SketchUcation Plugin Store
[Plugin] FollowMe and keep (v0.04 update 20090210)
Re: [Plugin] FollowMe and keep (v0.04 update 20090210)
Postby rainfrog » Tue Dec 22, 2009 4:35 am
Hello! This is my first time posting here and I'm a fairly new "tinkerer" with Sketchup. However, I'm already stuck on the shortcomings of the FollowMe tool, and also I seem to want a result that I can't find a plugin to simulate. It's best explained in the attached model.
Basically, I want a profile to follow a path much like in the FollowMe and keep plugin, but in a way that preserves the proportions of the profile perpendicular to the path, whether that path is level or on a slope. This is the result you see in real life, with such things as railings, tunnels, street curbs, roller coasters, etc. If they rose a theoretically very steep hill, they don't have squashed cross-sections because of a profile remaining "level" on two axes. A tunnel needs a constant clearance throughout. A roller coaster's metal tubes remain circular in profile perpendicular to the path, not flattened ellipses as they climb a slope. I'm looking for a profile to remain perpendicular to the x,y plane (ie. "level") on only ONE of its local axes, not two. I hope this makes sense. It's hard for me to explain!
In the attached model, I have a layer called "Method" that hopefully helps to show how I got the desired result manually.
rainfrog
Postby mitcorb » Tue Dec 22, 2009 7:03 pm
Welcome:
It looks as if you have posted in the thread with the Plugin that is supposed to do what it appears that you are wanting--if that makes any sense.
Follow me and keep is supposed to overcome the twisting tendency that Follow me is plagued ? with.
Do read the previous posts in this thread, especially the first one, which should have a downloadable file embedded.
Also, watch for other replies here.
mitcorb
Top SketchUcator
Operating system: Windows
SketchUp version: 8
License type: Free
SketchUp use: architecture
Postby rainfrog » Tue Dec 22, 2009 9:00 pm
There is indeed a difference between what I'm looking for and what FollowMe and Keep does. As I said, it's hard to explain! So attached here is another file to better illustrate the difference (I hope)...
rainfrog
Postby mitcorb » Tue Dec 22, 2009 10:47 pm
Ok,
I am having difficulty downloading your 2nd file, but I think the problem is on this end.
What I am thinking is maybe Chris Fullmer's Perpendicular Face Tool which has a custom cross section input. It will prompt you along the way with a little popup tag if the protocol is not followed.
See if this is what you need, while I try to open your file.
mitcorb
Top SketchUcator
SketchUp version: 8
License type: Free
Postby mitcorb » Tue Dec 22, 2009 11:09 pm
rainfrog:
I was able to view your second skp. The bent U shape solid could also be formed using the Fredoscale suite of tools, I think. There is a bending tool in the set. I was thinking that you would first make the u shape with follow me on the xy plane, then use bending tool to warp it upward.
What would be neat is if Didier Bur's Lines2tubes had a feature where you give it a cross section of the the size you need, select the line/curve/path, and voomp! there you go.
Kirill has a 2faces and path routine that may be able to do it, however, I would have to verify this.
I don't know if I have helped at all. At least see the Fullmer tool and the Fredoscale tool to see if these may work. Fredo6 has plenty of pdf docs to explain the workings. You must also download the LibFredo doc ruby.
mitcorb
Top SketchUcator
SketchUp version: 8
License type: Free
Postby Chris Fullmer » Tue Dec 22, 2009 11:18 pm
Yeah, thats an interesting shape to make. Seems simple, but as you've seen, each tool has its own way of handling following a path through 3 dimensional space. I am not sure if there is a single tool out there that does precisely this.
But Fredo's tools have some awesome bending abilities that would help. And I agree that you mgiht look at Kiril's 2 faces and a path script. It might do it how you want it.
