[Plugin Library] LibFredo6 - v11.6a - 23 Jan 21
Re: [Plugin Library] LibFredo6 3.3a (27 Aug 09)
Postby Jean-Franco » Fri Aug 28, 2009 6:30 pm
Jean-Franco
Jean-Franco
Postby pilou » Fri Aug 28, 2009 6:57 pm
Ah bouffre! :mrgreen: :fro: :enlight:
Speedy Galerie
Top SketchUcator
Postby fredo6 » Fri Aug 28, 2009 7:15 pm
massimo wrote:Hi Fredo i have noticed that the zipped folder LibFredo3.3a contains a folder LibFredo6_Dir_32. No need for that, no? Thank you very much.
Strange. Are you sure?
I checked that the Zip file does not have any reference to LibFredo6_Dir_32. So, could it come from your installation ?
Thanks to advise
Fredo
fredo6
PluginStore Author
PluginStore Author
Postby massimo » Fri Aug 28, 2009 8:02 pm
Not installed yet. The downloaded zip file contains a LibFredo6_Dir_33 folder, a LibFredo6 file plus another LibFredo6_Dir_32 folder with an empty IMAGES_Standard sub-folder. At least in my download. :)
But i believe i have simply to remove it.
massimo
Postby fredo6 » Fri Aug 28, 2009 8:43 pm
massimo wrote:Not installed yet. The downloaded zip file contains a LibFredo6_Dir_33 folder, a LibFredo6 file plus another LibFredo6_Dir_32 folder with an empty IMAGES_Standard sub-folder. At least in my download. :)
Can you then install it (Open Zip file, Select All, Extract in Plugins folder) and check whether you have any trace of the LibFredo6_Dir_32 in the folder created.
I did it on several machines, and no trace of the old folder.
fredo6
PluginStore Author
PluginStore Author
Postby massimo » Fri Aug 28, 2009 8:50 pm
Hmmm really strange. I overwrote the Libfredo_32 empty folder on the existing folder and now it's no more empty ...
This is what i have after the download.
massimo
Postby massimo » Fri Aug 28, 2009 9:06 pm
And this is the contents of the Libfredo_32 folder. And the IMAGES folder is empty. But i imagine i can delete any previous LibFredo.
massimo
Postby fredo6 » Fri Aug 28, 2009 9:19 pm
massimo wrote:And this is the contents of the Libfredo_32 folder. And the IMAGES folder is empty. But i imagine i can delete any previous LibFredo.
If you have a LibFredo6_Dir_33 folder in good shape, you can indeed remove the folder of the previous version LibFredo6_Dir_32.
By the way, are you able to run the scripts like RoundCorner 2.1 and my other scripts after your installation ?
fredo6
PluginStore Author
PluginStore Author
Postby massimo » Fri Aug 28, 2009 9:24 pm
I have deleted LibFredo6_Dir_32 and, after a quick test, RoundCorner and FredoScale seem to work fine. Thanks. :)
massimo
Postby iamarchitecture » Sun Sep 06, 2009 10:56 am
Thanks Fredo
iamarchitecture
Postby oblin77 » Sun Sep 13, 2009 7:47 am
Hello again
Where can I find this group of plugin : RoundCorner 2.1, GhostComp 1.0 and ToolsOnSurface 1.5
I would like to change my soft and I've seen your plugin
wonderfull
Thank
Olivier
oblin77
Postby Jean-Franco » Sun Sep 13, 2009 10:26 am
Dear Olivier,
you can find a collection of plugins here: viewtopic.php?f=180&t=10142
They are sorted in a way you should understand easily.
And you can also have a look at there: http://www.sketchucation.com/extensions-index/
Jean-Franco
Jean-Franco
Re: [Plugin Library] LibFredo6 3.4a (17 Sep 09)
Postby fredo6 » Thu Sep 17, 2009 9:58 pm
NEW VERSION 3.4a - 17 Sep 09
Needed for Tools On Surface v1.5 (and compatible for FredoScale, RoundCorner 2.1, GhostComp 1.0 and HoverSelect).
