[Plugin] Selection ToysRe: [Plugin] Selection Toys (1.9.0) — 11 June 2009Done!
Re: [Plugin] Selection Toys (1.9.0) — 11 June 2009You're a champ!
% (THERE'S NO PLACE LIKE) G28 X0.0 Y0.0 Z0.0 M30 %
Re: [Plugin] Selection Toys (1.9.0) — 11 June 2009Thomthom:
I would make a suggestion here. I think the title of this ruby should be Thomthom Selection Toys, in your own honor and ownership. You have advanced Sketchup to a new level here! Thank you. I take the slow, deliberate approach in my aimless wandering.
Re: [Plugin] Selection Toys (1.9.0) — 11 June 2009hmmm. perhaps my last post here was a bit effusive and over the top. excuse me.
Too effusive? No such thing around here!
Re: [Plugin] Selection Toys (1.9.0) — 11 June 2009heh, no worries. I'm glad you liked it.
Re: [Plugin] Selection Toys (1.9.0) — 11 June 2009Well, then, you guys must have been napping. And I reinstate what I said about naming that plugin.
Best Regards, mitcorb I take the slow, deliberate approach in my aimless wandering.
Re: [Plugin] Selection Toys (1.9.0) — 11 June 2009I think I'll keep the name as it is. But I do accept donations in the shape of cookies*.
![]() * Cookies can be replaced with beer. (Excluding white beer and Budweiser and Spitfire). Thomas Thomassen — SketchUp Monkey & Coding addict
I do not know how to do the cookies thing in cyberspace. I am sure they would taste a little bit flat, and I'm not sure if you would want one of those giant cookies or just "byte" size. It is ok with me if you want to keep the name as is. Now to business. I tried to do a Select Loop on a roughly cylindrical model with a lot of triangular faces. The target loop was a fairly direct series of segments. I first set Edges only, then select loop. This portion of the model is contained inside a group. What I got was the edge and the two adjacent triangular faces highlighted. I was obviously expecting a loop around the circumference to be highlighted. What did I do wrong? mitcorb I take the slow, deliberate approach in my aimless wandering.
Re: [Plugin] Selection Toys (1.9.0) — 11 June 2009It only deals with faces with four edges at the moment.
Loop is one of the functions I plan to improve at some point. Thomas Thomassen — SketchUp Monkey & Coding addict
Re: [Plugin] Selection Toys (1.9.0) — 11 June 2009Thanks so much Thomas!!! Any way to be able to create a shortcut for Select>Loop function? I use it a lot and would like to assign it to a key on my keyboard, but it doesn't show up as an option in preferences.
Guide Tool at Winning With Sketchup Content Creator at Skapeup
You have to select one edge first. You can only assign shortcut to menu items if they apper in the menu's at the time. I use the loop function myself allot. I really wish it was smarter though. And I want to make a function that select the next connected edges if they are under a given angle. Thomas Thomassen — SketchUp Monkey & Coding addict
Re: [Plugin] Selection Toys (1.9.0) — 11 June 2009Holy crap! Fantastic work -- thanks for sharing it
Re: [Plugin] Selection Toys (1.9.0) — 11 June 2009Dear thomthom,
perhaps you should take a look at Matt plugin Selection Manager I think he had already well-done made the development you are thinking of ![]() ![]() *simon Re: [Plugin] Selection Toys (1.9.0) — 11 June 2009Ah, I'll keep that in mind. Thanks for the heads up.
Re: [Plugin] Selection Toys (1.9.0) — 11 June 2009Dear TOM....
you have made a section (included in yr plugin ) that can find copies of the same group at the same time yr plugin is able to finde "same area"s. the question is: (for the next step) is it possible to find smae shapes--->convert them to copies of 1 component? ..... if it is possible then SU would be really poweful , bkz then it could import from other application , with less polygon... and it would be great step .... ![]()
Re: [Plugin] Selection Toys (1.9.0) — 11 June 2009I have considered this - as lately we've been using more and more Revit at work and when I import via DWG windows that should have been the same - isn't. It's certainly something I'd like to see myself.
Re: [Plugin] Selection Toys (1.10.0) — 7 July 2009
Re: [Plugin] Selection Toys (1.10.1) — 7 July 2009
Re: [Plugin] Selection Toys (1.10.1) — 7 July 2009Thom,
Anyway to have the selection tools work with multiple selections or by adding to a selection? Let's say I select two faces with two different materials and I want to extend the selection to connected by material for both faces, is this possible? Same with Select Loop. It would be nice to select a line, run select loop, then while holding shift select another line and get to run select loop to add to selection. Don't know if this is possible though. 3D Artist at Clearstory 3D Imaging
In it's current state: no. But it's something I wish for myself. But it requires complete rewrite of all the functions - making them into tools. It's something I'd like to add to version 2. Thomas Thomassen — SketchUp Monkey & Coding addict
Re: [Plugin] Selection Toys (1.10.1) — 8 July 2009@Thomthom:
I seem to be having a problem with Selection Toys. I see it in plugins and I see Selection in drop down menu with a flyout trigger to the right, but nothing flies out. So I am unable to use the various selection tools. In case it is a conflict or interoperability issue, I will mention that I have downloaded in the last few days updates of Extrude edges, Grow, Projections v2 and I am experimenting with Sculpt. I have also, Hoverselect. I just thought you would want to know about this. Of course, the possibility exists that it has nothing to do with the plugins mentioned and I am just not activating Selection in the proper way. Nonetheless, thank you for the opportunity to use the plugin. mitcorb I take the slow, deliberate approach in my aimless wandering.
Re: [Plugin] Selection Toys (1.10.1) — 8 July 2009Can you open the Console and see if there's any error messages that appear there?
Re: [Plugin] Selection Toys (1.10.1) — 8 July 2009I will give that a try, and post back. Thanks
Re: [Plugin] Selection Toys (1.10.1) — 8 July 2009Thomthom:
My apologies, it is not your plugin, but Matt Extend Tool that has the Selection with the fly out trigger. This time the fly out did happen and it says Extend edges. However, at this time, the Extend Edges is not working, and it may have to do with interoperability with other tools. Sculpt is currently not working, though I understand that it is still in development. By the way, at first I could get no activity in the Ruby Console with the dead end menu with "Selection >". Then, for some reason the fly out trigger '>' worked and Extend Edges flew out, and the console displayed that action, but no results from the selection. I will stop here, before it gets confusing. I take the slow, deliberate approach in my aimless wandering.
Re: [Plugin] Selection Toys (1.10.1) — 8 July 2009That's odd... Can't say I can provide any explanation to that. Poke Matt and let him know.
Re: [Plugin] Selection Toys (1.11.0) — 9 July 2009
Re: [Plugin] Selection Toys (1.12.0) — 9 July 2009
Wow! Really useful. Alas! When I load select_toys.rb it does not appear in the plugins dropdown ![]() i7-4930K 3.4Ghz, 2x GTX780 6GB, 32GB DDR3-1600 ECC, OCZ Vertex 4 500GB, WD Black 3TB, 32TB NAS, 4x 27" Monitors, SpaceMouse Pro, X-keys XK-60
All the menus are access via the context-menu. This is because the commands depends on the selection. Putting them all in the plugin menu would leave a huge number of menus that most of the time wouldn't do anything. Thomas Thomassen — SketchUp Monkey & Coding addict
Users browsing this forum: Саныч, designovka, Malcolm7, sixten610, tiredothis, xiohandal and 9 guests
