[Plugin] Scale and Rotate Multiple (UPDATED Dec 22, 09)
Re: [Plugin] Scale and Rotate Multiple (UPDATED March 22, 09)
Postby plot-paris » Mon Apr 20, 2009 10:01 am
fantastic tool, Chris. I like it a lot! :ecstatic:
(how about an additional 'move' function? for offsetting each group/component...)
plot-paris
Postby numerobis » Tue Apr 21, 2009 9:17 am
WOW! Very cool! Thank You!
3ds max feeling in sketchup...
numerobis
Postby Pixero » Sat May 09, 2009 9:31 am
Great script, but may I suggest a few enhancements:
I'd like to be able to rotate and/or scale randomly within a min to max value, a selection of components by a chooseable local axis. (I.E. each components axis.)
This script only works on the global/world Z axis, right?
Preferably the user should be able to choose X, Y or Z or any combination of them. And choose between Local or World axis.
"Why would you want that?" you may ask.
Well I've spent some time making trees and this would speed it up considerably.
I can think of other uses as well... :)
Let me know if I need to explain better what I want.
Pixero
Postby Chris Fullmer » Sat May 09, 2009 10:10 am
I think it might exist already, so correct me if you are thinking something more. If you select "axis" it will scale and rotate on each component's local axis.
Does that do the trick?
Chris
All my Plugins I've written
SketchUp Team
SketchUp Team
Postby Pixero » Sat May 09, 2009 12:02 pm
Chris Fullmer wrote:I think it might exist already, so correct me if you are thinking something more.
Do you have the name of that plugin? Or do you mean you think its already in your script?
Chris Fullmer wrote: If you select "axis" it will scale and rotate on each component's local axis.
Chris
Thats right but your script only rotates around the Z axis?
I would like to be able to select x, y, z axis or any combination of them. Like three checkboxes one for each axis. Or a drop down menu.
(It should still have Z axis as default.)
And a checkbox for scale and one for rotation so you can have the script do just one of them or both in a easy to use way.
If you want I could make a image explaining what I want.
Pixero
Postby Chris Fullmer » Sat May 09, 2009 1:14 pm
Ahh, yes. That makes sense now. Correct. the script only rotates on the z axis.
Part of the problem with the checkboxes is that I would need to use web dialogs to make that work, and at this point, I have no clue how to do that. I could probably get all the options implemented using the default SU inputbox (expanding the current one), but that inputbox is very clunky and I don't love it. But I'll think about it and see if I can think of an easy way to get it all into the inputbox and not make it too overcrowded and difficult to understand.
If you'd like to mock up an image, that would be fine with me too! Thanks Jan, you've been a great help on this script,
Chris
SketchUp Team
SketchUp Team
Postby Pixero » Sat May 09, 2009 6:15 pm
Here is a mockup of a possible interface without a fancy web dialog.
"Scale about" is same as current version.
Should maybe change name to something like: "Origin"
Pixero
Postby jsrocha » Thu May 28, 2009 12:44 pm
Hi! first of all, great plugin!!
i have a suggestion: is it possible to have an "aplly" button in the plugin interface? i mean, sometimes is good to play around with the settings, and when you hit "ok", if you want to play a little more, you have to go all the way down again and set everything again.....so, i think an aplly button will help a lot, because it wont close the plugin window, so you can change the settings and aplly them again in the same window!
anyway, this is a very useful script, thanks a lot!
regards from brasil,
Jsrocha
jsrocha
Postby accabrera » Sat Aug 01, 2009 2:58 am
Thanks a lot Chris, amazing plugin!!!
accabrera
Postby Chris Fullmer » Sat Aug 01, 2009 4:54 am
Muito obrigado amigos!
@jsrocha I am learning how to use web dialogs, so once I get that down, I would be interested in trying to update some of these scripts to use them. One of the biggest benefits is the abilty to have an easier ability to implement things like you requested. I suppose I could do it without a webdialog, but it seems like it would be easier to control in a web dialog.
@accabrera - Thanks, glad you like it!
Chris
SketchUp Team
SketchUp Team
Postby utiler » Sun Aug 02, 2009 12:15 am
Pixero wrote:Here is a mockup of a possible interface without a fancy web dialog.
Great idea, Jan!!! Chris do you see this being implemented....?
Cheers,
utiler
Top SketchUcator
Postby plot-paris » Sun Aug 02, 2009 8:57 am
Chris Fullmer wrote:I am learning how to use web dialogs, so once I get that down, I would be interested in trying to update some of these scripts
great things to come then... I can't wait to see what you are going to come up with :bounce:
plot-paris
Postby Chris Fullmer » Sun Aug 02, 2009 4:45 pm
That's some good pressure :)
Andrew, yeah if I can ever get around to these updates I dream of, that is something I would like to add.
