SketchUcation Plugin Store
[Plugin Library] LibFredo6 - v4.9c - 20 May 13
Re: [Plugin Library] LibFredo6 - v4.4j - 11 Apr 12
Postby thomthom » Thu Apr 12, 2012 9:36 am
Didier Bur wrote:I'll just warn users of this library NOT to install it with a Ctrl-A and then drag-drop the files in their Plugins folder. Doing the extraction this way DOESN't create any folder structure and obiously generates errors when loading the library and plugin.
I've always done that - using Windows' native archive feature. Never had any problems.
Global Moderator
Operating system: Windows
SketchUp version: 8
License type: Pro
SketchUp use: architecture
Level of SketchUp: Advanced
Postby fredo6 » Thu Apr 12, 2012 11:14 am
Didier Bur wrote:Hi Fredo,
Thanks for all your huge work and for sharing it with the community.
The safer (and only) way is to select "Extract" in Winzip, point to the correct folder and tick "use folder structure" checkbox.
Now back to removing my 148 wrongly located files :roflmao:
Didier,
Normally, what I say is:
- Select all files (Ctrl A)
- Extract to the destination folder (i.e. not 'drag and drop')
- Answer Yes to overwrite files
Drag and Drop requires, as you say, to make sure Winzip option to use folder structure is On.
Fredo
fredo6
Top SketchUcator
Postby Didier Bur » Fri Apr 13, 2012 2:08 pm
Sorry Fredo, my mistake :oops:
Didier Bur (Bytes Farmer)
Ecole Nationale Supérieure d'Architecture de Nancy (F)
http://rld.crai.archi.fr/rubylibrarydepot/
Didier Bur
SketchUp version: 8
License type: Pro
Re: [Plugin Library] LibFredo6 - v4.4m - 14 Apr 12
Postby fredo6 » Sat Apr 14, 2012 6:37 pm
NEW RELEASE: LibFredo6 v4.4m - 14 Apr 12
LibFredo6 4.4 is a new release which essentially support the publishing of ThruPaint and ReverseOrientFaces as part of FredoTools
This small update fixes some issues in ThruPaint and integrate the translation to Spanish (Defisto, Oxer) and Chinese (guanjin)
See main post of this thread for Download.
Fredo
fredo6
Top SketchUcator
Postby nphong63 » Mon Apr 16, 2012 1:15 pm
thank you!
nphong63
LibFredo6.rb
Postby kespencer1 » Fri Apr 20, 2012 2:59 pm
Hey y'all. I need some help. For whatever reason, LibFredo6 plugin is starting to crash Sketchup. (Yes I know it's this one because I systematically went through and tested sketchup with each plugin I have.)Anyone know a fix for it?
Now that I think about it, it MAY be something that it activates. All I really know is that if I delete it, Sketchup doesn't crash. But then I can't use curveloft and whatnot. ANY help is appreciated.
kespencer1
Postby 3deeidee » Thu Apr 26, 2012 10:37 am
the round corner tool seems like something i would use a lot. Unfortunatly i cannot get it to work properly. I have downloaded the LibFredo6 and placed it in the plugin folder (that is the .rb and the folder) and i also downloaded the round corner tool and also placed it in the plugin folder (the .rb and the folder). As i understand correctly it should then work. But nothing happens when i open SU. I'm working on a mac with SU7 pro.
Ruud
3deeidee
Postby TIG » Thu Apr 26, 2012 10:53 am
Assuming the file/folders were extracted 'intact' and then put into the correct Plugins folder [Macintosh HD/...Lib/.../plugins] and not a spurious 'User' one... then a restart of Sketchup should auto-load the tool for you.
However, like many such tools this is an Extension and so it needs a one off activation, which is done through Preferences > Extensions.
Once it is activated its menu items and toolbar becomes available to you - if it hasn't auto-activated then the toolbar can be activated from the appropriate menu item too...
Global Moderator
SketchUp version: 8
License type: Pro
Re: LibFredo6.rb
Postby TIG » Fri Apr 27, 2012 12:50 pm
kespencer1 wrote:Hey y'all. I need some help. For whatever reason, LibFredo6 plugin is starting to crash Sketchup. (Yes I know it's this one because I systematically went through and tested sketchup with each plugin I have.)Anyone know a fix for it?
