SketchUcation Premium Membership
[Plugin] 1001bit Tools - Architectural tools for SketchUp
Re: Find!!! - Architectural tools for SketchUp
Postby fakircho » Thu Feb 05, 2009 12:29 pm
Thanks for the inference addition to the wall tool.
I hate to be difficult but can it work the same way as the rest of the Sketchup tools. That is
when you pint with your mouse it should pick up the red or green axis and then you lock it with the shift key? That would be perfect :berserk:
fakircho
Postby GOHCH » Thu Feb 05, 2009 2:30 pm
dizain wrote:Error:
No such file to load -- C:/Program Files/Google/Google SketchUp 7/Plugins/1001bit/1001bit_loader.rb
hi dizain,
can you double check whether you have moved the 1001bit_loader.rb file to the Plugins folder?
1001bit_loader.rb file should be in 1001bit folder while
1001bit_tools.rbs file should be in Plugins folder.
thanks
GOHCH
Name: Goh Chun Hee
Postby Aidus » Thu Feb 05, 2009 2:34 pm
Well I rather do all work by myself organized like I want it :)
CPU: Intel Core i7 Extreme Edition 965
RAM: OCZ Gold DDR3 1600MHz 12Gb
Video: Asus Radeon HD4870 X2 2Gb
Mobo: Asus P6T Deluxe 1366 Intel X58
Aidus
Postby dizain » Thu Feb 05, 2009 5:48 pm
Hi GOHCH,
the files are in the folders as specified but the error continues ...
the file 1001bit_tools.rbs must be in both folders, 1001bit and Plugins folder?
dizain
Postby dizain » Thu Feb 05, 2009 5:56 pm
For GOHCH
My folders...
dizain
Postby fakircho » Fri Feb 06, 2009 8:52 am
Some questions about the stair components. Will it be possible to have some attribute options
on a stair so that you can select different handrails for example and also give it some parametric options
or would one always have to make a new stair if changes are needed ?
fakircho
Postby GOHCH » Sat Feb 07, 2009 8:28 am
dizain wrote:For GOHCH
My folders...
hi dizain,
i believe it's the path/language:
please use notepad to edit the 1001bit_path_win_su7.rb file in Sketchup's plugins folder.
change the path
$GH1001bit_path="C:/Program Files/Google/Google SketchUp 7/Plugins/1001bit"
to
$GH1001bit_path="C:/Programmi/Google/Google SketchUp 7/Plugins/1001bit"
cheers!
GOHCH
Name: Goh Chun Hee
Postby GOHCH » Sat Feb 07, 2009 8:34 am
fakircho wrote:Some questions about the stair components. Will it be possible to have some attribute options
hi fakircho,
Current tools creates a new set of staircase and doesn't allow for real time editing of parameters.
As for handrails, you can use the vertical wall tool to create handrails. (the vertical wall tool can allow for selection of custom drawn profile)
meanwhile, i am working on a handrail tool that can extrude along curve-twist path correctly.
cheers!
GOHCH
Name: Goh Chun Hee
Postby dizain » Mon Feb 09, 2009 10:45 am
Everything works ok ...
For the cost of the plugins?
Thanks Gohch.
dizain
Postby GOHCH » Mon Feb 09, 2009 3:11 pm
dizain wrote:Everything works ok ...
Thanks Gohch.
hi dizain,
Don't want to charge anything until i've sorted out the Mac version, and make sure that it is stable.
after that we'll have to put a stop to the free license.
The current beta test license is valid without time limit for this version of 1001bit tools.
Mac users can register for beta test license now and keep it for the Mac version later.
(sorry guys, still waiting for may macbook.... no stock, i hope they can deliver soon...)
As for retail price of 1001bit... :| :| :| please let me keep it secret for a little while longer. :roll: :roll: :roll:
cheers! :D
GOHCH
Name: Goh Chun Hee
Postby Burkhard » Mon Feb 09, 2009 5:29 pm
Hope with the same license or should I register again?
I've had registered earlier but I'm a Mac user.
Burkhard
Premium Member
Premium Member
Operating system: Windows
SketchUp version: 8
License type: Pro
SketchUp use: interior design
Level of SketchUp: Advanced
Postby GOHCH » Tue Feb 10, 2009 4:50 pm
Burkhard wrote:Hope with the same license or should I register again?
hi Burkhard,
No need to register again. The activation key for windows and mac will be the same.
cheers!
GOHCH
Name: Goh Chun Hee
Postby GOHCH » Mon Feb 16, 2009 2:39 pm
hi everyone,
The Mac compatible version of 1001bit tools is finally ready for download!
(version 1.1.2)
http://www.1001bit.com/freedownload.html
Following are the updates in this version:
1)Works on both Mac and Windows
2)Toolbars included
3)Inference added to vertical wall tool
4)Bug fix on roof tool
For those who has the previous version, just unzip into same location and overwrite the files.
