SketchUcation Plugin Store
[Plugin] New Piping System Plugin
Re: New Piping System Plugin
Postby SHK » Wed Apr 29, 2009 10:29 am
Daniel,
please make sure, your length snapping under "Model info>units" is using a value bigger then 00000.
This should solve your problem.
Regards, Sebastian
P.S. we could fix a problem at the mail server. All email addresses ending with @3skeng.com are now up and running.
SHK
Postby craigbic » Thu Apr 30, 2009 4:26 pm
Awesome plugin! Very intuitive interface. I can't wait for the conceptual version. Keep up the good work! :ecstatic:
Checkout the Sketchup Graphics Blog at http://sketchupgraphics.com
craigbic
Postby JClements » Thu Apr 30, 2009 7:28 pm
Very nice UI!!! I see Josef Leibinger authored the Ruby. Kudos to him as well.
Suggestions:
1- Allow input of a radius either through typing in a value followed by an "R" or input of math such as "1.235/2".
2- Option to simultaneously draw centerlines on a user defined layer.
3- Elbows and reducer. Reconstitute separate arc segments into true circle.
4- T's. If the diameter of both pipes are equal then the diameter endcap of the branching pipe shows through the pipe it is centered on due to "Z-fighting" in SU. An option to hide the edge of the this diameter or to put in it on a hidden layer would remedy this.
5- eccentric reducers.
6- Option to use pre-selected centerlines? I'm guessing this could be useful if using client supplied CAD drawing; not sure how it would be implement though :). Perhaps when edge intersections are detected (like a T) it would query the user to pick a pipe, T, or elbow.
5- I agree with Jean Lemire about naming the groups.
John
Illustrator
Beaverton, Oregon
JClements
Premium Member
Premium Member
Operating system: Windows
SketchUp version: 8
License type: Pro
SketchUp use: illustration, cartoons
Postby urgen » Thu Apr 30, 2009 7:32 pm
....Many thanks to SHK (Sebastian Kummer?) and talent of Josef Leibinger!...Very useful!... PIPESOAPSKINBUBLE? ;) :D
--pupil forever...------
urgen
Postby Pilou » Thu Apr 30, 2009 10:41 pm
In the video we can see a modification in "Real time" ,
a move of a grey pipe with automatic transformation
That is possible because it's built with library components or it's possible with any pipes built with the plug?
Speedy Galerie
Pilou
Top SketchUcator
SketchUp version: 6
License type: Free/Make
SketchUp use: hobby
Level of SketchUp: Advanced
Postby SHK » Fri May 01, 2009 9:19 am
Thank you for your answers, suggestions and positive feedback. Yes, Josef Leibinger is part of our software team and he is dong a great Job.
We have very interesting functions (flex, editing...) on our roadmap. We are working hard to convert our prototypes into products "ready to publish".
SHK
Postby Burkhard » Fri May 01, 2009 11:11 am
A short hint. If you have open the tutor and switch to the selection tool, the tutor appears everytime you try to orbit around with the mouse wheel.
Greetings to Josef...
Burkhard
Burkhard
Premium Member
Premium Member
SketchUp version: 8
License type: Pro
SketchUp use: interior design
Postby MALAISE » Sat May 02, 2009 3:40 pm
This plugin really simplifies pipes drawings. I agree J.LEMIRE about improvements which could be implemented.
Gut gemacht Leute, erste Klasse Arbeit.
MALAISE :thumb:
MALAISE
Postby JClements » Wed May 13, 2009 8:35 am
A couple more suggestions:
1- Choose to put group on a specific, predesignated layer, but keep extruded contents on Layer0.
2- Choice of the number segments for circles and arcs.
I believe it currently defaults to 60 segments; this is impractical for any models with more than few pipes as it will surely creat files in the megabytes.
John
Illustrator
Beaverton, Oregon
JClements
Premium Member
Premium Member
SketchUp version: 8
License type: Pro
Postby SHK » Wed May 20, 2009 7:08 pm
Today we published the MAC version. We are very interested, how many of you are working with a MAC...
Best regards
Sebastian
SHK
Postby RoboDoc » Thu May 28, 2009 6:41 pm
Hello,
I installed the Mac plugin and it is working well. Great system. I had a problem, though. When I first installed the plugin, I was happily making 2" round pipe as desired. After a bit, it changed to hexagonal profile pipe and I can't seem to get things back to round. There didn't seem to be any solution in the tutorial. How do you choose between the profile of the various pipes?
R
RoboDoc
Postby Jean Lemire » Mon Jun 01, 2009 4:00 pm
Hi folks.
After installing the Mac plugin, SU 7 stop working. SU starts then exit immediately.
