SketchUcation Plugin Store
[Plugin] Material Tools (2.6.0) — 19 February 2013
Re: [Plugin] Material Tools (2.5.2) — 04 October 2011
Postby jorge2011 » Wed Oct 05, 2011 12:09 am
Thank you very much. :)
jorge2011
Operating system: Windows
SketchUp version: 7
License type: Pro
SketchUp use: architecture
Postby irwanwr » Tue Nov 29, 2011 5:38 pm
thank you very much for this plugins. :thumb:
it's very useful for me to keep the file size as small as it could.
irwanwr
SketchUp version: 8
License type: Free
SketchUp use: hobby
Level of SketchUp: Beginner
Postby halroach » Sun Mar 18, 2012 9:21 am
1. Does the 'remove specific material work on textures?
2. I've got a problem when trying to remove a specific material. Have many many materials in my model and the list of materials in the plugin is not long enough for me to see all of them. Any solution?
3. The reason I am trying to use this plugin is for removing a material that has a TGA in it (which causes annoying errors when I first open the model). I am not able to find the TGA in the model, but am able to find the material it is in. When I try to right click on the material in the regular materials window, sketchup freezes for 10 seconds or so, and then I see the context menu for only a fraction of a second, and I am not able to actually delete the material. This happens a lot when I have a lot of materials in a model.
This is a sketchup bug that's been around for quite a long time! Any suggestions?
4. 'List textures in console' doesn't seem to do anything other than opening the console box, but nothing happens.
(I'm using latest sketchup pro 8 with windows 7 64bit)
halroach
Postby thomthom » Mon Mar 19, 2012 9:57 am
Halroach wrote:1. Does the 'remove specific material work on textures?
You mean removing texture from material?
The plugin would remove the material - entirely. Making no distinction if it is textured or not.
Halroach wrote:2. I've got a problem when trying to remove a specific material. Have many many materials in my model and the list of materials in the plugin is not long enough for me to see all of them. Any solution?
That's a bug in SketchUp. Only way around it is to create a WebDialog instead - which I don't have the time for right now.
Halroach wrote:3. The reason I am trying to use this plugin is for removing a material that has a TGA in it (which causes annoying errors when I first open the model). I am not able to find the TGA in the model, but am able to find the material it is in. When I try to right click on the material in the regular materials window, sketchup freezes for 10 seconds or so, and then I see the context menu for only a fraction of a second, and I am not able to actually delete the material. This happens a lot when I have a lot of materials in a model.
Have you tried assigning a different texture to that material - if the purpose is to avoid the errors when you open the model? (What does the error say btw?)
Halroach wrote:4. 'List textures in console' doesn't seem to do anything other than opening the console box, but nothing happens.
Huh! I see that as well. Sure is a bug.
Global Moderator
SketchUp version: 8
License type: Pro
Level of SketchUp: Advanced
Postby halroach » Mon Mar 19, 2012 10:38 am
1. cool
2. I imagine the sketchup team is aware of the bug... I really wish I could just mark a bunch of selected materials in one go, and delete them...
3. That's a good idea! I just unchecked the texture in the material, purged, saved, and the error doesn't appear anymore.
The error I get looked like this:
4. happy I could be of assistance
halroach
Postby TIG » Mon Mar 19, 2012 11:41 am
If you have a long list in a UI dialog you can click in the list pane and then use the up/down arrow keys to scroll to the item you want.
If you want to jump a long way up/down a list [i.e. to somethings that's off screen!] let's say you are on 'Aardvark' but you want to jump to 'White' then press the W key and it'll jump to the first W - perhaps 'Wheat' [assuming alphanumeric sorting], then you can press the down-arrow until 'White' is the select item...
It's not perfect... BUT it does allow you to access any item in an overly long list in a standard UI dialog... :geek:
Global Moderator
SketchUp version: 8
License type: Pro
Postby halroach » Mon Mar 19, 2012 2:18 pm
TIG wrote:If you have a long list in a UI dialog you can click in the list pane and then use the up/down arrow keys to scroll to the item you want.
For some reason my list is not sorted alphanumerically... but your tip is good to know!
halroach
Postby TIG » Mon Mar 19, 2012 2:57 pm
If you have an array of strings then array.sort! will sort it...
I'm unfamiliar with the code producing this list - but it should be easy enough to have an ordered list ??
Global Moderator
SketchUp version: 8
License type: Pro
Postby thomthom » Mon Mar 19, 2012 3:08 pm
TIG wrote:If you have an array of strings then array.sort! will sort it...
Since the list of SketchUp material names which is UTF-8 - meaning there can be multi-byte characters. And Ruby's #sort will mangle these characters because it treat each byte as individual characters.
This is another reason why a WebDialog is better - since one can make a dropdown box with scrollbar and utilize the fact the JS is Unicode compatible. (In addition I have a natural sort algorithm that would ensure that you get numbers in correct order ( 1,2,3,10...etc instead of 1,10,2,3... )
Global Moderator
SketchUp version: 8
License type: Pro
Postby EarthMover » Sat Aug 11, 2012 1:27 pm
Thom, possible to add removing materials from all groups and components? Not the materials on the inside surfaces, just anything applied to a group or component itself and replacing it with default?
A designer is an emerging synthesis of artist, inventor, mechanic, objective economist and evolutionary strategist. - R. Buckminster Fuller
Some of my 3D crap
EarthMover
Top SketchUcator
Postby TIG » Sat Aug 11, 2012 1:43 pm
Something like
Code: Select all
Sketchup.active_model.definitions.each{|d|next if d.image?;d.instances.each{|i|i.material=nil}}
for every group/instance in the model, ignoring whether visible/locked etc...
