[Plugin] FredoScale - v3.1a - 18 Dec 18
Re: [Plugin] FreeScale 2.0a beta (+Shear, Stretch, Bend, Twist)
Postby ken » Mon Mar 30, 2009 11:12 pm
Fredo
I have done as requested, still have problem, pic 2. I have sent to you a PM with my files.
Thanks for the help
Ken
ken
Premium Member
Premium Member
Postby jmmad » Mon Mar 30, 2009 11:14 pm
Fredo6 wrote:I cannot reproduce the freeze (see video attached). Is it something always reproducable in your environment?
Can any other user try to reproduce it?
Bench Moder trial.wmv
Fredo
I detected that the freez only happens when i have set the planes to a certain position and hit control, then 2 planes apear instead of one and i stretch from the center, but while im stretching the component SU freezes, always.
Thxs for responding.
All the rest works like charm :sketchstatic:
Get Upa !
jmmad
Postby malvin » Mon Mar 30, 2009 11:33 pm
How do I download the zip? I have only php file saved.
Please advice
malvin
Postby Chris Fullmer » Tue Mar 31, 2009 12:04 am
You should just be able to click on it and it should pop up a windows asking if you want to save or open. What operating system are you on? What browser are you using?
Chris
All my Plugins I've written
SketchUp Team
SketchUp Team
Postby malvin » Tue Mar 31, 2009 12:20 am
Chris Fullmer wrote:You should just be able to click on it and it should pop up a windows asking if you want to save or open. What operating system are you on? What browser are you using?
Chris
malvin
Chris
malvin
Postby malvin » Tue Mar 31, 2009 12:24 am
Chris
I have Windows XP Pro, Internet Explorer 6
The window does pop up to save or open but instead of save the zip file.php is saved
Please advice
Olga
malvin
Postby Ecuadorian » Tue Mar 31, 2009 12:36 am
Get rid of Internet explorer and get either Firefox or Google Chrome. Both are free and a lot less of a headache.
Ecuadorian
Postby solo » Tue Mar 31, 2009 12:42 am
hmmmm, I would'nt say that IE is that bad, pretty stable IMO.
However I noticed that Malvin is using version 6, considering version 8 is out and he has not upgraded one can deduce that he does not have updates enabled therefore all his definitions and drivers are probably outdated.
http://www.solos-art.com
solo
Global Moderator
Postby malvin » Tue Mar 31, 2009 1:15 am
Yes, solo, I do not have updates enabled so that might be the reason but I do download stuff now and then and only very seldom I run into this problem when instead of zip I have file.php downloaded. That might be the promlem
malvin
Postby xrok1 » Tue Mar 31, 2009 1:16 am
i noticed a quirk?
if i use the SP toolbar to create a cone, i cannot stretch it up or down no matter what. i can however stretch it from the sides?
its not too important to me i just thought i'd mention it in case its a bigger thing than i can tell.
“There are three classes of people: those who see. Those who see when they are shown. Those who do not see.”
xrok1
Postby boilingsnow » Tue Mar 31, 2009 2:19 am
Thank you very much Fredo!
But it seems that the streching tool doesn't work on cylinders.
boilingsnow
Postby jmmad » Tue Mar 31, 2009 2:29 am
boilingsnow & xrok1
stretch wont affect curves.
to affect it you must explode the curve first.
Get Upa !
jmmad
Postby xrok1 » Tue Mar 31, 2009 2:32 am
if i stretch a cone from the point upward, what does that have to do with a curve?
xrok1
Postby utiler » Tue Mar 31, 2009 2:40 am
solo wrote:hmmmm, I would'nt say that IE is that bad, pretty stable IMO.
Pete, I just un-installed 8 as it was causing some issues and couldn't be bothered to troubleshooting... less time on FreeScale. ;)
utiler
Top SketchUcator
Postby jmmad » Tue Mar 31, 2009 2:44 am
xrok1 wrote:if i stretch a cone from the point upward, what does that have to do with a curve?
You are right
The problem with a cone is that upwards its made of triangles you cannot stretch a triangle it would be the same as using scale.
As it wont work with a 3 side piramid in any direction
Get Upa !
jmmad
Postby fredo6 » Tue Mar 31, 2009 6:24 am
jmmad,
On your problem of freeze, and since you seem to be able to reproduce the problem, could you just try with the attached file (just drop it into the FREESCALE_Dir_20 folder).
I am not too sure of what it can be, but I rewrite one part of the code differently.
