[Plugin Library] LibFredo6 - v11.2c - 11 Oct 20
Re: [Plugin Library] LibFredo6 - v11.0a - 19 Aug 20
Postby fredo6 » Mon Aug 24, 2020 8:30 pm
This is a bug and it is quite old. Strange that you are the first to signal it.
I have fixed it and it will go in the next release LibFredo6 v11.0b.
fredo6
PluginStore Author
PluginStore Author
Re: [Plugin Library] LibFredo6 - v11.0b - 24 Aug 20
Postby fredo6 » Mon Aug 24, 2020 9:02 pm
NEW RELEASE: LibFredo6 v11.0b - 24 Aug 20
LibFredo6 11.0b fixes a bug for JointPushPull (Ctrl Toggle)
_______________________________________________________________________________________
Requirements: SU2017 and above
See plugin home page of LibFredo6 for Download of LibFredo6.
Main Post of the LibFredo6 thread
Fredo
3
fredo6
PluginStore Author
PluginStore Author
Postby iaincsthorp » Mon Aug 24, 2020 10:25 pm
Hello - Downloaded and installed over earlier version. Restarted Sketchup and MacBook Pro. This is what I get. Any suggestions? I've been using Fredo Corner for several years now. Never had any problem.
MacBook Pro (15-inch, 2018)
OS X Catalina 10.15.4
Error Loading File Fredo6_!LibFredo6.rb
Error: #<LoadError: dlopen(/var/folders/6_/9kz2gk_x7b70xbzsq4ghcpt00000gn/T/com.sketchup.SketchUp.2019.johnthorp/Fredo6_LibFredo6_TemporaryFiles/Binaries/SU19/bin_LibFredo6.bundle, 9): Library not loaded: @executable_path/../Frameworks/Ruby.framework/Versions/2.5.5/Ruby
Referenced from: /var/folders/6_/9kz2gk_x7b70xbzsq4ghcpt00000gn/T/com.sketchup.SketchUp.2019.johnthorp/Fredo6_LibFredo6_TemporaryFiles/Binaries/SU19/bin_LibFredo6.bundle
Reason: image not found - /var/folders/6_/9kz2gk_x7b70xbzsq4ghcpt00000gn/T/com.sketchup.SketchUp.2019.johnthorp/Fredo6_LibFredo6_TemporaryFiles/Binaries/SU19/bin_LibFredo6.bundle>
/Applications/SketchUp 2019/SketchUp.app/Contents/Frameworks/Ruby.framework/Versions/2.5.1/lib/ruby/2.5.0/rubygems/core_ext/kernel_require.rb:59:in `require'
/users/johnthorp/library/application support/sketchup 2019/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe:622:in `load_binary'
/users/johnthorp/library/application support/sketchup 2019/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe:257:in `startup'
/Users/johnthorp/Library/Application Support/SketchUp 2019/SketchUp/Plugins/Fredo6_!LibFredo6.rb:61:in `process'
/Users/johnthorp/Library/Application Support/SketchUp 2019/SketchUp/Plugins/Fredo6_!LibFredo6.rb:68:in `<module:LibFredo6_Loader>'
/Users/johnthorp/Library/Application Support/SketchUp 2019/SketchUp/Plugins/Fredo6_!LibFredo6.rb:30:in `<top (required)>'
Error Loading File Fredo6_FredoCorner.rb
Error: #<TypeError: can't convert nil into an exact number>
/Users/johnthorp/Library/Application Support/SketchUp 2019/SketchUp/Plugins/Fredo6_!LibFredo6.rb:77:in `-'
/Users/johnthorp/Library/Application Support/SketchUp 2019/SketchUp/Plugins/Fredo6_!LibFredo6.rb:77:in `<top (required)>'
/Users/johnthorp/Library/Application Support/SketchUp 2019/SketchUp/Plugins/Fredo6_FredoCorner.rb:52:in `<module:Fredo6>'
/Users/johnthorp/Library/Application Support/SketchUp 2019/SketchUp/Plugins/Fredo6_FredoCorner.rb:28:in `<top (required)>'
iaincsthorp
Postby TIG » Tue Aug 25, 2020 11:29 am
V2020 Win10 - the newest LibFredo was just installed and now all of the Fredo extensions show up with French text, not the usual English !?
The Tools > Fredo Tools > Traduction [aka Translation] is set to EN, but FR is showing...
V2019 took the new LibFredo and left everything in EN ? most odd...
