SketchUcation Plugin Store
[Plugin] V-Ray Tools (2.1.0) — 11 March 2013
Re: [Plugin] V-Ray Toys (1.2.0) — 16 February 2010
Postby nattawout » Sat Feb 20, 2010 4:23 am
thank you very much
nattawout
Postby nomeradona » Sat Feb 20, 2010 7:07 am
thanks thom, for the new release of vray i have to overwrite the old file right?
nomeradona
Postby thomthom » Sat Feb 20, 2010 11:43 am
you're talking about V-Ray Toys or V-Ray for Sketchup?
Global Moderator
Operating system: Windows
SketchUp version: 8
License type: Pro
SketchUp use: architecture
Level of SketchUp: Advanced
Postby troyhome » Thu Aug 19, 2010 3:06 pm
I'm running 1.48.83 vfsu on my mac and vray toys doesn't work. Under Tools, there is a check by Load Vray on demand, but vfsu still loads. ?? any ideas? thanks! I used the great plug to prevent the extra time it takes SU to load. I miss that now.
Etch-A-Render
SU Pro 8.0.4810 Mac/ SU Pro 8.0.4811 PC
Thea: (MacOSX 32bit) RV481_v1.0.7 (SU2TH .86)/ (PC 64bit) RV481_v1.0.7 (SU2TH .86)
Vray: VfSU 1.49.01
troyhome
Operating system: Mac
SketchUp version: 8
License type: Pro
Postby sadyo » Sun Aug 22, 2010 4:26 am
troyhome wrote:I'm running 1.48.83 vfsu on my mac and vray toys doesn't work. Under Tools, there is a check by Load Vray on demand, but vfsu still loads. ?? any ideas? thanks! I used the great plug to prevent the extra time it takes SU to load. I miss that now.
I'm running 1.48.89 vfsu, and it still working fine for me, I also experienced the same problem when first using this tool.
You just have to click out the VRay Toolbar first, then restart the SketchUp
sadyo
Postby troyhome » Wed Aug 25, 2010 4:35 pm
I'll try that- thanks!
update:
I opened SU, clicked on the Vray Toolbar and quick SU. I reopened SU and no change :(
What did i miss?
update:
I thought it was solved, but the toolbar was just hiding...i thought it still took a long time to load SU...
Etch-A-Render
Vray: VfSU 1.49.01
troyhome
SketchUp version: 8
License type: Pro
Postby thomthom » Wed Aug 25, 2010 4:59 pm
hm.... maybe it's not finding the location of VfSU on OSX properly... any error messages in the Ruby Console?
Global Moderator
SketchUp version: 8
License type: Pro
Postby troyhome » Thu Aug 26, 2010 4:41 pm
ThomThom, no errors reported...
Etch-A-Render
Vray: VfSU 1.49.01
troyhome
SketchUp version: 8
License type: Pro
Postby thomthom » Thu Aug 26, 2010 4:55 pm
You have the console open before you click Load V-Ray ?
Global Moderator
SketchUp version: 8
License type: Pro
Postby troyhome » Fri Aug 27, 2010 1:01 am
No, i just opened the Ruby Consol after SU started and didn't see anything.
There is permanently a check beside Load Vray, if that gives you any hints... I try to uncheck it and nothing happens.
Etch-A-Render
Vray: VfSU 1.49.01
troyhome
SketchUp version: 8
License type: Pro
Postby troyhome » Fri Aug 27, 2010 1:06 am
There is permanently a check beside Load Vray on Demand, if that gives you any hints... I try to uncheck it and nothing happens.
Etch-A-Render
Vray: VfSU 1.49.01
troyhome
SketchUp version: 8
License type: Pro
Postby troyhome » Fri Aug 27, 2010 1:25 am
okay- i am an idiot- i had forgotten to go into preferences and uncheck Vray in the extensions... well you know the rest. DUHHH... how many of these moments am i going to have this month??
Etch-A-Render
Vray: VfSU 1.49.01
troyhome
SketchUp version: 8
License type: Pro
Postby thomthom » Fri Aug 27, 2010 7:05 am
13 ... ?
Global Moderator
SketchUp version: 8
License type: Pro
Postby sadyo » Tue Sep 07, 2010 11:22 am
this lovely plugin is not working on Sketchup8 :?: ... waiting for an update :P
sadyo
Postby thomthom » Tue Sep 07, 2010 12:57 pm
sadyo wrote:this lovely plugin is not working on Sketchup8 :?: ... waiting for an update :P
I'm using it with SU8...
What exactly is not working for you? Error messages? No menus? VfSU won't start?
Global Moderator
SketchUp version: 8
License type: Pro
Postby sadyo » Wed Sep 08, 2010 2:38 am
No error massages and menus is appear as usual, but it did not operate properly, i mean, nothing happen, there is no any VRay toys effect afterwards and VRay is still allready ON when i open the SU8 and not "on demand" like it should be :wink:
1. i've put "VRayToys folder" and VRayToys.rb in SU8 plugin folder "\Program Files\Google\Google SketchUp 8\Plugins"
2. i open the SU8, turn off the VRay toolbar and i quit SU8
3. i open the SU8 again (this way is working when i'm still SU7) and then nothing happen...
sorry if my explanation somewhat confusing :)
sadyo
Postby thomthom » Wed Sep 08, 2010 7:23 am
sadyo wrote:1. i've put "VRayToys folder" and VRayToys.rb in SU8 plugin folder "\Program Files\Google\Google SketchUp 8\Plugins"
Did you just close the toolbar, or did you disable VfSU from Window > Preferences > Extensions ?
You need to do the latter.
Global Moderator
SketchUp version: 8
License type: Pro
Postby setesur1 » Mon Sep 13, 2010 11:00 pm
Thank you very much. This looks very useful.
