[Plugin Library] LibFredo6 - v9.5j - 25 Feb 20
Re: [Plugin Library] LibFredo6 - v9.5a - 23 Dec 19
Postby markvladi » Mon Dec 23, 2019 7:21 pm
After installing LibFredo6_v9.4b, an error appears.
markvladi
Postby Dave R » Mon Dec 23, 2019 11:00 pm
Did you try restarting SketchUp?
Global Moderator
Postby markvladi » Tue Dec 24, 2019 5:32 pm
Yes. After selecting a template, the Bugsplat window crashes. The button "View report data" is not active. After removing the "Fredo6_! LibFredo6 folders" and "Fredo6_! LibFredo6.rb folders" from the plugin directory, SketchUp18 opens. When upgrading to SketchUp19, the same thing happens.
markvladi
Postby Dave R » Tue Dec 24, 2019 5:57 pm
When you installed SketchUp from the downloaded installer, did you right click on it and choose Run as administrator from the Context menu?
Global Moderator
Postby markvladi » Wed Dec 25, 2019 6:36 pm
Yes.
markvladi
Postby yonofun » Mon Jan 06, 2020 6:00 pm
sh: /Users/Jonathan/Documents/Animator Videos/ffmpeg-4.2.2.cpgz: Permission denied
mac high sierra 10.13.6 I've followed countless tutorials to get ffmpeg installed properly, starting with libfredo6 for animator in sketchup. After downloading the zip and or package file from ffmpeg.org, I don't get the same results from the step by step tutorials. Even in terminal I'm getting unsuccessful responses to line commands at a certain point. I found animator very user friendly and edited a great technical video very efficiently. I'm stuck not being able to generate an mp4 video file to share on my website. Please help
yonofun
Postby fredo6 » Mon Jan 06, 2020 6:53 pm
Did you see my answer in the Animator subforum?
I give a link to the latest version of FFmpeg for Mac.
- This points to a zip file.
- Extract the file 'ffmpeg' located in the zip archive under 'bin'
- put this file somewhere on your Mac where it's convenient to you
- In the Animator video, Click on the button 'locate FFMpeg' and point to this local file.
Fredo
fredo6
PluginStore Author
PluginStore Author
Re: [Plugin Library] LibFredo6 - v9.5b - 08 Jan 20
Postby fredo6 » Wed Jan 08, 2020 5:56 pm
NEW RELEASE: LibFredo6 v9.5b - 08 Jan 20
LibFredo6 9.5b is a minor release for bug fixing and adjustments.
_______________________________________________________________________________________
See plugin home page of LibFredo6 for Download of LibFredo6.
Main Post of the LibFredo6 thread
Fredo
fredo6
PluginStore Author
PluginStore Author
Postby penumbra » Wed Jan 08, 2020 10:31 pm
On SU 2018 the new update (with LibFredo v9.5b) is not preserving the guides.
(Correction) posted in wrong forum, this comment was meant for Fredo Guides.
penumbra
Postby fredo6 » Thu Jan 09, 2020 7:22 am
penumbra wrote:On SU 2018 the new update (with LibFredo v9.5b) is not preserving the guides.
Could you open the Ruby Console when you protect guides and then when you delete them, in order to see if there are error messages. Thanks.
fredo6
PluginStore Author
PluginStore Author
Postby penumbra » Thu Jan 09, 2020 7:29 pm
ruby console is blank, doesn't show any activity.
penumbra
Postby fredo6 » Thu Jan 09, 2020 10:05 pm
Does the problem happens with any model?
fredo6
PluginStore Author
PluginStore Author
Postby penumbra » Thu Jan 09, 2020 10:47 pm
interestingly, no it does not. starting a fresh model the plugin works fine.
but here is something that pops up on the ruby consol when i start the sketchup file where it doesn't work.
penumbra
Postby fredo6 » Thu Jan 09, 2020 11:05 pm
Could you post or PM me the model.
Because of this error, the process of protection does not start and thus is not active for this model.
Fredo
fredo6
PluginStore Author
PluginStore Author
Postby Box » Fri Jan 10, 2020 5:12 am
Hi Fredo,
I just updated libfredo and it seems to have caused an issue with Curvizard.
Any curve and any action creates stange edges between points.
Postby fredo6 » Fri Jan 10, 2020 10:45 am
Box wrote:Hi Fredo,
Many thanks for signaling the problem.
Definitely a major bug, which I fixed in LibFredo6 v9.5c, just published.