But I don't see FR as an alternative language listed in v2019's Translation dialog...
EN is the 'preferred' language is both versions...
I thought there was a common set of 'defaults' across SketchUp versions ?
PS:
I fixed it by setting the 2nd/3rd language preferences to 'none' so only EN is set up.
For some reason when the first language is EN and FR is the second FR prevails !
This happens in v2020 & v2019 !
Having just EN set up it works as before...
Global Moderator
Postby fredo6 » Tue Aug 25, 2020 3:59 pm
iaincsthorp wrote:Hello - Downloaded and installed over earlier version. Restarted Sketchup and MacBook Pro. This is what I get. Any suggestions? I've been using Fredo Corner for several years now. Never had any problem.
Did you restart Sketchup after installation?
Do you still have the problem?
fredo6
PluginStore Author
PluginStore Author
Postby fredo6 » Tue Aug 25, 2020 4:04 pm
TIG wrote:V2020 Win10 - the newest LibFredo was just installed and now all of the Fredo extensions show up with French text, not the usual English !?
That's not new actually. Always been like this...
Default language (i.e. 'none') happens to be my English, whereas EN states for real English, for which I don't provide a translation (and would happily let an English contributor provides a good translation).
If you specify EN + FR, then you'll get mostly French, because LibFredo6 looks at language in order and find nothing for EN and something for French.
I'll do something to avoid confusion.
fredo6
PluginStore Author
PluginStore Author
Postby TIG » Tue Aug 25, 2020 4:26 pm
I didn't specify any language.
In v2019 it lists EN, but in v2020 it auto lists EN/FR/ES [or DE if I don't recall right !]
Global Moderator
Re: [Plugin Library] LibFredo6 - v11.1a - 26 Aug 20
Postby fredo6 » Wed Aug 26, 2020 4:35 pm
NEW RELEASE: LibFredo6 v11.1a - 26 Aug 20
LibFredo6 11.1a fixes an issue where a unsigned 'shadow' extension top_libFredo6 appears in the Extension Manager.
Fredo
fredo6
PluginStore Author
PluginStore Author
Postby iaincsthorp » Thu Aug 27, 2020 6:02 pm
OS X Catalina 10.15.4[/quote]
Did you restart Sketchup after installation? A: Yes
Do you still have the problem?[/quote] A: Yes
Here's today's error message
/users/johnthorp/library/application support/sketchup 2019/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe:610:in `load_binary'
/users/johnthorp/library/application support/sketchup 2019/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe:250:in `startup'
/Users/johnthorp/Library/Application Support/SketchUp 2019/SketchUp/Plugins/Fredo6_!LibFredo6.rb:62:in `process'
/Users/johnthorp/Library/Application Support/SketchUp 2019/SketchUp/Plugins/Fredo6_!LibFredo6.rb:69:in `<module:LibFredo6_Loader>'
/Users/johnthorp/Library/Application Support/SketchUp 2019/SketchUp/Plugins/Fredo6_!LibFredo6.rb:78:in `-'
/Users/johnthorp/Library/Application Support/SketchUp 2019/SketchUp/Plugins/Fredo6_!LibFredo6.rb:78:in `<top (required)>'
Error Loading File Fredo6_FredoSpline.rb
/Users/johnthorp/Library/Application Support/SketchUp 2019/SketchUp/Plugins/Fredo6_FredoSpline.rb:50:in `<module:Fredo6>'
/Users/johnthorp/Library/Application Support/SketchUp 2019/SketchUp/Plugins/Fredo6_FredoSpline.rb:26:in `<top (required)>'
Error Loading File Fredo6_FredoTools.rb
/Users/johnthorp/Library/Application Support/SketchUp 2019/SketchUp/Plugins/Fredo6_FredoTools.rb:47:in `<module:Fredo6>'
/Users/johnthorp/Library/Application Support/SketchUp 2019/SketchUp/Plugins/Fredo6_FredoTools.rb:26:in `<top (required)>'
iaincsthorp
Postby iaincsthorp » Thu Aug 27, 2020 6:16 pm
Here is what I see in Extension Manager: (better now - earlier today the LibFredo extension installed as 'Unsigned'
https://www.dropbox.com/s/jibuoymuco6wn ... M.png?dl=0
Thanks for your help!
iaincsthorp
Postby fredo6 » Thu Aug 27, 2020 9:03 pm
Iain,
Does LibFredo (and my other plugins) still load and work despite of that?