I had to uninstall all and then reinstall all.
I am using OS 10.4.11 (Tiger).
Is this pluggin only for OS 10.5 (Leopard) ?
I have to wait before trying a new install of this plugin.
Just ideas.
Jean (Johnny) Lemire from Richelieu, Quebec, Canada.
Jean Lemire
Global Moderator
SketchUp version: 8
License type: Pro
SketchUp use: engineering and mechanical design
Postby bhealy27 » Sat Jun 06, 2009 4:53 pm
I can't find the files this Plugin installed on my Mac. Either they are in some strange location or I don't know what the name of the files are. How do I uninstall these if I don't want it cluttering up my system?
I've looked in Library>Application Support>Google Sketchup 7>Sketchup>Plugins in both the Macintosh HD and User Directories without luck.
bhealy27
Postby Burkhard » Sat Jun 06, 2009 7:02 pm
called 3dskeng and has its own two button toolbar
Burkhard
Premium Member
Premium Member
SketchUp version: 8
License type: Pro
Postby Howard Leslie » Sun Jun 07, 2009 11:30 am
Sebastian / Josef,
Great plug-in.
Excellent user interface - very fast to use.
A few suggestions / ideas / requests:
1. Ability to specify number of segments for circles (pipe profiles) (to help keep file sizes down).
2. Ability to have pipe sections, pipe junctions etc as COMPONENTS - or all geometry as COMPONENTS
3. Ability to NAME these Components (if user requires it).
4. Ability to automatically generate Centrelines for all geometry eg each pipe section - very useful for snapping / lining up / offsetting other geometry to. This centreline to go on its own layer eg "Centreline"
5. Ability to Specify "Pipes" of Square or Rectangular Cross Section. This plug-in could then be used to model other types of Ducts eg Ventilation Systems / Air-Conditioning Systems.
6. See the excellent Profile Builder Plug-in. If you have centrelines you will be able to generate total LENGTHS for each Pipe section. From the pipe profile (area) you can then calculate VOLUME of each Pipe Section. Some type of Reporting function that will generate Lengths, Volumes and Totals for each Pipe Section (Named Components). These Reporting out type functions / code already exist in several other Plug-ins eg by TIG, Jim Foltz and others.
Just a thought...
Potentially both The Profile Builder and your Piping System Plug-in Compliment each other very well.
Maybe you should Team Up with Dale Martens who created The Profile Builder plug-in so that you can have the best of both worlds ???
You could use Dale's Profile Builder so that you can use any profile / cross-section you want to - but they would be modelled in a very simple and intuitive way using your superb drawing engine / user interface ???
A marriage made in su heaven ??? !!!
Keep up the good work on this fantastic plug-in.
Regards
Howard L'
Howard Leslie
SketchUp version: 8
License type: Pro
Postby JClements » Sun Jun 07, 2009 3:31 pm
What is the STATUS of this plugin's DEVELOPMENT ?????
[Edit] I now see that you can change the circle segmentation value when the pipe tool is intiated by typing in the VCB (a.k.a "Measurements" box in the SU taskbar). This is mentioned in the tutor dialog which I had turned off.
John
Illustrator
Beaverton, Oregon
JClements
Premium Member
Premium Member
SketchUp version: 8
License type: Pro
Postby Coronel » Sun Jun 07, 2009 11:29 pm
It don't work on Mac
Coronel
Postby bianhai » Mon Jun 08, 2009 4:55 am
Good! :thumb:
bianhai
Banned
Postby Bob James » Tue Jun 23, 2009 3:07 am
I just downloaded this plugin and it works fine on my MacPro.
In addition to Profile Builder I often use the "Convert Arcs, Circles, Curves and Lines to Cylinders" plugin. It has the advantage of being able to define a material, opt to make a the whole thing a group or make each tube a group, in addition to defining the diameter and precision. A neat plugin.
This "New Piping System Plugin" would be nice if it had some standard library of fittings.
"If you don't plan ahead you'll be at the mercy of those that do" - Ashleigh Brilliant
"Bad is not good until worse happens" - Bob James
Bob James
Premium Member
Premium Member
SketchUp version: 8
License type: Pro
SketchUp use: other
Postby watkins » Sat Jun 27, 2009 2:19 pm
Dear SHK,
Can this plugin be used to plan a domestic central heating system - boiler, radiators, control valves, pumps etc?
The technology behind this plugin suggests that it could be adapted to wiring schemes too, both domestic and industrial.
Regards,
Bob
watkins
Postby Coronel » Fri Jul 03, 2009 3:16 pm
Bob James wrote:I just downloaded this plugin and it works fine on my MacPro.
2x2 Ghz Power PC G5 with 10.5.7 and SU 7 here.
