[Plugin] Shape Bender Beta
Re: [Plugin] Shape Bender Beta v0.55 UPDATED April 21, 2010
Postby pbacot » Tue Apr 09, 2013 6:53 am
Thanks for helping guys. Perseverance furthers as the good book says, and you (TIG and Dave especially) show real perseverance with the age-old users' problems of plugin installation and startup. Maybe the new SCF loader will take some of that fun away...
Top SketchUcator
Postby TIG » Tue Apr 09, 2013 10:22 am
pbacot wrote:...Maybe the new SCF loader will take some of that fun away...
Let's hope against hope... :D
Global Moderator
Postby cholme » Wed Apr 17, 2013 5:45 am
This looks awesome... but I don't know if I have something set wrong. I was trying to bend some text to an arc and it took about 3 minutes just to see the preview. I looked at the sample video and it looked like it went pretty quick, am I missing something?
cholme
Postby thomthom » Wed Apr 17, 2013 8:47 am
Maybe your text has more polygons. Hard to tell without sample model or screenshots.
PluginStore Author
PluginStore Author
Postby alio » Thu Apr 25, 2013 2:32 pm
Im a rookie...how do I install this plug in? Is it a rbz. file? Is that how I go about it?
alio
Postby TIG » Thu Apr 25, 2013 3:24 pm
Please read this...
http://sketchucation.com/resources/tuto ... up-plugins
Can I recommend that first you learn to use the SCF Search functions - you'll be amazed what you might then learn...
Global Moderator
Postby alio » Thu Apr 25, 2013 4:25 pm
Thanks for the information.
alio
Postby panda_ska8er » Sun May 19, 2013 1:35 pm
Thank you very much!
panda_ska8er
Postby JLspeeddragon » Sat Jul 13, 2013 2:19 am
Great Plugin! I cant get enuf of how easy and fun it is.. Dont forget to DL the weld and Progress plugin if you are trying this for the first time
JLspeeddragon
Shape Bender Problem?
Postby Vic12 » Sat Jul 13, 2013 1:25 pm
Hi -
I've downloaded and installed both shape bender and progressbar.rb
I can see shape bender checked in my extensions folder - so it should be active
I can also see progressbar.rb in my plugins folder - although can't find it anywhere on screen - but assume it is there (is there a way to check that?)
but I cannot find shape bender (or Chris Fullmer's tools) anywhere in my toolbar
any suggestions on how to activate/use?
thanks
Vic12
Premium Member
Premium Member
Postby TIG » Sat Jul 13, 2013 1:55 pm
Progressbar.rb is the helper that adds a progress-bar to the status-bar when you are using ShapeBender plugin.
That 'script' doesn't 'appear' anywhere else otherwise...
You haven't completed your User-profile details so we don't know your OS or SUp version...
If you can see the ShapeBender plugin's Extension and check it, then it should add the Toolbar option to the View > Toolbars list
Unless perhaps you have somehow mis-installed the plugin's files and moved some of them from their subfolder into the main Plugins folder?
How did you install the plugin?
There are several 'foolproof' ways of doing this - with 'AutoInstallers' etc...
Manual installs are prone to have problems...
Do you have FULL security permissions to your Plugins folder?
Is there a 'Compatibility Files...' link/button on the Explorer window's top bars - a sure sign of limited rights...
Fix the permissions to be FULL for all users etc...
Global Moderator
Postby Vic12 » Sat Jul 13, 2013 2:12 pm
Help-
I've downloaded and installed both progressbar.rb and shape bender - progressbar is in my plug-in folder and shape bender shows up as checked in my extensions -
but I cannot find it in my toolbar anywhere
what am I doing wrong-
what am I not activating?
thanks
Vic12
Premium Member
Premium Member
Postby Vic12 » Sat Jul 13, 2013 2:21 pm
Hi TIG - sorry missed your first post-
I installed both shape bender and progressbar manually
library - applications support - sketchup 8 - plugins
but I think I might have moved the shape bender rb out of the folder it came in - when it first wasn't showing up -
maybe that's the problem- just moved back in and I'll restart and see if that helps?
I'm on MAC OS 10.7.5 and running SU 8
or do I need to uninstall and re-install?
Vic12
Premium Member
Premium Member
Postby Vic12 » Sat Jul 13, 2013 2:33 pm
when I unzip the file - I get a folder
clf_shape_bender_v055
inside the folder is another folder w/ clf_shape_bender and the ruby script clf_shape_bender_loader.rb
I took the ruby out of the folder and placed it in my plugins folder
HD-library-applications support-google8-SU-plugins
then shape bender showed up in my extensions - checked-
but nowhere in my toolbar -
when I put the rb back in the folder it came in then the extension went away-
thanks - Victoria
Vic12
Premium Member
Premium Member
Postby Dave R » Sat Jul 13, 2013 3:53 pm
Victoria, your screen shot shows you haven't installed Shape Bender correctly. Move the two files in the far right column into the Plugins folder directly. Then restart SketchUp. If you installed it with the SCF Plugin Store you wouldn't have this problem.
