[Plugin] FredoScale - v3.1a - 18 Dec 18
Re: [Plugin] FredoScale - v2.7a - 19 Oct 14
Postby fredo6 » Mon Jun 01, 2015 11:10 am
Pilou,
You have to explode the curves of the cylinder
Fredo
fredo6
PluginStore Author
PluginStore Author
Postby pbacot » Thu Jun 25, 2015 8:15 pm
I use Fredoscale Stretch A LOT to make different versions of the same window type. I wonder if these modifications would be difficult or impossible--and if they might happen someday:
1. If nested components are unchanged in the operation have them stay the same definition.
2. If nested components are changed in the operation, make them "unique" with new name (how it works now).
3. Do this for all nested components. (At present I am not sure what rules apply. If I have components, say a muntins in a sash, and I stretch the window: The sash which is used in other windows might not change in those non-operation components (it becomes unigue), but the muntins might be affected in those other windows--which isn't desirable.)
4. If multiple instances of the same component are changed in the operation AND they remain identical to one another--make them unique from the old version but the share the same definition (e.g. two identical window components in the same assembly).
oh, and an aside: Is there a way to have the divider always on by default? It never is and the hot key doesn't work for me (on a Mac).
Thank you for the wonderful plugins. I use them A LOT. :D
Top SketchUcator
Postby fredo6 » Thu Jun 25, 2015 9:24 pm
These suggested enhancements can be done and make a lot of sense actually.
I think that the current behavior if that all components and nested components are made unique.
Indeed I have to dive again into the code which is now old for me.
For the divider, you have an option in the Default Parameters dialog box to enable or disable the Divider (and also the slicer for Bend) by default.
Fredo
fredo6
PluginStore Author
PluginStore Author
Postby Dcch » Sun Oct 25, 2015 9:36 pm
ayuda no puedo instalar el plugin me da error indandome que no tengo la actualizacion, gracias de antemano
Dcch
Re: [Plugin] FredoScale - v2.8a - 13 Nov 15
Postby fredo6 » Fri Nov 13, 2015 11:32 pm
NEW RELEASE: FredoScale v2.8a - 13 Nov 15
FredoScale 2.8a is a maintenance release for bug fixing
See main post of this thread for Download.
Fredo
fredo6
PluginStore Author
PluginStore Author
Postby derei » Thu Dec 17, 2015 5:50 pm
FredoScale doesn't allow absolute input? I must admit, I never tried before, but as the native SketchUp Scale tool accepts absolute input (scale to 100mm -> will scale to match size, not the scaling ratio), I just needed to scale very precisely with FredoScale and it seems to not work like that.
Please confirm. Thanks
DESIGNER AND ARTIST DEREI.UK
derei
Postby pbacot » Fri Dec 18, 2015 4:12 am
Yeah it does. (not the same method as SU tool though)
Top SketchUcator
Postby derei » Fri Dec 18, 2015 2:12 pm
pbacot wrote:Yeah it does. (not the same method as SU tool though)
Would you please tell me how, then? :mrgreen:
Much appreciated.
derei
Postby massimo » Fri Dec 18, 2015 2:59 pm
Much appreciated.
-Pick a tool;
-click on a handle. You can press CTRL if you want to scale symmetrically from the centre;
-press TAB key;
-input a measure;
-click OK or press ENTER.
massimo
Postby etzaelpinon » Wed Dec 30, 2015 6:05 pm
-it Dies pretty easily when organic components selected and or when a small group of drawings selected.
etzaelpinon
Postby TIG » Wed Dec 30, 2015 8:20 pm
etzaelpinon wrote:-it Dies pretty easily when organic components selected and or when a small group of drawings selected.
An example or two would help...
Otherwise Fredo would need to rely entirely on his ESP...
Global Moderator
Postby sasasaps » Thu Jan 14, 2016 7:31 pm
Hello everyone,
Amazing plugin! But, the more I use it I go finding some problems, I don´t know if they are common bugs or just limitations of the plugin.
I usually have problems at exploding, grouping or regrouping geometry that has been sheared preaviously (I have just noticed it when using "shear").
The reshaped elements or components return to their original shape, (previous to FredoScale), after doing any of the operations listed:
- after exploding a reshaped group. (sometimes)
- after "copying-pasting out" a plane from a reshaped group.
- after grouping a set of reshaped groups.
sasasaps
Postby dozer157 » Tue Mar 01, 2016 9:29 pm
Download LINK? -_-
dozer157
Postby Dave R » Sat Mar 05, 2016 1:40 pm
dozer157 wrote:Download LINK? -_-
It's very clearly spelled out in the first post of this thread.
Global Moderator
Postby masterpaul » Thu Mar 10, 2016 12:24 pm
Can I use this to scale a component without scaling any inner components/geometry (just increasing and decreasing the space between objects)?