Are you sure it's installed properly - file and folder ?
Do you have the latest version ?
Global Moderator
SketchUp version: 8
License type: Pro
Re: [Plugin Library] LibFredo6 - v4.5a - 08 May 12
Postby fredo6 » Tue May 08, 2012 10:23 pm
NEW RELEASE: LibFredo6 v4.5a - 08 May 12
LibFredo6 4.5 is a update dedicated to
Fredo
fredo6
Top SketchUcator
Postby jooooe » Sat May 12, 2012 3:28 pm
sorry! this is not suit for Mac?
jooooe
Postby Dave R » Sat May 12, 2012 10:22 pm
jooooe wrote:sorry! this is not suit for Mac?
What makes you think that? It works fine on my Mac as well as many others.
Inspecting mirrors is a job I could easily see myself doing.
Global Moderator
SketchUp version: 8
License type: Pro
SketchUp use: woodworking
Re: [Library] LibFredo6 3.1c (11 Apr 09)
Postby ihanna » Mon Jun 04, 2012 8:42 pm
Fredo6 wrote:NEW VERSION 3.1c 11 Apr 09 NOW RELEASED
Needed for for FreeScale 2.0c
see http://www.sketchucation.com/forums/scf/viewtopic.php?f=180&t=17947&p=144178#p144178
Note: For those who have downloaded the release (c) of 9 Avril, which was available for a few minutes, please download again the version of 11 Apr.
hello,
I just want to ask some help, I've already download those files twice but still not working, can you give me some advice? Thanks in advance.
______________________________________________________________________________________________
You must be the change you wish to see in the world. —Gandhi
ihanna
Postby Dave R » Tue Jun 05, 2012 12:01 am
ihanna wrote:hello,
You have to meet us half way. Give us something to help you out. We can't see your computer from here and you've given us no clue as to what you've done short of downloading the files. :roll: Did you extract the zip file into Program Files/ Google/Google SketchUp 8/Plugins? Did you extract them correctly? Do you have admin rights to install files into the Plugins folder?
Post a screen shot of your Plugins folder showing the files installed correctly and we'll go from there.
Global Moderator
SketchUp version: 8
License type: Pro
Postby TIG » Tue Jun 05, 2012 8:27 am
These files don't do much on there own. :?
They are 'helpers' for many of Fredo's other tools, which don't work without the file and subfolder of files etc that form the 'Lib'... :o
Global Moderator
SketchUp version: 8
License type: Pro
Postby GooUser » Sun Jun 10, 2012 4:20 pm
Thanks you very lot ! It's Great.
GooUser
Postby Luaner » Mon Jun 18, 2012 3:37 am
Thanks again~❤
Luaner
Postby the.pjt » Tue Jun 19, 2012 7:58 pm
hi dear ferdo , I have a little question ...
.. maybe it's a bad question and I know that it takes much time for you to write these features fur us ... thanks a lot for time you spend and offering your incredible codes freely to us ... thanks ferdo ..
my question is
how to disable time tracer and updater part due to have a faster startup and a lighter SU ?
I'm a ruby newbie .. but you codes are too complex for me to trace .. :) .. I just wanna to know the .rb files that does these extra works ...
I'm sorry for asking these .. I believe that these parts ( specially Updater module )are very useful for all users .. and thanks for codding these parts ferdo .. :P
thanks
the.pjt
Postby fredo6 » Tue Jun 19, 2012 9:10 pm
the.pjt wrote:my question is
You don't need to edit the ruby files.
Normally, go to the CheckForUpdate dialog box and enter 999 (days) in the 'next check' field.
Fredo
PS: 'Check for update' does not go to the Internet when SU Starts. It just checks the date to see if it should display the reminder, so it is very fast. The fact is that that the reminder is based on a WebDialog and the first web dialogs are used, it takes a little bit long (SU may load extra stuff or perform some operations in the background).
fredo6
Top SketchUcator
Postby the.pjt » Tue Jun 19, 2012 9:50 pm
thanks feredo ... I hade done that ( 999 ) several days ago .. but I alwase see the ruby image (update check ) at start up .. how about time tracer tool ?
thanks for answer and support ferdo :ecstatic:
the.pjt
Postby disco_UK » Wed Jun 20, 2012 7:00 pm
hi Fredo, Thanks for this work you've done :thumb:
I have unzipped it to my plugins folder on C:/Program Files(x86)/google/Google Sketchup 8/plugins but for some reasons I just cant find it in the menus! I have also put LibFredo6.rb in the plugins. am I missing something?
kindest regards
Disco
disco_UK
Postby disco_UK » Wed Jun 20, 2012 8:06 pm
:oops:
Can't seem to get the toolbar up. I've followed some of the posts and checked its in the right directory, and also ticked the box in Sketchup.
