[Plugin] Greeble 2 released! (Updated August 31st, 2009)
Re: [Plugin] Greeble 2 released!
Postby pilou » Mon Mar 09, 2009 7:06 pm
Hihi
I believe that is Protrude ;)
The competitor of this one :mrgreen:
Speedy Galerie
Top SketchUcator
Postby Chris Fullmer » Mon Mar 09, 2009 7:12 pm
Pilou wrote:The competitor of this one :mrgreen:
Sheesh!, get me in trouble with Jim!
Actually, you'd probably have to say my script is a competitor of protrude, since I wrote mine long after Jim wrote his (and Tig wrote his and Didier had written his :) ) For me it was just a great script to write to help me learn how to write scripts. Its largely inferior to Jims.
Plus I know Jim had been working on a true greeble with little greebles added to all protruded faces. I want him to finish that one!
All my Plugins I've written
SketchUp Team
SketchUp Team
Postby pilou » Mon Mar 09, 2009 7:12 pm
But Zorro2 by Whaat is cool too and give you more control :mrgreen:
And works also for a 3D object! :fro:
@Chris
(yes Protrude has just the Button to press between each generation ;) :D
Speedy Galerie
Top SketchUcator
Postby bugmcw » Tue Mar 10, 2009 12:38 am
well i had protrude already (go figure)
but when i press 'divide' on a rectangular face it does nothing.... any ideas?
bugmcw
Postby pilou » Tue Mar 10, 2009 12:45 am
You must select face or object not grouped first!
Except that no idea :roll:
Speedy Galerie
Top SketchUcator
Postby bugmcw » Tue Mar 10, 2009 1:14 am
hahah fortunately for me i got THAT far.... i select the face and just click away an nothing happens, maybe i will try to re-download it
[edit] redownloaded and reinstalled with same issue as before.... this is too weird... i can select rectangle, then choose Protrude... the dialogue box pops up, i hit divide and nothing.... weird...
bugmcw
Postby Jim » Tue Mar 10, 2009 1:26 am
bugmcw wrote:hahah fortunately for me i got THAT far.... i select the face and just click away an nothing happens, maybe i will try to re-download it
It's my fault - it doesn't work on a Mac and I don't have a Mac to try it on. I'm sure I could get it to work. Anyone want to buy me a Mac?
Jim
Global Moderator
Postby xrok1 » Tue Mar 10, 2009 1:28 am
i'll model you one if that helps. :roflmao:
“There are three classes of people: those who see. Those who see when they are shown. Those who do not see.”
xrok1
Postby pilou » Tue Mar 10, 2009 1:29 am
So goto the Protrude thread and ask your problem ! ;)
Maybe it's because you have a Mac :roll:
Damned crossing post :roll:
Speedy Galerie
Top SketchUcator
Postby bugmcw » Tue Mar 10, 2009 2:15 am
haha i wont buy you one Jim, but youre more than welcome to test on mine! let me know if i can help!
bugmcw
Re: [Plugin] Greeble 2 released! (Updated March 9th, 2009)
Postby Chris Fullmer » Tue Sep 01, 2009 5:58 am
Ressurecting the dead - or at leas the long forgotten!
But I've updated this script, and its a big enough update that I thought I'd post and let people know. Two main things are that it now works inside of groups and components and does not cause bug splats! (that was a big bug I never noticed until about 3 weeks ago, oops!). Also, the script remembers your settings between uses (but not between SketchUp sessions).
So if you have an old copy (include clf_greeble.rb or an old clf_greeble2.rb) please delete them and install this one.
UPDATE August 31, 2009
2.20:: 2009-08-31
  • Fixed a MAJOR bug that would cuase SketchUp to crash when greeble was used inside a group or component. So yes, you can now safely use Greeble inside a group or component!
  • Changed some code that should theoretically speed things up ever so slightly....frankly I don't think it helped.
  • Changed some code to make it run smarter, skip certain methods if they were not being executed.
  • Fixed some code that could cause problems when faces would overlap.
2.21:: 2009-08-31
  • Now user input settings are rembered between script uses.
Download
This script is hosted at http://www.smustard.com/script/Greeble2
Chris
SketchUp Team
SketchUp Team
Re: [Plugin] Greeble 2 released! (Updated August 31st, 2009)
Postby skkor9y » Wed Oct 28, 2009 10:03 pm
hi,CHRIS your tools are doin magic.
though my heart was shrunk when two of yr tools didnt worked ...
but yr solution(to PIBUZ),of updating component spray worked...
once again thanx..to u and also pibuz
skkor9y
Postby roytchaikowsky » Tue Nov 24, 2009 9:14 pm
This thread cannot be in page 11 man
roytchaikowsky
Postby Chris Fullmer » Tue Nov 24, 2009 9:27 pm
Ummm, what?
SketchUp Team
SketchUp Team
Postby Gaieus » Tue Nov 24, 2009 9:45 pm
It was probably sunken to page 11 of the Ruby Forum. He must have been surprised how that comes although this is such a great plugin
Roy, there IS a reason; this forum is quite active and not only due to the published plugins but also to the technical discussions between the scripters.
Here is a better (cleaner) list of the plugins published on this forum so far (not totally proof though)
search.php?keywords=Plugin&terms=all&author=&sc=1&sf=titleonly&sr=topics&sk=s&sd=a&st=0&ch=300&t=0&submit=Search
Note that this list spans over 21 pages itself so something inevitably must be below page 10.
