[Plugin] Zorro2 (beta)Re: [Plugin] Zorro2 (beta)Gracias Senor Zorro. How can our village ever repay you?
Please, register (free) to access all the attachments on the forums. If I make it look easy. . .rest assured--it probably is.
Re: [Plugin] Zorro2 (beta)Quick one. I've deleted the old zorro ruby from plugins folder. How come under Tools menu I see 2 zorros?
I'm seeing the same thing Chango70... "Success consists of going from failure to failure without loss of enthusiasm." - Churchill
Re: [Plugin] Zorro2 (beta)Its not just Zorro. I've deleted a redundent obj importer (can't remember which) yet it still shows up in my menu?!?
Re: [Plugin] Zorro2 (beta)It may have been Jim's obj importer (at least that's the only one I know of)
Re: [Plugin] Zorro2 (beta)I added a Feature to your old Version (1.0) to automatic fill faces cut
Sketchup::set_status_text("Draw cut line, Push SHIFT to: Fill-Face-Automatic", SB_PROMPT) maybe you can added in your current Version? here is the Code.Snipped:
__________________________
http://blog.simkea.de/
Thanks! I actually experimented with this feature, as well. However, I found that half the time, the faces that were automatically created were reversed, which became quite annoying. I suppose I could give the user the option if a certain key is pressed (as you have shown). The shift key would not work since it used for inference locking.
Re: [Plugin] Zorro2 (beta)Here is my modifed Version of Zorro 1.0.
with Icons Plz use it... and please forgive me, that I did without asking changed. my Changes: - Icon and Cursor - Press: Shift -> Fill Faces to Cut - Automatic Switch zu perspectiv-view-mode Please, register (free) to access all the attachments on the forums. __________________________
Re: [Plugin] Zorro2 (beta)Amazing!!!
in the past Zorro.rb has been a really cool toy (and quite an addictive one at that). but now with its parallel-projection capabilities and especially it's section-cut function Zorro is a valuable and indispensable tools (one of those 'how did we manage to live without it'-tools). absolutely fantastic, accurate and extremely fast! I love it!!! ![]()
LOL thats it!
Re: [Plugin] Zorro2 (beta)So how do u get rid of it then?
Re: [Plugin] Zorro2 (beta)I don't know. I have a fairly freash install of Windows (and all that follows) so my Plugins folder is still pretty virgin (about 3 or 4 new plugins ever since).
Ask Jim maybe. Gai...
Re: [Plugin] Zorro2 (beta)I dont know what is happening but Zorro 2 is constantly failing to make any cuts here.
in fact, sometimes it ABSOLUTELY refuses to cut anything... even simple models, be them grouped or completely exploded. It starts creating the line, but I click the other end of the line but the line doesnt goes away... it like if I was not clicking.
Open the Ruby Console Window and tell me what error message you are getting. Thanks
Did you delete the old zorro ruby from the plugins folder? That solved the issues I had.
Re: [Plugin] Zorro2 (beta)Nice icon schorradt, but it does not work in parallel view ( on mac )
Re: [Plugin] Zorro2 (beta)yes i know
but i hope to a better version in Zorro 2 ... with my Icon and Cursor and the feature to find faces in Cut ... very nice. __________________________
Error: #<ArgumentError: Points are not planar> C:/Program Files (x86)/Google/Google SketchUp 7/Plugins/Zorro2.rb:273:in `add_face' C:/Program Files (x86)/Google/Google SketchUp 7/Plugins/Zorro2.rb:273:in `cut_geometry' C:/Program Files (x86)/Google/Google SketchUp 7/Plugins/Zorro2.rb:107:in `onLButtonUp' C:/Program Files (x86)/Google/Google SketchUp 7/Plugins/Zorro2.rb:273 Please, register (free) to access all the attachments on the forums.
Re: [Plugin] Zorro2 (beta)Dale, when I click on a section cut and select the "Slice Model at Section" nothing happens. I've read the tutorial, but I can't figure out what I'm doing wrong. I only have Zorro2.rb in my Plugins folder so it can't be a conflict with the original one.
What a great feature this section option is!! I can't wait to get it working. Ron
Re: [Plugin] Zorro2 (beta)After you do that Ron, try deleting the section plane. Your model should stay cut in half. I guess that is the desired functionality.
Chris
Re: [Plugin] Zorro2 (beta)Hi Chris, I tried that but...no luck. I zorro sliced a cube, activated the section cut tool, selected "Slice Model at Section" and erased said section cut, but nothing. I'll keep fiddling around.
Edit: When I erase the section cut the model goes back to being "whole". The section cut always stays normal to the model surface not the Zorro cut. Ron
Re: [Plugin] Zorro2 (beta)The Slice Section feature does not work for me. I've even deleted and reinstalled.....no worky. Am I the only one with this problem?
Ron
Re: [Plugin] Zorro2 (beta)Have you tried removing all other plugins except the new zorro?
Chris
Re: [Plugin] Zorro2 (beta)I hadn't thought to do this, but this didn't work either. Funny, I've never had any problems whatsoever installing and using plugins. I'm obviously doing something wrong.
I've invoked the slice-model option with the section cut plane inside and outside the model. I've tried grouping.....I've tried it with both drinking beer and not drinking beer....I've tried everything. Argggg... Ron
Re: [Plugin] Zorro2 (beta)So the option to slice the model (or whatever its called) does show up though, right? Try opening the ruby console and the running the slice. See if any error messages come up in the ruby console. If they do, post them here. BTW, what version of SU are you using this on?
Chris
Re: [Plugin] Zorro2 (beta)[quote="bellwells"].. I zorro sliced a cube, activated the section cut tool, selected "Slice Model at Section" and erased said section cut, but nothing. quote]
Try the simple way...leave Zorro and use just the Sketchup sectionplane. Select the plane after the end position and run the script. For me it has nothing to do with zorro
Re: [Plugin] Zorro2 (beta)Ahh, I second what burkhaard says. I don't start zorro first or anything. just make a section plane, then right click on it to find the slice option.
Chris
Re: [Plugin] Zorro2 (beta)Oh, I see. I was thinking you could "zorro" the model in any plane desired and then R-click "slice section" to achieve a section cut normal to that plane.
Apparently this script does NOT work with my beer. Edit: I changed beer and everything is working fine....Thanks. Ron
SketchUcation One-Liner AdvertsNeed SketchUp Books, Models, Styles or Textures? Check out our One Stop Shop for SketchUp.