I make several attempts and no luck. I also did a manual installation but no luck. I only got some console message errors depending on the path of the installed components.
Could you please write me your components paths? Thanks
Coronel
Postby Bob James » Sun Jul 05, 2009 8:45 am
Coronel wrote:Could you please write me your components paths? Thanks
Coronel,
It just clicked on the 3skenglt© for Google Sketchup 7.mpkg file.
I could not find out where the mpkg file installed the working files: definitely not in the plugins folder.
When you say you "manually" installed it, just what did you manually install??
Note this from the SHK website:
The installation of 3skeng does not work on my computer. What can I do?
We have tested the setup software and the 3skeng software very carefully. Nevertheless it is a new software and we may have not tested all possible configurations. If you are an registered user, please send us an email to support@3skeng.com with a description of the problem as detailed as possible. Clarifying screen shots are highly appreciated. We will help you as soon as possible!
Bob James
Premium Member
Premium Member
SketchUp version: 8
License type: Pro
SketchUp use: other
Postby Coronel » Sun Jul 05, 2009 1:33 pm
Coronel,
I looked for the installed files and was trying the plugin moving them to different possible locations where SU could find them. I made a probe with another user account library, in documents folder like some rubys do, in the own SU folder plugin... I was reading the ruby and its needed files and all seems to be in the right place but I still get start up errors.
I was reading their forums and made same post there too.
Thank you I will try with their support mail.
Coronel
Postby Bob James » Sun Jul 05, 2009 8:15 pm
Coronel wrote:I looked for the installed files and was trying the plugin moving them to different possible locations where SU could find them. I made a probe with another user account library, in documents folder like some rubys do, in the own SU folder plugin... I was reading the ruby and its needed files and all seems to be in the right place but I still get start up errors.
Where are the files/ruby located?
Bob James
Premium Member
Premium Member
SketchUp version: 8
License type: Pro
SketchUp use: other
Postby Coronel » Wed Jul 08, 2009 4:03 pm
localhost/Users/me/Library/Application Support/Google SketchUp 7/SketchUp/plugins/3skenglt (folder)/
localhost/Users/me/Library/Application Support/Google SketchUp 7/SketchUp/plugins/3SkengltExtension.rb
it requires 'sketchup.rb' and 'extensions.rb', in the same plugins folder.
Coronel
Postby modelhead » Wed Jul 08, 2009 4:30 pm
Here we go again.
With all due respect, if we let every Joe that can write software launch his/her product at the SCF we are quickly going to lose credibility. This forum benefits from reports and critiques by users, that are motivated to post by the relevant features of the product. Subjective, first hand users of a product only.
I can’t imagine the clutter we are going to have here in a year or so if this keeps up.
modelhead
Postby thomthom » Wed Jul 08, 2009 5:13 pm
modelhead wrote:Here we go again.
What what what? :?:
Global Moderator
SketchUp version: 8
License type: Pro
SketchUp use: architecture
Postby modelhead » Wed Jul 08, 2009 8:51 pm
From time to time as you know I am pretty impulsive.
Thom thom you can set me straight if I have made a mistake. I guess a better way to have expressed myself would have been as a request. I have been gathering speed on the annoyance meter over all the products being sold here.
I have already taken a shot at Mike over a similar thing here...
viewtopic.php?f=72&t=20426
If you want to launch your product here pay for an ad...don't create a forum thread about it.
My feeling is, on the other hand, a legitimate post should come only from those who have first-hand experience, have purchased and used the product in production so therefore can give evidence that it is viable and should be considered.
@SHK...I'm just going to say sorry in advance. I just got you caught in my crossfire.
I think things are going to get pretty watered down at the forum if we don't draw a line.
modelhead
Postby Burkhard » Wed Jul 08, 2009 9:12 pm
I like it to see what people do for and with SU.
Where is the place I get to know when not here?...and... would you say the same about smustard and their commercial scripts?
This is a platform where people can present their products/scripts/plugins related to SU. It is our decision to talk about and to test it. For me it is a difference with marketing and let people know about something new.
my2cents
Burkhard
Premium Member
Premium Member
SketchUp version: 8
License type: Pro
Postby modelhead » Wed Jul 08, 2009 9:23 pm
Yes I agree with you but the commercialization of the open forum is going to make it all less valuable as we continue. It is already leading members to waste time on items presented without any sort of authentication.
There is no doubt that as the forum has grown it has become harder to make choices about where you should spend your time or where you should contribute. Just because of the volumn of information.
modelhead
Not a Premium Member yet? Check out the great time-limited deal we are offering.
Next
Return to Plugins
Users browsing this forum: ajorda20 and 12 guests
