[Plugin] FollowMe and keep (v0.04 update 20090210)
FollowMe and keep the dirction of profiles.
Tip:construction point in selection will be treated as the align_point!
v0.04 20090210
1 if path started at a vertex of profile,the vertex will be treated as align point.
2 auto reverse face to get directviewing result.v0.03 20090209
1 start at nearest vertex when path is closed
2 fix some bugsv0.02 20090208
1 perfect ending;
2 autosmooth.
Wow that was quick...I will give it a whirl... Thank you.
I dropped Fak.rbs into plugins folder but it does not show up.
not sure if im doing something wrong but i cant see it in the plugins menu...
Terrible!!!
PS Is it only for pro version? Because I see nothing on the Plugins menus free V6, V7
Tried on the other comp... same thing.
open fak.skp,
follow the text in the each page. -
could you help me ?
I don't see any FAK command in the plugins menu after extracting the FAK.rbs file in my Plugins directory. -
It does not show in plugins.
Wikii, if its any use this is what i get when i try and load it from the ruby console:
load "FAK.rbs" Error: #<SyntaxError: (eval):131:in `load': C:/Program Files (x86)/Google/Google SketchUp 7/Plugins/FAK.rbs:1: no .<digit> floating literal anymore; put 0 before dot RBS1.0 ^ C:/Program Files (x86)/Google/Google SketchUp 7/Plugins/FAK.rbs:1: syntax error RBS1.0 ^ C:/Program Files (x86)/Google/Google SketchUp 7/Plugins/FAK.rbs:1: Invalid char `\030' in expression> (eval):131
Sorry , I did't test it without Sutool.
I have posted the fixed version,please download it again.
Yes ! now it works !
thank you. -
Works!
Works like a charm, thanks very much
in scene3 we have this at the end for the smallest surface.
Seems last at the end are false!
You can add a hori line at the end of curve to avoid it.
Not a big deal than you can erase it but... perfection is needed
I do not understand exactly the difference between the two first scenes.
See below the top view when I selelect parallel projection.
Yes but it is some tedious
Beauty is go to the endThe curious thing is all seems good till the previous module
[attachment=0:14ocmtqc]<!-- ia0 -->FAK_test_scene1.jpg<!-- ia0 -->[/attachment:14ocmtqc]In the second scene,there is a construction point at start of the curve.
