SketchUcation Plugin Store
[Plugin] HoverSelect - v1.1d - 26 Nov 09
Re: [Plugin] HoverSelect - v1.1d - 26 Nov 09
Postby mitcorb » Sun Jan 17, 2010 11:32 pm
From what I can tell, this is a tool for edge selection only.
I could sure use a Hoverselect Only Faces as a way to select faces exposed to the camera. Otherwise, you box select every thing in the box from here to the horizon, then you have to unselect the stuff on the other side of the mesh that you discover after orbiting the model.
One good use for a Hoverselect face tool is to then apply Joint Push Pull to those selected faces.
mitcorb
Top SketchUcator
Operating system: Windows
SketchUp version: 8
License type: Free
SketchUp use: architecture
Postby mitcorb » Mon Jan 25, 2010 8:19 pm
So... this is not a good idea?
mitcorb
Top SketchUcator
SketchUp version: 8
License type: Free
Postby Fredo6 » Tue Jan 26, 2010 9:43 am
mitcorb wrote:So... this is not a good idea?
It is...
I may end up doing it in my redesign of HoverSelect
Fredo
Fredo6
Top SketchUcator
Postby blakelywallace » Wed Feb 10, 2010 4:24 am
Hey Fredo,
Any news on the addition of a lasso selection tool? Would be super handy...
Many thanks for all your hard work :)
blakelywallace
Postby hebeijianke » Thu Aug 26, 2010 4:38 pm
When I use this tool "Selection by rectangle:"
If I select a line that is hiden
It does not work
hebeijianke
Postby Fredo6 » Thu Aug 26, 2010 5:30 pm
hebeijianke wrote:Hi
It does not work
By default, the rectangle selection selects only on visible edges (like the Eraser tool).
To include all edges, you have to use the Shift modifier (pressed or in toggle mode). The green rectangle border gets thicker and the hidden edges are highlighted.
Fredo
Fredo6
Top SketchUcator
Postby hebeijianke » Thu Aug 26, 2010 7:06 pm
I see :D
hebeijianke
Postby dereeei » Sat Mar 12, 2011 5:20 pm
Script doesn't work for me, I mean it doesn't select anything. I have the menu, i can "use" the selection tool, but it doesn't select any edge. Compatibility issue with SU8 maybe?
dereeei
Postby Oxer » Mon Apr 25, 2011 3:25 pm
Hi Fredo and thanks for the plugin!
I have translated the plugin to Spanish language this is the file:
HoverSelect_11d-ES.zip
http://www.oxervision.blogspot.com/
Oxer
Operating system: Mac
SketchUp version: 8
License type: Pro
SketchUp use: illustration, cartoons
Level of SketchUp: Advanced
Postby amuyobo » Thu Jun 09, 2011 3:31 pm
Just started using Sketchup - this plugin is an absolute must! Thank You!
amuyobo
Postby Carrozza » Thu Sep 22, 2011 2:48 pm
I have pretty much the same problems as Dereeei (see above): when I activate the plugin and click-hover on edges nothing get selected.
What's worst, in rare occasions it works, it seems mostly after having performed a rectangle select action.
What works flawlessly is the click-on-face selection, but that's the less useful feature because for what I understand it pretty much replicate the native double-click Sketchup funcionality.
Could someone please help me make this great plugin work?
Cheers!
Carrozza
Postby Fredo6 » Fri Sep 23, 2011 6:07 am
Carrozza wrote:I have pretty much the same problems as Dereeei (see above): when I activate the plugin and click-hover on edges nothing get selected.
Just in case, did you check the edge property filter? By default, HoverSelect does not select Smooth edges (even if they appear as plain edges). But you can change the filter.
Fredo
Fredo6
Top SketchUcator
Postby Carrozza » Fri Sep 23, 2011 7:53 am
I thing filters are correct (all four button pressed); I can say it because when I disable some type of edges there's a forbid sign near the cursor while overing excluded edge types.
I made tests in a few different situations and models, but no luck so far.
In case it matters here are all the plugins installed:
Chris's Shape Bender.
Didier's Projections.
Diggory's Recurve.
Fredo's Bezier Spline, Curviloft, Hover Select, Scale, Joint PushPull, Round Corner, Tools on surface.
ThomThom's Cleanup.
I have Sketchup 8 running on Windows 7 64 bit, graphics card is Nvidia GeForce GT 525M (mobile).
Thanks for your great plugins and your help.
Carrozza
Postby Carrozza » Mon Sep 26, 2011 10:39 am
Fredo, is there hope you'll look into this issue?
Unfortunately selecting only edges without faces is a real pain in Sketchup...
Carrozza
Postby Fredo6 » Mon Sep 26, 2011 12:15 pm
Carrozza wrote:Fredo, is there hope you'll look into this issue?
I'll see what I can do quickly and come back
Fredo
Fredo6
Top SketchUcator
Postby irwanwr » Fri Dec 23, 2011 5:46 am
i'll try to learn and use this one too. IA.
thank you Fredo
irwanwr
SketchUp version: 8
License type: Free
SketchUp use: hobby
Level of SketchUp: Beginner
Postby Swissmountain » Fri May 04, 2012 10:27 pm
Hey Fredo, same problem over here on Mac OSX Snowleopard, Sketchup 8.0.11751 & LibFredo6 - v4.4m - 14 Apr 12
I see the menu but can't select anything, there is no selection rectangle either.
Thank you for everything you do
Ciao
Cogito ergo dum-di-dum
Swissmountain
Postby Fredo6 » Sat May 05, 2012 5:31 pm
Does this problem happen only with HoverSelect or all my plugins?
If so, this may come from a conflict with some other plugins (like some versions of Podium and Matchbox)
Fredo
Fredo6
Top SketchUcator
Postby Swissmountain » Tue May 08, 2012 10:58 pm
All your other plugins work like a charm on my machine Fredo, thank you for the update to the round corner and curviloft scripts earlier this year!
The hoverselect sounds like an amazing tool for speeding up more organic modeling approaches which require selection and scaling of splines, I would love to make it a part of my toolbox.
Swissmountain
Need Authorised SketchUp Training by experts in various disciplines? Check out our Training details.
PreviousNext
Return to Plugins
Users browsing this forum: anteolic, bakti, Bing [Bot], CadFather, gera007, gregpettigrew, lcb163, UanYang and 14 guests
