SketchUcation Premium Membership
[Plugin] Archiver.rb - update
Re: [Plugin] Archiver.rb - update
Postby TIG » Tue Apr 07, 2009 5:21 pm
takesh h wrote:Hi TIG,
Another brilliant ruby script from the brilliant mind.
I'm going to add this gem to pushpullbar's Ruby Index, so let me clarify a couple of things before I do that.
1. Should I have the link few posts above as the "definite" version of archiver.rb for now? Can I request Didier Bur to update your archiver.rb in Ruby Library Depot to the above version? It doesn't look like Didier had time to update the site for quite some time.
2. I always thought "_" is more common (less problematic) divider than "-" in file names, is there any specific reason you chose "-" as a default divider?
Thanks in advance.
v1.7 is the best one - link to that. Didier can add v1.7 if he wants to...
It's easy to change the separators - edit the file and make sep="_" or whatever text you want that's allowed in filenames. The only advantage is that in the filename "model[yy-mm-dd_hh-mm-ss].skp" the date and time are more easily read separated by the _. You could even use sep="" and get "model[090407_072210].skp"... It's easily adjustable to suit your own whims...
Global Moderator
Operating system: Windows
SketchUp version: 2013
License type: Pro
SketchUp use: architecture
Level of SketchUp: Advanced
Postby takesh h » Tue Apr 07, 2009 5:31 pm
Thanks for explanation, that makes whole a lot of sense.
I'll forward the link to Didier Bur. :thumb:
takesh h
Postby takesh h » Wed Apr 08, 2009 3:38 am
TIG,
It's online now.
http://www.pushpullbar.com/forums/ruby- ... post146070
If there is anything wrong with my review, please don't hesitate to tell me.
Thanks a bunch.
takesh h
Postby Jeff Hammond » Sat Apr 11, 2009 4:09 pm
just reporting back after a week or so of using archiver.
this plugin is awesome!
thanks again TIG.
dotdotdot
Jeff Hammond
Global Moderator
Operating system: Mac
SketchUp version: 8
License type: Pro
Postby TIG » Mon Apr 13, 2009 7:26 pm
Glad its useful...
If anyone else has any feedback (even critical !) please let me know...
Global Moderator
License type: Pro
Postby Jim » Wed Apr 15, 2009 1:28 pm
TIG wrote:Glad its useful...
What happens if you open an archived model, then use archiver again? Does the date-stamped filename get longer, or does the date-stamp get updated?
Also, a good option may be to have a "branch" option. Branching would prompt for a new filename and save the model under that name. A branch might be used to experiment with variations in a model, then allow to switch back and forth between branches.
Personally, I have turned off SketchUp Auto-save and am in the habit of hitting Ctrl-s (save) to save the model. So, maybe it could be tied to the built-in Model > Save through the onSaveModel ModelObserver.
Just thoughts - I would consider it an essential plugin as it is. Thanks.
Jim
Global Moderator
SketchUp version: 8
License type: Pro
SketchUp use: other
Postby TIG » Wed Apr 15, 2009 1:57 pm
If you open an archive and modify it and then archive it you will get another date-time stamp added to the end of its name, in another Archives folder within the original Archives folder... I'd recommend copying archives rather than using them direct since saving alterations overwrites the earlier version. That way you know which version of the model you are working on but keep the original archive unchanged... You can always open an archive and save_as Model-Option-B etc...
Your 'branch' option is called 'design options' in Revit... At the moment you will need to save as a number of models and archive each as desired... Your 'Archiver+Option' would archive the current Model.skp make /Archives/Model[yy-mm-dd_hh-mm-ss].skp and then open a save_as dialog with suggested incremented option name - e.g. Model[Option-01].skp - you could always change what's inside the []. Work on that version and make archives etc as usual. Then perhaps you decide that you want to explore another variant... pick 'Archiver+Option' again - it then spots the [] on end of the name and suggests a save_as with an incremented name - e.g. Model[Option-02].skp etc etc... Option-01 to Option-99 would be the typical range...
I'll see what I can clobber together... watch this space...
Global Moderator
License type: Pro
Postby Jim » Wed Apr 15, 2009 2:19 pm
Well, as I said these are just ideas from a casual user, and things I don't strictly "need." Maybe some power-users can give more input.
Jim
Global Moderator
SketchUp version: 8
License type: Pro
SketchUp use: other
Re: [Plugin] Archiver.rb - update v1.8
Postby TIG » Wed Apr 15, 2009 5:42 pm
Here's v1.8
It now has an extra menu option 'Archive Option'.
This archives the file and then gives you a 'save_as' dialog -
with the default new option's file-name entered as "Model[Option-01].skp" ..-02] etc.
This 'option' 'number' is based on the highest value option found in the model's folder.
You can overwrite an existing file if desired (you will be warned 1st).
The current active model-window now opens with the latest option you have just saved.
If you save a model as an 'option', then to be recognised as such it should have its name in the format "Model[Option-nn].skp" - it must have the surrounding "[..]" and a separating "-" between the number and any text; the string "Option" could be set in the save_as dialog to say something else, BUT since new options always use "[Option-nn]" anyway it's recommended to leave it unchanged.
Please test and feedback...
