[Plugin Library] LibFredo6 - v8.1h - 06 Apr 18
Re: [Plugin Library] LibFredo6 - v5.1c - 22 Aug 13 (for SU13
Postby fredo6 » Thu Aug 22, 2013 4:54 pm
NEW RELEASE: LibFredo6 v5.1c - 22 Aug 13
LibFredo6 5.1b was wrongly publishing.
So you should re-install 5.1c if you had installed 5.1a. Sorry again for inconvenience.
User avatar
PluginStore Author
PluginStore Author
Postby Ken » Thu Aug 22, 2013 5:22 pm
Fredo6
Thanks for the quick reply. I just had a feeling it was "fast fingers".
Ken
User avatar
Ken
Premium Member
Premium Member
Postby fredo6 » Thu Aug 22, 2013 5:25 pm
Ken wrote:Fredo6
Ken
On top o that, the keyboard was slippery....
Hope it works now.
User avatar
PluginStore Author
PluginStore Author
Postby Ken » Thu Aug 22, 2013 5:33 pm
fredo6 wrote:
Ken wrote:Fredo6
Ken
Hope it works now.
Boy is my imagination running wild now.
Again thanks
Also,TIG, thank you. Never hurts to be reminded to double check the obvious. I also suffer from the "fast finger" syndrome.
User avatar
Ken
Premium Member
Premium Member
Postby the fox8000 » Fri Aug 23, 2013 6:09 pm
When i put the files in my folder and open sketchup it says (Error Loading File ZLoader__OnSurface.rb no such file to load -- LibFredo6.rb)
How do I fix it?
the fox8000
Postby Dave R » Fri Aug 23, 2013 7:46 pm
Go back and read the first post of this thread. And then install LibFredo6 like it says to do.
Inspecting mirrors is a job I could easily see myself doing.
If you are the smartest person in the room, you are in the wrong room.
User avatar
Global Moderator
Re: [Plugin Library] LibFredo6 - v5.2a - 30 Aug 13
Postby fredo6 » Sun Sep 01, 2013 11:00 am
NEW RELEASE: LibFredo6 v5.2a - 30 Aug 13
LibFredo6 5.2 is a follow up technical release that implements final naming conventions for files and folders to be compliant with EWH requirements.
For LibFredo6, the footprint is based on one file and one subfolder:
For my scripts, new naming conventions are also based on one file and one subfolder. I will progressively re-release the scripts with the new naming conventions. For instance, FredoScale v2.5 footprint is now :
For convenience, LibFredo6 5.2 is compatible with the old and new naming conventions. So if you have CURVILOFT_Dir_12 folder, it will be loaded normally (until I publish the new version based on Fredo6_Curviloft and Fredo6_Curviloft).
It is also a good idea to clean up your plugin directory and remove the older versions.
In the menu Windows > LibFredo6 Settings...> Purge Obsolete Files, you will find a dialog box allowing to remove all or some of these older versions.
VERY IMPORTANT: if you have installed 000_AdditionalPluginFolders, you MUST upgrade it to its version 4.1 or higher. Otherwise, you will not load LibFredo6 5.2 (but instead the older version of LibFredo6).
User avatar
PluginStore Author
PluginStore Author
Postby zooen » Mon Sep 02, 2013 9:30 pm
Bonjour,
Apparemment on a plu le Français, pour ce super-plugin !! :?:
User avatar
zooen
Postby fredo6 » Mon Sep 02, 2013 9:35 pm
zooen wrote:Bonjour,
French is available and included (all my scripts are available in French).
- Automatically set to French if your system is French
- or go to the menu Windows > LibFredo6 settings... > Choose preferred language
User avatar
PluginStore Author
PluginStore Author
Postby Lana » Mon Sep 23, 2013 4:56 am
Very good. I have SU8 and ok. Very, very, very tanks!
User avatar
Lana
Postby songkran77 » Mon Sep 30, 2013 1:05 pm
thank you vermush
songkran77
Postby ekisticsplanning » Mon Sep 30, 2013 11:19 pm
I'm trying to install toposhaper on a Mac and its a no go. I've got my permissions set on the plug ins folder. Have LibFredo 5.1 installed, and have ToolsOnSurfaces working fine. I've copied the TOPOSHAPER_Dir_10 folder to the plug-ins folder and it will NOT show up in Sketchup.
Anyone have any ideas?? Dying to try this plug in.
ekisticsplanning
Postby TIG » Tue Oct 01, 2013 9:12 am
How have you installed it ?
Leaving files inside their RBZ will cause issues...
Did you use Preferences > Extensions > Install... on the downloaded RBZ file or the SketchUcation Plugins Store AutoInstaller within SketchUp itself - these methods are 'foolproof'...
The correct Plugins folder is found using this in the Ruby Console +<enter>
Sketchup.find_support_file('Plugins)
In v2013 it is in your own user library folder tree, so you should automatically have the needed FULL read/write permissions ?
Have you looked in Preferences > Extensions and activated its Extension ?
Have you activated its Toolbar in View > Tool Palettes [MAC, or Toolbars PC] ??
User avatar
Global Moderator
Postby thaihung50 » Wed Oct 02, 2013 9:56 am
merci
thaihung50
Postby Arpas » Sat Oct 19, 2013 10:18 pm
Fredo: I'm new here... your work is just awesome. Thanks a lot. I put this link in my favorites. Thanks again!
Armpa
Arpas
Postby Garry K » Mon Oct 21, 2013 11:42 pm
Fredo,
I've been playing around with the settings to see if I can get the rounding of a curved and twisted handrail to work a bit better. I am looking for a 6 facet 1/2" corner round.
