[Plugin] Perpendicular Face Tools (UPDATED 26-03-09)Re: [Plugin] Perpendicular Face Tools v0.1 betaVery Interesting. I have that plugin installed with no conflicts. I'll dig around tomorrow and see what I can find. Sorry for the inconvenience,
Chris
Re: [Plugin] Perpendicular Face Tools v0.1 betaThanks for playing attention, no matter for inconvenience, don't worry
MALAISE La Connaissance n'a de valeur que partagée
Mover2 does not use a file or method named cd_power_n.rb.
Re: [Plugin] Perpendicular Face Tools v0.1 betaI know, its cad_fathers's SCF powertools toolbar plugin that wrapped mover2 into a file called cd_power_n.rb. If you open that file, its just your script. So I'm guessing it has something to do with how its being loaded from his main plugin loader maybe? I don't know. I know I've got my whole script wrapped in a class so I thought I should not have conflicts. But perhaps there is more to it than that.
Chris
Re: [Plugin] Perpendicular Face Tools v0.1 betaI'm not getting bug-splats with custom-face, BUT it does inconveniently make a group of the selected face and not explode it at the end. It's easily fixed by adding a line of code after line #299, to explode the temporary group...
How's the orienting face rotation on end of line going ? . TIG
Re: [Plugin] Perpendicular Face Tools v0.1 betaI've tried this improvement, the group is still present, not exploded.
Re: [Plugin] Perpendicular Face Tools v0.1 betaHey Tig, I probably could explode the group without any conflicts. I was thinking I didn't want the added face to interefere with the model, but its probably not an issue. Or maybe I explode it by default and have a ctrl key modifier that leaves it grouped. I've been wanting to figure out modifier keys.
As for the rotation thing, I still have not got it worked out @Malaise, I think maybe that added the ungroup function to the custom face tool only, and maybe you tested it on one of the other tools. It would need to be added for each tool. I'll look into it, and maybe even get it implemented sometime this century Thanks everyone, thanks TIG! Chris
Re: [Plugin] Perpendicular Face Tools v0.1 betaIt's the original face that needs to be un-grouped. I agree that the face put on the end of the line is best left grouped to allow you to move its origin or rotate it about the line etc - you can explode it before doing a followme etc...
Here's my thinking on the rotation conundrum... Let's do the square for now - seems to me that first you make a group containing a 'flat' square with its centre set at the origin and then move it to the select vertex at the end of the edge, transform rotating it so its face is perpendicular to the picked-vertex's edge... So far so good. Now we check the geometry of the square - it only has four vertices, so find the two with the lowest Z-value***. These are the vertices of the bottom-most edge. Now find the mid-point between them - we use this to work out the vector from the 'centre' (picked-vertex's location) to this mid-point and the angle between that and a 'vertical' vector in the same plane as the face: that 'angle' is the angle that we'll use later on to rotate everything so that it is 'orthogonal' to the XYZ axes. Let's call the centre 'c' and two lowest points 'p1' and 'p2' - these are known - and the mid-point we'll call 'm' - that we need to get... To find a point mid-way between two others use...
We can then get the vector from 'c' to 'm', let's call it 'cm' - simply subtract the point values...
Now to find the 'vertical vector' (let's call it 'vv') - first find a point ('t') 1 unit away from 'c' above the surface of the face by the edge's [positive] 'vector' and then project it down till it hits the face at 'v' - the line between 'c' and 'v' is the 'vertical vector' against which we'll rotate the face...
Now get it's angle to the 'mid-point vector'
You then need to work on the face of the square and transform/rotate the whole thing around the picked-vertex's edge by the 'angle'... Done. ***Note: IF the Z of all of the square's vertices is the same [simple test to look at the four] then it's 'flat' so then we'll find the lowest two Ys and rotate it to be orthogonal about the Z axis instead. Also note that in this 'flat' case the 'vertical' vector needs to be (0,-1,0) to match the Y... For the custom face do something similar but group the face, copy it, explode the original back to where it was and then use the copy's bounding box centre as its 'origin', move and transform it to the vertex, use the new location's bounds to get an enclosing rectangle to get minimum Zs etc, all as above etc etc... I haven't tried this code, but it should at least form the basis of something that''ll work... . TIG
Re: [Plugin] Perpendicular Face Tools v0.1 betaThanks for walking me through this TIG. Hopefully I'll get a chance to try to get this implemented tonight or tomorrow. Lots of work-work and school-work today
Chris
Re: [Plugin] Perpendicular Face Tools v0.1 betalooking at this, I wondered how difficult it would be to create a script that 'blended' between two diffrent faces at either end of a line.
Re: [Plugin] Perpendicular Face Tools v0.1 betaUnfortunately, it would be very difficult - for me! I have thought similar thoughts, and that is a plugin that is on my wishlist. I am working on anther ruby that begins to get into that arena of morphing from one shape to another, but it is really new territory for me. Maybe in time
Chris
Like this? Please, register (free) to access all the attachments on the forums. “There are three classes of people: those who see. Those who see when they are shown. Those who do not see.”
Re: [Plugin] Perpendicular Face Tools v0.1 betaNot like that. That simply scales the shape. They are talking about morphing for instance a circle shape to a star shape.
Re: [Plugin] Perpendicular Face Tools v0.1 betathat would be a loft wouldn't it?
