by Bob James » Sat Jul 11, 2009 8:22 am
•BTM wrote:The attachment at the bottom of the first post.
Maybe I should change my user name to "Dumb and Dumber". The only thing at the bottom of the first post " [Plugin] RoundCorner 2.0a - 9 Jul 09" was RoundCorner 2.0a and Quickcard RoundCorner - English - v2.0.pdf. At the top of that post was: "RoundCorner .......requires you also upgrade to LibFredo6 3.2a or higher. See that post at http://www.sketchucation.com/forums/scf ... 47#p144178". That took me to this post where there is no LibFredo6 3.2a download
"If you don't plan ahead you'll be at the mercy of those that do" - Ashleigh Brilliant
"Bad is not good until worse happens" - Bob James
Bob James
- Premium Member
- Operating system: Windows
- SketchUp version: 8
- License type: Pro
- SketchUp use: other
- Level of SketchUp: Advanced
by COSEDIMARCO » Sat Jul 11, 2009 8:45 am
Hi Bob at then end of the first post in this 3D there's the attachment with the new Libraries
COSEDIMARCO
by Free Agent » Sat Jul 11, 2009 8:35 pm
through the round corners parameters under Tools is ther any way to make is so that the geometry isnt automatically softened?
Free Agent
- Name: Sean
by Fredo6 » Sat Jul 11, 2009 9:00 pm
Free Agent wrote:through the round corners parameters under Tools is ther any way to make is so that the geometry isnt automatically softened?
I answered your question in the main thread related to RoundCorner. See http://forums.sketchucation.com/viewtopic.php?f=180&t=20485&p=172147#p172147LibFredo6 is just a shared library, common to my scripts (and used by FredoScale and HoverSelect). It does not contain anything specific to RoundCorner.
Fredo6
- Top SketchUcator
by Bob James » Sun Jul 12, 2009 9:05 am
COSEDIMARCO wrote:Hi Bob at then end of the first post in this 3D there's the attachment with the new Libraries
Egads!! Was that there all the time. Arrrggghhh.
Bob James
- Premium Member
- License type: Pro
by Zante » Mon Jul 13, 2009 12:24 pm
The bend modifier seems to add a load of geometry to things. : [
Zante
by szanini » Sat Jul 18, 2009 12:20 am
You're the man!!!
szanini
- Name: Sandro Adriano Carbone Zanini
- License type: Free
- SketchUp use: architecture
by pierrearchi » Sat Jul 25, 2009 10:06 pm
Fredo, I work on Macintel + macOSX and nothing work (nothing appear) on SKP7 pro !! I use : Fredoscale 2.0g + Libfredo6 3.2a + Round corner 2.0b. I have put them in the right folder : Both in plugins file inside Application support file path. Merci Fredo pour ta reponse et (pour l'ensemble de ton oeuvre) car il me tarde d'utiliser tes plugins sous Mac !!. Bye, Pierre.
pierrearchi
by mariocha » Sun Jul 26, 2009 4:17 pm
pierrearchi wrote:I use : Fredoscale 2.0g + Libfredo6 3.2a + Round corner 2.0b. I have put them in the right folder : Both in plugins file inside Application support file path.
Well, I think that, since Mac OS 10.5.6 or around, it is preferable to put the plugins in / user/Librairy /Application support/ etc... Ce que j'ai fait, et tout baigne nickel ( comme disent les français). Fredo must be complimented .... again.
Mario C. Certified SketchUp Trainer, QC CA, Mac Pro 2xQuad core & MacBook Pro 3.06 Ghz.
mariocha
- Premium Member
- Operating system: Mac
- License type: Pro
by Bob James » Mon Jul 27, 2009 6:24 pm
mariocha wrote:Well, I think that, since Mac OS 10.5.6 or around, it is preferable to put the plugins in /user/Librairy /Application support/ etc...
That certainly is true of Profile Builder and Podium, but LibFredo6.rb works just fine in the usual place (Mac/Library/Applications Support/Google SketchUp 7/plugins).
Bob James
- Premium Member
- License type: Pro
by COSEDIMARCO » Fri Aug 28, 2009 5:17 am
Hi Fredo. Where can I find new version of Tools on surface?
COSEDIMARCO
by Fredo6 » Fri Aug 28, 2009 3:04 pm
COSEDIMARCO wrote:Hi Fredo. Where can I find new version of Tools on surface?