Global Moderator
Postby Vic12 » Sat Jul 13, 2013 6:27 pm
got it working thanks - but it hasn't solved my problem like I thought it would
I'm trying to create a curved ramp and cannot solve the complex curve
I'm uploading the file - with the desired curve - and the desired ramp
I'm thinking there's a drape tool?
or??
thanks
(macos su8)
Vic12
Premium Member
Premium Member
Postby TIG » Sun Jul 14, 2013 8:55 am
This is not the plugin for that as the starting form. :(
There are several other approaches... :D
Look at Fredo's CurviLoft to extrude the profile along the paths
Or say my Extrude tool's EEbyRails.
Or FredoScale on a simple PushPulled slab?
It's an 'extrusion of a bent form' issue, not really a 'bending of an extruded form' issue...
EDIT: TIG
I see you have posted this in another thread and got similar answers from others.
Use their examples...
Global Moderator
Postby Burkhard » Sun Jul 14, 2013 11:21 am
You can simple do it with shape bender.
For better results, you' need some better preparations.
Burkhard
Premium Member
Premium Member
shape bender
Postby smganeles » Mon Jul 15, 2013 4:44 am
after using the shape bender plugin to bend a fairly complex shape to a specified curve, some random edges of the rendering were left out and dissapeared
otherwise it seemed to work fine (besides making sketchup not respond for a while because i am on a slow and old computer)
these were not in the original rendering before the object was bent
what could have gone wrong and is there any way to fix this
pictures of both before and after the bending are attached
smganeles
Postby TIG » Mon Jul 15, 2013 11:02 am
SketchUp [and OpenGL] have problems creating facets if they are very very tiny.
Your steel-beam has some very small segments to its rounded edges.
You could probably make a much simpler version with far fewer facets.
When ShapeBender [or other tools like FollowMe etc] try to 'extrude' these tiny facets they can fail to form some faces simply because they are now so very tiny.
To overcome this...
Scale the steel/curve/line x100.
Do the ShapeBending etc...
Then Scale down x0.01.
These tiny facets can exist, BUT it's the creating them that is an issue...
This is the known problem and it's fix.
Depending on the facets' "tininess" you can scale x10, x100 or x1000 and then back...
Global Moderator
Postby smganeles » Mon Jul 15, 2013 6:28 pm
thank u
i will try this
smganeles
Postby draftprint3d » Tue Jul 30, 2013 4:03 am
When I am bending a shape, it goes a lot faster when Netflix is playing fullscreen in front. I have no explanation but that is what I observe.
draftprint3d
Postby thomthom » Tue Jul 30, 2013 10:59 am
Odd... but it might be that the full screen app in front disable UI functions in SketchUp that would otherwise slow things down.
PluginStore Author
PluginStore Author
Postby Z Donk » Thu Aug 01, 2013 8:15 pm
Hey, I just loaded this up and am trying to use it for the first time. Got it in my Plugin folder etc.. I'm trying to do exactly what chris did in his first example video and running into a wall: Once i have the simple group selected, as commanded, the "select a single line on the red axis" is the next command. Try as I might, I can't get the selection to take. It highlights blue, It's on the red axis, its a single line. The next command for selecting a curve does not come.... Tried it as a group, as an exploded group, etc. -The line is selected then the grid doesn't show and the commands stop there.. Bear in mind, I'm an intermediate sketchup user but even recreating Chris's simple example I hit a wall.
(Ultimately, I'm trying to bend a 3d geometric rectangle plate along 3 different angles)
Z Donk
Postby Z Donk » Fri Aug 02, 2013 3:39 am
Hi moderator, I found the problem, I didn't know I had to have the entire file in my plugins folder.. Off and running.
Z Donk
Postby Dave R » Fri Aug 02, 2013 12:02 pm
Z Donk wrote:Hi moderator, I found the problem, I didn't know I had to have the entire file in my plugins folder.. Off and running.
So we can put your problem down to incorrect installation? That seems to be the most common reason plugins don't work for folks. It's one of the reasons for the Sketchucation Plugin Store. If you haven't got it and installed it, you should.
Global Moderator
Postby PabloNCS » Wed Sep 04, 2013 5:23 am
Hi everyone,
I don't know what am I doing wrong, but the text I am trying to bend does not mantein its original size and it kind of stretches out.
Anyone can give a hint?
Thanks.
PabloNCS
Postby Dave R » Wed Sep 04, 2013 10:17 am
The length of the arc is longer than the length of the original text and the original line so of course the text would get stretched. Make the straight line the same length as the text and the arc the length of the straight line and it works better. The letters will still get a bit distorted but that's to be expected. You might even make the arc a little shorter than the straight line in the case of your text.
Global Moderator
Postby PabloNCS » Wed Sep 04, 2013 7:09 pm
Thanks for the tip. It worked better that way.
PabloNCS
Postby archipenti » Thu Sep 12, 2013 4:58 am
Hello
Seems we can not use custom axes for the "red axis"
is there any update or solutions for this little bug?
archipenti
PreviousNext
Return to Plugins
Users browsing this forum: ArkiMarcow, moraides, Snekflek and 8 guests
