[Plugin Library] LibFredo6 - v4.9b - 19 May 13Re: [Library] LibFredo6 3.1f install problemI think I have followed the manual instructions for installing LibFredo6_3.1f to the letter. I have tried it several times this afternoon. Whatever I do, I do not get the LibFredo6 Settings menu to appear when I start SU7. SU7 starts normally without any error messages. I am at a loss to know what to do next to troubleshoot my installation.
This might be because you did not install FreeScale or HoverSelect. Actually, I arranged that, unless a script using LibFredo6 is used, the library itself is not loaded, in order not to pollute Sketchup, not even with the menu (except a very small bootstrap code). Remember that, alone, LibFredo6 does not provide any functionality. Fredo
Re: [Library] LibFredo6 3.1f (04 May 09)I only wish it were that simple. I tried both with and without putting FreeScale in the Plugins folder. When FreeScale is in the folder, I get:
"Error Loading File FreeScale_Common.rb (eval):1: uninitialized constant FreeScale::T6" Where do I go from here?
Re: [Library] LibFredo6 3.1f (04 May 09)It seems to be because LibFredo6 is not loaded. Do you have a file LibFredo6.rb in the Sketchup Plugins directory?
Fredo
Yes. The file "LibFredo6.rb" is here "C:\Program Files\Google\Google SketchUp 7\Plugins" The size is "3.03 KB (3,108 bytes)" The modification date is "Tuesday, February 10, 2009, 9:29:56 PM"
Re: [Library] LibFredo6 3.1f (04 May 09)Then, I would suggest you resinstall with the Zip files, because your current settup is missing something, or files may not be in the right place.
For FreeScale, the footprint at the Sketchup Plugin Directory level should be Although you don't really have to care, here is the inside. But the rule is not to modify or rename any of the files. I hope this helps. Fredo Please, register (free) to access all the attachments on the forums.
Re: [Library] LibFredo6 3.1f (04 May 09)You were right, of course. I was missing files. Once, I found the latest I was able to install and run FreeScale. Thanks so much for your help.
The reason I found your wonderful plugin in the first place was that I was looking for a way to model bending 1 1/2" x 1 1/2" x 78" vertical wooden elements so that their tops would be offset in both the x and y directions by perhaps 4", creating a gentle bow. When I try the Radial bending tool, what I get is not a curved bend (similar to the one shown in the tool's icon) but a skewing. The documentation didn't help me. What am I missing?
Re: [Library] LibFredo6 3.1f (04 May 09)Ah, I found the video. Bend works with embedded slice F4. Thanks.
Re: [Library] LibFredo6 3.1f (04 May 09)Wow! This plugin is amazing. Love it a lot - very easy to use too. When is the next update?
Re: [Library] LibFredo6 3.2a (09 Jul 09)NEW VERSION 3.2a
Needed for for RoundCorner 2.0 (and compatible for FredoScale and HoverSelect). see main post at http://www.sketchucation.com/forums/scf/viewtopic.php?f=180&t=17947&p=144178#p144178
Re: [Library] LibFredo6 3.2a (09 Jul 09)Thank you very much for this essential tool.
hire me: http://www.nonsolo3d.it/ !
Re: [Library] LibFredo6 3.2a (09 Jul 09)I can find no place to download 3.2a
"If you don't plan ahead you'll be at the mercy of those that do" - Ashleigh Brilliant
"Bad is not good until worse happens" - Bob James
… Bottom of first post of this thread.
Clicking on that just takes me back the same page "If you don't plan ahead you'll be at the mercy of those that do" - Ashleigh Brilliant
The attachment at the bottom of the first post.
Maybe I should change my user name to "Dumb and Dumber". The only thing at the bottom of the first post "[Plugin] RoundCorner 2.0a - 9 Jul 09" was RoundCorner 2.0a and Quickcard RoundCorner - English - v2.0.pdf. At the top of that post was: "RoundCorner .......requires you also upgrade to LibFredo6 3.2a or higher. See that post at http://www.sketchucation.com/forums/scf ... 47#p144178". That took me to this post where there is no LibFredo6 3.2a download "If you don't plan ahead you'll be at the mercy of those that do" - Ashleigh Brilliant
Re: [Library] LibFredo6 3.2a (09 Jul 09)Hi Bob
at then end of the first post in this 3D there's the attachment with the new Libraries
Re: [Library] LibFredo6 3.2a (09 Jul 09)through the round corners parameters under Tools is ther any way to make is so that the geometry isnt automatically softened?
I answered your question in the main thread related to RoundCorner. See http://forums.sketchucation.com/viewtopic.php?f=180&t=20485&p=172147#p172147 LibFredo6 is just a shared library, common to my scripts (and used by FredoScale and HoverSelect). It does not contain anything specific to RoundCorner.
Egads!! Was that there all the time. Arrrggghhh. "If you don't plan ahead you'll be at the mercy of those that do" - Ashleigh Brilliant
Re: [Library] LibFredo6 3.2a (09 Jul 09)The bend modifier seems to add a load of geometry to things. : [
Re: [Library] LibFredo6 3.2a (09 Jul 09)You're the man!!!
Re: [Library] LibFredo6 3.2a (09 Jul 09)Fredo,
I work on Macintel + macOSX and nothing work (nothing appear) on SKP7 pro !! I use : Fredoscale 2.0g + Libfredo6 3.2a + Round corner 2.0b. I have put them in the right folder : Both in plugins file inside Application support file path. Merci Fredo pour ta reponse et (pour l'ensemble de ton oeuvre) car il me tarde d'utiliser tes plugins sous Mac !!. Bye, Pierre.
Well, I think that, since Mac OS 10.5.6 or around, it is preferable to put the plugins in /user/Librairy /Application support/ etc... Ce que j'ai fait, et tout baigne nickel (comme disent les français). Fredo must be complimented .... again. Mario C.
Certified SketchUp Trainer, QC CA, Mac Pro 2xQuad core & MacBook Pro 3.06 Ghz.
That certainly is true of Profile Builder and Podium, but LibFredo6.rb works just fine in the usual place (Mac/Library/Applications Support/Google SketchUp 7/plugins). "If you don't plan ahead you'll be at the mercy of those that do" - Ashleigh Brilliant
Re: [Plugin Library] LibFredo6 3.3a (27 Aug 09)NEW VERSION 3.3a - 27 Aug 09
Needed for for RoundCorner 2.1, GhostComp 1.0 (and compatible for FredoScale and HoverSelect). Small evolutions (some for Palettes), bug fixing, ... see main post at http://www.sketchucation.com/forums/scf/viewtopic.php?f=180&t=17947&p=144178#p144178 Last edited by Fredo6 on Thu Sep 17, 2009 9:57 pm, edited 1 time in total.
Re: [Plugin Library] LibFredo6 3.3a (27 Aug 09)Hi Fredo. Where can I find new version of Tools on surface?
Not yet ready. It will be a refresh, with a palette for better visualizing the options, some improvements to the Freehand tool and a few other evolutions. Fredo
Re: [Plugin Library] LibFredo6 3.3a (27 Aug 09)Hi Fredo i have noticed that the zipped folder LibFredo3.3a contains a folder LibFredo6_Dir_32. No need for that, no? Thank you very much.
Re: [Plugin Library] LibFredo6 3.3a (27 Aug 09)Sorry what is "GhostComp 1.0"?
SketchUcation One-Liner AdvertsVertex Tools for SketchUp. Take control over each vertex with this vertex editor for SketchUp.
