SketchUcation Plugin Store
[Plugin] Shape Bender Beta v0.55 UPDATED April 21, 2010
Re: [Plugin] Shape Bender Beta v0.1
Postby David_H » Thu Apr 09, 2009 4:29 pm
Yup . ..this is a much easier way to bend steel.
If I make it look easy. . .rest assured--it probably is.
David_H
Top SketchUcator
Postby tinanne » Thu Apr 09, 2009 4:37 pm
Chris AWESOME script and thank you for the videos! Watching someone work with the ruby really helps me to understand how to use it and where it will apply to my needs. Great job and thank you again!
tinanne
Premium Member
Premium Member
Operating system: Windows
SketchUp version: 7
License type: Pro
SketchUp use: architecture
Postby Free Agent » Thu Apr 09, 2009 7:51 pm
very cool thank you :fro:
Free Agent
Postby boilingsnow » Thu Apr 09, 2009 8:09 pm
David_H wrote:Yup . ..this is a much easier way to bend steel.
But the model you pasted can also be created easily without shape bender.
boilingsnow
Postby David_H » Thu Apr 09, 2009 9:40 pm
Very true, But not as fun.
David_H
Top SketchUcator
Postby Chris Fullmer » Thu Apr 09, 2009 11:40 pm
All right, thanks for the comments so far! I've got lots to think about. That bug where it smooths the end faces if your shape lines ep exactly with the line......I'll have to think about that. Its sort of done on purpose, but that is an exception where it is not desireable. I'll see if I can think of a way for it to be smarter.
I'm working on groups and components as we speak. That is my #1 frustration with the script is that it explodes everything and it won't take components. I'd like to get that fixed and updated tonight. We'll see :) Thanks everyone, seriously!
Chris
All my Plugins I've written
SketchUp Team
SketchUp version: 8
License type: Pro
SketchUp use: landscape architecture
Level of SketchUp: Advanced
Postby •BTM » Fri Apr 10, 2009 4:04 am
Great!! 2 things: 1, why do a few random lines appear when I use it?
also, sketchup said that there were problems, and when I agreed to let it fix them, this was the message:
Code: Select all
Results of Validity Check.
CLoop (39755) for CFace (39754) has zero area
Loop 0 of CFace (39754) is an invalid outer loop
Entity CFace (39754) should be erased - done
CLoop (39760) for CFace (39759) has zero area
Loop 0 of CFace (39759) is an invalid outer loop
Entity CFace (39759) should be erased - done
CLoop (40274) for CFace (40273) has zero area
Loop 0 of CFace (40273) is an invalid outer loop
Entity CFace (40273) should be erased - done
CLoop (40279) for CFace (40278) has zero area
Loop 0 of CFace (40278) is an invalid outer loop
Entity CFace (40278) should be erased - done
CLoop (43115) for CFace (43114) has zero area
Loop 0 of CFace (43114) is an invalid outer loop
Entity CFace (43114) should be erased - done
CLoop (43500) for CFace (43499) has zero area
Loop 0 of CFace (43499) is an invalid outer loop
Entity CFace (43499) should be erased - done
•BTM
Postby Chris Fullmer » Fri Apr 10, 2009 4:20 am
Hmmm, very interesting.
Well, the lines appear because a face is being bent in a way that it is not able to do, so SketchUp steps in and adds the extra lines so that it can bend as needed. I'd be interested if anyone out there has a method for determining what faces are going to need that extra geometry so I can add the lines myself beforehand.
The invalid geometry actually probably has a lot to do with problem above. Invalid geometry can be fixed automatically, the worst that can happen is that it will delete a few bad faces. Ok, thats not really ideal. So hopefully I'll get it fixed :)
On a happier note, I got the script to work with groups and components. I've got a few other things I want to try to implement tonight before I post the update though. So far so good.
Chris
SketchUp Team
SketchUp version: 8
License type: Pro
Postby •BTM » Fri Apr 10, 2009 4:22 am
And up arrow isn't toggling orientation.
•BTM
Postby Chris Fullmer » Fri Apr 10, 2009 4:26 am
•BTM wrote:And up arrow isn't toggling orientation.
Really? Thats too bad. If the model is complex, it will take a second or two to "toggle". Its not necessarily immediate. It might need to think about it for a bit.
So if you've waited patiently and its still not working, that is no good. Could you open the Ruby Console and see if it gives any errors when you press the up arrow key?
Chris
SketchUp Team
SketchUp version: 8
License type: Pro
Postby Jeff Hammond » Fri Apr 10, 2009 4:40 am
just a by-the-way going back to the perpendicular face/mac osx
the up arrow does work with this script on macs so it's probably something to do with the gear's geometry.
dotdotdot
Jeff Hammond
Global Moderator
Operating system: Mac
SketchUp version: 8
License type: Pro
Postby •BTM » Fri Apr 10, 2009 4:41 am
Actually, I tried it with a simple rectangle as well. It give no errors in the console, nothing happens at all. :? With the console opened, I selected the (rectangle) group, then shape bend, then the straight line, then curved. after I selected the curved line, I pressed the up arrow. Nothing happens at all. Am I doing something wrong?
