SketchUcation Plugin Store
[Plugin] Material Tools (2.6.0) — 19 February 2013
Re: [Plugin] Remove Materials (1.3.0) — 8 July 2009
Postby TIG » Thu Aug 19, 2010 2:45 pm
Gaieus wrote:Hi Thom,
sorry for bumping the topic... Could you add "Remove materials applied to back faces"? (Or is there a plugin that does that already?)
viewtopic.php?p=264134#p264134 = My recent tools include three options:
1. If a face has no front-material but does have a back-material it reverses the face and moves the back-material onto the front keeping the UV mapping etc. It works on selected faces, and after a confirmation-dialog faces in groups, components, or just 'all'.
2. If a face has a front-material and also has a back-material it reverses the face and moves the back-material onto the front keeping the UV mapping etc and erases the other material - i.e. the back-material is finally defaulted [it is 'forced' - use with care!]. It works only on selected faces.
3. It removes back-materials from all selected faces, and after a confirmation-dialog faces in groups, components, or just 'all'.
Global Moderator
Operating system: Windows
SketchUp version: 2013
License type: Pro
SketchUp use: architecture
Level of SketchUp: Advanced
Re: [Plugin] Remove Materials (1.4.0) — 19 August 2010
Postby Gaieus » Thu Aug 19, 2010 3:33 pm
:thumb:
Cool, TIG, thanks! I knew I remembered reading something but you guys spoil us with the abundance of new plugins every day so it's really hard to keep up with the development!
:D
Administrator
License type: Pro
SketchUp use: historical reconstruction
Postby Ben Ritter » Thu Aug 19, 2010 3:47 pm
Thomas, thank you.
Ben Ritter
Postby Zacchia » Thu Aug 19, 2010 4:08 pm
thanks for this plugin!!
SketchUp Pro, CasCADos, TheaRender, TwilightRender
Zacchia
Re: [Plugin] Material Tools (2.2.0) — 21 October2010
Postby thomthom » Thu Oct 21, 2010 8:24 pm
Some various updates to this plugin - renamed it as well.
Global Moderator
SketchUp version: 8
License type: Pro
Postby Caleidos4D » Thu Oct 21, 2010 8:47 pm
Thanks thomthom :berserk: :thumb: :thumb: :thumb:
Caleidos4D
Postby CAntonis » Thu Oct 21, 2010 9:17 pm
Thank U.
It 'll come in handy! Thats for sure!
CAntonis
CAntonis
Postby dedmin » Fri Oct 22, 2010 9:44 am
Instance Material to Faces paints materials also to the back faces. Apply Color Adjustments bugsplats SketchUP when nothing is selected. The names are somehow misleading because this tools work on a selection - maybe to put them on the right click menu when click on the selection or add "selected" to the name.
WinXp SP3
SketchUP 8
dedmin
Postby thomthom » Fri Oct 22, 2010 11:37 am
dedmin wrote:Instance Material to Faces paints materials also to the back faces.
Yes - by design to preserve the same visual appearance.
dedmin wrote: Apply Color Adjustments bugsplats SketchUP when nothing is selected.
:shock: It doesn't use the selection at all - it processes all colour adjusted textures in the model. Got a sample model where this occurs? I've not seen any bugplats with this. Can't reproduce it either.
dedmin wrote:The names are somehow misleading because this tools work on a selection - maybe to put them on the right click menu when click on the selection or add "selected" to the name.
Not all work on the selection.
Global Moderator
SketchUp version: 8
License type: Pro
Postby dedmin » Fri Oct 22, 2010 11:46 am
Itis a clean file - nothing there
dedmin
Postby thomthom » Fri Oct 22, 2010 11:49 am
I tried with a completely empty file - no splat.
Admin or user account?
Global Moderator
SketchUp version: 8
License type: Pro
Postby dedmin » Fri Oct 22, 2010 11:52 am
Video_2010-10-22_135039.wmv
Admin
dedmin
Postby thomthom » Fri Oct 22, 2010 11:59 am
And you said it does this if the selection was empty?
It doesn't always do this?