Global Moderator
License type: Pro
Re: [Plugin] Archiver.rb - update v1.9
Postby TIG » Thu Apr 16, 2009 11:54 am
Here's v1.9
Minor change to 'Archive Option' - the original model is now saved immediately before it is archived and then saved as an Option.
Usage:
    Pick 'Archiver' to make an archive copy of the current model.
    It saves the model (in its current state) into a sub-folder
    within the model's folder called 'Archives'. It's named with
    a [suffix] - date (yy-mm-dd_hh-mm-ss),
    e.g. Model[09-12-18_12-34-56].skp.
    The separators can be customized from '-' to '_' etc,
    just change one line - sep="-" to sep="_" etc...
    If later on you don't save the main model with those changes
    then that archive copy still has those changes current at the
    time of the archiving.
    If there is an 'Archives' folder then an extra 'File' menu
    item is added - "Open Archives"...
    'Archive Option' is an additional function that saves the model as it
    stands - say 'Model.skp' - then it makes an archive of it - say
    'Model[09-04-16_12-25-05].skp' and then opens a 'save_as' dialog in
    which it will have preset the next available unused Option name - say
    'Model[Option-01].skp' - which you are prompted to save_as: you can
    choose to overwrite an earlier option if desired - if so you are
    warned about overwriting it. The Options are kept in the same folder
    as the original. It is recommended that you do not change the naming
    convention... The model is then saved. The current SketchUp window
    then shows this latest Option.
    Options can be archived in the same way as other models - in the
    example above the archive's name might then be
    'Model[Option-01][09-04-16_12-30-55].skp'...
    If you subsequently use 'Archive Option' on an 'Option' itself it then
    names the new Option with the next available free Option name - in
    this case it would 'Model[Option-02].skp' and the process repeats...
    It uses the [-] characters as separators so don't change the Option's
    name if you want it to be recognised as one by 'Archive Option'.
Feedback please...
Global Moderator
License type: Pro
Postby Jeff Hammond » Fri Apr 17, 2009 3:49 pm
i'm not sure if i'm using 1.9 properly but here's what i'm getting...
it works the same as 1.7 in that if i select file->archiver, a archive will be created in a new folder inside the main model's folder.. file->open archives will allow me to search through/open files in the archive folder..
everything is fine there..
now,
if i select file->archive option it works exactly the same as when i use file->archiver except i now have a .tmp (ex- 1239979595.tmp) file saved in the main model's folder. no dialogs or options etc..
dotdotdot
Jeff Hammond
Global Moderator
SketchUp version: 8
License type: Pro
Postby TIG » Fri Apr 17, 2009 4:55 pm
Sounds like a Mac problem [again]. Works fine on PC. Please run it with the Ruby Console open and report the error you get. The .tmp file is made so that the original and newly named copy can swap over - that's failing...
Global Moderator
License type: Pro
Postby Jeff Hammond » Fri Apr 17, 2009 5:12 pm
here's the error message:
Error: #<Errno::ENOENT: No such file or directory - \Users\jethro\Desktop\ARCHIVER_TEST\>
/Library/Application Support/Google SketchUp 7/SketchUp/Tools/Archiver.rb:214:in `open'
/Library/Application Support/Google SketchUp 7/SketchUp/Tools/Archiver.rb:214:in `entries'
/Library/Application Support/Google SketchUp 7/SketchUp/Tools/Archiver.rb:214:in `option'
/Library/Application Support/Google SketchUp 7/SketchUp/Tools/Archiver.rb:255
that is after i have a model folder (ARCHIVER_TEST) with a couple of archives saved (they are in a folder created by the ruby called 'Archives' which resides inside the main folder.
it's looking like \ vs. / again?
dotdotdot
Jeff Hammond
Global Moderator
SketchUp version: 8
License type: Pro
Re: [Plugin] Archiver.rb - update - v2.0
Postby TIG » Fri Apr 17, 2009 5:19 pm
It was \ versus / ! I suspected it - I have made an error in one step in the sub-routine for 'option'. I have just redone all of the path bits to ensure PC/Mac compatibility...
Here's v2.0 - it works OK on my PC AND should now work on your Mac too...
Sorry for the problem - I don't have access to a Mac to test this, so please report back...
Global Moderator
License type: Pro
Postby Jeff Hammond » Fri Apr 17, 2009 5:52 pm
ok, that fixed it..
i only had a quick look at it as i'm about to leave for the day but it looks like there will only be one archives folder created now and i can view all the files related to the main folder via 'Open Archives'.
is that correct? if so, i like it!
i'll be able to check it out more thoroughly tonight but it's looking like a nice improvement.
thanks
dotdotdot
Jeff Hammond
Global Moderator
SketchUp version: 8
License type: Pro
Postby Tobobo » Wed Feb 29, 2012 2:22 pm
Thanks TIG
Toby
Philippians 4:13
http://tobyjoyce.wix.com/home
Tobobo
SketchUp version: 8
License type: Pro
SketchUp use: landscape architecture
Need SketchUp Books, Models, Styles or Textures? Check out our One Stop Shop for SketchUp.
Next
Return to Plugins
Users browsing this forum: arch92, arredamentibp, esteromx, greeeeeeeeee, intelthunder, manibus, McGyver, muze, nabou, onkravets, Renderiza and 14 guests
