[Plugin Library] LibFredo6 - v4.9c - 20 May 13 (for SU13)Re: [Plugin Library] LibFredo6 - v4.2a - 16 Sep 11Hello Fredo6,
I'm on Mac running OS X Snow Leopard and I've DL all your files and don' manage to install it properly despite I've been following your advices on the .pdf or this web site. I don't know exactly what's wrong with what I'm doing but it's not working... libFredo6.rb and libFredo6.pluging are in the right (I think) directory "Macintosh HD/Library/Application Support/Google SketchUp 8/SketchUp/plugins" I've DL 000_AdditionalPluginFolders.rb and put it in this directory "Macintosh HD/Library/Application Support/Google SketchUp 7/SketchUp/plugins" but same same, it's not working. Basically I'm a bit lost and would love to find the solution to make it work. This tools looks amazing to use and make the work so much easier. If any one as a idea I will be pleased and really thankful.
Re: [Plugin Library] LibFredo6 - v4.2a - 16 Sep 11hi,
do you have any working plugins? i.e. others that do work. can you post a screenshot of the path to your plugins folder. john
First, I guess you use Sketchup 8. So the standard directory for Plugins should be "Macintosh HD/Library/Application Support/Google SketchUp 8/SketchUp/plugins". I say that as you seem to use also the ...Google Sketchup 7...directory. Second, LibFredo6 is not really a plugin by itself, but a library supporting other plugins. At least did you check you have a menu Windows > LibFredo6 settings..... If so, then you have a correct installation and ready to dowload and install my other scripts (like FredoScale, Roundcorner, ...) Fredo
Re: [Plugin Library] LibFredo6 - v4.2a - 16 Sep 11Hi,
John, No i don't have any working plugin yet. So here the first screenshot where I put all of them. I don't think I should put it here (second screenshot) Fredo, Yes I use SU pro 8 (I copy/past from the first post you give So Where should I put LibFredo6 ? No I don't see LibFredo6 settings in my menu, I don't get what to do btw LibFredo6, and 000_AdditionalPluginFolders or even FreeScale.... Sorry guys I'm a waist of time... Thank your help Please, register (free) to access all the attachments on the forums.
Your footprint is not correct. You don't have a Folder LIBFREDO6_Dir_42 in your SU Plugins folder (and you have a file LibFredo6.plugin which should not be there). I suggest you download the ZIP file and do the extraction in a separate directory. You hsould have only: - 1 file, LibFredo6.rb - 1 folder LIBFREDO6_Dir_42 Then, when it is OK, copy the file and the folder to the SU Plugins Directory, that is, Macintosh HD/Library/Application Support/Google SketchUp 8/SketchUp/plugins Fredo
Re: [Plugin Library] LibFredo6 - v4.2a - 16 Sep 11Ok, that's all working.
I don't know why but I tough the all file would not go by it self in the plugin directory, that was my mistake. Now I just have to learn how to use them and create great product. Thank a lot Fredo for your precious help. The tools you develop are just super important and super efficient. Thank you so much.
Re: [Plugin Library] LibFredo6 - v4.2a - 16 Sep 11I am having trouble with putting round edges on an inset box, within a box. When I try to round the edges, the inset box disappears. I have attached a very simple model which will illustrate my problem if you select the edges and round them. Any idea what I need to do differently in order to make all the edges (both inside and outside edges) become rounded?
Re: [Plugin Library] LibFredo6 - v4.2a - 16 Sep 11Does it disappear or does it just get skinned over? What settings are you using?
Inspecting mirrors is a job I could easily see myself doing.
Re: [Plugin Library] LibFredo6 - v4.2a - 16 Sep 11Maybe it just gets skinned over. I'm pretty new to SketchUp, so I have not sdjusted any settings from the default settings on Pro8. An outline of the original inset box still shows up when I do the round edges, but it appears to be back in the same plane as the outer box.
If you are referring to the Round Edge settings, I have been using 3/16" radius edges with 6 segments. Last edited by tjwilson on Fri Oct 14, 2011 11:42 am, edited 1 time in total.
Re: [Plugin Library] LibFredo6 - v4.2a - 16 Sep 11If you meant the settings on RoundEdge,I was using an edge radius of 3/16" and have tried a number of different segments for rounding, but 6 segments would be fine.
Re: [Plugin Library] LibFredo6 - v4.2a - 16 Sep 11I suspected the skinned over thing. I see that on inside round overs, too. Use Intersect Faces and then delete the skin. Keep the segment count low for the curves to avoid holes in the corners due to small faces that could be generated. SketchUp might not fill them in.
Re: [Plugin Library] LibFredo6 - v4.2a - 16 Sep 11That did it!!! Many thanks.
Re: [Plugin Library] LibFredo6 - v4.2a - 16 Sep 11Many thanks Fredo !
You save my black hair ![]()
Re: [Plugin Library] LibFredo6 - v4.2a - 16 Sep 11Everytime i try to download instead of getting a .zip file i get a .php file. Anyone got a solution??