Global Moderator
SketchUp version: 8
License type: Pro
Postby dedmin » Fri Oct 22, 2010 12:07 pm
Video_2010-10-22_140535.wmv
dedmin
Postby thomthom » Fri Oct 22, 2010 12:12 pm
So it crashes all the time? No exceptions?
Global Moderator
SketchUp version: 8
License type: Pro
Postby dedmin » Fri Oct 22, 2010 12:19 pm
As far as I tried - yes.
dedmin
Postby thomthom » Fri Oct 22, 2010 12:19 pm
Ok - I'll see if I can make a debug version to detect where it splats.
Global Moderator
SketchUp version: 8
License type: Pro
Postby ray678 » Thu Dec 02, 2010 7:03 pm
thanks for sharing
ray678
Postby spence » Fri Dec 03, 2010 6:30 pm
This is a great plugin Thomas, thanks :D
Spence
spence
Premium Member
Premium Member
Postby nektares » Sat Dec 04, 2010 8:09 pm
Thanks ThomThom! your plug-ins are really cool!
nektares
Postby bentleykfrog » Fri Jan 07, 2011 4:30 am
Great plugin thomthom, nice work, only wish remove by selection would remove the materials applied to faces and groups/components inside selected groups/components, and components in selection are made unique.
bentleykfrog
Postby Rich O Brien » Thu Jun 02, 2011 8:55 pm
I'm not getting 'Remove Material from selection' to work?
:::Blog:::
I'm a Trimbler now!
Rich O Brien
Administrator
SketchUp version: 8
License type: Pro
SketchUp use: engineering and mechanical design
Postby thomthom » Thu Jun 02, 2011 8:57 pm
Rich O'Brien wrote:I'm not getting 'Remove Material from selection' to work?
Errors in the console?
Global Moderator
SketchUp version: 8
License type: Pro
Postby Rich O Brien » Thu Jun 02, 2011 8:58 pm
My bad...
Code: Select all
Error: #<NameError: undefined local variable or method `ents' for TT::Plugins::MaterialTools:Module>
C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/tt_material_tools.rb:270:in `remove_all_from_selection'
C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/tt_material_tools.rb:256:in `each'
C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/tt_material_tools.rb:256:in `remove_all_from_selection'
C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/tt_material_tools.rb:62
C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/recurve.rb:17:in `call'
:::Blog:::
I'm a Trimbler now!
Rich O Brien
Administrator
SketchUp version: 8
License type: Pro
Postby Rich O Brien » Thu Jun 02, 2011 8:59 pm
Actually I just noticed that right clicking produces this error
Code: Select all
Error: #<LocalJumpError: unexpected return>
(eval):106:in `load'
C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/tt_material_tools.rb:270:in `call'
:::Blog:::
I'm a Trimbler now!
Rich O Brien
Administrator
SketchUp version: 8
License type: Pro
Postby Rich O Brien » Thu Jun 02, 2011 9:00 pm
Sorry this error
Code: Select all
(eval):106:in `call'
(eval):106
:::Blog:::
I'm a Trimbler now!
Rich O Brien
Administrator
SketchUp version: 8
License type: Pro
Postby Rich O Brien » Thu Jun 02, 2011 9:02 pm
I think the problem is with Recurve? i'm getting all sorts of errors when I right click
:::Blog:::
I'm a Trimbler now!
Rich O Brien
Administrator
SketchUp version: 8
License type: Pro
Postby Rich O Brien » Tue Jun 28, 2011 12:32 pm
Problem isn't Recurve as I've removed it....
Code: Select all
:::Blog:::
I'm a Trimbler now!
Rich O Brien
Administrator
SketchUp version: 8
License type: Pro
Postby thomthom » Tue Jun 28, 2011 12:57 pm
Stop breaking things!
Global Moderator
SketchUp version: 8
License type: Pro
Postby Rich O Brien » Tue Jun 28, 2011 12:58 pm
They call me Mr.Glass
:::Blog:::
I'm a Trimbler now!
Rich O Brien
Administrator
SketchUp version: 8
License type: Pro
Not a Premium Member yet? Check out the great time-limited deal we are offering.
PreviousNext
Return to Plugins
Users browsing this forum: Bing [Bot], blajnov, fdrs, Foxjester, kabiegoh, MikaK, toshimimishina, trantheanhhp and 13 guests