Not yet ready. It will be a refresh, with a palette for better visualizing the options, some improvements to the Freehand tool and a few other evolutions. Fredo
Fredo6
- Top SketchUcator
by massimo » Fri Aug 28, 2009 4:43 pm
Hi Fredo i have noticed that the zipped folder LibFredo3.3a contains a folder LibFredo6_Dir_32. No need for that, no? Thank you very much.
massimo
- Global Moderator
- Name: Massimo Siracusa
- SketchUp version: 7
- License type: Pro
by Pilou » Fri Aug 28, 2009 5:59 pm
Sorry what is "GhostComp 1.0"?
Pilou
- Top SketchUcator
- SketchUp version: 6
- SketchUp use: hobby
by Jean-Franco » Fri Aug 28, 2009 6:30 pm
Jean-Franco
Jean-Franco
- Name: Jean-Franco
- License type: Pro
- SketchUp use: woodworking
by Pilou » Fri Aug 28, 2009 6:57 pm
Pilou
- Top SketchUcator
by Fredo6 » Fri Aug 28, 2009 7:15 pm
massimo wrote:Hi Fredo i have noticed that the zipped folder LibFredo3.3a contains a folder LibFredo6_Dir_32. No need for that, no? Thank you very much.
Strange. Are you sure? I checked that the Zip file does not have any reference to LibFredo6_Dir_32. So, could it come from your installation ? Thanks to advise Fredo
Fredo6
- Top SketchUcator
by massimo » Fri Aug 28, 2009 8:02 pm
Not installed yet. The downloaded zip file contains a LibFredo6_Dir_33 folder, a LibFredo6 file plus another LibFredo6_Dir_32 folder with an empty IMAGES_Standard sub-folder. At least in my download.  But i believe i have simply to remove it.
massimo
- Global Moderator
- License type: Pro
by Fredo6 » Fri Aug 28, 2009 8:43 pm
massimo wrote:Not installed yet. The downloaded zip file contains a LibFredo6_Dir_33 folder, a LibFredo6 file plus another LibFredo6_Dir_32 folder with an empty IMAGES_Standard sub-folder. At least in my download.  But i believe i have simply to remove it.
Can you then install it (Open Zip file, Select All, Extract in Plugins folder) and check whether you have any trace of the LibFredo6_Dir_32 in the folder created. I did it on several machines, and no trace of the old folder.
Fredo6
- Top SketchUcator
by massimo » Fri Aug 28, 2009 8:50 pm
Hmmm really strange. I overwrote the Libfredo_32 empty folder on the existing folder and now it's no more empty ... This is what i have after the download.
massimo
- Global Moderator
- License type: Pro
by massimo » Fri Aug 28, 2009 9:06 pm
And this is the contents of the Libfredo_32 folder. And the IMAGES folder is empty. But i imagine i can delete any previous LibFredo.
massimo
- Global Moderator
- License type: Pro
by Fredo6 » Fri Aug 28, 2009 9:19 pm
massimo wrote:And this is the contents of the Libfredo_32 folder. And the IMAGES folder is empty. But i imagine i can delete any previous LibFredo.
If you have a LibFredo6_Dir_33 folder in good shape, you can indeed remove the folder of the previous version LibFredo6_Dir_32. By the way, are you able to run the scripts like RoundCorner 2.1 and my other scripts after your installation ?
Fredo6
- Top SketchUcator
by massimo » Fri Aug 28, 2009 9:24 pm
I have deleted LibFredo6_Dir_32 and, after a quick test, RoundCorner and FredoScale seem to work fine. Thanks.
massimo
- Global Moderator
- License type: Pro
by oblin77 » Sun Sep 13, 2009 7:47 am
Hello again
Where can I find this group of plugin : RoundCorner 2.1, GhostComp 1.0 and ToolsOnSurface 1.5
I would like to change my soft and I've seen your plugin
wonderfull
Thank
Olivier
oblin77
- Name: olivier
by Jean-Franco » Sun Sep 13, 2009 10:26 am
Dear Olivier, you can find a collection of plugins here: viewtopic.php?f=180&t=10142They are sorted in a way you should understand easily. And you can also have a look at there: http://www.sketchucation.com/extensions-index/
Jean-Franco
Jean-Franco
- Name: Jean-Franco
- License type: Pro
by notareal » Fri Sep 18, 2009 8:51 am
notareal
- Thea Render
- Name: notareal
by Bob James » Fri Sep 18, 2009 7:46 pm
Fredo Tools alive and well on MacPro/Leopard (Tools on Surface, Round Corner, Joint Push-Pull)
Bob James
- Premium Member
- License type: Pro
Not a Premium Member yet? Check out the great time-limited deal we are offering.
- Robot
Return to Plugins