Re: [Plugin Library] LibFredo6 - v4.2a - 16 Sep 11H. I heard this from Mac users in the past. Try to change the extension from php to zip and see what happens.
Re: [Plugin Library] LibFredo6 - v4.2a - 16 Sep 11In my experience, it may be that the page? loads too fast to pick up the zip, so you get a php temporary placeholder. So, what I have done is cancel the call, wait a short while, and try again until I see the .zip This has worked for me. If you are getting persistent php, then perhaps your security settings are too strong? I am not sure.
Re: [Plugin Library] LibFredo6 - v4.2a - 16 Sep 11On my MacBook Pro, zip files don't display an extension. The just look like a folder. In fact the icon is a folder. Perhaps you could eliminate the extension altogether. Installing the files consists of simply opening the folder, copying the contents and pasting them into Plugins.
Re: [Plugin Library] LibFredo6 - v4.2a - 16 Sep 11Hi guys, this is my first time posting here but I got a problem that I'm not sure if that's already solved or not, still I've just installed the new LibFredo6 - v4.2a days ago and this is what I get whenever I start Sketchup :
And this is the how my Plugin folder looks like : I'm using Sketchup 8.0.4811, via Windows 7. Can someone plz tell me what I do wrong or just how to fix this, I've been using Joint Push Pull, Round Corner and Tools On Surface for times and there's no problem until this. Thnx alot. I always appreciate you and your works, Fredo6. Please, register (free) to access all the attachments on the forums.
Re: [Plugin Library] LibFredo6 - v4.2a - 16 Sep 11Not sure if this will solve the problem, but you have a very old version of FredoScale, called FreeScale.
Could you remove: - ZLoader__Freescale.rb - FreeScale_dir_20 folder Thanks. Fredo
Re: [Plugin Library] LibFredo6 - v4.2a - 16 Sep 11My greatful thnx to you and your quick respond, problem solved
Thnx again, Fredo, you're the one.
Re: [Plugin Library] LibFredo6 - v4.3a - 19 Dec 11NEW RELEASE: LibFredo6 v4.3a - 19 Dec 11
LibFredo6 4.3 is a new release which essentially support the publishing of FredoTools suite of Plugins See main post of this thread for Download. Fredo
Re: [Plugin Library] LibFredo6 - v4.3a - 19 Dec 11Don't know if this is a problem or not, just installed the 20dec11 update of fredo 6
These are binary files. It is strange that your unzip utility (I guess 7-zip) tries to open them. It should not. Fredo
Re: [Plugin Library] LibFredo6 - v4.3b - 22 Dec 11NEW RELEASE: LibFredo6 v4.3b - 22 Dec 11
LibFredo6 4.3 is a new release which essentially support the publishing of FredoTools suite of Plugins Release 4.3b includes (on top of 4.3a)
Re: [Plugin Library] LibFredo6 - v4.3b - 22 Dec 11Fredo your plugin is awesome, but I can't use it! I run Skethcup Pro 7 on my Mac Book Pro. I've installed your plugin (LibFredo6 first, and then RoundCorner) following your detailed instructions; I thought it were an easy things to do, but they don't work!
Can you please help me?? I'll always be graitfull !!
Re: [Plugin Library] LibFredo6 - v4.3b - 22 Dec 11Dear Fredo
I have downloaded the first 4 plugins from your Plugin Library list "Libfredo6 v4.3b - 22Dec11 but cannot get any toolbar icons appearing when I open my SU8Pro programme. I note your Important Paragraph about the downloading of LibFredo6 in respect of the appearance of the plugin toolbars but inspite of following the download instructions precisely I can only access the 4 plugins via the entry "Fredo6 Collection" in the Tools menu. I have ticked off the plugins Fredo Scale & Tools on Surface in the VIEW/TOOLBAR menu but Curiloft & Roundcorner are not shown in the dropdown menu. I would be extremely gratefull if you could suggest where I am going wrong as without the plugin icons showing in the main toolbar it becomes rather difficult to use the plugins to their best advantage. Best regards OldSwinger
It might come from the Unzip operation, which is a frequent problem, especially on Mac. Please make sure that in the SU Plugins directory you have the right footprint, that is: - LibFredo6.rb - LIBFREDO6_Dir_43 folder - ROUNDCORNER_Dir_23 folder Fredo
Re: [Plugin Library] LibFredo6 - v4.3b - 22 Dec 11Is the LibFredo6-34 supposed to stay in the di
rectory after extracting?
Re: [Plugin Library] LibFredo6 - v4.3b - 22 Dec 11You should have a folder called "LIBFREDO6_Dir_43" and a file called "LibFredo6.rb" If you installed the current version you shouldn't have "LibFredo6-34" at all.
SketchUcation One-Liner AdvertsVertex Tools for SketchUp. Take control over each vertex with this vertex editor for SketchUp.