This is my first message in this your great forum.
I am spain. Perdon for my English.
See you later
setesur1
Postby sadyo » Tue Sep 14, 2010 2:01 am
yes, I've done both ways...
Finally, I tried to remove the VRayToys first, then put it back...
Weird, VRayToys can work again like it should :D
But, when i try to Load VRay, it takes 15-20 minute to Appear :cry:
Is there something i done wrong? please help...
sadyo
Postby thomthom » Tue Sep 14, 2010 7:21 am
15-20minutes???
Does it do that if it loads normally?
Global Moderator
SketchUp version: 8
License type: Pro
Postby sadyo » Tue Sep 14, 2010 11:00 am
thomthom wrote:15-20minutes???
No Mr.Thom, when i was use SU7, VRay just need 5-10 second to loads with VRayToys :P
I'm with Win XP Pro SP3 and using VRay 1.48.89, Do i have to re-install my VRay?
sadyo
Postby thomthom » Tue Sep 14, 2010 11:06 am
I'm confused now. :? :oops:
Global Moderator
SketchUp version: 8
License type: Pro
Postby sadyo » Tue Sep 14, 2010 11:11 am
thomthom wrote:I'm confused now. :? :oops:
Oh no.... is there anything i should do :cry:
sadyo
Postby iqbal.ai » Tue Oct 26, 2010 1:45 pm
hai,
can i know.. this ruby for .....?
iqbal.ai
Postby retep37 » Mon Dec 06, 2010 8:53 pm
thomthom wrote:Updated to make Load on Demand compatible with the new VfSU release.
When using VfSU 1.48.66 or newer - you can now enable or disable VfSU from Preferences -> Extensions in SketchUp.
But that will enable VfSU for all SU sessions. If you want to enable VfSU in just one session then use V-Ray Toys->Start V-Ray.
Thank you for creating the updated script. This is working for me on SU 8 with V-Ray 01.48.89. Does anyone know of a method to disable VfSU automatically (without having to go into Preferences -> Extensions)? I know this is a one time step, however I may be using V-Ray Toys in a company environment to offer the option of loading V-Ray upon demand. I am looking for a way to have the default state of SU 8 such that it will NOT load V-Ray. This was possible under SU 7 as one could simply rename the ruby script file to ".disabled". It seems that the way scripts load are a bit different under SU 8. If anyone knows of the file or registry location where the information regarding the disabled extension is being stored in SU 8 I would appreciate it.
Thanks,
Peter
retep37
SketchUp version: 8
License type: Pro
Level of SketchUp: Beginner
Postby thomthom » Mon Dec 06, 2010 9:26 pm
1.2 of this plugin works with VfSU 1.48.xx. Disable VfSU under extensions and you can use this plugin to load it. That is how I got my environment set up.
(I need to update the description.)
Global Moderator
SketchUp version: 8
License type: Pro
Postby retep37 » Mon Dec 06, 2010 9:53 pm
Yes, it absolutely works. Thanks for creating it and keeping it up to date. :enlight:
Semi-related to V-Ray Toys, does anyone know of a way to disable V-Ray for SU prior to first launch of the software? Manually disabling VfSU in extensions must obviously change something that I may be able to replicate on another machine...prefs file, registry, etc. Thanks if anyone knows.
retep37
SketchUp version: 8
License type: Pro
Postby retep37 » Mon Dec 06, 2010 11:47 pm
Found it, if anyone else is ever interested. This information is stored on a per user basis in the current user key of the registry:
[HKEY_USERS\..........................\Software\Google\SketchUp8\Extensions]
"Dynamic Components"=dword:00000001
"Sandbox Tools2.0"=dword:00000001
"Solar North Toolbar1.0.0"=dword:00000001
"Photo Textures1.0.0"=dword:00000001
"Ruby Script Examples"=dword:00000000
"Ocean Modeling"=dword:00000000
"Utilities Tools"=dword:00000000
"V-Ray For SketchUp1.48.89"=dword:00000000
In a quick test, pre-populating the registry with a zero value for the V-Ray extension does stop it from loading upon first open of SU. This has the same effect as going to Windows > Preferences > Extensions and turning it off. A little thing, but could be useful, especially if someone is trying to prevent V-Ray for SU from loading on many computers.
retep37
SketchUp version: 8
License type: Pro
Postby halroach » Mon Jan 31, 2011 1:41 pm
thomthom wrote:1.2 of this plugin works with VfSU 1.48.xx. Disable VfSU under extensions and you can use this plugin to load it. That is how I got my environment set up.
The way you have it set up - the plugin works well. (with vfsi disabled under preferences)
If you leave the vfsu extension checked to load under preferences - it loads the toolbar, and only some parts of vray work. I have to kind of re-load it again by using the vray toys to get everything to work fine.
I also can't uncheck the "Load V-Ray on demand" in any scenario.
Thanks for the plugin!
halroach
Postby thomthom » Mon Jan 31, 2011 1:47 pm
Halroach wrote:If you leave the vfsu extension checked to load under preferences - it loads the toolbar, and only some parts of vray work.
:?: :o :shock:
I'm not seeing that. If the VfSU extension is set to load it loads VfSU normally - as it should.
Halroach wrote:I also can't uncheck the "Load V-Ray on demand" in any scenario.
Yea, that is a wee bug due to they way it used to work. Shouldn't matter.
Global Moderator
SketchUp version: 8
License type: Pro
Not a Premium Member yet? Check out the great time-limited deal we are offering.
PreviousNext
Return to Plugins
Users browsing this forum: elatiara, jmarcinue, jonorman, jorge2011, Meganito, red54, thuphappro and 7 guests