•BTM
Postby Jeff Hammond » Fri Apr 10, 2009 5:09 am
it sounds like you're doing it properly.. that did happen to me once yesterday (didn't get any response from the up arrow and i wasn't getting the green outline showing a preview bend.. (it was after i tried a super complex shape being bent to a weird 3d curve -- i was trying to break the ruby :D and succeeded)
i quit sketchup and relaunched and it worked again.
try that.
dotdotdot
Jeff Hammond
Global Moderator
SketchUp version: 8
License type: Pro
Postby Chris Fullmer » Fri Apr 10, 2009 5:11 am
Hmm, here's the order of operations:
Select a group (must be a group, not a component in the current version of the script)
Activate the script
Select a straight line - must be drawn on the red axis. It will add "start" and "end" tags to it if it was selected correctly.
Select the curve. Now the grids should appear and you should be able to press the up arrow.
Hope that helps,
Chris
Jeff, I found a better method for the up arrow key. I still need to implement it in the perpendicular face tools script though - I probably will have time for that tomorrow.
SketchUp Team
SketchUp version: 8
License type: Pro
Postby Chris Fullmer » Fri Apr 10, 2009 5:14 am
Jeff Hammond wrote: i was trying to break the ruby :D and succeeded)
I've tried hard to make it unbreakable.....but it has tried harder to remain breakable :)
SketchUp Team
SketchUp version: 8
License type: Pro
Re: [Plugin] Shape Bender Beta v0.2 UPDATED Mar. 10, 2009
Postby Chris Fullmer » Fri Apr 10, 2009 8:26 am
UPDATED! v 0.2 Beta
A few major improvements. Now you can bend a component or a group. It can be scaled or rotated however you want, no need to explode and re-group immediately before using the plugin anymore. The shape to bend can also be comprised of groups and components. The script will explode them all by necessity though.
Also I added dynamic highlighting. Now when you move the mouse over a line or curve that is an acceptable selection, it is highlighted. This should help make it easier to know what is an acceptable line or curve.
Hopefully it is more stable now. I've tweaked a few other spots in the code, but nothing major. Just those 2 things listed above. Let me know if I broke anything, or if you like what I fixed.
Chris
SketchUp Team
SketchUp version: 8
License type: Pro
Postby watkins » Fri Apr 10, 2009 10:21 am
Dear Chris,
Many thanks for you wonderful new plugin. I should like to thank you for your generosity too. It is greatly appreciated.
I assume you meant 10 April and not 10 March.
Kind regards,
Bob
watkins
Postby Dave R » Fri Apr 10, 2009 11:23 am
Chris, I didn't have any trouble with the plugin yesterday when I tried it. When I woke up this morning there was an e-mail froma friend who was trying it. He sent it to me and I'm getting the same weird results. See the screen grab. The group starts out as long has the straight line. I tried it without the swirly thing at the end and get the same results. I've also tried changing the length of the curve but without luck. I discovered that it depends upon which direction the straight line is drawn. If the line is drawn from right to left, the geometry is added as shown. I also notice that if the curve is drawn from right to left the start and end points are transposed compared to the line.
Right to left-drawn line:
Left to right-drawn line, right to left-drawn curve
Left to right-drawn line, left to right drawn curve
Is there any chance of getting the plugin to ignore the direction of the drawn lines and curves?
Edited to add, I tried it with the new version and got the same results.
Inspecting mirrors is a job I could easily see myself doing.
Global Moderator
SketchUp version: 2013
License type: Pro
SketchUp use: woodworking
Postby •BTM » Fri Apr 10, 2009 1:35 pm
Even with the new one, the up arrow NEVER does anything. I've been doing it properly, but nothing happens. Could another script have broken it? Also, I'm now having trouble with the smoothing. When the shape is first created, I have to open it again, because it doesn't appear smooth until I do.
•BTM
Postby DonVid » Fri Apr 10, 2009 2:08 pm
Greetings Chris:
This is another great plugin that surpasses other 3D modeling program: easy, intuitive and precise. It can give several steps ahead when modeling architectural objects and entities.
Thanks a MM.
DonVid
DonVid
Re: [Plugin] Shape Bender Beta v0.2 UPDATED April 10, 2009
Postby Chris Fullmer » Fri Apr 10, 2009 5:08 pm
oh no!!, the script is indeed not working if you draw the first line from right to left......grrrr! I've got an idea of how to fix it though. Give me an hour or two and I'll get it updated very shortly. Sorry, sorry, sorry. Thanks for pointing it out.
@Bob, yes I meant April - oops! - The date is updated now, thanks!
