by Dave R » Sat Jun 29, 2019 6:25 pm
kinhkhaag wrote:The plugin does not work in the Sketchup 2019 when I select a line, curve nothing happens
Yes. It does work in SketchUp 2019. SB.gif Most likely you haven't set up the model correctly to use it. If you share the SKP file, I'm sure we can help you make it work.
- Global Moderator
- Name: Dave R
- Operating system: Windows
- SketchUp version: 2021
- License type: Pro
- SketchUp use: woodworking
- Level of SketchUp: Advanced
by kinhkhaag » Tue Jul 02, 2019 1:26 pm
Dave R wrote:kinhkhaag wrote:The plugin does not work in the Sketchup 2019 when I select a line, curve nothing happens
I don't can for SU 2019 finish EX:
kinhkhaag
- Name: kinhkha
- SketchUp version: 2015
- License type: Free/Make
- SketchUp use: architecture
- Level of SketchUp: Beginner
by TIG » Tue Jul 02, 2019 1:45 pm
Your example SKP is very similar to Dave's demonstration. Your red-axis line is elevated and the curve in vertical - but it will still work.
To reiterate...
Preselect the group. Activate the ShapeBender tool. Click on the Line. Click on the Curve. Press Enter to accept 'ghost' version of the bent form...
- Global Moderator
- Name: TIG
- License type: Pro
by TIG » Tue Jul 02, 2019 2:05 pm
NOTE: there was an issue with a few tools [like ShapeBender] found in the first version of v2019, but that was fixed in the more recent MR version currently available - have you downloaded the latest v2019 version ?
The issue related to the way SketchUp can take either a point or a vertex when setting up geometry. This well established protocol was unexpectedly broken in v2019 first incarnation, but that problem is now fixed in the current v2019 installer...
To see if that's the case with your set up open the Ruby Console before running the tool. The error message [if any] should be obvious...
- Global Moderator
- Name: TIG
- License type: Pro
by clarinaya » Wed Oct 09, 2019 12:35 am
Hello,
actually when i try to use shape bender after completing make group etc, the words “start” and “end” should appear at each end of reference line along the red axis, but not. I use skp pro 2019, what should i do?
clarinaya
- Name: Clara Castro
- SketchUp version: 2019
- License type: Pro
by Dave R » Thu Oct 10, 2019 10:41 pm
clarinaya wrote:I use skp pro 2019, what should i do?
As you can see in the GIF in my previous post, Start and End do show up in SU2019. If they don't for you, perhaps it is the way you have your model setup. You could share it so we can check it out. Or it could be an incorrect installation of SketchUp. When you installed SketchUp 2019 did you right click on the downloaded installer and choose Run as administrator?
- Global Moderator
- Name: Dave R
- License type: Pro
by TIG » Fri Oct 11, 2019 12:41 pm
There was an issue with the early version of SketchUp v2019, in which the way the API should treat vertices as points was broken [it had worked OK for many years!], so as a result any API code which used a vertex directly [rather that getting it into a point] to locate something - like a text label - failed. The newer Maintenance Release versions fixed this and ShapeBender [and others] should now work again. If you run it with the Ruby Console open you should see the error messages. Look back through this thread - recent posts discussed it, and the confirmation that it's fixed... viewtopic.php?p=650879#p650879So please install the latest version of v2019 - it will hopefully fix your problem... As Dave says please use "Run as administrator" to install in properly...
- Global Moderator
- Name: TIG
- License type: Pro
by ktsbanam » Mon Dec 30, 2019 5:38 pm
hi! sorry to bother you First of all, I would like to thank you for your dedication You can fix the shape bender plugin error on Sketchup 2019. It can't be used. Thanks for your contribution.
ktsbanam
- Name: nguyễn bá nam
by Dave R » Mon Dec 30, 2019 5:44 pm
ktsbanam wrote:First of all, I would like to thank you for your dedication You can fix the shape bender plugin error on Sketchup 2019. It can't be used.
What do you mean it can't be used? It works just fine in SketchUp 2019. Are you still using SketchUp 2019.0? Proof: sb.gif If you'd read a few of the previous posts in this thread you would have seen that it does work in SU2019. viewtopic.php?f=323&t=18210&start=1230#p650802
- Global Moderator
- Name: Dave R
- License type: Pro
by eLaCiD » Fri Mar 27, 2020 3:29 pm
Sorry but don't work on SU 15. On SU 8 work OK. On SU 15 when I select toolbar icon it would have to show stright line on cursor but nothing. Can't select line and can't select curve.
eLaCiD
- Name: eLaCiD
- SketchUp version: 8
- SketchUp use: other
by TIG » Fri Mar 27, 2020 3:33 pm
It does work on all current SketchUp versions... If you open the Ruby Console and try it, then what happens ? Any error messages ??
