[Plugin] Center on Origin UPDATE May 23, 2013
Re: [Plugin] Center on Origin
Postby nesh70 » Sat Nov 02, 2013 4:39 am
nesh70 wrote:Hi!
Thanks for creating so useful SU plugin!
BTW, is there a way to center a model or component like the image B (not like the original script do - image A)?
Best regards!
I found out how to achieve it, changing the line
vector = point.vector_to [0,0,0]
to
vector = point.vector_to [0,0,model.bounds.height / 2]
nesh70
Re: [Plugin] Center on Origin UPDATE May 23, 2013
Postby TIG » Sat Nov 02, 2013 11:43 am
Why not use something like
vector = point.vector_to(model.bounds.center)
for the center, or
pt=model.bounds.center
pt.z=model.bounds.min.z
vector = point.vector_to(pt)
for the center-bottom
Global Moderator
Postby babak » Sun Nov 03, 2013 10:03 pm
nesh70 wrote:
nesh70 wrote:Hi!
I use this plugin for centering an object while setting it's bounding box bottom at 0 :
center_group_bottom.rb
You can find it at http://www.fsdeveloper.com/forum/showthread.php?t=71321
download link
http://www.fsdeveloper.com/forum/attach ... 1310763814
babak
Postby nesh70 » Mon Nov 04, 2013 5:44 pm
babak wrote:
nesh70 wrote:
nesh70 wrote:Hi!
download link
Thanks babak! It works perfectly! Just what I wanted!
nesh70
Postby tsurfing » Sat May 10, 2014 3:48 am
Hi Chris,
Tried to enter the patch script at the start of this thread, but the the ruby script is different than what you quoted:
And here's another option. If you want it to reset the component rotation and scale, edit the ruby file in a plain text editor (like Notepad for example) and after the line:
if comp.typename == "Group" || comp.typename == "ComponentInstance"
add the two following lines:
t = Geom::Transformation.new
comp.transformation = t
This is it now:
sela.each do |e|
if e.is_a?(Sketchup::Group) || e.is_a?(Sketchup::ComponentInstance)
to_move << e
I need to zero out the components rotation/scale
What's your thoughts?
Terry
tsurfing
Previous
Return to Plugins
Users browsing this forum: alpunia, DenisGavrilyuk, L13291898300, magduss11 and 9 guests