I cannot reproduce the problem on my Mac (Catalina and MBP too). So, I need to investigate why you get the problem.
Fredo
fredo6
PluginStore Author
PluginStore Author
Postby fredo6 » Thu Aug 27, 2020 10:23 pm
Iain
One thing to check is whether the binary file has been successfully copied.
Could you do the following in SU2019
1) Open the RubyConsole
2) Type File.join(Sketchup.temp_dir, 'Fredo6_LibFredo6_TemporaryFiles')
3) The console should display the result, something like
4) Open the Finder and use the menu Go > Go to Folder (or Shift-Command-G) and type the result of the previous step in the prompt dialog
5) If you open the directory in the finder, could you check if there is
- a subfolder: binaries
- and within it a subfolder SU19 with a file bin_LibFredo6.bundle
If there is no file, then we have the explanation. This might be a problem of security settings.
If there is a file, then this is another problem.
fredo6
PluginStore Author
PluginStore Author
Postby iaincsthorp » Fri Aug 28, 2020 3:16 am
fredo6 wrote:Iain,
Fredo
No, unfortunately not. No Fredo toolbars are showing up.
iaincsthorp
Postby fredo6 » Fri Aug 28, 2020 6:13 am
Did you reboot your Mac?
fredo6
PluginStore Author
PluginStore Author
fredo corner and library error on sketch 19
Postby dr1416 » Fri Sep 04, 2020 5:31 pm
hallo , i have install on my Mac book last version of fredolibrary and new version of fredo corner, but have an error,
the precedent version goes whiteout any problem.
the error message after install and restart sketchup are the follow:
Error: #<LoadError: dlopen(/var/folders/hg/ft5s36856yl18m96ljb_10k80000gn/T/com.sketchup.SketchUp.2019.diegoruina/Fredo6_LibFredo6_TemporaryFiles/Binaries/SU19/bin_LibFredo6.bundle, 9): Library not loaded: @executable_path/../Frameworks/Ruby.framework/Versions/2.5.5/Ruby
Referenced from: /var/folders/hg/ft5s36856yl18m96ljb_10k80000gn/T/com.sketchup.SketchUp.2019.diegoruina/Fredo6_LibFredo6_TemporaryFiles/Binaries/SU19/bin_LibFredo6.bundle
Reason: image not found - /var/folders/hg/ft5s36856yl18m96ljb_10k80000gn/T/com.sketchup.SketchUp.2019.diegoruina/Fredo6_LibFredo6_TemporaryFiles/Binaries/SU19/bin_LibFredo6.bundle>
/private/var/folders/hg/ft5s36856yl18m96ljb_10k80000gn/T/AppTranslocation/E9C8BF29-3F67-4B14-99E3-C8AB0895B975/d/SketchUp.app/Contents/Frameworks/Ruby.framework/Versions/2.5.1/lib/ruby/2.5.0/rubygems/core_ext/kernel_require.rb:59:in `require'
/users/diegoruina/library/application support/sketchup 2019/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe:610:in `load_binary'
/users/diegoruina/library/application support/sketchup 2019/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe:250:in `startup'
/Users/diegoruina/Library/Application Support/SketchUp 2019/SketchUp/Plugins/Fredo6_!LibFredo6.rb:62:in `process'
/Users/diegoruina/Library/Application Support/SketchUp 2019/SketchUp/Plugins/Fredo6_!LibFredo6.rb:69:in `<module:LibFredo6_Loader>'
/Users/diegoruina/Library/Application Support/SketchUp 2019/SketchUp/Plugins/Fredo6_!LibFredo6.rb:30:in `<top (required)>'
dr1416
Re: fredo corner and library error on sketch 19
Postby TIG » Fri Sep 04, 2020 6:08 pm
I am merging this into the main thread - where Fredo is more likely to see it !
Global Moderator
Postby dr1416 » Mon Sep 07, 2020 9:46 am
thanks , sorry I don't see an other post exit.
dr1416
Postby dr1416 » Mon Sep 07, 2020 9:48 am
for fredo6,
i ave look your message but system say I'm not able to reply at PM
dr1416
Postby dr1416 » Mon Sep 07, 2020 2:02 pm
last update I have manual cancelled any files of fredo lib and reinstall,
now go
dr1416
Re: [Plugin Library] LibFredo6 - v11.1c - 08 Sep 20
Postby fredo6 » Tue Sep 08, 2020 4:02 pm
NEW RELEASE: LibFredo6 v11.1c - 08 Sep 20
LibFredo6 11.1c includes various bug fixes.
