SketchUcation Plugin Store
[Plugin] Zorro2 (beta)
Re: [Plugin] Zorro2 (beta)
Postby TIG » Sat Mar 31, 2012 12:01 pm
Do you have any of these other plugins installed?
They might ill-advisedly overwrite some native class/methods and cause issues with legit scripts.
    SketchyPhysics
    DrivingDimensions
    Matchbox
    Solar[***+ something or other]
    Some versions of Podium
    Any other 'unusual' scripts you've recently installed???
If so, try disabling them all [move their .rb/.rbs files out of Plugins temporarily and restart Sketchup...
Move them back in one at a time until the culprit is found - then you must choose between Zorro and that other tool auto-loading...
Report back...
Global Moderator
Operating system: Windows
SketchUp version: 8
License type: Pro
SketchUp use: architecture
Level of SketchUp: Advanced
Postby dropemjackem » Mon Apr 30, 2012 7:15 am
having trouble opening it not sure wich file to use to open keeps tryin to open in sketchup
dropemjackem
Postby TIG » Mon Apr 30, 2012 11:49 am
dropemjackem wrote:having trouble opening it not sure wich file to use to open keeps tryin to open in sketchup
Do you have any idea how to install a plugin ?
There are several good help pages on this...
You do not need to 'open' it.
In the case of a single .rb file like this you just put it into your Sketchup Plugins folder [ensure you have suitable access-rights to do this].
Now restart Sketchup and the tool auto-loads and becomes available to use.
Read [and follow] its usage instructions available on the download page.
Note that a .rb file is just a kind of 'text file', if anything you should associate its opening with Notepad.exe, that way you can open the file and read the first part, which is often its usage instructions etc too...
Tools that are more complex often come inside a .zip file and consist of several 'parts' which need 'extracting' before they are 'installed' - again there are lots of useful pages on doing this - but let's not run before we can walk and leave this for another day ;)
Global Moderator
SketchUp version: 8
License type: Pro
Postby thomthom » Mon Apr 30, 2012 11:53 am
Generic installation guide: http://www.thomthom.net/thoughts/2012/0 ... -sketchup/
Global Moderator
SketchUp version: 8
License type: Pro
Postby rks218 » Tue May 08, 2012 7:40 am
does anyone know how to download the given .rb, I went to Window > Preferences > Extensions, and
checked all the boxes; but Im still not sure how to download the plugin. thanks
rks218
Postby TIG » Tue May 08, 2012 10:44 am
rks218 wrote:does anyone know how to download the given .rb, I went to Window > Preferences > Extensions, and checked all the boxes; but I'm still not sure how to download the plugin. thanks
Please see thomthom's recent post in this thread for a helpful link... [he has also made a 'simple-installer' that lets you 'auto' install many kinds of downloaded files/archives more easily...]
The Preferences Extension installer only works on 'archives'*** [that is .rbz files which are a kind of .zip file].
Once you have downloaded such a file then you can run the installer on it.
Also if a downloaded file is a .zip, then you can rename it as a.rbz and it'll work that way too...
Complex toolset usually com as 'archives'.
A rbz/zip archive is a collection of files and subfolders, which need to be extracted and put into the Sketchup Plugins folder in the same relative relationship - the v8M2 installer assists you, but in all prior versions you has to do this installation 'by hand'...
B U T - now read this carefully - ***the Zorro tool is relatively simple and it comes in a single .rb file; this is easy to install: simply download it by clicking its link and specifying its destination folder on your computer... and then move that .rb file into the Sketchup Plugins folder, then restart Sketchup to auto-load the tool - it should then appear in the the specified menu - follow the tool's usage instructions...
Global Moderator
SketchUp version: 8
License type: Pro
Postby fcbschwein » Mon May 28, 2012 9:02 am
superb!
fcbschwein
Postby masum_nobi » Fri Jun 08, 2012 9:27 am
Thanks....... :sketchstatic:
masum_nobi
Postby bobpineo » Fri Sep 14, 2012 2:38 pm
Whaat!
thank you so much for making this plugin!
I been using SU for about 8 years now, and I do projects in a variety of scales and for different project types...
Zorro is one of the most useful plugins I have (and I have alot!).
Very simple, but very very powerful.
Thank you for thinking of it.
Bob
Bob Pineo, Design Develop LLC http://www.designdevelop.org.
bobpineo
Premium Member
Premium Member
SketchUp version: 8
License type: Pro
Postby volatile_ant » Sun Oct 21, 2012 6:55 am
This is a great plugin, thanks for sharing!
Now for a question: Maxwell render has the ability to hide groups from the camera, essentially allowing a real-light section perspective to be rendered (instead of holes in the model letting light in at the section cut).
Is it possible to keep the 'trash' geometry (what will eventually be 'hidden' in a rendering) and have the two halves of the model in two separate groups?
