[Plugin] Material Tools
Re: [Plugin] Material Tools (2.5.2) — 04 October 2011
Postby thomthom » Wed Jan 16, 2013 11:30 am
oh... I might have forgotten to upload this little update... :oops:
PluginStore Author
PluginStore Author
Postby rv1974 » Wed Jan 16, 2013 12:01 pm
thomthom wrote:oh... I might have forgotten to upload this little update... :oops:
unpardonable forgetfulness
:mrgreen:
rv1974
Postby thomthom » Wed Jan 16, 2013 12:58 pm
Give me a couple of days. I need to release an update to TT_Lib2 first.
PluginStore Author
PluginStore Author
Postby rv1974 » Thu Jan 17, 2013 9:01 am
Yet another thing:
Assign component\group mat to its front faces (to the inner geometry with default mat) would be amazing feature.
There's already the great 'remove C-G materials.rb' , something the opposite is also needed.
rv1974
Postby thomthom » Thu Jan 17, 2013 9:49 am
How would you handle groups with faces of multiple materials? It's just not an symmetrical operation.
PluginStore Author
PluginStore Author
Postby rv1974 » Thu Jan 17, 2013 11:02 am
thomthom wrote:How would you handle groups with faces of multiple materials? It's just not an symmetrical operation.
Only default material within the would inherit the comp\group mat. The manually set multiple mats would survive.
rv1974
Postby thomthom » Thu Jan 17, 2013 11:22 am
Oh - I misread you. I thought you wanted face material to group materials.
You want the instance materials to be applied to all faces with default material in the group/component? That's already there: "Instance Material to Faces"
PluginStore Author
PluginStore Author
Postby rv1974 » Thu Jan 17, 2013 12:16 pm
damn how could I miss it.
rv1974
Postby rv1974 » Wed Jan 23, 2013 11:10 am
thomthom wrote:Give me a couple of days. I need to release an update to TT_Lib2 first.
...bump
:roll:
rv1974
Postby thomthom » Wed Jan 23, 2013 11:16 am
Yeeea.... didn't happen... :( I've run into a bug that needs fixing.
PluginStore Author
PluginStore Author
Re: [Plugin] Material Tools (2.6.0) — 19 February 2013
Postby thomthom » Tue Feb 19, 2013 8:11 pm
Version 2.6.0
  • Added Transparent Material to Backside.
  • Added support Fredo updater.
PluginStore Author
PluginStore Author
Postby rv1974 » Wed Feb 20, 2013 8:06 am
:thumb:
rv1974
Postby EarthMover » Thu Feb 21, 2013 8:33 pm
Thanks for the update! The transparent material to backside is a huge help! :thumb:
Content Creator at Skapeup
EarthMover
Premium Member
Premium Member
Postby lubessy » Mon Mar 11, 2013 10:02 pm
Hello,
I have problem installing this tool..
so after i downloaded.. I placed the "material tool rb " into the sketchup-> plugin forlder
and so when i opened a new sketchup.. i still don't see a new plugin for material tool...
could you tell me how to set this up after i download it???
Don't I just need to copy and paste into the sketchup- plugin folder?
and I am using sketchup 8pro version too....
lubessy
Postby thomthom » Tue Mar 12, 2013 8:31 am
Notice it's an RBZ - not RB file. See this thread on how to install RBZ files: viewtopic.php?t=42315#InstallRBZ
(I'd forgotten to add the How To link for this download which I usually have)
PluginStore Author
PluginStore Author
Postby make » Wed Jun 26, 2013 9:33 pm
Nice work, thomthom!!!!
Thanks!
make
Postby Quang Le » Tue Nov 12, 2013 2:40 am
Very good, material tools are a great tool and helps me alot...
Thank so much Thomthom...!
Quang Le
Postby Quang Le » Tue Nov 12, 2013 7:37 am
I encountered problems when installing [Plugin] Material Tools (2.6.0). with the following error message:
"material tools requires a newer version, 2.7.0, of TT_lib"
I also use TT_Lib2-2.9.0, but still error...I doubt Google SketchUp 8 version is too old ...