Fredo
fredo6
PluginStore Author
PluginStore Author
Re: [Plugin Library] LibFredo6 - v9.5c - 10 Jan 20
Postby fredo6 » Fri Jan 10, 2020 10:48 am
NEW RELEASE: LibFredo6 v9.5c - 10 Jan 20
LibFredo6 9.5c fixes a major regression bug affecting Curvizard. It is strongly advised to upgrade
Fredo
3
fredo6
PluginStore Author
PluginStore Author
Postby Box » Fri Jan 10, 2020 1:39 pm
Thanks Fredo for being so proactive and responding so quickly on all your plugins. On my phone at the moment so will confirm as soon as I'm able.
Postby Box » Fri Jan 10, 2020 4:44 pm
Thanks again Fredo.
Postby penumbra » Sat Jan 11, 2020 6:24 pm
Hi Fredo
Many thanks for looking at the issues with my file and FredoGuides. I sent you a separate PM with a WeTransfer link. Hopeful the file can shed some light and provide the necessary feedback.
penumbra
Postby pibuz » Thu Jan 30, 2020 9:04 am
Hi Fredo!
What a wonderful set of plugins you have done! I am grateful to you, your work is sparing me loads of time!!!
I'd have a question: is there any chance your tool "area report by material" could take into account ALSO the faces which are painted from the outside of a group/component? Since I work a lot with DCs this would be a greatly useful add-on..
Thanks in advance!
pibuz
Postby fredo6 » Thu Jan 30, 2020 9:23 am
pibuz wrote: is there any chance your tool "area report by material" could take into account ALSO the faces which are painted from the outside of a group/component?
This is a good idea, and I think this is manageable.
Fredo
fredo6
PluginStore Author
PluginStore Author
Re: [Plugin Library] LibFredo6 - v9.5d - 03 Feb 20
Postby fredo6 » Mon Feb 03, 2020 4:31 pm
NEW RELEASE: LibFredo6 v9.5d - 03 Feb 20
LibFredo6 9.5d fixes a major regression bug affecting Curvizard, preventing the generation as Sketchup curves for some tools. It is strongly advised to upgrade
Fredo
fredo6
PluginStore Author
PluginStore Author
Re: [Plugin Library] LibFredo6 - v9.5e - 05 Feb 20
Postby fredo6 » Wed Feb 05, 2020 9:38 pm
NEW RELEASE: LibFredo6 v9.5e - 05 Feb 20
LibFredo6 9.5e is a minor release
  • necessary for FredoTools::ReportLabelArea to count face area by material when material is applied to groups or components instead of faces
  • For the opening of certain files on Mac, due to changes made in SU2019.3 and SU2020.
Fredo
fredo6
PluginStore Author
PluginStore Author
Postby fredo6 » Wed Feb 05, 2020 9:59 pm
pibuz wrote:is there any chance your tool "area report by material" could take into account ALSO the faces which are painted from the outside of a group/component?
This is now available in FredoTools::ReportLabelArea v3.2a, with
fredo6
PluginStore Author
PluginStore Author
Postby rv1974 » Fri Feb 07, 2020 3:33 pm
For some reason I can't install libfredo 9.5.e on SU2020 (win10 64 bit)
rv1974
Postby TIG » Fri Feb 07, 2020 4:07 pm
The Lib installs fine for me [same OS etc] and it is fully signed etc...
Global Moderator
Postby rv1974 » Sat Feb 08, 2020 7:15 am
Manual extract to plugins folder solved the issue.
rv1974
Re: [Plugin Library] LibFredo6 - v9.5f - 08 Feb 20
Postby fredo6 » Sat Feb 08, 2020 10:28 pm
NEW RELEASE: LibFredo6 v9.5f - 08 Feb 20
LibFredo6 9.5f is a minor release necessary for VisuHole to capture stencil from container where axes are not oriented with Z being the normal to the thin plate.
Fredo
fredo6
PluginStore Author
PluginStore Author
Re: [Plugin Library] LibFredo6 - v9.5g - 09 Feb 20
Postby fredo6 » Sun Feb 09, 2020 10:11 pm
NEW RELEASE: LibFredo6 v9.5g - 09 Feb 20
LibFredo6 9.5g is a minor release necessary for Animator and FredoTools::MoveAlong. It corrects a problem when moving objects.
Fredo
fredo6
PluginStore Author
PluginStore Author
PreviousNext
Return to Plugins
Users browsing this forum: ASsuzan, Kenn22, omerarslan, z34miry and 20 guests