Chris
SketchUp Team
SketchUp Team
Postby utiler » Mon Aug 03, 2009 1:08 am
Cool, appreciated all you have done for SU workflow.... :bounce:
utiler
Top SketchUcator
Postby xrok1 » Fri Aug 21, 2009 10:32 pm
now where's that bump button :?:
“There are three classes of people: those who see. Those who see when they are shown. Those who do not see.”
xrok1
Postby MartinRinehart » Sat Aug 22, 2009 12:01 pm
Chris, is it HTML, JavaScript or the linkage between these and Ruby (or all three)? I'm planning a frontal assault on the latter (rewrite Lininger but going much slower) which I could kick up to the front of the line. I've done HTML (http://www.easyHTMLtutorial.com) and am mulling on JS.
Martin
Author, Edges to Rubies - The Complete SketchUp Tutorial at http://www.MartinRinehart.com/models/tutorial.
MartinRinehart
Postby Chris Fullmer » Mon Aug 24, 2009 6:10 am
Hi Martin, I'm not even sure what it is that is holding me up. I don't know HTML at all. I don't JS at all. And I have no clue how they interact. So reading through JS tutorials leaves me confused because I don't understand what its doing tot he HTML. Reading through HTML tutorials seems to help the most currently. So I will gladly look over your HTML tutorial.
Chris
SketchUp Team
SketchUp Team
Postby plot-paris » Thu Oct 08, 2009 12:42 pm
just a big THANK YOU!!! again, Chris.
you saved me about 15 minutes rotating and scaling a whole bunch of trees... :ecstatic:
plot-paris
Postby DIEGO-RODRIGUEZ » Fri Oct 09, 2009 12:15 am
hi Chris
I proposed an idea on the forum.
viewtopic.php?f=180&t=22569
If you have not seen her.
I think your plugins, could adapt well to the idea
interested? is possible?
greetings
DIEGO-RODRIGUEZ
Banned
Postby majid » Sun Oct 25, 2009 3:24 pm
:berserk: recently I saw this. thank you for generousity
majid
Top SketchUcator
Postby Chris Fullmer » Sun Oct 25, 2009 6:52 pm
I just got a report that this might not be working right in 7.1!
So if you use it and it moves components all over th place, instead of just scaling them, please let me know. I need to look into it.
But otherwise I hope you find it useful :)
Chris
SketchUp Team
SketchUp Team
Postby Chris Fullmer » Thu Dec 10, 2009 9:21 pm
Can any Mac users verify if this script is working on SU 7.1? It appears to working great on Vista, SU 7.1 but I still have a report or two of it not working.
Anyone have any example files where it is not working for them?
Chris
SketchUp Team
SketchUp Team
Postby thomthom » Thu Dec 10, 2009 9:39 pm
Chris Fullmer wrote:Can any Mac users verify if this script is working on SU 7.1? It appears to working great on Vista, SU 7.1 but I still have a report or two of it not working.
Chris
SU 7.1M1, OSX10.4
A´OK!
PluginStore Author
PluginStore Author
Postby Chris Fullmer » Thu Dec 10, 2009 10:12 pm
Thanks Thom!
I should mention what is not working for some, just in case you just verified it loaded.
I have heard 2 or 3 reports of this plugin thoring components all over the place, instead of using their axes. It seems that for some, this plugin does not scale and rotate according to the specified axes.
So if anyone still feels like testing further, awesome. Otherwise, I'll write a debugging version and give that to anyone who wants to test it out, see what is broken on their system.
Thanks again,
Chris
SketchUp Team
SketchUp Team
Postby thomthom » Thu Dec 10, 2009 10:18 pm
I just tried the random rotate and scale. That worked as expected. But if you have specific procedures that's reported to fail, then I can try that.
PluginStore Author
PluginStore Author
Postby Pixero » Thu Dec 10, 2009 10:53 pm
Yeah, I've seen that two times recently when using axis.
When I choose component base everything was o.k. though. :?:
Pixero
Postby Chris Fullmer » Thu Dec 10, 2009 11:24 pm
Has it been on all components? or is just on face-me perhaps?
SketchUp Team
SketchUp Team
Postby thomthom » Thu Dec 10, 2009 11:33 pm
I tried with groups, components and face-me components. Can't reproduce.
...maybe it has to do with nesting..?
PluginStore Author
PluginStore Author
Postby thomthom » Thu Dec 10, 2009 11:37 pm
just noticed something when orbiting after random rotate and scale; face-me components float about all over the place.
PluginStore Author
PluginStore Author
Postby thomthom » Thu Dec 10, 2009 11:42 pm
that also occurs on PC.
See attached file for a sample of dancing Sang! :lol:
PluginStore Author
PluginStore Author
PreviousNext
Return to Plugins
Users browsing this forum: Bishal1000, boogie_lbc2 and 18 guests
