by kwistenbiebel » Fri Jan 30, 2009 4:58 pm
AcesHigh wrote:I dont know what is happening but Zorro 2 is constantly failing to make any cuts here.
in fact, sometimes it ABSOLUTELY refuses to cut anything... even simple models, be them grouped or completely exploded. It starts creating the line, but I click the other end of the line but the line doesnt goes away... it like if I was not clicking.
Did you delete the old zorro ruby from the plugins folder? That solved the issues I had.
kwistenbiebel
by Burkhard » Fri Jan 30, 2009 6:17 pm
Nice icon schorradt, but it does not work in parallel view ( on mac )
Burkhard
- Premium Member
- Operating system: Windows
- SketchUp version: 8
- License type: Pro
- SketchUp use: interior design
- Level of SketchUp: Advanced
by schorradt » Fri Jan 30, 2009 6:52 pm
yes i know  the parallel mode is a problem. but i hope to a better version in Zorro 2 ... with my Icon and Cursor  and the feature to find faces in Cut ... very nice.
schorradt
- Name: Henry Schorradt
by AcesHigh » Wed Feb 11, 2009 4:26 am
Whaat wrote:AcesHigh wrote:I dont know what is happening but Zorro 2 is constantly failing to make any cuts here.
Open the Ruby Console Window and tell me what error message you are getting. Thanks
Error: #<ArgumentError: Points are not planar> C:/Program Files (x86)/Google/Google SketchUp 7/Plugins/Zorro2.rb:273:in `add_face' C:/Program Files (x86)/Google/Google SketchUp 7/Plugins/Zorro2.rb:273:in `cut_geometry' C:/Program Files (x86)/Google/Google SketchUp 7/Plugins/Zorro2.rb:107:in `onLButtonUp' C:/Program Files (x86)/Google/Google SketchUp 7/Plugins/Zorro2.rb:273
AcesHigh
by bellwells » Wed Feb 11, 2009 7:19 am
Dale, when I click on a section cut and select the "Slice Model at Section" nothing happens. I've read the tutorial, but I can't figure out what I'm doing wrong. I only have Zorro2.rb in my Plugins folder so it can't be a conflict with the original one.
What a great feature this section option is!! I can't wait to get it working.
Ron
bellwells
- Name: Ron Wells
by Chris Fullmer » Wed Feb 11, 2009 7:31 am
After you do that Ron, try deleting the section plane. Your model should stay cut in half. I guess that is the desired functionality.
Chris
- SketchUp Team
- Name: Chris Fullmer
- License type: Pro
- SketchUp use: landscape architecture
by bellwells » Thu Feb 12, 2009 2:38 am
Hi Chris, I tried that but...no luck. I zorro sliced a cube, activated the section cut tool, selected "Slice Model at Section" and erased said section cut, but nothing. I'll keep fiddling around.
Edit: When I erase the section cut the model goes back to being "whole". The section cut always stays normal to the model surface not the Zorro cut.
Ron
bellwells
- Name: Ron Wells
by bellwells » Fri Feb 13, 2009 7:59 pm
The Slice Section feature does not work for me. I've even deleted and reinstalled.....no worky. Am I the only one with this problem?
Ron
bellwells
- Name: Ron Wells
by Chris Fullmer » Fri Feb 13, 2009 8:24 pm
Have you tried removing all other plugins except the new zorro?
Chris
- SketchUp Team
- License type: Pro
by bellwells » Fri Feb 13, 2009 9:14 pm
I hadn't thought to do this, but this didn't work either. Funny, I've never had any problems whatsoever installing and using plugins. I'm obviously doing something wrong.
I've invoked the slice-model option with the section cut plane inside and outside the model. I've tried grouping.....I've tried it with both drinking beer and not drinking beer....I've tried everything. Argggg...
Ron
bellwells
- Name: Ron Wells
by Chris Fullmer » Fri Feb 13, 2009 9:41 pm
So the option to slice the model (or whatever its called) does show up though, right? Try opening the ruby console and the running the slice. See if any error messages come up in the ruby console. If they do, post them here. BTW, what version of SU are you using this on?
Chris
- SketchUp Team
- License type: Pro
by Burkhard » Fri Feb 13, 2009 9:55 pm
[quote="bellwells"].. I zorro sliced a cube, activated the section cut tool, selected "Slice Model at Section" and erased said section cut, but nothing. quote] Try the simple way...leave Zorro and use just the Sketchup sectionplane. Select the plane after the end position and run the script. For me it has nothing to do with zorro
Burkhard
- Premium Member
- License type: Pro
by Chris Fullmer » Fri Feb 13, 2009 10:16 pm
Ahh, I second what burkhaard says. I don't start zorro first or anything. just make a section plane, then right click on it to find the slice option.
Chris
- SketchUp Team
- License type: Pro
by bellwells » Sat Feb 14, 2009 12:40 am
Oh, I see. I was thinking you could "zorro" the model in any plane desired and then R-click "slice section" to achieve a section cut normal to that plane.
Apparently this script does NOT work with my beer.
Edit: I changed beer and everything is working fine....Thanks.