Being that I know enough about programming to get myself into trouble, but not enough to get myself out, I was able to modify your script so the 'Slice Model at Section' tool no longer deletes any geometry, but am completely lost when trying to end up with two groups at the end.
volatile_ant
Postby Keastone » Tue Oct 30, 2012 7:53 am
I'm trying to install Zorro2 on my mac. When I read the write ups on how to install it says a .rbz file is needed for SU8. Well I have SU8 but the only zorro2 file I can manage to find is the .rb file which is mentioned for SU7. I've tried both ways to install the plugin and neither seems to work. Any ideas?
Keastone
Name: Keaton A Ernst
Operating system: Mac
SketchUp version: 8
License type: Free
Postby TIG » Tue Oct 30, 2012 11:20 am
Keastone wrote:I'm trying to install Zorro2 on my mac. When I read the write ups on how to install it says a .rbz file is needed for SU8. Well I have SU8 but the only zorro2 file I can manage to find is the .rb file which is mentioned for SU7. I've tried both ways to install the plugin and neither seems to work. Any ideas?
You are misconstruing things.
I have never seen anywhere saying you HAVE to have a RBZ archive to install a script in v8 - rather it says that with v8 there is an additional format of archive [RBZ] devised to assist in a simple automated installation... obviously this has only confused some of you :roll:
Version 8 CAN automate the installation of toolsets that are packaged as RBZ archives.
BUT this in no way precludes you from manually installing RB/RBS, or any files or subfolders of files that have been properly extracted from a ZIP archive [an RBZ is simply a ZIP file with its filetype suffix changed!] Thomthom has made a v8 'Simple Plugins Installer' that automates the installation of all such file/archive types - get it from the Resources > Plugins Index. It'll stop you over thinking things.
Since this tool here comes as a simple RB file [i.e. there are no complications of support files in subfolders - additional helper files, toolbar/webdialog files and the like] - thomthom's tool can easily auto-install it for you. Alternatively you can simply drop this lone RB file into your MAC's 'plugins' folder, and restart SketchUp... However, I still recommend thomthom's solution as it applies to all types with little effort/though on your part... This method will also avoid some MAC issue where a user installs a plugin manually into the 'plugins' folder and it doesn't work - because he's not used the correct folder in the HD Lib path, rather using the wrong folder in the 'User' Lib path.
Incidentally ensure that you have FULL access-rights permissions to that 'plugins' folder, because you need it to install files but some tools need to write log-files or make/write to their own subfolders etc with that folder - and limited access-rights can cause issues...
Global Moderator
SketchUp version: 8
License type: Pro
Postby kevo » Tue Oct 30, 2012 5:20 pm
I'm going to try this when I get chance, many thanks.
Can I use a curved sandbox plane as shaped cutting plane? Either with this, or some other plugin, btw?
kevo
Postby Gaieus » Tue Oct 30, 2012 6:05 pm
No, Zorro2 will use the section plane as a cutting plane and that is always flat by nature. I cannot think of another plugin that would perform such a cutting operation now (this does not mean it does not exist) and of course, a manual intersection may be extremely tedious with complex geometry and/or lots of nested elements in groups/components.
Some boolean tools may make it easier but still, nested things can be an obstacle.
Administrator
SketchUp version: 8
License type: Pro
SketchUp use: historical reconstruction
Postby vanderbijlps » Fri Nov 30, 2012 9:09 am
Firstly - Awesome plugin!!! Well done and thank you very much for sharing
I get a bugsplat every time I've tried to use Zoro2. Then went through the exercise of disabling all my plugins one at a time. The problem is caused by the SU Podium plugin - the moment I disable it, Zoro2 works!
Any way around this?
Kind regards
PvdB
vanderbijlps
Postby Pilou » Fri Nov 30, 2012 10:01 am
Make 2 folders "Plugins" one with Podium, and one without it ;)
And rename them when you want use Zorro2 ;)
Speedy Galerie
Pilou
Top SketchUcator
SketchUp version: 6
License type: Free
SketchUp use: hobby
Postby DesertRaven » Fri Dec 07, 2012 7:27 pm
Gaieus wrote:No, Zorro2 will use the section plane as a cutting plane and that is always flat by nature. I cannot think of another plugin that would perform such a cutting operation now (this does not mean it does not exist) and of course, a manual intersection may be extremely tedious with complex geometry and/or lots of nested elements in groups/components.
Maybe it is a good idea to create SU models with cleaned up geometry in general as a code of good conduct. That way you can, via boolean subtract, make any section of any shape you wish.
Also I don't understand why in SU version 8 they have not gotten it together to fix the section tool so that it makes filled up solid section or sections with a hatch pattern??