Can you help me?
Thank so much.
Quang Le
Postby tt_su » Tue Nov 12, 2013 11:30 am
Did you have an old version of TT_Lib2 installed?
Do you have files that have gotten stuck in the VirtualStore?
tt_su
SketchUp Team
SketchUp Team
Postby Quang Le » Thu Nov 14, 2013 3:51 am
Thank Thomthom...! I understand that...
I have removed old TT_lib and instal new TT_lib2 of you.
I have now used material tools and thank you so much.
Quang Le
Postby rami_lpm » Wed Sep 17, 2014 1:37 pm
Hi.
I had this error while running 'instance material to faces'
With and without geometry selected.
Code: Select all
Error: #<NameError: undefined local variable or method `selection' for TT::Plugins::MaterialTools:Module>
C:/Users/ramiro velazco/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/tt_material_tools/core.rb:149:in `instance_materials_to_faces'
C:/Users/ramiro velazco/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/tt_material_tools/core.rb:40:in `block in <module:MaterialTools>'
-e:1:in `call'
I solved it(I think?) by adding
Code: Select all
selection = model.selection
in core.rb right after line 148
Thanks for a wonderful tool.
rami_lpm
PluginStore Author
PluginStore Author
Postby thomthom » Sun Oct 26, 2014 11:10 am
I just noticed this post. I've filed an issue: https://bitbucket.org/thomthom/material ... aterial-to
Thanks for the report!
PluginStore Author
PluginStore Author
Postby dem » Fri Oct 31, 2014 4:41 am
Hi. Some features not works(
Transparent Material to Backside quetly do nothing, but with Instance Material to Faces console dsy:
C:/Users/dem/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/tt_material_tools/core.rb:149:in `instance_materials_to_faces'
C:/Users/dem/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/tt_material_tools/core.rb:40:in `block in <module:MaterialTools>'
-e:1:in `call'
Tested in SU2013 & SU2014
dem
Postby thomthom » Sat Nov 01, 2014 7:08 pm
Yes, this is the same issue as rami reported: viewtopic.php?f=323&t=17587&view=unread#p537988
PluginStore Author
PluginStore Author
Postby josephkim626 » Mon Nov 24, 2014 4:30 pm
Thanks Thomas!
I love the plug in, and very often use it.
I had some suggestion on improving this plugin:
All the listed functions such as "remove from all faces and edges" and "all textures" would be nice to be applied to SELECTION rather than in the entire model.
Thanks!
josephkim626
Postby ddsstudio » Thu May 21, 2015 10:49 pm
I installed the plugin and everything seems to work great, except the "List Textures in Console" function. It opens the console but there is no list.
What am I missing?
Thanks for a awesome plugin!
ddsstudio
Postby thomthom » Mon May 25, 2015 9:54 am
What version of SU?
You might want to open the console before invoking that function if you are on an older SU version.
PluginStore Author
PluginStore Author
Postby Mr Lukestar » Fri Jun 09, 2017 3:05 am
Hi sorry I'm a beginner at this.
I have downloaded and add the Material Tool, it in showing in extension manage (sketch 2017 pro). It is installed.
But I cannot find it anywhere in the menu tabs - so how to use???
Any i missing something?
Luke
Mr Lukestar
Postby josephkim626 » Fri Jun 09, 2017 9:18 am
It does not have a toolbar icon, if that is what you mean.
It will show up in the menu however.
Look under:
Extensions > Material Tools.
josephkim626
Postby hank » Wed Mar 21, 2018 1:22 pm
Thanks for a great plugin thomthom. As is mentioned on Extension Warehouse, "List Textures in Console" generates a blank console window. Is this just a SU2018 thing or are other folks experiencing that issue?
hank
PreviousNext
Return to Plugins
Users browsing this forum: LeoKnebel and 11 guests