Fredo
fredo6
PluginStore Author
PluginStore Author
Postby juju » Tue Sep 08, 2020 7:29 pm
It looks like I completely missed LibFredo6 v11.1b, thanks for the update.
juju
Premium Member
Premium Member
Postby yhjeong » Thu Sep 10, 2020 7:44 am
Error: #<ArgumentError: invalid byte sequence in UTF-8>
c:/users/정영호/appdata/roaming/sketchup/sketchup 2020/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe:45:in `gsub'
c:/users/정영호/appdata/roaming/sketchup/sketchup 2020/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe:45:in `get_dir_from_ENV'
c:/users/정영호/appdata/roaming/sketchup/sketchup 2020/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe:425:in `su_appdata'
c:/users/정영호/appdata/roaming/sketchup/sketchup 2020/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe:443:in `dir_appdata'
c:/users/정영호/appdata/roaming/sketchup/sketchup 2020/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe:206:in `startup'
C:/Users/정영호/AppData/Roaming/SketchUp/SketchUp 2020/SketchUp/Plugins/Fredo6_!LibFredo6.rb:62:in `process'
C:/Users/정영호/AppData/Roaming/SketchUp/SketchUp 2020/SketchUp/Plugins/Fredo6_!LibFredo6.rb:69:in `<module:LibFredo6_Loader>'
C:/Users/정영호/AppData/Roaming/SketchUp/SketchUp 2020/SketchUp/Plugins/Fredo6_!LibFredo6.rb:30:in `<top (required)>'
i experienced load errors.
Plz tell me how to fix it
yhjeong
Postby TIG » Thu Sep 10, 2020 9:07 am
@yhjeong
Fredo will reply in detail, but it looks like your Korean user-name [정영호] is causing the issue.
Ruby expects any text-strings to be UTF-8 encoded.
In earlier Ruby versions non-ASCII characters always caused problems.
In the newer versions of SketchUp there is text-encoding possibilities.
I know Fredo uses these latest methods.
But somehow your Korean user-name is almost certainly causing the problem...
Global Moderator
Postby Arkitekto1994 » Fri Sep 18, 2020 3:35 am
Hi. Im having a trouble finding the file via extension manager. The files are in .rbz.skp, how can I convert it to purely .rbz file?
Arkitekto1994
Postby TIG » Sun Sep 20, 2020 6:29 pm
Why are the files .RBZ.SKP ??
A downloaded .RBZ file from the PluginStore should be saved with that file-type.
How did it get changed ?
I suspect your web-browser settings for downloaded file-types are FUBAR...
Alternatively try renaming it without the .SKP ending and then the .RBZ file might be usable...
However, you need to fix your download options...
Global Moderator
Re: [Plugin Library] LibFredo6 - v11.2a - 27 Sep 20
Postby fredo6 » Sun Sep 27, 2020 8:51 pm
NEW RELEASE: LibFredo6 v11.2a - 27 Sep 20
LibFredo6 11.2a includes technical adjustments for some dialogs.
Fredo
fredo6
PluginStore Author
PluginStore Author
Postby mexicano31 » Thu Oct 08, 2020 12:34 pm
fredo6 wrote:Iain
The same problem. But in the folder Binaries\SU19 i have a file bin_body_Lib6G6.so
mexicano31
Re: [Plugin Library] LibFredo6 - v11.2b - 09 Oct 20
Postby fredo6 » Fri Oct 09, 2020 5:10 pm
NEW RELEASE: LibFredo6 v11.2b - 09 Oct 20
LibFredo6 11.2b includes technical adjustments for video generation used by Animator
Fredo
fredo6
PluginStore Author
PluginStore Author
Re: [Plugin Library] LibFredo6 - v11.2c - 11 Oct 20
Postby fredo6 » Sun Oct 11, 2020 10:41 pm
NEW RELEASE: LibFredo6 v11.2c - 11 Oct 20
LibFredo6 11.2c fixes a bug in the generation of videos for Animator (.MOV format can now be excluded)
Fredo
fredo6
PluginStore Author
PluginStore Author
Postby loesshill » Thu Oct 22, 2020 9:07 pm
I've installed several extensions plus Libfredo6 months ago, and they all worked well,(thank you).
Today they do not work. Please advise.
loesshill
PreviousNext
Return to Plugins
Users browsing this forum: archMariRibeiro, Attilakw, harunarchi, JLingard, majabivamaja and 19 guests