Thanks to advise
Fredo
fredo6
PluginStore Author
PluginStore Author
Postby jmmad » Tue Mar 31, 2009 7:21 am
Fredo6 wrote:On your problem of freeze, and since you seem to be able to reproduce the problem, could you just try with the attached file (just drop it into the FREESCALE_Dir_20 folder).
I did what you told me.
But the freeze continues but its only with this component y tried to duplicate the bug with similar components (a component with 4 nested components inside) and the tool works perfect.
Its strange i think this might be a isolated problem not much to worry about.
Thxs for the concern and help
Get Upa !
jmmad
Postby fredo6 » Tue Mar 31, 2009 12:55 pm
Daniel S wrote:* A feature of the native protactor-rotate tool is missing... The ability of holding down the primary mouse button, and dragging the protractor is great:
http://sites.google.com/site/sketchupsage/tweak/rotate
This option can be added?
Thank you again for this amazings tools,
Daniel S
Daniel,
Can you try if this works for you (drop the attached file into LIBFREDO6_Dir_31 folder). I must say that I did not know this function, but using it a little bit, it seems very convenient. So thank you for signaling it and evangelizing other users.
Fredo
fredo6
PluginStore Author
PluginStore Author
Postby princedragoncok » Tue Mar 31, 2009 1:05 pm
Thank you for this great set of tools fredo. Seem to handle even complex geometry well. mighty impressed!
princedragoncok
Postby Daniel S » Tue Mar 31, 2009 2:19 pm
Fredo6 wrote:Daniel,
Fredo
Works great for endpoints but if you place the protactor on edges and drag it dosen´t lock in the exact point you start the operation. Is like the protactor slips. The same happens if you place the protactor on a face and drag.
Thank you for adding this option!!! :sketchstatic: :sketchstatic:
Daniel S
Daniel S
Postby fredo6 » Tue Mar 31, 2009 3:23 pm
of course.
Sorry for that
Fredo
fredo6
PluginStore Author
PluginStore Author
Postby Daniel S » Tue Mar 31, 2009 5:25 pm
The protactor still slips for me.
Daniel S
Daniel S
Postby fredo6 » Tue Mar 31, 2009 5:56 pm
Daniel S wrote:The protactor still slips for me.
Daniel S
Re-sorry.
I guess this is better now
Fredo
fredo6
PluginStore Author
PluginStore Author
Postby pilou » Tue Mar 31, 2009 6:24 pm
Is it possible to use the radial Bending only for "slicer" a volume without to bend?
If yes how?
If I click (start end) a "straight line" along an edge nothing append when release the protractor without bending :oops:
Speedy Galerie
Top SketchUcator
Postby fredo6 » Tue Mar 31, 2009 7:11 pm
Pilou wrote:Is it possible to use the radial Bending only for "slicer" a volume without to bend?
If yes how?
I had the idea to isolate the slicer as a separate tool (then in 3 directions). so at least one requestor.
In between, you have one in SketchyFFD
Fredo
PS: If you don't bend, then nothing happens, which is the natural and intentional behavior
fredo6
PluginStore Author
PluginStore Author
Postby Daniel S » Tue Mar 31, 2009 8:40 pm
The latest Lib6Protractor.rb works very well like the native SU tool. :sketchstatic: :sketchstatic: :sketchstatic:
Thank you Again!!!
Daniel S
Daniel S
Postby Jean-Franco » Tue Mar 31, 2009 9:21 pm
Hi, Fredo I've a recurent problem after bending. See my picture.
Any idea of what happens ?
Jean-Franco
Jean-Franco
Postby thomthom » Tue Mar 31, 2009 9:31 pm
Jean-Franco wrote:Hi, Fredo I've a recurent problem after bending. See my picture.
They are still co-planar. But there is hidden lines created there. Turn on Hidden Geometry and erase the lines on that surface and you can do a regular push/pull.
PluginStore Author
PluginStore Author
Postby fredo6 » Tue Mar 31, 2009 9:32 pm
Very simple;
If you show hidden geometry you'll see all the subface.
In your case, you can easily clean up all those coplanar edges, and then have a surface you can push pull with the native Sketchup tool.
Fredo
Actually, I could have the script do the clean up of coplanar edges automatically as an option. Maybe I'll do that.
fredo6
PluginStore Author
PluginStore Author
PreviousNext
Return to Plugins
Users browsing this forum: Mônica Ferreira , Schwerin, tabulador and 13 guests