Cheers and Have fun!
GOHCH
Name: Goh Chun Hee
Postby Burkhard » Mon Feb 16, 2009 7:11 pm
Hi Gohch, thanks for the fast update. Have a nice time on Mac.
How to install on Mac ? ( The folder contains no 1001bit_loader.rbs just the 1001bit_loader.rb ) You mentioned before that the .rbs should go under Plugins while the .rb go into the 1001bit folder )
Burkhard
Sorry, I just noted you're faq has been updated, thanks
Burkhard
Premium Member
Premium Member
SketchUp version: 8
License type: Pro
Postby utiler » Tue Mar 10, 2009 1:28 am
Hi Goh Chun Hee,
Firstly, pardon my asking but can you tell me your first name? Or is it Goh or Goh Chun? I don’t want to be rude and get it wrong….
I have been playing with the 1001bits tools quite a bit and find them fantastic!!! I’m glad I stumbled across them, I guess you are being inundated with requested and comments via the pushpullbar and SCF forums….
I have a few questions about a couple of the tools.
Selection method…
I note that for some functions you need to select the face first then select the function whereas others require the function to be set up first then select the face. This would be much easier if the process was consistent across the board. Eg: select face first or set up function first.
Edits and Modify tools
I know you have an extend tool for lines but what I would like to see is a tool for lines and or faces to extend to a plane. Eg: say you have a roof of 5 degrees and you want the walls to extend and trim to the underside of the roof plane.
• Select faces and or edges of the top of wall
• Select face to extend to [whether in the group or not]
• Walls extend and clean up to the cut plane…..
Horizontal / Vertical Louvres
I think these need to have the option of a ‘zero’ thickness as the window and door functions do. This allows for painting a translucent material to a plane rather than having to paint both front and back…
Roof
I love this tool!!!! However, have you thought about creating a setup tool to create the selection face to define the roof? I know there is a ‘roof.rb’ tool created by TIG viewtopic.php?f=153&t=3470 which creates the whole roof profile. All you would need is to write a script that asks for
• Roof pitch
• Overhang length[vertical or sloping fascia]
• Skillion, Gable or hip roof
Also, give the option in the dialogue box to toggle on or off rafters or purlins. This would make the tool more flexible for use with structural steel buildings…..
And another idea; I note that the screens and grills tool allows for a profile to be selected. This would be fantastic to integrate into the rafters or purlins tool for such members as ‘I’ beams, ‘C’ and ‘Z’ purlins…. In the case of purlins, the ultimate would be for a line profile to be selected as they are generally 1.2mm thick and it makes not sense to create additional faces than needed.
BTW, as for the version, can you advise what version is current? I have 1.1.0 registered to utiler. [Windows]
Thanks again, I look forward to hearing from you soon….
utiler
Top SketchUcator
SketchUp version: 8
License type: Pro
SketchUp use: architecture
Postby GOHCH » Wed Mar 11, 2009 4:44 pm
hi Andrew,
Thanks for the detailed suggestions.
Most ppl call me Goh (which is actually family name) i'm perfectly happy to be called by that, easier to remember.
version 1.1.2 works both for Windows and Mac. in fact. i'll be putting up version 1.1.3 in the weekend (after i've finished with some minor touchups)
version 1.1.3 will include an extrude tool, which will extrude selected face profile through curved and sloping path(edges).
SU's standard followme has the problem of twisting the profile along the way,
this extrude tool will fix that.
Meant for extruding handrails for spiral staircases and curved car park ramps.
also the louvres in v1.1.3 will have the option of 0 thickness, single face louvres.
there's also a newly added slope edges tool which is creates or modify selected edges to a fixed gradient.
I hope to put it up for download by Sunday.
The activation keys for version 1.1.0 is still valid (will remain valid for all version 1.1.x).
cheers!
Goh C H
GOHCH
Name: Goh Chun Hee
Postby utiler » Fri Mar 13, 2009 3:16 am
Goh,
Having a problem with Dividing panels..... [see attached]
Each time I set my parameters then select the face, the panel is placed at the axis origin. What am I doing wrong!!!
Cheers
utiler
Top SketchUcator
SketchUp version: 8
License type: Pro
Postby GOHCH » Fri Mar 13, 2009 12:58 pm
utiler wrote:Goh,
Cheers
hi utiler,
can you send me the skp file? (if the file is big, just a skp file containing the problematic face will do.)
Thanks & cheers!
GOHCH
Name: Goh Chun Hee
Postby thomthom » Fri Mar 13, 2009 1:01 pm
utiler wrote:Goh,
Cheers
That's the same problem I had with horizontal louvres. vertical works fine oddly enough. Open the Ruby Console and see if you get any messages.
