SketchUcation Plugin Store
[Plugin] FredoScale 2.2a - 24 Jul 11
Re: [Plugin] FredoScale 2.2a - 24 Jul 11
Postby d12dozr » Wed May 09, 2012 4:31 am
Sweet update...Thanks, Fredo! :thumb: ...and Jeff for the inspiration :)
"There is a man in the world who will never be turned down... he is the man who delivers the goods."
d12dozr
Top SketchUcator
Operating system: Windows
SketchUp version: 8
License type: Pro
SketchUp use: product design
Level of SketchUp: Advanced
Postby Daniel S » Wed May 09, 2012 4:44 am
Great Update Fredo!!! :ecstatic: :ecstatic: :ecstatic:
I remember a lot this request...
viewtopic.php?f=180&t=24831
I just tried your plugin and I had perfect results in seconds!!
Thank you for making a much more powerful Sketchup Fredo!!!
Daniel S
Daniel S
Postby Wong CK » Mon May 28, 2012 7:35 am
Help!!!! I am a newbie of SU.... I get nothing after installed your plugin... :cry:
Wong CK
Postby TIG » Mon May 28, 2012 10:57 am
Wong CK wrote:Help!!!! I am a newbie of SU.... I get nothing after installed your plugin... :cry:
Have you got the supporting 'Fredo Lib' file/subfolder downloaded/installed as explained on the download page ?
Have you activated the tool under Window > Preferences > Extensions > FredoScale ?
Have you then activated its toolbar from View > Toolbars > Fredo Scale ?
Have you then got the menu item Tools > Fredo6 Collection > FredoScale ... ?
Global Moderator
SketchUp version: 8
License type: Pro
SketchUp use: architecture
Postby redlerred7 » Mon May 28, 2012 11:29 am
do you also have the Fredo file library, which has a link found in the first post, that you need to use the plugin?
redlerred7
Postby kira » Thu May 31, 2012 3:39 am
thank you
kira
Postby SnowTiger » Mon Jun 04, 2012 7:44 pm
This is an Excellent Plugin that I would recommend to anyone and everyone who might ever need to create organic shapes such as boat sails and/or tensile roof structures and the like.
It is extremely easy to use and works very well.
The fact that it is Free is also amazing because it certainly does have value and will save you tons of time regardless what you are trying to create with it.
Thanks again so much for sharing this excellent Plugin as well as for continuing to make improvements/updates.
:fro:
SnowTiger
Postby sags » Thu Jun 14, 2012 1:00 pm
thanks...This is an Excellent Plugin. :thumb:
sags
Postby Rosta » Wed Jun 20, 2012 11:43 pm
what should I do - look at the attachment, thanks for an answer
Rosta
Postby Dave R » Wed Jun 20, 2012 11:52 pm
Looks like a bad install.
Show us a screen shot of your Plugins folder as well as one showing the contents of the folder called FREDOSCALE_Dir_22. It appears you haven't got _loader.rb inside that folder. If you didn't get that one in there, you probably have others you didn't get in there, too. Follow the instructions in the first post of this thread and take a look at the sticky post about installing zipped plugins.
Inspecting mirrors is a job I could easily see myself doing.
Global Moderator
SketchUp version: 8
License type: Pro
SketchUp use: woodworking
Postby Rosta » Thu Jun 21, 2012 2:27 pm
Thanks, I did a new install and now it is ok. But I have another problem. I'd like to have Toolbar of FredoScale. I have the check of FredoScale ON in View -> Toolbars but I have nothing. Thanks
Rosta
Postby Dave R » Thu Jun 21, 2012 2:38 pm
Perhaps your install still isn't correct. Did the toolbar icons get extracted to the right folder? Did you check the box for FredoScale under Extensions?
Global Moderator
SketchUp version: 8
License type: Pro
Postby Rosta » Thu Jun 21, 2012 2:54 pm
I am a beginner for setup of SU. I do know what I did but now I have everything. Thanksssss
Rosta
Postby Kgon » Thu Jun 21, 2012 5:52 pm
Hi there guys.
Well i'm having some problems with this set of tools...mainly with the twisting tool...everything seems fine 'till i give the last click to finish the "command"...immediately i get a bugsplat, no matter the shape even with a single cube it crashes :cry: . Im using sketchup 8 and windows 7 64 bit.
Any clue? Thanks in advise
Kgon
Postby fredo6 » Thu Jun 21, 2012 10:26 pm
Kgon wrote:Hi there guys.
It may come from a conflict with another plugin: Podium (some versions), Matchbox, Sun Position, may be others.
Did you try the Bend functions and do you get a bugsplat too.
Fredo
fredo6
Top SketchUcator
Postby alexpacio » Fri Jul 06, 2012 11:39 am
few days is that I do not work anymore fredoscale.
fredoscale using the center of the object (CTRL), I scale the entire object and not expanding the center.
What has happened?
What should I change?
thanks
Solved.