OR
Code: Select all
Sketchup.active_model.selection.each{|e|e.material=nil if(e.is_a?(Sketchup::Group)||e.is_a?(Sketchup::ComponentInstance))&& !e.locked?)}}
to process all groups/instances in a selection, ignoring locked ones...
Copy/paste one-liners into the Ruby Console...
Global Moderator
SketchUp version: 8
License type: Pro
Postby rv1974 » Wed Jan 16, 2013 8:27 am
Fantastic tools! :thumb: Thank you.
What I really miss :roll: is additional script to assign the front faces material to backfaces (at least
on geometry with transparent mats).
rv1974
SketchUp version: 8
License type: Pro
Postby massimo » Wed Jan 16, 2013 8:44 am
rv1974 wrote:Fantastic tools! :thumb: Thank you.
viewtopic.php?p=155759#p155759
massimo
Global Moderator
SketchUp version: 7
License type: Pro
SketchUp use: other
Postby thomthom » Wed Jan 16, 2013 9:47 am
Global Moderator
SketchUp version: 8
License type: Pro
Postby rv1974 » Wed Jan 16, 2013 11:09 am
thomthom wrote:
What exactly do you ask?
If it's already there (the last line) I for some mystic reason don't have it (the version is updated)
If it's a printscreen of the latest future update- it looks awesome (exactly what I mean (if it processes entire model)).
P.S. How do you make the printscreen of the dropped down list???
rv1974
SketchUp version: 8
License type: Pro
Postby thomthom » Wed Jan 16, 2013 11:30 am
oh... I might have forgotten to upload this little update... :oops:
Global Moderator
SketchUp version: 8
License type: Pro
Postby rv1974 » Wed Jan 16, 2013 12:01 pm
thomthom wrote:oh... I might have forgotten to upload this little update... :oops:
unpardonable forgetfulness
:mrgreen:
rv1974
SketchUp version: 8
License type: Pro
Postby thomthom » Wed Jan 16, 2013 12:58 pm
Give me a couple of days. I need to release an update to TT_Lib2 first.
Global Moderator
SketchUp version: 8
License type: Pro
Postby rv1974 » Thu Jan 17, 2013 9:01 am
Yet another thing:
Assign component\group mat to its front faces (to the inner geometry with default mat) would be amazing feature.
There's already the great 'remove C-G materials.rb' , something the opposite is also needed.
rv1974
SketchUp version: 8
License type: Pro
Postby thomthom » Thu Jan 17, 2013 9:49 am
How would you handle groups with faces of multiple materials? It's just not an symmetrical operation.
Global Moderator
SketchUp version: 8
License type: Pro
Postby rv1974 » Thu Jan 17, 2013 11:02 am
thomthom wrote:How would you handle groups with faces of multiple materials? It's just not an symmetrical operation.
Only default material within the would inherit the comp\group mat. The manually set multiple mats would survive.
rv1974
SketchUp version: 8
License type: Pro
Postby thomthom » Thu Jan 17, 2013 11:22 am
Oh - I misread you. I thought you wanted face material to group materials.
You want the instance materials to be applied to all faces with default material in the group/component? That's already there: "Instance Material to Faces"
Global Moderator
SketchUp version: 8
License type: Pro
Postby rv1974 » Thu Jan 17, 2013 12:16 pm
damn how could I miss it.
rv1974
SketchUp version: 8
License type: Pro
Postby rv1974 » Wed Jan 23, 2013 11:10 am
thomthom wrote:Give me a couple of days. I need to release an update to TT_Lib2 first.
...bump
:roll:
rv1974
SketchUp version: 8
License type: Pro
Postby thomthom » Wed Jan 23, 2013 11:16 am
Yeeea.... didn't happen... :( I've run into a bug that needs fixing.
Global Moderator
SketchUp version: 8
License type: Pro
Re: [Plugin] Material Tools (2.6.0) — 19 February 2013
Postby thomthom » Tue Feb 19, 2013 8:11 pm
Version 2.6.0
  • Added Transparent Material to Backside.
  • Added support Fredo updater.
Global Moderator
SketchUp version: 8
License type: Pro
Postby rv1974 » Wed Feb 20, 2013 8:06 am
:thumb:
rv1974
SketchUp version: 8
License type: Pro
Postby EarthMover » Thu Feb 21, 2013 8:33 pm
Thanks for the update! The transparent material to backside is a huge help! :thumb:
Some of my 3D crap
EarthMover
Top SketchUcator
Postby lubessy » Mon Mar 11, 2013 10:02 pm
Hello,
I have problem installing this tool..
so after i downloaded.. I placed the "material tool rb " into the sketchup-> plugin forlder
and so when i opened a new sketchup.. i still don't see a new plugin for material tool...
could you tell me how to set this up after i download it???
Don't I just need to copy and paste into the sketchup- plugin folder?
and I am using sketchup 8pro version too....
lubessy
SketchUp version: 8
License type: Pro
SketchUp use: interior design
Postby thomthom » Tue Mar 12, 2013 8:31 am
Notice it's an RBZ - not RB file. See this thread on how to install RBZ files: viewtopic.php?t=42315#InstallRBZ
(I'd forgotten to add the How To link for this download which I usually have)
Global Moderator
SketchUp version: 8
License type: Pro
Not a Premium Member yet? Check out the great time-limited deal we are offering.
PreviousNext
Return to Plugins
Users browsing this forum: Google Feedfetcher, gullfo, Gábor, petrash1alex, TIG, tigartos and 20 guests
