SketchUcation Premium Membership
[Plugin] V-Ray Tools (2.1.0) — 11 March 2013
Re: [Plugin] V-Ray Toys (1.1.1)
Postby MrWip » Thu May 14, 2009 5:12 pm
Ok...
But when you're working on other things than photorealistic renders(and it happens often for an architect..), it's really usefull to have a way to match a clean light calculation (without any lens effect and other stuffs like that..) on a quick sketch (Clay render are far more clear with this method).
Besides, I don't want to move to Vray up to 1.0, regarding to the amount of problem it does create (even with some ruby like 'remove CG materials'). It's sad to see that the solutions offered to solve the original bugs are worse than the bugs themselves. But that's something to be discuss on an other topic, I guess...
MrWip
Postby Jorgensen » Thu May 21, 2009 12:56 am
Hi Thom Thom
When I try to export via your exporter I always get a 'Failed to save image' :-(
What can I be doing wrong ?
Jorgensen
Jorgensen
Name: Bo Jorgensen
Postby thomthom » Thu May 21, 2009 10:14 am
hm... not sure, can you post a image of your setup when you try to save?
Global Moderator
Operating system: Windows
SketchUp version: 8
License type: Pro
SketchUp use: architecture
Level of SketchUp: Advanced
Postby Jorgensen » Thu May 21, 2009 9:26 pm
witch setup ? :shock:
I can export normaly via export > 2d
Jorgensen
Name: Bo Jorgensen
Postby J40 » Mon Jun 15, 2009 8:43 pm
Hey Thom,
I use your plugin since i upgraded VfSU.
It works beautifully with the vray outcome. :thumb:
But the export image doesn't work for me at all. :?
After choosing files destination with the browser window, naming the file
J40
Postby thomthom » Mon Jun 15, 2009 9:06 pm
hm... your height reports "infinity". What's your aspect ratio set to? How does that window look like?
Global Moderator
SketchUp version: 8
License type: Pro
Postby J40 » Mon Jun 15, 2009 9:26 pm
this particular screenshot was undefined. but this message pops in all models that i've tried on.
i do set the aspect ratio and the plugin gives me the with info but still fails to export....
J40
Postby thomthom » Mon Jun 15, 2009 10:01 pm
What's the filename you try to save to?
Global Moderator
SketchUp version: 8
License type: Pro
Postby J40 » Mon Jun 15, 2009 10:35 pm
I've tried all sort of combination: numbers, letters and both together.
Too bad i can't export, exactly now i'm working on project that it would be a lot of help.
btw is the file type line in browser should be empty?
J40
Postby thomthom » Tue Jun 16, 2009 7:23 am
It doesn't offer any list of filetypes.
You must remember to append the file type to the file name. For instance: Image01.png
Global Moderator
SketchUp version: 8
License type: Pro
Postby J40 » Tue Jun 16, 2009 9:03 am
Ahh... now it works :D
Thanks Thom
J40
Postby thomthom » Tue Jun 16, 2009 9:08 am
Good to hear it works now. I'll put it down on my to-do list for that plugin to verify the filetype. I think I did this myself once - and you know you need to change something when you are confused over something you made yourself. :oops:
Global Moderator
SketchUp version: 8
License type: Pro
Postby AcesHigh » Wed Jun 17, 2009 3:08 am
I will request another VRAY toy...
as you may know, VRAY wont render properly textures that are skewed, etc... that is, it wont properly run most of the textures from models downloaded from 3D Warehouse.
Unless you make each texture a UNIQUE texture.
Problem is, the Unique Texture plugin only makes one unique texture at a time. You must select faces and manually do it. Now, if a model has hundreds of faces, it becomes quite a difficult task.
I wish there was a tool for making unique textures automatically. Also, check faces befoehand to analize if the texture in that face is skewed or not. Only makes it unique if its skewed/etc and wont show at VRAY renders.
AcesHigh
Postby thomthom » Wed Jun 17, 2009 7:19 am
I'm afraid that there's no API to make textures unique. :(
Global Moderator
SketchUp version: 8
License type: Pro
Postby AcesHigh » Wed Jun 17, 2009 2:52 pm
sorry, could you please speak english? I cant understand ancient sumerian :D
what do you mean "there is no API" to do that? :?