Postby jhearcht » Wed Sep 15, 2010 3:14 am
SketchUp 6.4.265 on Windows XP
As a newbie, apparently I'm missing something that a more experienced modeler would take for granted.
I downloaded Greeble 2, along with Progress Bar and Offset. Put them in the Plug-ins folder. After a re-start, "Chris Fullmer Tools" appears in Plug-ins menu.
I select a grouped rectangular box with Juniper vegetation texture. I want to add some roughness to the surface. So I select the Greeble tool and enter some numbers. After clicking OK, nothing happens. I also trying selecting just one surface, but no go.
I was assuming the tool would draw a 2D grid with my +/- dimensions, then pull each piece up to a random height. If I could get some kind of response, I could then play with the numbers to get the look I want : pointy pyramids may do the trick.
Do I need to draw a grid before selecting the tool? Is there an auto grid tool? Should I greeble one face at a time? What do I need to do before invoking the Greeble tool?
Thanks for covering my ignorance with your intelligence. :)
jhearcht
Postby Chris Fullmer » Thu Sep 16, 2010 12:34 am
Hi jhearcht, it should work. But it does require a grid be drawn first. It will extrude each face, so if you just have one large face, it can extrude that face only. If you have a thousand faces, it then extrudes all those faces.
As a note, this plugin is apparently broken with SketchUp version 8.0 for now. I need to look into a fix for it. (but it should be working with version 6.x like you have).
You could upload your model and I'll see if I can play with it and see if there is some odd error if that would help,
Chris
SketchUp Team
SketchUp Team
Postby pilou » Thu Sep 16, 2010 12:36 am
Funny I just reply there :enlight:
Speedy Galerie
Top SketchUcator
Re: [Plugin] Greeble 2 released! (AUpdated August 31st, 2009
Postby craigcampbell66 » Sun Sep 19, 2010 7:01 am
Sketchup 7 windows7 pro 64
Hi all, I am in need of some advice re the Greeble plugin. I seem to follow the workflow in the tutorials/videos but with no effect. Not a ripple. Have tried on planes/grids/boxes/spheres.
Any advice appreciated.
thanks in advance, Craig
craigcampbell66
Postby pilou » Sun Sep 19, 2010 10:55 am
(I am in meters unity)I suppose that is the problem ;)
I have also nothing when I input inch unity ;)
surely measures are not accorded and i don't want have an headache for make conversion
for have the good measures :mrgreen:
so I take meter unity for simplify my life :)
Draw a simple box (7,6,4) select it and input numbers as shown
If you don't obtain something like this there is a problem :)
click image for zoom
Speedy Galerie
Top SketchUcator
Postby craigcampbell66 » Mon Sep 20, 2010 12:10 am
Hi, I tried again to use the greeble with the numbers in your parameters. Some success. It ceases to work at all when I input something into the offset parameters. I have tried in on a box and a sphere with the same results.
I have the offset.rb installed in the plugins folder along with the progressbar.rb and the greeble
any ideas as to where I am going wrong.
craigcampbell66
My Pain
Postby bagatelo » Sat Mar 19, 2011 3:46 am
Please do download the file and see if it is possible to solve my problem. The file was created in the latest version of Sketchup.
bagatelo
Re: My Pain
Postby TIG » Sat Mar 19, 2011 2:32 pm
bagatelo wrote:Please do download the file and see if it is possible to solve my problem. The file was created in the latest version of Sketchup.
This is made with my old Latticeizer script, 3cm frames and default pane with some PudhPull on the panes [with existing lines NOT kept] afterwards...
Global Moderator
Postby bagatelo » Sat Mar 19, 2011 3:43 pm
Please note the presentation that I have made in the attached file. That's exactly what I need. In some cases, I do not use handles in aluminum bar. I use ordinary handles. So I do not pull over 3cm from top face to bottom. In some cases, I use different spaces for 0.5cm, as requested by the woodworker or architect that I work. Thank you for your attention.
One day I will no more bore you, because I'm trying to learn Ruby Script. Thanks.
bagatelo
Postby pilou » Thu Jun 16, 2011 9:50 pm
This plug is always very funny :enlight:
Speedy Galerie
Top SketchUcator
Postby Chris Fullmer » Fri Jun 17, 2011 4:25 am
Pilou, you crack me up! Great stuff as always.
Chris
PS - what is your artistic style called, with all the vibrant colors and nonsensical shapes? I thought I remembered you using a term once that I found very interesting.
SketchUp Team
SketchUp Team
Postby pilou » Fri Jun 17, 2011 8:34 am
Surely "Flashy" :mrgreen: for the other term I don't remember. :oops:
Speedy Strange surreal geometrical attractor ? :)
Because I don't spend more ten minutes by scenes! :roll:
If you have 5 minutes you can see some Zbrush folish ;)
(section Zibi Art )
PS You have remarked that I have an immoderated use of your crazy "Random Painter" plug with SU ;)
Speedy Galerie
Top SketchUcator
Postby Bertier » Fri Jun 17, 2011 2:20 pm
can't get no greeble :(
Bertier
Postby pilou » Fri Jun 17, 2011 3:34 pm
Go to SMustard ;) (it's free)
Speedy Galerie
Top SketchUcator
Postby Bertier » Fri Jun 17, 2011 3:56 pm
c'est installé avec tout ce qu'il faut mais ça ne fonctionne pas...
Bertier
PreviousNext
Return to Plugins
Users browsing this forum: No registered users and 14 guests