I.E there are 20 sub components in the the component and I would like the components to remain the same size while scale, and only the size between the components to shrink and expand proportionally.
masterpaul
Postby pbacot » Thu Mar 10, 2016 4:53 pm
masterpaul wrote:Can I use this to scale a component without scaling any inner components/geometry (just increasing and decreasing the space between objects)?
From your description I don't think so. I have not seen any sort of setting that would allow that. You can do that sort of thing sequentially in one direction with "stretching" controlling the "divider" location, and performing a stretch for each space, but it wouldn't be possible in all directions.
Top SketchUcator
Postby masterpaul » Thu Mar 10, 2016 11:04 pm
Yeah unfortunately; however I found another method:
If someone has access to sketchup pro and dynamic components he can permanently set the dimensions of each component (for example in the size attributes click lenx, type "=40",press enter and repeat for lenY and LenZ) and it's really simple to do. Then no mater how many components he has selected and scales them all at ones they will always remain the original size, increasing or decreasing the space between them. Saves a lot of time when doing seating on stadiums for example.
Regular Sketchup users will have to do it the old fashion way until someone creates a plugin for this.
masterpaul
Postby nbromz » Thu Nov 10, 2016 9:25 am
Just installed Sketchup 2017, and when using the Fredoscale- radial bending sketchup crashes as soon as the command is completed. Just wondering whether this is a problem with my system or a known compatibility problem for Sketchup 2017?
Kind Regards,
Nigel
nbromz
Postby Dave R » Thu Nov 10, 2016 5:51 pm
I just tested it and it works fine on my machine. Did you install Fredoscale and LibFredo6 fresh from the Plugin Store or did you just copy over from an older SU install?
Global Moderator
Postby nbromz » Thu Nov 10, 2016 11:09 pm
Just removed and reinstalled them but still the same problem
regards,
Nigel
nbromz
Postby nbromz » Thu Nov 10, 2016 11:51 pm
Just done an installation repair on sketchup and now the plugin is working great - thank god-as its one of my favourites!
Regards,
Nigel
nbromz
Postby nbromz » Tue Nov 29, 2016 9:47 am
Sorry i thought i solved the problem with the installation but it crashes when an object is grouped- works fine when exploded - but get bug splat when bending a group object.
Iam using Sketchup 2017- windows 7 professional
nbromz
Postby fredo6 » Tue Nov 29, 2016 11:45 am
nbromz wrote:Hi,
Could you post or PM the model, with indications of which part you try to bend.
In general complications come from multiple instances of components.
Fredo
fredo6
PluginStore Author
PluginStore Author
Postby pjalbert » Wed Nov 30, 2016 9:25 pm
hi guys
Actually I am having the same problem in Sketchup 2017 Pro. I wanted to bend a cube, and as soon I exit the tool it bugsplatted on me. It also crashes using "twisting with orientation of scaling box". It only happens when the object is a group or component.
pjalbert
Postby FZSarasota » Thu Dec 15, 2016 4:16 am
Hi Fredo,
EDIT: I moved this post over to the thread you linked in last reply.
viewtopic.php?f=323&t=66489
-Terry
FZSarasota
Postby joxter87 » Fri Dec 16, 2016 9:51 am
Hi Fredo!
I have a colleague with the same issue as FZSarasota and pjalbert, after using
radial bend and deselect the object SUP17 crash, it occurs only when used on a
component or a group.
You are however able to save the bend first and then deselect the object to preserve it
when you reopen the document.
As we use this tool everyday in our work its very frustrating. I have the same
setup except i use Windows 10 and he uses Windows 7, for me it works perfect.
We have tried to re-install the plugins whithout any result.
Otherwise, Thank you for a great plugin!
joxter87
Postby FZSarasota » Sun Dec 18, 2016 11:08 pm
Hi Fredo,
EDIT: I moved this message over to this thread (sorry for the mis-post).
-Terry
FZSarasota
Postby fredo6 » Mon Dec 19, 2016 6:57 am
For info, the crash of RadialBend (and Twist), when you have the Dicing on, is identified.
There is another thread to follow up on the issue.
I don't have a 'clean' fix for the time being.
Fredo
fredo6
PluginStore Author
PluginStore Author
Postby FZSarasota » Mon Dec 19, 2016 8:20 am
Thanks for the heads up, I'll go to that thread... Don't worry Fredo, all the other tools in the plugin work Great! I'll grab the fix whenever you release it (take your time, wink) :fro:
-Terry
PS: I moved the last two posts over to the thread you listed.....
FZSarasota
Postby slb_jwm » Sat Dec 24, 2016 1:03 am
Just reinstalled FredoScale v2.8a in SU 2017. Working fine, but the Extension Manager says 'Outdated signature'. The LibGFredo6 extension is happily saying 'Signed'.
Does this matter?
slb_jwm
PluginStore Author
PluginStore Author
PreviousNext
Return to Plugins
Users browsing this forum: abuskky, elmpi, Grand_Dada, jeanny_octavia, phj4131 and 17 guests