Global Moderator
Name: Thomas Thomassen
SketchUp version: 2013
License type: Pro
Postby GOHCH » Fri Mar 13, 2009 5:43 pm
utiler wrote:Goh,
Cheers
hi utiler,
The panel divider is meant for dividing a face into a few segments;
1 row and 1 column will be the minimum.
1 row and 0 column doesn't really make sense, hence the failure.
I'll put in checking mechanisms in the dialog boxes in future so that undesired entry are either corrected or highlighted to the user.
cheers!
GOHCH
Name: Goh Chun Hee
Postby GOHCH » Fri Mar 13, 2009 6:24 pm
thomthom wrote:That's the same problem I had with horizontal louvres. vertical works fine oddly enough. Open the Ruby Console and see if you get any messages.
hi thomthom,
you're right, there's a bug there. just emailed you the patched hlouvres.rbs file.
I'll put this in the version 1.1.3 release, hopefully tomorrow or day after.
cheers!
GOHCH
Name: Goh Chun Hee
Postby thomthom » Fri Mar 13, 2009 6:43 pm
:thumb: Excellent!
Global Moderator
License type: Pro
Postby utiler » Sat Mar 14, 2009 4:07 am
Thanks Goh, I'll go try it out..... I assumed 1 row or 1 column would add a mullion or transom to the panel...
utiler
Top SketchUcator
SketchUp version: 8
License type: Pro
Postby utiler » Sat Mar 14, 2009 4:16 am
I did try that Goh but still the problem is occurring. I will PM you the .skp file and a short .swf file of the process.....
thanks!!!
utiler
Top SketchUcator
SketchUp version: 8
License type: Pro
Postby GOHCH » Sat Mar 14, 2009 6:36 am
hi Andrew,
really odd, because i have no problem using the panel divider tool on the same face that you seems to have problem with,
with the same settings.
utiler-dividepanel.swf
i'll try a few different configurations and see....
thanks
GOHCH
Name: Goh Chun Hee
Postby GOHCH » Sun Mar 15, 2009 6:11 am
hi everyone, version 1.1.3 is now ready for download.
Upgrades include:
1) Slope selected edges tool - converts selected edges to slope along a fixed gradient.
http://www.1001bit.com/products/slopeedges.shtml
user can enter:
- height difference
- angle (in degrees)
- gradient (as in 1 to 200)
- pick end level
This tool comes with an interactive dialog box that can be used to calculate angles, gradient, or height.
This tool can be used to create sloping path/driveway from flat plane.
2) Extrude along path tool - extrude profile along selected path.
http://www.1001bit.com/products/extrude1.shtml
This tool solves the twisting problem that occurs when you extrude a profile along a curved and sloping path with SU's standard followme tool.
Useful for creating handrails for spiral staircases, carpark ramps, cicular ramps etc.
3) Bug fixes on horizontal and vertical louvres tools.
User can now enter 0 for louver thickness to create single plane louvres.
4) Option to show different toolbars separately.
from menu View >> Toolbars
Installation
Just download the file
http://www.1001bit.com/download/1001bit(1.1.3).zip
and replace/overwrite the current files in your 1001bit folder.
The user license that you have for v1.1.x is still valid. If you choose to delete the old folders before installing the new ones,
Please keep a copy of the 1001bit.key file, which contains your license information.
As long as you put this file back into the 1001bit folder, your license remains valid.
Thanks and cheers!
Goh C H
GOHCH
Name: Goh Chun Hee
Postby utiler » Sun Mar 15, 2009 10:17 am
Way to go, Goh!!! :sketchstatic: :sketchstatic: :sketchstatic:
utiler
Top SketchUcator
SketchUp version: 8
License type: Pro
Postby Pilou » Sun Mar 15, 2009 11:45 am
Works like a charm! :enlight:
Except Undo to the beginning of the start session Seems block after Extrude profil along a path! :o
Soften Edges seems the blockage! And it's repeatable at any times! ;)
So Big bug! :) (V6) (Plug not install in the V7)
Speedy Galerie
Pilou
Top SketchUcator
SketchUp version: 6
License type: Free/Make
SketchUp use: hobby
Postby GOHCH » Sun Mar 15, 2009 1:54 pm
hi Pilou,
Thanks, missed that out.
Bug fixed -- download the patch from
http://www.1001bit.com/download/extrude1_patch(15-Mar-09).zip
and overwrite the extrude1.rbs file.
Thanks and cheers!
Goh C H
GOHCH
Name: Goh Chun Hee
Postby sepo » Sun Mar 15, 2009 3:43 pm
Fantastic toolset. :thumb:
sepo
License type: Pro
Not a Premium Member yet? Check out the great time-limited deal we are offering.
PreviousNext
Return to Plugins
Users browsing this forum: antoineb89, araboneger, casa_22, tak2hata and 5 guests