Why we need another plug in for this basic function, which already exists, is beyond me!
simplicity is the ultimate sophistication
DesertRaven
Name: Olav Schneider
SketchUp version: 8
License type: Pro
Postby Skwatz » Sun Dec 30, 2012 8:04 pm
the reason why sketchup doesn't fil in the solids is because is doesn't is is a solid!
not even when you work with the boolean substract.
you draw lines and sketchup conect them with planes.
i can't be solved to my opinion, otherwise you need to change the fundaments of sketchup.
if you want a progame that works with volumetric and 'real ' boolean use 3ds max or autocad.
keeping your model clean is true but not easy at al, and when you use groups (like me) slicesing them is a hell of a job.
so...
Thx for this great plugin :D!!
Skwatz
Name: Alexander Vandenberghe
SketchUp version: 8
License type: Free
Postby cotty » Sun Dec 30, 2012 10:30 pm
Skwatz wrote:the reason why sketchup doesn't fil in the solids is because is doesn't is is a solid!
There are solid tools, so there have to be solids too ;)
A picture is worth a 1000 words. A 3D SketchUp model is worth a (1e3)^2 words?!
my little gallery
cotty
Top SketchUcator
SketchUp version: 8
License type: Free
SketchUp use: education
Postby DesertRaven » Tue Jan 01, 2013 12:11 am
so...
Dude, you are completely wrong or you are just not doing it right, the last time I did a section with boolean subtract, there were faces in the section! :lol:
Also it is very easy to keep your geometry clean by just paying attention to what you are doing and not being sloppy and lazy. (I constantly get models from other companies especially architects, that are just F>U>B>A>R> because they don't even care to learn their S*@t.
And No sir I'm not going to buy 3D MAX or any other tool just because sketchup is a "half assed" software that just needs some fixing.
Sketchup has all it needs to be an outstanding tool, there are just some things that never got fixed and I'm not talking about adding more commands and buttons, just fixing what there is already would be a leap into the right direction.
DesertRaven
SketchUp version: 8
License type: Pro
Postby svadilfari » Fri Feb 01, 2013 12:46 pm
Hey guys,
I am trying to cut my model, everytime there is a bug and SU crashes down?
Any solutions, advices?
It is quite complicated model with a lot of components and materials, could it be that?
svadilfari
SketchUp version: 8
License type: Pro
Postby Pilou » Fri Feb 01, 2013 1:22 pm
Without post your model (save as V6) it's impossible to say something :)
Speedy Galerie
Pilou
Top SketchUcator
SketchUp version: 6
License type: Free
SketchUp use: hobby
Postby TIG » Fri Feb 01, 2013 1:24 pm
You answer is in your question.
Zorro isn't magic.
If there are zillions of 'containers' contents to cut it only needs to trip up once for a splat!
Because the process is destructive you are presumably working on a copy of the original SKP and you probably have little use for its 'structure' of groups/instances...
So, in that copy, why not explode all containers in the active model [iterating until there are none in the Outliner - that's an easy way to select them...]
Also erase all hidden layers and their contents etc... and all hidden objects too [if any]/
Also purge the model of unused things... this will speed up what it has to look through when 'cutting'...
Now retry on the slimline group-free version of the SKP.
It should be much quicker and less prone to failure...
Global Moderator
SketchUp version: 8
License type: Pro
Postby qianyi » Mon Mar 11, 2013 10:53 am
my schoolmate recommend me this plugin,seems useful ,looking forward! :ecstatic:
qianyi
SketchUp version: 8
License type: Pro
Postby Ronnie » Sun Mar 17, 2013 8:59 pm
Would be pretty cool if you could also split at section plane, but without deleting anything, like inserting a 10mm gab or whatever at the intersection of the section plane.
Very useful for cutting a model up for 3d printing.
Ronnie
Postby jolran » Sun Mar 17, 2013 9:32 pm
You can by right clicking section plane, create groups from slice. But it doesent destroy original group.
jolran
SketchUp version: 8
License type: Pro
SketchUp use: other
Postby Box » Sun Mar 17, 2013 9:33 pm
Or use tigs slicer.
Opinions are like wives.
Those found on the internet have been known to contain varying traces of nuts!
SketchUp version: 8
License type: Free
SketchUp use: other
Postby Ronnie » Sun Mar 17, 2013 10:02 pm
jolran wrote:You can by right clicking section plane, create groups from slice. But it doesent destroy original group.
Thanks.
Ronnie
Postby Da Man » Wed Mar 27, 2013 3:44 am
I'm new to this. where does this plugin? my sketchup 8 only has .rbz plugins
Da Man
SketchUp version: 8
License type: Free
Level of SketchUp: Beginner
Postby olishea » Wed Mar 27, 2013 5:39 am
Da Man wrote:I'm new to this. where does this plugin? my sketchup 8 only has .rbz plugins
C:\Program Files\Google\Google SketchUp8\Plugins
oli
olishea
Premium Member
Premium Member
Need SketchUp Books, Models, Styles or Textures? Check out our One Stop Shop for SketchUp.
PreviousNext
Return to Plugins
Users browsing this forum: OrinHin, radiacor and 8 guests
