SketchUcation Plugin Store
[Plugin] 1001bit Tools - Architectural tools for SketchUp
Re: [Plugin] 1001bit Tools - Architectural tools for SketchUp
Postby bagatelo » Sat Jan 23, 2010 5:29 pm
The use of their tools could be increased if they opened a type of API of their tools, not opening the code of their scripts. They could make more money if they documented the use of their tools by another scripts.
What do I have in mind? I have a lot of things. Use your imagination.
bagatelo
Operating system: Windows
SketchUp version: 8
License type: Pro
SketchUp use: interior design
Postby GOHCH » Sun Jan 24, 2010 12:12 pm
hi bagatelo,
That's an interesting thought. Haven't thought about the tools from this direction.
Current tools were written with very specific and rigid work flow. To create modules which are useful(and will have to be flexible) will definitely require a lot more thoughts than what i'm doing now. ;)
Can't say much about whether i'll move along this direction in future at this stage.
(I'm working on some improvements to the tools, as well as some new ideas, which i hope to finish within the next few months.)
cheers!
GOHCH
Name: Goh Chun Hee
BrainStorm
Postby bagatelo » Mon Jan 25, 2010 3:01 am
I don't know the way of the professional users' of Sketchup around the world works, but in my case, I work with precise units, with certain patterns that never change, in although the forms can change. I know that technology BIM could be implemented inside of Sketchup. I see windows opening a hole automatically in the wall when inserting the component window. I see kitchen closets that turn off drawers when inserting in the place equipments as ovens or dishewasher.
Is possible to insert components of the library through script or plugin?
Something that I think it would be fantastic in the sketchup it would be the possibility to record macros or actions, like Photoshop ou Microsoft Excell.
Please watch those videos to understand how I think:
http://www.youtube.com/watch?v=D_rEiL69k40
http://www.youtube.com/watch?v=Puo1oAQpDtk
http://www.youtube.com/watch?v=OPuFPN02AKU
bagatelo
SketchUp version: 8
License type: Pro
Postby GOHCH » Wed Jan 27, 2010 12:59 pm
I haven't tried Chief Architect and Revit; however looking from the videos, they are standalone applications. I've heard that Revit is really good by the way...
Working as standalone application has its advantages because you are in total control of how users use the model, and you do not have to make room to capture things that are not created by your application. This allows you to integrate a lot of functions because you can be sure that all entities created/imported by your application has been properly 'prepared' and their associated parameters properly indexed and stored.
The downside is, you had better have a good team developing this because you will need to have almost everything an architect needs to use ready all by yourself.
Opposite of that are plugins, which handles only specific functions. Because of that nature, and that you cannot possibly be the single source to solve all users' need, a good plugin should (IMHO) be very clear on how it is intended to fit into a working environment where the users may very well have other plugins by other ppl installed. In my mind you should keep everything as open and neutral so that it is easy for others to pick up the model and continue working on it with some other plugins. This is the main reason i have been hesitant to assign material, or layers or adding attributes to the groups created using 1001bit tools. I do have plan to allow users the options to define layers in future; but that will only be on preference basis, not a rigid requirement.
I hope i haven't bored anyone to death yet.... ;)
GOHCH
Name: Goh Chun Hee
Postby bagatelo » Fri Jan 29, 2010 2:40 am
Ok, I understand. Each side has their advantages and disadvantages.
I will post here in this topic some ideas that I have growing i my mind about your plugins.
1) Possibility to create and to save presets of tools. Possibility to export and import these presets.
2) Possibility to see in real time the alterations in the controls of the tool. It would be as the controls of tools of the photoshop, that allow to see in real time which will be the result of the taken action.
3) Possibility to edit the created objects.
4) I can translate your plugin to portuguese.
5) Possibilities to create grooves in angles, not just in the horizontal. Sometimes that I need to create Grooves in the vertical. Sometimes I need to create grooves in X.
For now is enough. Cheers
bagatelo
SketchUp version: 8
License type: Pro
Re: Find!!! - Architectural tools for SketchUp
Postby Elibjr » Fri Feb 19, 2010 10:02 pm
WOW Goh, this is really useful now. Thank you for such a great plugin!