BTM - sorry about the arrow key. I'm guessing its another script breaking it. Would you mind poking around to see which one it is? I don't even know how another script could, but its "amazing" what other scripts do........ Also, the smoothing thing is an odd bug I agree. I noticed it to, but I couldn't find a fix. I'll look into again today and see if I can get it working better.
Thanks everyone for the quick and detailed feeedback! :)
Chris
SketchUp Team
SketchUp version: 8
License type: Pro
Postby Dave R » Fri Apr 10, 2009 5:20 pm
Thank you
Global Moderator
License type: Pro
Re: [Plugin] Shape Bender Beta v0.25 UPDATED April 10, 2009
Postby Chris Fullmer » Fri Apr 10, 2009 5:30 pm
UPDATED v2.5 beta!
0.25 Beta:: 2009-04-10
  • Hit the down arrow key to change the start/end positions of the line. The line needs to have its start point "to the left" of the endpoint... If you notice weird behavior in how the shape is lining up on the curve, try hitting the down arrow key.
  • Up arrow key AND Home hey toggle the curve. Downd arrow key AND End toggle the line now for added compatibility (for BTM :)
So please tell your friend to re-download the plugin Dave, and try using the down arrow key or End key to toggle the line. Essentially the start point on the line needs to have its x position be less than the end point's x position. Hence, "to the left of" the endpoint. But obviously that just depends on how you orient your view.
BTM, I also added Home and End keys to the toggle. Try those to see if they work,
Thanks!
Chris
I'll still look into the faceting of faeces.
SketchUp Team
SketchUp version: 8
License type: Pro
Postby Dave R » Fri Apr 10, 2009 5:49 pm
Thank you Chris. This is great.
Global Moderator
License type: Pro
Postby Jim Smith » Fri Apr 10, 2009 5:51 pm
Thanks Chris, this is a very welcome plugin and I will find it very useful.
"Out of clutter find simplicity,
from discord find harmony,
In the middle of difficulty lies opportunity"
Albert Einstein
Jim Smith
Premium Member
Premium Member
SketchUp version: 8
License type: Pro
Postby Pilou » Fri Apr 10, 2009 6:07 pm
Don't forget that the second curve can be vertical and in fact has any 3D orientations! ;)
Speedy Galerie
Pilou
Top SketchUcator
SketchUp version: 6
License type: Free/Make
SketchUp use: hobby
Postby Chris Fullmer » Fri Apr 10, 2009 6:13 pm
Pilou wrote:Don't forget that the second curve can be vertical and in fact has any 3D orientation! ;)
Really???? Thats pretty cool! I have not tested that - at all. The way I made it work, I never implemented any z position checking, except on selecting the first line. So I suppose it makes sense that it will let you choose a curve with some z variation. Thanks for the picture!
Also, the curve doesn't have to be a curve at all. Just a series of connected lines work perfectly well too. Though they normally create some weird bendining since they are not so smooth as a true arc, or bezier curve.
Chris
SketchUp Team
SketchUp version: 8
License type: Pro
Postby Chris Fullmer » Fri Apr 10, 2009 6:24 pm
This is a complex bend I did. It took about an hour to figure out the bend position, and about 10 minutes to finalize it. It is a 9mb car component.
the model is here:
http://sketchup.google.com/3dwarehouse/ ... 85d8c0f2bc
SketchUp Team
SketchUp version: 8
License type: Pro
Postby xrok1 » Fri Apr 10, 2009 6:33 pm
Chris great job, i love it!
on the smoothing thing can you not manually set the angle between normals with your script when you smooth it, to be say 45deg. ? it seems to be smoothing 90deg. angles. also you could consider not smoothing at all then the user could decide if they need smoothing and at what angle. Or maybe you could read the smoothing settings of the group to be bent before you bend it and then reapply the same settings to your output.
“There are three classes of people: those who see. Those who see when they are shown. Those who do not see.”
xrok1
Postby Chris Fullmer » Fri Apr 10, 2009 6:46 pm
xrok1 wrote:Or maybe you could read the smoothing settings of the group to be bent before you bend it and then reapply the same settings to your output.
That is what is supposed to be happening more or less. It is trying to leave all edges unchanged, except the ones that it adds when it slices the model up for the bending locations. But what happens is that if a en existing line falls exactly in the same place as where the script adds lines, it can't tell that a line was already there and sometimes it will appear to smooth existing hard edges. This is the case when the end face is lined up exactly to the end of the line.
Are you seeing it happen more often than expected? If so, could you upload a model where it is behaving poorly, thanks!
Chris
SketchUp Team
SketchUp version: 8
License type: Pro
Need SketchUp Books, Models, Styles or Textures? Check out our One Stop Shop for SketchUp.
PreviousNext
Return to Plugins
Users browsing this forum: hdb, hebeijianke, longsomboon, stephax and 8 guests