Re: [Plugin] Perpendicular Face Tools v0.1 betaIn Nurbs language it's more kown as a sweep
Re: [Plugin] Perpendicular Face Tools (UPDATED March 25, 2009)WOOHOO!!! I finally got it. Little by little I"m understanding transformations....after getting TONS of help from TIG on this script, and Fredo and pretty much everyone else. So I'm pleased to announce the updates to this script:
Perpendicular Face Tools Description: Three Perpendicular Face tools to help create faces perpendicular to the end of lines. Usage: Activate it at Plugins>Chris Fullmer Tools>Perpendicular Line Tools. Change the size of squares by entering a new dimension into the measuerments box after the face has been created. Change the radius of circles by entering "12s" for 12 sides into the measurements box. To use the custom face tool, create your face flat on the groundplane. The script attempts to line up the x axis as the bottom edge of the face. v1.0 Updates: * The original face now explodes upon exiting the custom face tool. * Added support so that faces will stay oriented with a flat edge on the horizontal plane. * Holding ctrl while creating a face will over-ride the flat horizontal feature and revert back to the default SketchUp "Arbitrary Rotation". * Now faces can be added anywhere to a line - on the endpoint (existing feature), in the middle of a line, or on a vertex of 2 lines. The vertex of 3 lines is not supported. I think that is everything that was requested on this script and more. Faces now orient better, the custom face gets exploded on exiting the tool, AND being able to add perpendicular faces to a single edge, an endpoint and the vertices of 2 lines. Please let me know if there are bugs. Its quite possible. I've tried to test it thoroughly, but its always possible I've missed something Hope it helps, Chris PS. I think I'll do some icons for this tomorrow. Also, the video is not updated yet on the front page. I'm too tied to do it right now. I'll do it tomorrow.
Re: [Plugin] Perpendicular Face Tools (UPDATED March 25, 2009)I found a little bug where the custom face needs to be drawn with the back face pointing upwards. I'll try to fix that shortly so the face can be facing either way.
Chris
Re: [Plugin] Perpendicular Face Tools (UPDATED March 25, 2009)Chris, thank you so much for this, as well as other, wonderful scripts. Your expertise is highly appreciated!!
Re: [Plugin] Perpendicular Face Tools (UPDATED March 25, 2009)Thanks! I'm currently sitting at my computer pulling my hair out though because I can't make the custom face tool work more solidly......grrr. If I draw it, and then run the script, it normally works. But if I reverse it, its borken. OR sometimes just moving it or making a copy of it and using the copy is enough to make my script not orient it correctly. I've still got some ideas to fix it so no matter what you do it, it will orient itself uniformly. I'll get it. Once I do, I'll upload a new version. I've even got a great toolbar for the new update.
Chris
Thanks for the update. However, now I have two Chris Fullmer Menu in my plugins. Is that what you intended? #1 Scale and Rotate Component on Faces Select Lines by Lenght The other: #2 Perpendicular Face Tool 3 Line Tool Thanks for all your work Ken Government rushes to help the irresponsible and does little for the responsible.
Re: [Plugin] Perpendicular Face Tools (UPDATED March 25, 2009)Hmm, that is not at all what I intended. I'll check to see if I messed up my menu system somehow. Thanks for letting me know,
Chris
Re: [Plugin] Perpendicular Face Tools (UPDATED March 25, 2009)1 thing, (and this is more/less for discussion because i'm well aware i might be in the minority)
with the perp.circle, would you rather have the vertex of the segments at the top -or- one of the segments being horizontal (the way it's working now). personally, i think it would be better if the vertex were at the top so diameter/radius lines can be drawn vertically or horizontally.. (am i even making any sense? that aside, i really like the change to perp.square.. having the horizontal edge is great. dotdotdot
+1. Thank you, Chris.
Re: [Plugin] Perpendicular Face Tools (UPDATED March 25, 2009)for example... drawing something like this:
would be 3 or 4 steps faster if the vertex of the circle were up top instead of the segment.. regardless of that part though, this script is way better than having to manually draw the perpendicular plane to begin with.. Please, register (free) to access all the attachments on the forums. dotdotdot
Re: [Plugin] Perpendicular Face Tools (UPDATED AGAIN 3-25-09)ok, I have updated it again. This time it has a toolbar:
I've also attempted to fix some serious issues with the custom face tool and how it orients itself. Unfortunately, its still only about 99% right. There are times when the custom face tool will not orient the face as expected. Often when used on a line that perfectly on the y axis. I'm sure its just a bug in how I'm rotating. But I've looked at the code too long and its really messy. So maybe later I'll re-write it from scratch to clean it up. As for rotating so that a point is always up.....I'm listening. I don't quite get the benefit by the example you showed though. I generally like to draw through circles on the mid point of edges, not on the vertices. But I might be the only one. So do you have another example that shows how it would be useful to do it with a vertice always on top? I also updated the video on the front page. Chris Please, register (free) to access all the attachments on the forums.
if you type an uneven number of segments you will have a vert at the top. “There are three classes of people: those who see. Those who see when they are shown. Those who do not see.”
this one: they're both the same circle.. it's better (for me) to have the actual radius on a vert/horizontal. dotdotdot
yeah, and that would work to an extent but then the horizontal is off.. i usually work off of 1/4 circles, get them to the right height, and then divide them into 8"o.c. segments.. it's just easier for me if everything is straight up&down / side-to-side at the beginning of the process. dotdotdot
Re: [Plugin] Perpendicular Face Tools (UPDATED AGAIN 3-25-09)makes sense.
SketchUcation One-Liner AdvertsAre you a Premium Member? Get your freebies here. Are you not> a Premium Member yet? Upgrade your account to grab these freebies instantly.