GOHCH wrote::D :D :D Merry Christmas Everyone!!! :D :D :D
1001bit version 1.1.7 update is now ready for download!
http://www.1001bit.com/v1.1/download_registration_v1.1.shtml
3 new tools are added into this update:
Rectangular grille tools: convert edges into rectangular sections.
Circular grille tools: convert edges into circular sections.
both the grille tools only create grilles on a common plane defined by the first 3 points it finds from the selection.
any edges that are not on the plane will be projected onto the plane.
Extrude while maintaining tapering effect.
:D :D :D :D Wishing everyone a very Happy Christmas, and all the best in the coming year! :D :D :D :D
[flash=][/flash]
Elibjr
Premium Member
Premium Member
SketchUp version: 8
License type: Free
Postby GOHCH » Sat Feb 20, 2010 3:06 am
hi Elibjr,
wow, that's some nice work there! :thumb:
Someone asked me about creating standing seams for the roof of irregular shape.
I used the roof tool, set the rafter width to 5mm, height to 20mm and distance to 200mm and uncheck the batten/purlin
and here's the result with a single click:
:bounce:
GOHCH
Name: Goh Chun Hee
Postby Elibjr » Thu Feb 25, 2010 10:16 pm
That's great thinking Goh. Now I have a quick wat to create a standing seam metal roof! I have really appreciated the "modify selected vertex on entity" tool. It's great when you want to edit an irregular object one node at a time to get the exact shape. The "create screen" is truly my favorite for creating a simple continuous ceiling grid with ceiling panels. Thanks again.
EBell. :thumb:
Elibjr
Premium Member
Premium Member
SketchUp version: 8
License type: Free
Postby GOHCH » Sun Aug 08, 2010 4:33 pm
We've just launched 1001bit pro, and inside there's a metal deck tool which can be used to generate corrugated sheets, metal decks as well as standing seams :D
Take a look at the userguides on the tools in the Pro version at
http://www.1001bit.com/pro/userguide.html
GOHCH
Name: Goh Chun Hee
Postby onetoughkooky » Sun Feb 06, 2011 6:31 am
Hi Goh! I'm a SketchUcation n00b and I just discovered your toolset. AMAZING!!! :D
I have one question though, I'm trying create louvers for a curved surface (since my building is curved and I'm putting the louvers on its south-facing wall). Right now I'm playing around with "View Hidden Geometry" and then generating the louvers on a per-surface basis, but it's taking me quite some time and doesn't look very clean. Is there any way to generate the louvers (both horizontal and vertical) from a curved surface?
onetoughkooky
Postby GOHCH » Sun Feb 06, 2011 2:53 pm
hi,
I'm afraid there is currently no single function to generate louvres on a curved surface. What i would do, would be to use combination of 'extrude along sloping path' and 'linear array'
Step 1: select the path (can be different edges, but has to be connected)
Step 2: create a face on x y plane to define the profile of the louvre.
Step 3: use the 'extrude along sloping path tool'
Step 4: select the created louvre then use the 'linear array' tool to create multiple louvres
cheers! ;)
GOHCH
Name: Goh Chun Hee
Postby GOHCH » Sat Apr 16, 2011 9:13 am
hi everyone,
Haven't been doing much programming for the past few months... my day job has been getting quite crazy lately.
Anyway, I managed to work on the Panel Divide tool.
Previous version has issues of either conflict or simply unstable.
I have re-written the tool, and was hoping that this version works better :)
(this is a patch for the Pro version by the way. Once i'm sure that this is ok, i will write another for the standard version.)
Just replace the paneldivide.rbs file in your 1001bit_pro folder with this one.
Thanks and cheers!