Updated files and everything ok
thanks anyway :ecstatic: :ecstatic: :ecstatic:
alexpacio
Postby Pilou » Fri Jul 06, 2012 12:14 pm
Maybe you must post some file skp for more helps :) (save as V6)
And one image before / after :)
Speedy Galerie
Pilou
Top SketchUcator
SketchUp version: 6
License type: Free/Make
SketchUp use: hobby
Postby alexpacio » Fri Jul 06, 2012 4:18 pm
Pilou wrote:Maybe you must post some file skp for more helps :) (save as V6)
My screen capture
not scale
final result
alexpacio
Postby Gaieus » Fri Jul 06, 2012 4:40 pm
Roberto, these DB images do not load here this way (it actually links to a page where they are inserted). Could you rather attach them to your post?
Administrator
SketchUp version: 2013
License type: Pro
SketchUp use: historical reconstruction
Postby alexpacio » Fri Jul 06, 2012 4:46 pm
Gaieus wrote:Roberto, these DB images do not load here this way (it actually links to a page where they are inserted). Could you rather attach them to your post?
Sorry,
I solved it.
I reinstalled and fredoscale libfredo and now everything is ok.
Thanks anyway. :thumb: :thumb:
compliments for the speed of responses. This forum is a really quick. :D :D
sorry for my English (using Google translate) but my only language is Italian. :knockout: :knockout:
alexpacio
Postby Gaieus » Fri Jul 06, 2012 10:10 pm
We have an Italian subforum at the bottom (I have added you now). It's not the busiest forum but still, if you get stuck, there are a couple of Italians here...
Administrator
License type: Pro
Postby alfabenedict » Mon Aug 20, 2012 11:11 pm
Thank you! This SketchUp Bending rocks! :fro:
alfabenedict
Postby local » Tue Sep 04, 2012 10:50 pm
Hi!
I have a little problem with this plugin. If the stretching device provided by the component or group, then the attribute does not change the size.
Sorry, this turned out to google.
local
SketchUp version: 8
License type: Pro
Postby Dave R » Tue Sep 04, 2012 11:49 pm
I think I understand what you wrote, local, but it isn't entirely clear.
It is true that if you stretch a component or group, you only change the appearance of that entity but it doesn't change the definition not does it change any other instances of the component in the model. This happens with the native Scale tool as well. To change the definition (attributes) you need to open the component or group for editing and modify the geometry inside.
Global Moderator
SketchUp version: 8
License type: Pro
Postby thomthom » Wed Sep 05, 2012 8:08 am
Could it be that he's referring to Dynamic Components?
Global Moderator
SketchUp version: 8
License type: Pro
Postby local » Wed Sep 05, 2012 8:24 am
This component consists of several group.
local
SketchUp version: 8
License type: Pro
Postby pbacot » Wed Sep 05, 2012 4:41 pm
I am not sure of the question but the stretching tool alters the component itself,unlike the scale tool.
If more than one instance of the component is in drawing, stretching creates a new component definition--so the original component is unchanged.
Top SketchUcator
Operating system: Mac
SketchUp version: 8
License type: Pro
Postby pjbazel » Mon Sep 10, 2012 7:38 pm
Hello all,
This is my first post, but I have spent countless hours reading this forum and it has been the the most amazing SU resource. Im just learning, and I would have a fraction of my current knowledge/ability without this forum, not to mention the developers who make scripts for SU (thank you Fredo!!!) Im amazed how much effort and energy the individuals in this community are willing to give. Truly amazing!
I now have my first question, or at least a question I could not answer simply by reading. I tried to search for the answer, I did not find it, but im sure its simple.
Using Fredo scale box scaling, when I grab/drag a handle and scale it jumps from 1.0 to 1.05, and I can not get it to scale in this range (1.0-1.05) without typing the values. It would be very nice to stop this, and have it scale in this range without it jumping from 1.0 to 1.05.
Is there a way to change this?
thanks...
pjbazel
Postby Gaieus » Tue Sep 11, 2012 9:09 am
Hm. I tried both with the native Scale tool :scale: and FredoScale and I can easily move my mouse in a way that it smoothly "grows" the numbers by 0.01 increments.
Administrator
License type: Pro
Postby pjbazel » Tue Sep 11, 2012 9:24 am
Gaieus wrote:Hm. I tried both with the native Scale tool :scale: and FredoScale and I can easily move my mouse in a way that it smoothly "grows" the numbers by 0.01 increments.
When I use the native scale tool it scales by .01 increments. But, when using Fredo Scale it jumps to 1.05, and then scales up from there at .01 increments. Very frustrating. There is a similar issue when using target mode with small (not minute, but small) distances.When using scaling handles I can type in the values between 1 and 1.05, but with target mode there is no way to get the scaling through the small distance.
If anyone has any ideas please tell me what you think. There didn't seem to be anything in the settings to correct this.
pjbazel
Are you a Premium Member? Get your freebies here. Are you not a Premium Member yet? Upgrade your account to grab these freebies instantly.
PreviousNext
Return to Plugins
Users browsing this forum: Filberts, Galerin, Google Feedfetcher, gramiyoe, kobalt99, Krycek, peter_shaw, radiacor, sopsoppysop, szcsaba91, topcon and 9 guests