My perpendicular face tools is able to draw in that profile oriented exactly how you want it, but it does not "skin" the profiles. You almost need a 2 rail follow me solution so that the profile would know how to orient itself. Interesting,
Chris
All my Plugins I've written
SketchUp Team
SketchUp version: 8
License type: Pro
SketchUp use: landscape architecture
Level of SketchUp: Advanced
Postby mitcorb » Tue Dec 22, 2009 11:59 pm
Yeah Chris:
I just bent a replica of the example skp using Fredoscale. The cross section stayed intact, I just had to set the segment number and the extent of the bending to limit it to an eyeball estimate of the bend that rainfrog is showing.
I guess the moderator's are OK with this dialogue staying where it is?
mitcorb
Top SketchUcator
SketchUp version: 8
License type: Free
Postby rainfrog » Wed Dec 23, 2009 12:11 am
Thanks, mitcorb and Chris! I will definitely play around with the suggested plugins. I have Fredoscale but haven't begun to experiment with it yet. It'll probably be a few days (holidays coming up and I really should pull away from the computer a bit!)
I didn't mean to hijack the thread with an off-topic exchange. FollowMe and Keep is an incredible improvement over FollowMe and much appreciated, and it was the closest I had found to what I was trying to do.
rainfrog
Postby mitcorb » Wed Dec 23, 2009 3:30 am
It's OK, rainfrog:
I am just glad I was able to assist.
By the way, when I looked at the replica I did, at first it had a bounding box like a group. I clicked somewhere and the box disappeared. I could not retrieve the group, but the model remained. Also, I noticed that a line segment was bridging one of the bends, like it did not get bent by the plugin, even though I selected the whole thing before bending.
mitcorb
Top SketchUcator
SketchUp version: 8
License type: Free
Postby jarynzlesa » Mon Mar 22, 2010 12:26 am
works perfectly, thank you - good work :thumb:
jarynzlesa
SketchUp version: 7
License type: Free
SketchUp use: woodworking
Level of SketchUp: Beginner
Postby ciudadanochano » Mon Apr 05, 2010 1:06 pm
Hey!! I have a very stupid question...How can I download this plugin? I´m serching everywhere, but I can´t find the way. Thanks!!
ciudadanochano
Postby Gaieus » Mon Apr 05, 2010 1:53 pm
Hi Chano,
Plugins published on these forums are generally attached at the bottom of the very first post in their respective topics - in this case, download/install FAK.rb (or extract it from the FAK.rar archive also attached).
Administrator
SketchUp version: 8
License type: Pro
SketchUp use: historical reconstruction
Postby kienho » Fri Apr 09, 2010 6:59 am
Thank you Wikii! Your plugin helps me alot in modeling.
kienho
Postby Mike1158 » Fri Apr 09, 2010 8:31 am
Not working here.
Mike1158
Postby Tim Danaher » Tue Apr 27, 2010 4:53 pm
Is FMAK supposed to smooth the result automatically?
I can't get this one to smooth -- the resulting sweep is nice, though...
Tim Danaher
Postby Jeff Hammond » Tue Apr 27, 2010 5:26 pm
rainfrog wrote:Basically, I want a profile to follow a path much like in the FollowMe and keep plugin, but in a way that preserves the proportions of the profile perpendicular to the path, whether that path is level or on a slope.
hey rainfrog,
that's possible using the extrude along path tool in the 1001bit suite
http://www.1001bit.com/
followmeproblem_fixed.skp
dotdotdot
Jeff Hammond
Global Moderator
Operating system: Mac
SketchUp version: 8
License type: Pro
Postby Pilou » Tue Apr 27, 2010 6:28 pm
You can use also the TIG Extrude Edges by Rails by Face ;)
and maybe 2 faces + Path by Kirill2008
Speedy Galerie
Pilou
Top SketchUcator
SketchUp version: 6
License type: Free
SketchUp use: hobby
Postby xrok1 » Tue Apr 27, 2010 6:28 pm
the native follow me tool works this way???? did you try it?