Goh
GOHCH
Name: Goh Chun Hee
Postby GOHCH » Fri Apr 29, 2011 2:48 pm
hi everyone,
Here's the patch for panel divider tool for
1001bit standard version:
paneldivide_1001bit_standard(29-Apr-11)_patch.zip
and for 1001bit Pro
paneldivide_1001bit_pro(29-Apr-11)_patch.zip
(previous one has some bugs; please replace with this one)
on second thought, i recompiled all these into 1001bit Pro (v1.2); which also included the patch to
prevent the black command windows during loading and also speed up loading.
please download and try out from:
Hi everyone, there's a bug on 1001bit Pro version 1.2 with activation keys issued in 2010!
I have taken the upgrade off for a few days to fix the bug.
Sorry for the inconvenience!
comments, as usual, are always welcome!
cheers! :D
GohCH
GOHCH
Name: Goh Chun Hee
Postby Ken » Fri Apr 29, 2011 4:42 pm
Sir
How do I tell what version of your software I am using. The latest version is 1.1.7 however as you can see, that is not what the info screen shows.
Ken
Government rushes to help the irresponsible and does little for the responsible.
Ken
Premium Member
Premium Member
SketchUp version: 8
License type: Pro
SketchUp use: engineering and mechanical design
Level of SketchUp: Advanced
Postby GOHCH » Fri Apr 29, 2011 4:55 pm
Ooops :oops:
I have not been updating that version information!!!
(just uploaded the corrected zip file);
the info should show version 1.2 if your installed with the latest zip file (from the above link)
Sorry for the confusion :oops:
GohCH
GOHCH
Name: Goh Chun Hee
Postby Ken » Fri Apr 29, 2011 7:12 pm
GOHCH wrote:Ooops :oops:
GohCH
OK, I have tried to download Version 1.2. And again, I have now 30 day trial version has expired. And when I send in for another authorization number, I get that two authorization numbers have already been issued for this computer. Dam right, apparently I need a new number every time you upgrade the software. YOU HAVE THE LEAST UNDERSTANDABLE UPGRADE PROCEDURE THAT I HAVE EVER DEALT WITH.
So, one can not determine which version he has on his computer, because you don't keep track of the upgrades in the license info box, and when I do upgrade I have to go thought hoops to just get the software running again.
Dam, you have good software, just figure out how to do better with your license number. I went thought this not to long ago when I upgraded from Vista to Windows 7.
Pissed I am, Ken
It shouldn't be this hard to do an upgrade.
Ken
Premium Member
Premium Member
SketchUp version: 8
License type: Pro
Postby GOHCH » Sat Apr 30, 2011 12:31 am
hi Ken,
My apology for this. I was trying to make the loading faster to by pass the command windows and there seems to be a bug there!
There's an incompatibility with some of the activation keys issued last year which i have just realised. :(
Sorry everyone, I am taking 1001bit Pro version 1.2 off for fixing for a few days.
will put it up for download when fix that bug.
Again Ken, really sorry about the inconvenience!
Goh
GOHCH
Name: Goh Chun Hee
Postby Ken » Sat Apr 30, 2011 1:17 am
GOHCH wrote:hi Ken,
Goh
Sir
Mr Hee let me apologize for my bad forum behavior. Guess I should have waited before sending the above note. To all forum members, Mr. Hee has sent me a new authorization code that works and has alway in the past responded quickly and in a helpful manner. Sir there was very little inconvenience, just frustrations in trying to keep a desktop and laptop in sync.
Again, let me thank you for you very useful plugins and your continued assistance.
Ken
Ken
Premium Member
Premium Member
SketchUp version: 8
License type: Pro
Postby GOHCH » Sat Apr 30, 2011 4:41 pm
Hi Ken,
Thanks and please do not apologize for anything.
I am really grateful that you raised a very important bug, as well as reminding me the importance of clarity and ease of use.
If not for your comments, there will be a lot more people having problem with the bug right now.
and, for every feedback on issues, there are always a lot more people who are frustrated with similar issues.
Thanks again, and thanks for sending me your old key for debugging.
I'll try to debug this so that we can get rid of the command window that seems to slow down the loading.