I'm running 2.5a Round Corner along with 5.2a library - on Sketchup 7 and 8
It appears that a very tiny triangle isn't being turned into a face during the round Corner operation ( just a guess )
I can pick the three edges and use Utility Make Face and it does turn it into a face.
Any suggestions? any settings that I need to change?
Garry K
Premium Member
Premium Member
Re: [Plugin Library] LibFredo6 - v5.3g - 27 Oct 13
Postby fredo6 » Mon Oct 28, 2013 12:53 am
NEW RELEASE: LibFredo6 v5.3g - 28 Oct 13
LibFredo6 5.3 is a release for JointPushPull Interactive 3.0, which is just published.
User avatar
PluginStore Author
PluginStore Author
Re: [Plugin Library] LibFredo6 - v5.3h - 29 Oct 13
Postby fredo6 » Tue Oct 29, 2013 9:35 pm
NEW RELEASE: LibFredo6 v5.3h - 29 Oct 13
Version 5.3h includes some small fixes and adjustments
- Support of '=' in translation strings
- fix in the logging of errors, in relation with AdditionalPluginFolders
- Option for toolbar icons (for SU13 and above), based on a request from Ken
- Minor fixes
The LibFredo6 Default Parameter dialog boxes includes an option to show bigger or smaller icons for my plugins
If you choose Smaller (default), then you will get
If you choose Bigger, then you will get
Note that it only applies to SU13. In SU8 and previous versions of SU, the icon size is automatically adjusted by Sketchup
User avatar
PluginStore Author
PluginStore Author
Postby Oxer » Tue Oct 29, 2013 10:43 pm
Thanks for the update!!
New Spanish (Spain) Language File:
LibFredo6_SP.lang
User avatar
Oxer
Postby LAGRARI2012 » Wed Oct 30, 2013 4:28 am
Thanks you very much!!
User avatar
LAGRARI2012
Postby detcharles » Thu Oct 31, 2013 12:44 am
Help,
I installed the plugin and the tools work great, but the menu display looks very strange. The message box at the top left corner is all all scrambled and digitized. Here is a screen shot, take a look at the upper corner. Does anyone know whats going on?
I am running SU8 Pro on a Macbook Pro Retina and just upgraded to Mavrick operating system
detcharles
Postby fredo6 » Thu Oct 31, 2013 9:28 am
There are know problem about drawing texts on Mac with Retina.
Curiously, many users have the font too small, but you seem to have it too big.
So there must be a parameter to adjust the size of texts drawn (in OpenGL).
User avatar
PluginStore Author
PluginStore Author
Postby detcharles » Thu Oct 31, 2013 3:52 pm
What Should I do to fix it?
detcharles
Postby KevB » Tue Nov 05, 2013 11:32 pm
can somebody tell me where you put the shared library file ie the round corners
Kevin
KevB
Postby Dave R » Wed Nov 06, 2013 11:23 am
KevB wrote:can somebody tell me where you put the shared library file ie the round corners
Kevin
Go to the first post of the thread and read it. It tells you where to put the files. Why don't you install the Sketchucation Plugin Store? Then you can just let it auto install your plugins.
User avatar
Global Moderator
Postby detcharles » Wed Nov 06, 2013 5:37 pm
Hello,
I am reposting from earlier concerning a problem with the way the text is displayed in joint push pull. I included a photo [see attached].
Fredo mentioned its an issue with Open GL text sizing. Does anyone know how to adjust that?
Thank You
I am running SU8 PRO on a Macbook Pro Retina, OS Maverick
detcharles
Re: [Plugin Library] LibFredo6 - v5.4a - 07 Nov 13
Postby fredo6 » Fri Nov 08, 2013 12:08 am
NEW RELEASE: LibFredo6 v5.4a - 07 Nov 13
LibFredo6 5.4a is a pivot release for future Sketchup compatibility. It is also necessary for TopoShaper 1.1 (which includes an Altitude Editor)
Note: I will re-release all my scripts in the coming days, hopefully based on LibFredo6 5.4
User avatar
PluginStore Author
PluginStore Author
Postby guanjin » Fri Nov 08, 2013 5:18 am
fredo6 wrote:NEW RELEASE: LibFredo6 v5.4a - 07 Nov 13
I installed Fredo6_% 21LibFredo6 - v5.4a, tips or display version 5.3, you need 5.4
guanjin
User avatar
guanjin
Postby Oxer » Fri Nov 08, 2013 6:37 am
guanjin wrote:I installed Fredo6_% 21LibFredo6 - v5.4a, tips or display version 5.3, you need 5.4
For me the same when I run SU.
User avatar
Oxer
Re: [Plugin Library] LibFredo6 - v5.4b - 08 Nov 13
Postby fredo6 » Fri Nov 08, 2013 7:54 am
NEW RELEASE: LibFredo6 v5.4b - 08 Nov 13
Note: LibFredo6 5.4a was an incorrect release on the forum (it was OK on Plugin Store). So please move to 5.4b for avoidance of doubt
LibFredo6 5.4b is a pivot release for future Sketchup compatibility. It is also necessary for TopoShaper 1.1 (which includes an Altitude Editor)
User avatar
PluginStore Author
PluginStore Author
by Ad Machine » 5 minutes ago
Ad Machine
Robot
PreviousNext
Return to Plugins
Who is online
Users browsing this forum: hiroo wada, maltrayn, qwerty3210, stretchymantis and 16 guests
Visit our sponsors:
