SketchUcation Plugin Store
[Plugin] FredoScale 2.2a - 24 Jul 11
Re: [Plugin] FredoScale 2.2a - 24 Jul 11
Postby pbacot » Mon Apr 16, 2012 4:33 pm
Jonathan please post the file path. Click on the FredoScale_Dir22 folder and get info (command "i") and look at "where". The total path should read /Library/Application Support/Google SketchUp 8/SketchUp/plugins
Top SketchUcator
Operating system: Mac
SketchUp version: 8
License type: Pro
SketchUp use: architecture
Postby TIG » Mon Apr 16, 2012 4:34 pm
jcastro.arch wrote:I am having a bit of an issue. I am running Mac OS Lion and I just tried to install your Fredo Scale 2.2 a and LibFredo6 and placed the folders in the approiate plugins... but I dont see any of the tools when I start up SketchUP. I was hoping someone had come accross this issue and found a fix, or knows something about this occurance. Any help would be greatly appreaciated. Thanks!
At the risk of repeating ourselves yet again...
Are you extracting files from the zip correctly ?
Are you also getting and installing the required Lib' folder of supporting tools as advised on the download page ?
What 'Plugins folder' are you putting things into on your MAC ?
The root[HD]...Library...Plugins is good, user...Library...Plugins is bad.
There are several helpful posts about how to extract and install plugins...
Once everything is in the right folder[s] a restart will make the tool available.
Activate it from Preferences > Extensions.
Active it toolbar from View > Toolbars [slightly different name on a MAC ?].
Customize what appears on the tool's toolbar using the special menu items as explained in the tools help docs/pages...
Global Moderator
Operating system: Windows
SketchUp version: 8
License type: Pro
Level of SketchUp: Advanced
Postby Dave R » Mon Apr 16, 2012 5:28 pm
Just a note, on Mac, Preferences are found under the SketchUp menu to the left of File.
Inspecting mirrors is a job I could easily see myself doing.
Global Moderator
SketchUp version: 8
License type: Pro
SketchUp use: woodworking
Postby fredo6 » Tue May 08, 2012 9:17 pm
NEW FEATURES: with LibFredo6 4.5 - 08 May 12
If you upgrade to LibFredo6 4.5, you will get two new features for the Free Rotate tool (and other tools based on rotation such as Box Rotate, Twist, Free Planar Shearing).
These new functions are largely inspired from Jeff Hammond's mini-challenge.
  1. Rotate with Offset
    In the SU Rotate tool and previous versions of FredoScale Free Rotate, the inferences are only done about the base line of rotation. This makes difficult to perform rotation when the target point to infer is not on the base line.
    In the new version of Free Rotate, there is an extra step where you can select a target line at a certain offset to be used for inference. This is shown on the video below.
    Note that this step is proposed by default in Free Rotate (just click again if you don't need it) and as an option for other tools (via a long click).
  2. Inference on line
    The typical situation is to rotate a line until it exactly touches another line. This is a typical limitation of the SU Rotate tool which does not provide inference for this case.
    Free Rotate now proposes this inference.
    This is an old request from Daniel S, also mentioned by Jeff in his mini-challenge.
Please see this post for downloading the latest version of LibFredo6.
Fredo
fredo6
Top SketchUcator
Postby Jeff Hammond » Tue May 08, 2012 10:08 pm
holy crap!
that's perfect!
:thumb: :thumb:
dotdotdot
Jeff Hammond
Global Moderator
SketchUp version: 8
License type: Pro
Postby utiler » Wed May 09, 2012 12:25 am
Jeff Hammond wrote:holy crap!
that's perfect!
:thumb: :thumb:
That is perfect, Fredo!!!!
@Jeff - thanks for the challenge, I wasted hours on that bloody thing!!!! ;)
utiler
Top SketchUcator
SketchUp version: 8
License type: Pro
Postby Dave R » Wed May 09, 2012 12:28 am
Thank you Fredo.
And yes, Jeff, thanks for the challenge. I won't ever do it the hard way again.
Global Moderator
SketchUp version: 8
License type: Pro
Postby Pilou » Wed May 09, 2012 2:27 am
Vital Addition! :thumb:
I must try it for see if that gives the same result than a nurbs modeler! ;)
So YES this time seems very good! :fro:
1.3239127 Nurbs (height of brace cut vertically) Pilars are 1 * 1 * 10 , brace 1 * 1 * x : unity meter
1.323913m SU
Speedy Galerie
Pilou
Top SketchUcator
SketchUp version: 6
License type: Free
SketchUp use: hobby
Postby Jeff Hammond » Wed May 09, 2012 2:51 am
Pilou wrote:Vital Addition! :thumb:
i tested a few things against rhino and as far as i can tell, it gives the same exact results.. :thumb:
but the crazy thing is, fredo's version is faster :enlight:
the offset/rotate idea is very clever and well implemented.
bravo!
dotdotdot
Jeff Hammond
Global Moderator
SketchUp version: 8
License type: Pro
Postby Pilou » Wed May 09, 2012 2:52 am
And no more problem in the Big Zoom! :enlight: ;)
Speedy Galerie
Pilou
Top SketchUcator
SketchUp version: 6
License type: Free
SketchUp use: hobby
Postby Jeff Hammond » Wed May 09, 2012 2:53 am
utiler wrote:@Jeff - thanks for the challenge, I wasted hours on that bloody thing!!!! ;)
Dave R wrote:And yes, Jeff, thanks for the challenge. I won't ever do it the hard way again.
i'm just waiting for someone to come up with the next one!