Cheers! :D :D
Goh C H
GOHCH
Name: Goh Chun Hee
Postby GOHCH » Tue May 03, 2011 2:57 pm
hi everyone,
I've just uploaded the debugged 1001bit Pro (version 1.2) for download.
http://www.1001bit.com/pro/download/1001bit_pro(v1.2).zip
The update contains the following:
1) panel divide tool (re-written, should work better)
2) startup loading; loads faster and should not show the black command dialog,
and also got rid of the request code.
Please try out :D
cheers!
Goh
GOHCH
Name: Goh Chun Hee
Postby thomthom » Tue May 03, 2011 3:14 pm
GOHCH wrote:hi everyone,
Please try out :D
cheers!
Goh
Cheers! I'll give it a whirl. I've come to the habit of having 1001bit disabled by default and only load on demand due to the load performance and flashing command windows. Now I might keep it enabled. :)
Global Moderator
SketchUp version: 8
License type: Pro
SketchUp use: architecture
Postby utiler » Tue May 03, 2011 11:24 pm
Thanks Goh, great stuff!! :berserk:
utiler
Top SketchUcator
SketchUp version: 8
License type: Pro
Postby GOHCH » Tue Aug 09, 2011 12:35 am
hi everyone,
1001bit Pro Czech language pack is now available!
http://www.1001bit.com/discussions/viewtopic.php?f=17&t=1131
Special thanks to Marek Raab for his hardwork and sharing!
(And he even translated the images!)
:berserk: :berserk: :berserk:
GOHCH
Name: Goh Chun Hee
Postby esteromx » Tue May 15, 2012 6:36 am
esteromx
SketchUp version: 8
License type: Pro
Postby thomthom » Tue May 15, 2012 8:09 am
esteromx wrote:1001bit Pro version 2 is out. http://www.1001bit.com/pro/pro2_improvements.html
:thumb: :thumb: Nice!
Global Moderator
SketchUp version: 8
License type: Pro
Postby Krisidious » Tue May 15, 2012 8:22 am
bought... and installing pronto.
awesome awesome awesome...
Edges to 3D profiles
Extrude to target plane
Extrude along sloping curved path
Best fit face
what an incredible tool kit this has become... well it always has been. how can you top yourself, when you keep setting expectations so high.
instant tube frame or roll cage... just a few clicks and bang. and it lines up great. do you realize how much time I spent building the roll cage for my Nascar?
Kristoff Rand
Home Designer
Custom House Plans with a Point of View
Krisidious
SketchUp version: 8
License type: Pro
Postby TIG » Tue May 15, 2012 10:18 am
One 'tip' for v1 pro users who are upgrading to v2 pro...
If you install v2 files overwriting the v1 files, then Sketchup might no longer auto-load 1001tools at all, as there will be some initial error messages [re. incorrect key etc].
You cannot therefore enter your new key-code into a dialog as your upgrade email has instructed. Bummer !
However, if you look in the 1001tool's subfolder there's a file called 1001bit_pro.key... open that using Notepad or similar plain-text editor like Notepad++... edit>copy your new key string from you confirmation email [all 458 characters of it!] and then in the .key file edit use edit>select-all and then edit>paste to overwrite the old key string. Save the .key file and restart Sketchup, now 1001tools v2 pro should auto-load successfully with all of the new/improved features... Fixed !!
Global Moderator
SketchUp version: 8
License type: Pro
Postby thomthom » Tue May 15, 2012 10:30 am
TIG: Did you report this upgrade problem?
Global Moderator
SketchUp version: 8
License type: Pro
Postby TIG » Tue May 15, 2012 10:30 am
thomthom wrote:TIG: Did you report this upgrade problem?
Just about to...
EDIT: It's now reported to 1001 direct.
Global Moderator
SketchUp version: 8
License type: Pro
Postby Pilou » Tue May 15, 2012 10:44 am
French version of the news ;)
Speedy Galerie
Pilou
Top SketchUcator
SketchUp version: 6
License type: Free
SketchUp use: hobby
Vertex Tools for SketchUp. Take control over each vertex with this vertex editor for SketchUp.
PreviousNext
Return to Plugins
cron
Users browsing this forum: aclima, Dave R, ivo3D, lllPrince, Oxer, thomthom and 11 guests