Any help would be appreciated
A.Noob lol
disco_UK
Postby Dave R » Wed Jun 20, 2012 9:52 pm
Which toolbar can't you get to display?
Global Moderator
SketchUp version: 8
License type: Pro
Postby disco_UK » Thu Jun 21, 2012 7:41 am
Dave R wrote:Which toolbar can't you get to display?
The fredo sub menu under window. I've PM'd Fredo who has been kind enough to reply but so far I've not got to the bottom of it. I do have podium installed and fredo suggest it could be a clash with that?
Thanks for the reply Dave :-)
disco_UK
Postby Dave R » Thu Jun 21, 2012 8:33 am
Ah. I see. You said you couldn't get a toolbar to show which is confusing since it isn't a toolbar but a menu entry. So did you try disabling Podium and did that fix it?
Global Moderator
SketchUp version: 8
License type: Pro
Re: [Plugin Library] LibFredo6 - v4.6c - 11 Jul 12
Postby fredo6 » Wed Jul 11, 2012 11:16 pm
NEW RELEASE: LibFredo6 v4.6c - 11 Jul 12
LibFredo6 4.6 is a new release which essentially support the publishing of Curvizard
Fredo
fredo6
Top SketchUcator
Postby Osdap » Thu Jul 19, 2012 9:34 am
I am really new to the plugins for Google sketchup. Can anyone tell me how to update my plugins?
Osdap
Postby Pilou » Thu Jul 19, 2012 9:49 am
For the external plugins go to to this page for the name of the plugin
and go to to the end of the first post of the thread address read on the list!
You will find the last Update of each plugin!
And if you want the "indispensables" see my little list ;)
Speedy Galerie
Pilou
Top SketchUcator
SketchUp version: 6
License type: Free
SketchUp use: hobby
Postby kersnyc » Wed Jul 25, 2012 9:56 pm
I know this might sound silly but I'm new to this and am having trouble with downloading the plug ins.. I want to download round corners and I thought in order to do so I needed to install the LibFred06. When it goes to download and I need to unzip it I DO NOT have a Sketchup Plugins folder option... How do I go about installing this? What do I do...
Thank You
kersnyc
Postby TIG » Thu Jul 26, 2012 9:08 am
You do have a Plugins folder - unless you have deleted it. :shock:
It's automatically made by the Sketchup installation - it contains example scripts etc...
You will not have a Plugins Menu displayed unless you have some scripts 'active'.
Copy/Paste+<enter> this line of code into the Ruby Console [open that from Sketchup's Window menu] - it will display the path to the Plugins folder on you installation.
Code: Select all
Sketchup.find_support_file("Plugins")
For a PC it's typically:
C:/Program Files/Google/Google SketchUp 8/Plugins
Make sure you have FULL security access permissions [set via properties] for all of your Sketchup folder's subfolders and their contents...
I see you have v8 - with recent versions you could install archived tools using the Window>Preferences>Extensions 'load' button - BUT note that the archive needs to have a .rbz file suffix.
Thomthom has made a SimpleInstaller that does something similar, but also works on .zip archives and .rb/.rbs single files - automatically finding the Plugins folder and extracting files etc for you...
Find that in the Plugins Index - however you do need to put that into the Plugins folder and restart for it to auto-load, so we need to track down where that is...
Global Moderator
SketchUp version: 8
License type: Pro
Keyframe Animation plugin - animate your SketchUp model by adding movement to any object.
PreviousNext
Return to Plugins
Users browsing this forum: 335gibson, Aequilibris, CadFather, chrislbj, CTX, dirkmyers, ESTER313HOTMAIL, libeskiano, njh, tolling and 12 guests