dotdotdot
Jeff Hammond
Global Moderator
SketchUp version: 8
License type: Pro
Postby Pilou » Wed May 09, 2012 2:54 am
Only one decimal point difference! ;)
1.3239127m Nurbs (height of brace cut vertically) Pilars are 1 * 1 * 10 , brace 1 * 1 * x : unity meter
1.323913m SU
Seems very similar! :enlight:
Speedy Galerie
Pilou
Top SketchUcator
SketchUp version: 6
License type: Free
SketchUp use: hobby
Postby Jeff Hammond » Wed May 09, 2012 2:57 am
1.323913m SU
well, no.. sketchup just ran out of zeros :enlight:
9127 rounds up to 913 in sketchup..
dotdotdot
Jeff Hammond
Global Moderator
SketchUp version: 8
License type: Pro
Postby Pilou » Wed May 09, 2012 2:59 am
A great mini-challenge with some headaches! :mrgreen:
Maybe another solution without plug can be found who knows! ;)
Speedy Galerie
Pilou
Top SketchUcator
SketchUp version: 6
License type: Free
SketchUp use: hobby
Postby Jeff Hammond » Wed May 09, 2012 3:07 am
Pilou wrote:A great mini-challenge with some headaches! :mrgreen:
probably. but I don't care anymore. this solves it in my book.
:lol:
dotdotdot
Jeff Hammond
Global Moderator
SketchUp version: 8
License type: Pro
Postby d12dozr » Wed May 09, 2012 4:31 am
Sweet update...Thanks, Fredo! :thumb: ...and Jeff for the inspiration :)
"There is a man in the world who will never be turned down... he is the man who delivers the goods."
d12dozr
Top SketchUcator
SketchUp version: 8
License type: Pro
SketchUp use: product design
Postby Daniel S » Wed May 09, 2012 4:44 am
Great Update Fredo!!! :ecstatic: :ecstatic: :ecstatic:
I remember a lot this request...
viewtopic.php?f=180&t=24831
I just tried your plugin and I had perfect results in seconds!!
Thank you for making a much more powerful Sketchup Fredo!!!
Daniel S
Daniel S
Postby Wong CK » Mon May 28, 2012 7:35 am
Help!!!! I am a newbie of SU.... I get nothing after installed your plugin... :cry:
Wong CK
Postby TIG » Mon May 28, 2012 10:57 am
Wong CK wrote:Help!!!! I am a newbie of SU.... I get nothing after installed your plugin... :cry:
Have you got the supporting 'Fredo Lib' file/subfolder downloaded/installed as explained on the download page ?
Have you activated the tool under Window > Preferences > Extensions > FredoScale ?
Have you then activated its toolbar from View > Toolbars > Fredo Scale ?
Have you then got the menu item Tools > Fredo6 Collection > FredoScale ... ?
Global Moderator
SketchUp version: 8
License type: Pro
Postby redlerred7 » Mon May 28, 2012 11:29 am
do you also have the Fredo file library, which has a link found in the first post, that you need to use the plugin?
redlerred7
Postby kira » Thu May 31, 2012 3:39 am
thank you
kira
Postby SnowTiger » Mon Jun 04, 2012 7:44 pm
This is an Excellent Plugin that I would recommend to anyone and everyone who might ever need to create organic shapes such as boat sails and/or tensile roof structures and the like.
It is extremely easy to use and works very well.
The fact that it is Free is also amazing because it certainly does have value and will save you tons of time regardless what you are trying to create with it.
Thanks again so much for sharing this excellent Plugin as well as for continuing to make improvements/updates.
:fro:
SnowTiger
Postby sags » Thu Jun 14, 2012 1:00 pm
thanks...This is an Excellent Plugin. :thumb:
sags
Postby Rosta » Wed Jun 20, 2012 11:43 pm
what should I do - look at the attachment, thanks for an answer
Rosta
Postby Dave R » Wed Jun 20, 2012 11:52 pm
Looks like a bad install.
Show us a screen shot of your Plugins folder as well as one showing the contents of the folder called FREDOSCALE_Dir_22. It appears you haven't got _loader.rb inside that folder. If you didn't get that one in there, you probably have others you didn't get in there, too. Follow the instructions in the first post of this thread and take a look at the sticky post about installing zipped plugins.
Global Moderator
SketchUp version: 8
License type: Pro
Postby Rosta » Thu Jun 21, 2012 2:27 pm
Thanks, I did a new install and now it is ok. But I have another problem. I'd like to have Toolbar of FredoScale. I have the check of FredoScale ON in View -> Toolbars but I have nothing. Thanks
Rosta
Postby Dave R » Thu Jun 21, 2012 2:38 pm
Perhaps your install still isn't correct. Did the toolbar icons get extracted to the right folder? Did you check the box for FredoScale under Extensions?
Global Moderator
SketchUp version: 8
License type: Pro
Postby Rosta » Thu Jun 21, 2012 2:54 pm
I am a beginner for setup of SU. I do know what I did but now I have everything. Thanksssss
Rosta
Postby Kgon » Thu Jun 21, 2012 5:52 pm
Hi there guys.
Well i'm having some problems with this set of tools...mainly with the twisting tool...everything seems fine 'till i give the last click to finish the "command"...immediately i get a bugsplat, no matter the shape even with a single cube it crashes :cry: . Im using sketchup 8 and windows 7 64 bit.
Any clue? Thanks in advise
Kgon
Postby fredo6 » Thu Jun 21, 2012 10:26 pm
Kgon wrote:Hi there guys.
It may come from a conflict with another plugin: Podium (some versions), Matchbox, Sun Position, may be others.
Did you try the Bend functions and do you get a bugsplat too.
Fredo
fredo6
Top SketchUcator
Vertex Tools for SketchUp. Take control over each vertex with this vertex editor for SketchUp.
PreviousNext
Return to Plugins
Users browsing this forum: ALDob, doink4078, janinerealubit, rv1974 and 7 guests
