[Plugin] FredoScale - v3.1a - 18 Dec 18Re: [Plugin] FredoScale - v3.1a - 18 Dec 18
To what signature are you referring? SketchUp says the signature is up to date: Etaoin Shrdlu
% (THERE'S NO PLACE LIKE) G28 X0.0 Y0.0 Z0.0 M30 %
Re: [Plugin] FredoScale - v3.0a - 14 Jan 17
You need to split the horizontal lines into segments. The same would happen if you used a circle with only eight segments, it would transform into a funky shape, because the lines connect to the points, and only the points are relocated. (Eg, it will not curve a solid line, it just deforms the locations of the end-points.) Thus, your windows where they are on the roof-line, that has three segments. The points are relocated, on a curve, and you get a three-segment curve. However, your horizontal lines for the "siding", only have two points, per line. So, the line just connects from point to point, left and right, with no curve on the line, to match the line where the window has broken the line into three segments. Just as you would add more segments to a circle to hide the fact that it is actually just a bunch of lines and angles, to create the illusion of a "curve". Resolutions... 1: Break the line into a three-segment line, by adding a line with points aligned under the window, where the window points intersect that horizontal line of the roof. 2: For more realism, because that is a rather large curve, you should segment each line into 4-8 segments per line. That way, you will have full curves, retaining the "image/concept", of the original. This is the reason that SketchUp has no deform tools. When done on simple lines, without adding more segments, you get undesired results. Just as when you attempt three-point perspective, by lowering the camera near the ground and looking up. It always "looks funny", because the building edges are all perfect lines from corner to corner, instead of having a "true curve", as a camera or your eyes see. That is why 3D rendered things, look like 3D rendered things, instead of looking like reality, unless you use post-work deforms or complex multi-segment lines. (As objects such as people have, but buildings normally do not. Adding to the oddity of displaying 3D objects.) |