“There are three classes of people: those who see. Those who see when they are shown. Those who do not see.”
xrok1
Postby Jeff Hammond » Tue Apr 27, 2010 6:49 pm
Pilou wrote:You can use also the TIG Extrude Edges by Rails by Face ;)
they won't keep the bottom flat though.. i'm pretty sure 1001bit is the only ruby solution for this particular scenario.
dotdotdot
Jeff Hammond
Global Moderator
SketchUp version: 8
License type: Pro
Postby xrok1 » Tue Apr 27, 2010 6:53 pm
i downloaded his file and to me 1001bit and native follow me are identical, except 1001 triangulates. :?
xrok1
Postby thomthom » Tue Apr 27, 2010 6:54 pm
FollowMeAndKeep?
Global Moderator
SketchUp version: 8
License type: Pro
Postby xrok1 » Tue Apr 27, 2010 6:56 pm
FollowMeAndKeep?
FAK "squashes" the profile going up hill because it doesn't rotate.
xrok1
Postby Tim Danaher » Tue Apr 27, 2010 7:02 pm
I'm not having much luck with this at all...
Trying to sweep a spiral stair rail. I've got the path running smack through the midpoint of the balusters, and the profile lined up as centrally as possible, but the resulting handrail is never on the path.
The original path & Profile are in one group in the attached .skp, the resulting sweep in another...
Anyone point me to where I'm going wrong?
Ta,
Tim Danaher
Postby Jeff Hammond » Tue Apr 27, 2010 7:03 pm
xrok1 wrote:i downloaded his file and to me 1001bit and native follow me are identical, except 1001 triangulates. :?
check this comparison..
fm_vs_1001.skp
[edit] oh, regarding the 1001bit triangulation.. i run the deletecoplanaredges ruby on it afterwards.. found here..
http://www.cad-addict.com/2009/07/sketc ... edges.html
dotdotdot
Jeff Hammond
Global Moderator
SketchUp version: 8
License type: Pro
Postby Jeff Hammond » Tue Apr 27, 2010 7:19 pm
Tim Danaher wrote:I'm not having much luck with this at all...
Ta,
i really don't know what's going on there Tim and i don't have FAK.rb installed anymore but i tried it with the 1001bit extrude and it worked out..
that said, we're talking a $30 tool set vs. a free plugin so...
TD_baluster.skp
dotdotdot
Jeff Hammond
Global Moderator
SketchUp version: 8
License type: Pro
Postby Tim Danaher » Tue Apr 27, 2010 7:28 pm
Ta,
TD_baluster.skp
Thanks, Jeff -- Nice result... will have to pony up the dosh, then... :o
Tim Danaher
Postby xrok1 » Tue Apr 27, 2010 7:45 pm
Ta,
TD_baluster.skp
thanks for clearing that up Jeff. i hadn't noticed that detail. i thought he was refering to the height difference on the slopes. :oops:
xrok1
Postby Tim Danaher » Thu Apr 29, 2010 11:18 am
Tim Danaher wrote:
Jeff Hammond wrote:i really don't know what's going on there Tim and i don't have FAK.rb installed anymore but i tried it with the 1001bit extrude and it worked out..
TD_baluster.skp
Hah! No I won't... the developers have made it free for academic use, and since I teach SU at a design school... :berserk:
Tim Danaher
Postby Pilou » Thu Apr 29, 2010 1:06 pm
a $30 tool
It's free if you use it for personnal use :fro:
You will have just a starting message ;)
Speedy Galerie
Pilou
Top SketchUcator
SketchUp version: 6
License type: Free
SketchUp use: hobby
Postby xrok1 » Thu Apr 29, 2010 3:05 pm
it says 30 day trial period on mine?
xrok1
Keyframe Animation plugin - animate your SketchUp model by adding movement to any object.
PreviousNext
Return to Plugins
Users browsing this forum: Bing [Bot], entity66, fran ruggeri, gromatic, heomad, katajag and 12 guests
