
Ahah! Thou tries to trix me! That was " TT Toolkit" you saw - just a little snippet of WIP code. Not related to UV Toolkit.
- License type: Pro
by Gaieus » Fri Dec 31, 2010 6:31 pm
Ah, okay. My eyes are not the best since they have been replaced...
- Name: Csaba Pozsárkó
- SketchUp version: 2013
- License type: Pro
- SketchUp use: historical reconstruction
by thomthom » Fri Dec 31, 2010 6:59 pm
...so is my brain...
- License type: Pro
by Rich O Brien » Fri Dec 31, 2010 7:25 pm
Point proven on the post count
Rich O Brien
- Administrator
- Name: Rich O'Brien
- SketchUp version: 2017
- License type: Pro
- SketchUp use: engineering and mechanical design
Ooooops , thanks for the great update Thom
Rich O Brien
- Administrator
- License type: Pro
by Gaieus » Fri Dec 31, 2010 7:32 pm
rclub24 wrote:Point proven on the post count
Ditto
- License type: Pro
by nektares » Thu Jan 06, 2011 7:42 pm
this is fantastic! thanks thomas!
nektares
by thomthom » Thu Jan 06, 2011 10:14 pm
- License type: Pro
by TIG » Thu Jan 06, 2011 10:25 pm
Looks v_e_r_y promising [sell it to Solo quickly!] Awaiting a trial version...
- Global Moderator
- Name: TIG
- SketchUp version: 2021
- License type: Pro
- SketchUp use: architecture
by jason_maranto » Thu Jan 06, 2011 10:27 pm
You are officially my hero! Best, Jason.
jason_maranto
- Name: Jason Maranto
- SketchUp version: 8
- License type: Pro
- SketchUp use: illustration, cartoons
by notareal » Thu Jan 06, 2011 10:30 pm
thomthom wrote:UV Memory (2.1.0) Very Experimental! Use only on triangles and quad-faces.
I am sold already... looking good.
notareal
- Thea Render Support
- Name: notareal
by solo » Thu Jan 06, 2011 10:40 pm
You da man, will test this tomorrow.
solo
- Global Moderator
- Name: solo
- License type: Pro
by thomthom » Thu Jan 06, 2011 10:42 pm
- License type: Pro
by Rich O Brien » Thu Jan 06, 2011 11:07 pm
No, Mike, i'm more....
Rich O Brien
- Administrator
- License type: Pro
by mitcorb » Thu Jan 06, 2011 11:13 pm
Mike???
mitcorb
- Top SketchUcator
- Name: mitcorb
- SketchUp version: 2016
- License type: Pro
by Rich O Brien » Thu Jan 06, 2011 11:16 pm
Yeah, Mike
Rich O Brien
- Administrator
- License type: Pro
by thomthom » Thu Jan 06, 2011 11:22 pm
Well that's a new nick name...
- License type: Pro
by mitcorb » Fri Jan 07, 2011 12:09 am
And ThomThom left you like this on your last outing?
Edit: oops, in case that doesn't translate culturally, no insinuations intended.
mitcorb
- Top SketchUcator
- Name: mitcorb
- License type: Pro
by Gaieus » Fri Jan 07, 2011 1:26 pm
Unfortunately TT was not there at our last outing - but otherwise it was something like that... Back to-topic: fantastic tool, Thom, thanks a lot! I will now have to find another (improved) trick to do my arches...
- License type: Pro
by thomthom » Fri Jan 07, 2011 1:43 pm
Gaieus wrote:Back to-topic: fantastic tool, Thom, thanks a lot! I will now have to find another (improved) trick to do my arches...
I have something up my sleeves for that as well, but it's in it's third re-coding. (...or was that fourth...) to get it working right.
- License type: Pro
by Gaieus » Fri Jan 07, 2011 2:54 pm
Just let me know when you need a beta forum!
- License type: Pro
by erikB » Fri Jan 07, 2011 3:32 pm
TT this ruby is amazing !! Will be very usefull. erikB
erikB
- Name: Erik Bosquet
- License type: Pro
by Ben Ritter » Fri Jan 07, 2011 6:14 pm
Thank you so much Thomas.
Ben Ritter
- Name: Ben Ritter
- License type: Pro
by nektares » Fri Jan 07, 2011 10:20 pm
Thanks for this one ThomThom it makes alot easier several uvmapping situations! this is great! Thanks again!
nektares
by shura » Sat Jan 08, 2011 1:01 am
Yes very useful indeed, thank you Thomas! The Remember/Restore function is very innovative too. I tried to make a pillow but it didn't work (back). Maybe because I also edited by using Move tool on single vertices? However, with only Smoove it works well (front). testin.jpg
shura
- Name: Alexander
- SketchUp version: 7
- License type: Pro
- SketchUp use: interior design
by thomthom » Sat Jan 08, 2011 3:01 am
shura wrote: I tried to make a pillow but it didn't work (back). Maybe because I also edited by using Move tool on single vertices? However, with only Smoove it works well (front).
It didn't restore properly after using Move, but Smoove worked fine? How how odd... I really don't know why that would be. I'll try and see if I can reproduce it.
- License type: Pro
by shura » Sat Jan 08, 2011 8:26 am
Hi, I've reproduced the same process with a less complex geometry and it seems to work well (!). When it did not work before, I have fiddled a lot with the vertices - or maybe the memory got lost when saving the file? ChessPatTest.jpg
shura
- Name: Alexander
- License type: Pro
by thomthom » Sat Jan 08, 2011 1:50 pm
If you erase/recreate geometry you will loose mapping data.
- License type: Pro
by shura » Sat Jan 08, 2011 2:31 pm
Ah, that sounds plausible. Not sure what I did wrong, but I guess must have been something like that.
thank you Thomas
shura
- Name: Alexander
- License type: Pro
- Robot
Return to Plugins