Ron
bellwells
- Name: Ron Wells
by AcesHigh » Mon Feb 16, 2009 5:30 pm
AcesHigh wrote:Whaat wrote:AcesHigh wrote:I dont know what is happening but Zorro 2 is constantly failing to make any cuts here.
dont any of you guys know whats causing this?
AcesHigh
by Whaat » Mon Feb 16, 2009 5:43 pm
I have a theory. Can you post the SKP file please?
Whaat
- Name: Dale Martens
- License type: Pro
- SketchUp use: architecture
by AcesHigh » Tue Feb 17, 2009 4:11 am
here it is
AcesHigh
by AcesHigh » Fri Feb 20, 2009 1:58 am
hey Whaat, any thought on the matter? Thanks
AcesHigh
by Whaat » Fri Feb 20, 2009 3:53 am
AcesHigh wrote:hey Whaat, any thought on the matter? Thanks
Yes, your scene scale is too big. I won't get into the details, but the plugin will fail if you are using a huge scene scale. Your scene is about 10km across!
Whaat
- License type: Pro
by AcesHigh » Fri Feb 20, 2009 6:17 am
Whaat wrote:AcesHigh wrote:hey Whaat, any thought on the matter? Thanks
yup, it was supposed to be a sci-fi city. well, so you suggest that I scale down it. Haha, I cant even begin to understand whats the difference, to the PLUGIN, on the scale of the scene. Thanks for the help!
AcesHigh
by Free Agent » Mon Feb 23, 2009 1:53 pm
hey thanx for this, really speeds up the process of making a roof with hard modeled roof tiles the only suggestion i could make is that it explodes and groups everything it cuts through (at least in the case of similar components), because at present it is making separate unique components out of the indidual components it cuts through, increaseing the amount of components intances dramatically, and slowing down the drawing.
i then have to go in select all similar components, invert selection, group those, explode this groups contents and purge unused components, to get my component instances from 400 back to 1.
any thoughts
Free Agent
- Name: Sean
by Blugarero » Mon Mar 02, 2009 4:54 am
AWESOME PLUGIN. Especially when used with section cut plane...
Before I would have to explode all geometry and create a plane... then intersect with model, then erase everything I didn't need. On complex models this would take too long so I gave up. Now it took a minute at most on that same model.
Thank you!
Blugarero
by saurio » Tue Mar 03, 2009 6:45 am
Thanks Gracias Merçi Obrigado Dankeschön Grazie Efaristó
saurio
- Name: saurio
by jim_tim » Wed Mar 04, 2009 1:35 pm
Hi, I'm trying to do a section through a simple box just to test but every time I right click, then slice section plane it results in a bug splat. The model could not be more simple so I'm confused as to why it isn't working. Do I need to download another ruby?? I'm currently using SU7 pro
jim_tim
by Whaat » Wed Mar 04, 2009 5:22 pm
jim_tim wrote:Hi, I'm trying to do a section through a simple box just to test but every time I right click, then slice section plane it results in a bug splat. The model could not be more simple so I'm confused as to why it isn't working. Do I need to download another ruby?? I'm currently using SU7 pro
Please post the model. Thanks.
Whaat
- License type: Pro
by jim_tim » Thu Mar 05, 2009 4:23 pm
Hi, I think I worked out why it wasnt working. I had a 3ds component (toilet- high poly) in the box shape. Although the section plane wasn't through the component I don't think sketchup could cope with both the component and the procedure of taking a section. Is this normal for the ruby to make sketchup crash when using components? I guess in future projects I'll just take the section first then add components afterwards.
Jim
jim_tim
by sceyefeye » Wed Mar 11, 2009 10:06 am
hi there all, bit of a lurker on the forum
But I have to shout major kudos to whaat! You have just saved me mucha mulah! I was thinking about selling my car or something to purchase IRenderXT just to be able to render cut-away views eg 3d plans. As someone said earlier, too much hassel to creat cut sections and then delete what I don't need to take things into Kerkythea. Now hey it is simple as, well I don't think it gets much simpler
One thing though, I can get the section cut through model part working - the major bonus for me. But I literally only get a zoro entry in the tools drop down. According to your screen shots there seem to be some submenus and such, but none of that here. XP SP3 SketchUP 7 free. (Since discovering DoubleCAD I no longer need the pro file exports to go to CAD)
Anyway, a million thanks for something this useful and powerful
sceyefeye
- Name: Simon Dahl
by Whaat » Wed Mar 11, 2009 3:22 pm
sceyefeye wrote:According to your screen shots there seem to be some submenus and such, but none of that here.
I'm confused. I don't think I have posted any screenshots of the menu. There should only be one menu item in the Tools menu. Glad you like the plugin!
Whaat
- License type: Pro
by lapeno82 » Mon Mar 30, 2009 6:58 pm
OMG It really works!!!!  (with my 3billion entities with components in components in components etc.) and really really fast aswell!!! I'm so happy! You sir are a genius!
lapeno82
Need Authorised SketchUp Training by experts in various disciplines? Check out our Training details.
- Robot
Return to Plugins
