Jeff Hammond wrote:Just in case nobody else has noticed, there's an html file (freescale.donation.html) in the freescale_dir_20 folder.. you can make a donation via that link.
This he truly deserves!
[Plugin] FredoScale 2.2a - 24 Jul 11Re: [Plugin] FreeScale 2.0a beta (+Shear, Stretch, Bend, Twist)
This he truly deserves! Thomas Thomassen — SketchUp Monkey & Coding addict
Re: [Plugin] FreeScale 2.0a beta (+Shear, Stretch, Bend, Twist)And then after use Fredo's bend, clean selection can be useful for lighten the object
clean selection by architectboy or cleanup_model.rb by J.H. Aughey ![]() Please, register (free) to access all the attachments on the forums.
Re: [Plugin] FreeScale 2.0a beta (+Shear, Stretch, Bend, Twist)clean selection?
Re: [Plugin] FreeScale 2.0a beta (+Shear, Stretch, Bend, Twist)Last edited by Pilou on Sun Mar 29, 2009 10:48 pm, edited 1 time in total.
Re: [Plugin] FreeScale 2.0a beta (+Shear, Stretch, Bend, Twist)aha
Awesome plugin Fredo. Thank you very much.
Re: [Plugin] FreeScale 2.0a beta (+Shear, Stretch, Bend, Twist)GOOGLE SHOULD THANK PEOPLE LIKE YOU! This plugin is exactly what SU needed in the 7th version but they didn't see it. You're brilliant. THNX!!!
Re: [Plugin] FreeScale 2.0a beta (+Shear, Stretch, Bend, Twist)Master SuperFredo has done it again!
..it's a pleasure just to admire the genius! (hope google is listening) Thank You Fredo.
Re: [Plugin] FreeScale 2.0a beta (+Shear, Stretch, Bend, Twist)THANK YOU VERY VERY MUCH, thess tools were diarely needed in SU.
Cheers.
Re: [Plugin] FreeScale 2.0a beta (+Shear, Stretch, Bend, Twist)This is again one of the greatest plugins, Fredo! There are so many of "one of the greates plugins" by you now that the expression is getting inflated however.
Thanks a bunch! ![]() Gai...
Re: [Plugin] FreeScale 2.0a beta (+Shear, Stretch, Bend, Twist)Your scripts are just incredible!
Thank you Fredo You are great
Re: [Plugin] FreeScale 2.0a beta (+Shear, Stretch, Bend, Twist)I say "Wooooooaaaaaaaahhh!"
Google, be ashamed! Great job, man. Great job! Torben
Re: [Plugin] FreeScale 2.0a beta (+Shear, Stretch, Bend, Twist)A one man development team. Wonderful!
Google, shame on you +1
Got it, thank you very much for the response, and the plugin.
Re: [Plugin] FreeScale 2.0a beta (+Shear, Stretch, Bend, Twist)Wow! Just had my first cup of coffee and thought I would check to see about the "Bend" plugin. It's like christmas morning. Thanks sooooo much Fredo!
I will give it a try and post some results. Thanks again.
Re: [Plugin] FreeScale 2.0a beta (+Shear, Stretch, Bend, Twist) Thank you. This is like Christmas!Welcome to try Thea Render, Thea support | kerkythea.net -team member
Re: [Plugin] FreeScale 2.0a beta (+Shear, Stretch, Bend, Twist)this
is utterly AWESOME! You are doing an incredible job. Thank you so much!
Re: [Plugin] FreeScale 2.0a beta (+Shear, Stretch, Bend, Twist)Scripters like you are what gives the 'UP' in Sketchup. Thanks a ton for all you hard work and thoughtful rubies.
Re: [Plugin] FreeScale 2.0a beta (+Shear, Stretch, Bend, Twist)Thank you Fredo6
However, I seem to be the only one with this problem. The below jpg shows the error I recieve. I have removed the old version, still get the same error. Help Again thank you. Ken Please, register (free) to access all the attachments on the forums. Government rushes to help the irresponsible and does little for the responsible.
Re: [Plugin] FreeScale 2.0a beta (+Shear, Stretch, Bend, Twist)Ken, did you install LibFredo6 version 3.1? It is linked to in the first post of the thread.
Inspecting mirrors is a job I could easily see myself doing.
Re: [Plugin] FreeScale 2.0a beta (+Shear, Stretch, Bend, Twist)Is it possible to specify the number of slices it does when bending?
I think he does. He said he deleted the old version. But I suspect here is that Vista keeps a copy of the old version somewhere. I think I've heard of issues like that. Though I've never experienced it myself, I wonder if it happens when UAC is on... Thomas Thomassen — SketchUp Monkey & Coding addict
Yep, press tab when youve got the bend tool selected and change the top number, 20's usually pretty good, although you can go up to 60 if you need to.
Yes, I did install LibFredo6 version 3.1. However, I didn't remove all of the old program, I just renamed the directories until I was sure this version would work. Now, however, I did remove all of the old directories, I now have this error. Working my way to total victory. Thanks for the replies Ken Please, register (free) to access all the attachments on the forums. Government rushes to help the irresponsible and does little for the responsible.
Re: [Plugin] FreeScale 2.0a beta (+Shear, Stretch, Bend, Twist)This is just.. just... i mean...
Re: [Plugin] FreeScale 2.0a beta (+Shear, Stretch, Bend, Twist)you are a genius, i use your rubies daily and would have dropped sketchup a while ago if it wasnt for such awsome scripts, thank you.
a small request, could cadfather do your icons again, i liked his work with "Tools on Surface" and "BZ_Toolbar"... no offence Google tisk tisk
Ken, Do not remove or rename anything. Just install the Library LibFredo6 3.1 and FreeScale 2.0, as indicated. Then, if it works, you may want to remove the folders LIBFREDO6_Dir_30 and FREESCALE_Dir_10, but it does not really matter you do it right away, as they will never be loaded. Fredo
Re: [Plugin] FreeScale 2.0a beta (+Shear, Stretch, Bend, Twist)Fredo, you are truly amazing!!
Thanks so much for all your hard work, dedication and generosity!!!
Re: [Plugin] FreeScale 2.0a beta (+Shear, Stretch, Bend, Twist)awesome awesome awesome!!!
Fredo, if it wasn't for you, I think I would have left SU in my dust ages ago. Just simply fantastic and thank you!! Cheers, Chuck
MY BLOG Become a fan of OTB Designworks on Facebook, we'd love to have you! 3.2ghz 8 core Mac Pro. 10 gig RAM, 8800 GT GPU, dual monitors
Re: [Plugin] FreeScale 2.0a beta (+Shear, Stretch, Bend, Twist)This is .....
Well done....i m still wondering what is sketchup going to become with such smart people like Fredo.. Thanks a lot! Elisei Elisei (sketchupper)
____________________________________________________________ Before no life was done on Earth it was THE LIFE ITSELF...GOD Come and See EliseiDesign
SketchUcation One-Liner AdvertsArtisan Organic Toolset - a set of powerful organic modeling tools.