How did you install it ?
- Global Moderator
- Name: TIG
- License type: Pro
by gnicolaidou » Thu Apr 23, 2020 2:37 pm
Hey guys!  I'm quite new to Sketchup and to this forum actually, so please bear with me!  I've followed your conversation about Shape Bender, cause I'm also experiencing difficulties. I'm using Sketchup Pro 2019 and it seems that Shape Bender is not compatible with my version of Sketchup?? Don't understand. I'm sending you guys some screenshots of the messages I got. Really appreciate your help on this and any feedback! Many thanks! G.
gnicolaidou
- Name: Georgia
- License type: Pro
- SketchUp use: interior design
by Dave R » Thu Apr 23, 2020 2:50 pm
That message doesn't mean the extension won't work in SketchUp 2019. In fact it works very well. The message means it hasn't been marked as compatible. That's just a clerical thing that the author needs to take care of.
- Global Moderator
- Name: Dave R
- License type: Pro
by gnicolaidou » Thu Apr 23, 2020 3:08 pm
@Dave R Many thanks for the reply, appreciate it! However, I have installed the extension and tried it and still experiencing difficulties. I have gone though the relevant steps but for some reason it does not seem to 'find' the line I have drawn on the red axis...not sure why...so everything just stops there.
Many thanks!
Regards
G.
gnicolaidou
- Name: Georgia
- License type: Pro
by Dave R » Thu Apr 23, 2020 3:14 pm
Where is the line parallel to the red axis? Your screen shot isn't very useful. If you follow the instructions you select the component you want to bend, get the tool, click on the edge that is parallel to the red axis, then the curve.
In the GIF, below, I placed the line directly below the front edge of the component and the bent shape ends up with its front edge directly above the curve. It is important to get the location of the line relative to the component correct so that the bent shape has the right curve.
- Global Moderator
- Name: Dave R
- License type: Pro
by TIG » Thu Apr 23, 2020 3:18 pm
Follow what Dave R said...
But I can see a red-axis top-left ? Is your own line drawn on or parallel to that axis ? It should pick OK, BUT if you have reset the model's axes some time in the past it will fail, because the API assumes the default-axes. To check this hover your cursor above the visible axis line and right-click > context-menu... If the axes have been adjusted there's a 'Reset' menu item available. Select that item to reset the axes back to the default... Now repeat the 'bend' steps with a [new] line drawn parallel to the corrected red-axis and an appropriately sized/positioned arc, and the thing to bend...
- Global Moderator
- Name: TIG
- License type: Pro
by gnicolaidou » Fri Apr 24, 2020 9:52 am
Wow, you guys are awesome!!  Problem solved!! And it had to do with the model's axes, as TIG had very well spotted!!! I reset them and voila! Thank you both very much for your input and special thanks to TIG!!!!!! Regards G.
gnicolaidou
- Name: Georgia
- License type: Pro
by kakashi66 » Thu May 28, 2020 3:14 pm
Does this plugin work with 2020? I've installed it several times and I can't find it anywhere.
kakashi66
- Premium Member
- Name: patrick anderson
- License type: Pro
by Dave R » Thu May 28, 2020 3:51 pm
Yes. It works in SketchUp 2020. It should show up under Extensions>Chris Fullmer Tools or you can activate its toolbar.
- Global Moderator
- Name: Dave R
- License type: Pro
by Grey24601 » Mon Oct 12, 2020 6:02 pm
Hi Tig,
Sketchup 2020
I can not work out why the shapebender is not working. It creates the correct ghost but when I accept it, it just rotates the object? Any ideas/ What have I done wrong.
Grey24601
- Name: Graeme Robinson
- License type: Pro
- SketchUp use: landscape architecture
by Dave R » Mon Oct 12, 2020 6:12 pm
Grey24601 wrote: What have I done wrong.
You've set up the model incorrectly. You should have the straight line directly in front of the straight component as I have here. Not strung out down the red axis as you did. Screenshot - 10_12_2020 , 12_09_48 PM.png Screenshot - 10_12_2020 , 12_10_00 PM.png Set up as I show it, Shape Bender works as expected. It put the bent version the same distance behind the curve as the straight component is behind the straight line. You want to remember that the relationship between the location of the straight component and straight line affects the relationship of the bent component to the curve. Shape Bender did exactly what you asked it to do even though it's not what you were hoping for.
- Global Moderator
- Name: Dave R
- License type: Pro
- Robot
Return to Plugins