Small evolutions (mainly for Palettes), bug fixing, ...
see main post at http://www.sketchucation.com/forums/scf/viewtopic.php?f=180&t=17947&p=144178#p144178
fredo6
PluginStore Author
PluginStore Author
Postby notareal » Fri Sep 18, 2009 8:51 am
notareal
Thea Render Support
Thea Render Support
Postby Bob James » Fri Sep 18, 2009 7:46 pm
Fredo Tools alive and well on MacPro/Leopard (Tools on Surface, Round Corner, Joint Push-Pull)
Bob James
Premium Member
Premium Member
Re: [Plugin Library] LibFredo6 3.4b (08 Oct 09)
Postby fredo6 » Thu Oct 08, 2009 9:35 pm
[Upgrade 08 Oct 09] LibFredo6 3.4b
Complement of Plugin translation to Spanish by Gaonirico (previous was done by Pichuneke).
See main post at http://forums.sketchucation.com/viewtopic.php?f=180&t=17947#p144178
fredo6
PluginStore Author
PluginStore Author
Postby SimonSTJ » Fri Oct 09, 2009 6:09 pm
whwrw can I find (download libfredo6 3.3a or higher..?
SimonSTJ
Postby SimonSTJ » Fri Oct 09, 2009 6:38 pm
massimo wrote:I have deleted LibFredo6_Dir_32 and, after a quick test, RoundCorner and FredoScale seem to work fine. Thanks. :)
Hi.. Can you tell me where can I find libfredo6 3.3a or higher..?
SimonSTJ
Postby massimo » Fri Oct 09, 2009 6:44 pm
Hi Simon, go to the bottom of the very first post of this thread. You will find something like this...(see below)
massimo
Postby SimonSTJ » Fri Oct 09, 2009 6:59 pm
massimo wrote:Hi Simon, go to the bottom of the very first post of this thread. You will find something like this...(see below)
Thanks.. I've been doing that for the las 2 days hoping that I'll find something like that.
Thank you again..I'll try to install it right now and if I have any problems I'll wright to you again.. :)
SimonSTJ
Postby fredo6 » Tue Oct 20, 2009 7:33 am
Update 20 Oct 09 - Documentation available in French, thanks to Jean-Franco.
See main post http://forums.sketchucation.com/viewtopic.php?f=180&t=17947#p144178
Fredo
fredo6
PluginStore Author
PluginStore Author
Postby avya » Fri Oct 30, 2009 7:19 pm
thanks :thumb:
avya
Postby arturmercurio » Fri Oct 30, 2009 11:23 pm
Great work! amazing just perfect. my best regards.
http://www.arturcarvalho.me/
arturmercurio
Re: [Plugin Library] LibFredo6 3.4b (Chinese 11 Nov 09)
Postby fredo6 » Wed Nov 11, 2009 10:01 pm
[Chinese version - 11 Nov 09 - 21:50 CET
Diweiman and the SuBAR_CLT team at SketchupBar have translated the script into Chinese.
See main post at http://forums.sketchucation.com/viewtopic.php?f=180&t=17947&p=144178#p144178).
fredo6
PluginStore Author
PluginStore Author
Re: [Plugin Library] LibFredo6 3.4b - 11 Nov 09 (Chinese)
Postby blammas » Wed Nov 25, 2009 7:10 am
Is this compatible with windows 7? It doesn't show up in the folder once extracted...
blammas
Postby thomthom » Wed Nov 25, 2009 8:24 am
works fine on my windows7. But I have the UAC diabled, maybe that makes a difference.... Think there was an issue on Vista where files some times ended up in a compatibility folder...
PluginStore Author
PluginStore Author
Postby Khai » Fri Nov 27, 2009 4:25 pm
ok.. installed the Library to my new SU install and on starting SU I just get a load of Load Errors:
Error Loading File D:/7500 Modeling Apps/Google/Google Sketchup 7/plugins/LIBFREDO6_Dir_34/lib6config/tb uninitalized constant Traductor::T6
etc etc (list goes on...)
Edit ok - found it was an issue with Smustards Plugin organiser.
Khai
Postby pcrego » Wed Dec 02, 2009 9:56 pm
I am trying to download Round Corner but it says I am not authorized to do so.. Any help please?
pcrego
Postby qiujie19 » Fri Dec 11, 2009 2:10 pm
great i need the chinese version
qiujie19
Re: [Plugin Library] LibFredo6 - v3.4b - 11 Nov 09
Postby cherokee_ro » Fri Dec 18, 2009 11:30 am
hi, i'm getting an error like this : "uninitialized constant LibFredo6::Traductor" i installed the last version of libfredo6...anybidy knows why?
cherokee_ro
PreviousNext
Return to Plugins
Users browsing this forum: chairat5221, Majestic-12 Bot, yugo27 and 19 guests