AcesHigh
Postby thomthom » Wed Jun 17, 2009 2:59 pm
Sorry. What I mean is that we can only allow what SU allows us to control from Ruby. The API is the methods we can use to communicate with SU's model. Making textures unique is missing. :(
Global Moderator
SketchUp version: 8
License type: Pro
Postby AcesHigh » Thu Jun 18, 2009 1:12 pm
thomthom wrote:Sorry. What I mean is that we can only allow what SU allows us to control from Ruby. The API is the methods we can use to communicate with SU's model. Making textures unique is missing. :(
damn SU developers!
does that mean you cant even execute the Make Texture Unique command already implemented into GE? Maybe simulate a right click over the face and a left click over the command?? :)
AcesHigh
Postby thomthom » Thu Jun 18, 2009 1:14 pm
hmm... not sure.
maybe if you assigned a hotkey to it I could trigger that hotkey.
Global Moderator
SketchUp version: 8
License type: Pro
Postby AcesHigh » Thu Jun 18, 2009 7:46 pm
thomthom wrote:hmm... not sure.
cant the plugin itself assign a hotkey?
AcesHigh
Postby thomthom » Thu Jun 18, 2009 8:04 pm
nope!
Global Moderator
SketchUp version: 8
License type: Pro
Postby wahoowetzel » Sun Jan 24, 2010 6:37 pm
Hey ThomThom,
I'm trying to use the vray toys-specifically the camera sync function, and I'm not having any luck getting the tools to show up anywhere in sketchup. I've dropped the folder into my plugins folder like I've done with my other plugins, but no luck. I'm running Sketchup 7.1.6087 (the latest, I think) and vRay 01.05.30, in case that matters.
Any idea what the problem could be? I think I have it saved in the right place, I restarted sketchup several times and I've restarted my comp just in case.
wahoowetzel
Postby thomthom » Sun Jan 24, 2010 6:41 pm
Do you have one VRayToys folder and a vray_toys.rb file right under your plugins folder?
When loaded you should have an V-Ray Toys menu under Tools. And a V-Ray Tools toolbar.
Global Moderator
SketchUp version: 8
License type: Pro
Postby wahoowetzel » Sun Jan 24, 2010 6:53 pm
here's my current fie location setup.
Does this look correct? I've checked under tools and plugins and I don't see it in SKUP.
wahoowetzel
Postby thomthom » Sun Jan 24, 2010 7:11 pm
No, you should not have that vray_toys-1_1_1 folder there.
The VRayToys folder and a vray_toys.rb should be placed directly under SU's plugins folder.
Global Moderator
SketchUp version: 8
License type: Pro
Postby wahoowetzel » Sun Jan 24, 2010 7:30 pm
shoot, you're totally right. blanked out I guess.
Thanks again, and it seems like you're the go to guy for VfSU, I hope the beta testing is going well. It's rolling out in February right? Looking forward to it and thanks again!
wahoowetzel
Postby thomthom » Sun Jan 24, 2010 7:38 pm
Not sure exactly when it goes gold. But they're working hard to get it out soon. Crunch time I think.
Global Moderator
SketchUp version: 8
License type: Pro
Postby cadmunkey » Fri Feb 12, 2010 3:23 pm
Hi ThomThom, does this camera plugin work with the new Vray for SU release? I cant seem to get the zoom factor to output correctly anymore.
Have you had chance to use it yet in the new Vray at all?
cadmunkey
Postby thomthom » Fri Feb 12, 2010 4:04 pm
With the new VfSU you do not need to adjust the Zoom factor. Set it to one.
There is no features in this plugin for the new VfSU.
Global Moderator
SketchUp version: 8
License type: Pro
Postby cadmunkey » Fri Feb 12, 2010 4:18 pm
thomthom wrote:With the new VfSU you do not need to adjust the Zoom factor. Set it to one.
Thanks man!
cadmunkey
Re: [Plugin] V-Ray Toys (1.2.0) — 16 February 2010
Postby thomthom » Tue Feb 16, 2010 1:25 pm
Updated to make Load on Demand compatible with the new VfSU release.
When using VfSU 1.48.66 or newer - you can now enable or disable VfSU from Preferences -> Extensions in SketchUp.
But that will enable VfSU for all SU sessions. If you want to enable VfSU in just one session then use V-Ray Toys->Start V-Ray.
Global Moderator
SketchUp version: 8
License type: Pro
Artisan Organic Toolset - a set of powerful organic modeling tools.
PreviousNext
Return to Plugins
Users browsing this forum: afah, Bing [Bot], Dave R, ipaulsen, lele_poggi, libeskiano, nikoscha, pjalbert, rv1974 and 5 guests
