[Plugin] Selection ToysRe: [Plugin] Selection Toys (1.2.1)Please let me know if you get any messages in the console. I've not yet seen that behaviour. As you say, it could be conflicting with another plugin which I might not have installed.
Also, could you take a screenshot when it happens? Thomas Thomassen — SketchUp Monkey & Coding addict
I just experience this myself now. That'll make it easier for me to track down what's going on. Thomas Thomassen — SketchUp Monkey & Coding addict
Re: [Plugin] Selection Toys (1.2.1)I believe I might have sorted out the disabled menu problem.
Would you mind testing the plugin for me to see if it's sorted for sure? Send me a PM with your email. Thomas Thomassen — SketchUp Monkey & Coding addict
Re: [Plugin] Selection Toys (1.2.1)thomthom: Apologies for not getting that screenshot to you.
I just haven't had the time. ![]() I downloaded the the new version I'll put it in today and give it a run. Thank you. ![]() My email is kyprusplacid [at] g.mail dot com . I have gtalk. so, once you send me an email you will be on my IM. we can talk then, if you have gtalk. Last edited by remus on Mon Jan 12, 2009 10:06 pm, edited 1 time in total.
Reason: edited email address Re: [Plugin] Selection Toys (1.2.1)*email sent*
Re: [Plugin] Selection Toys (1.2.1)This is the screenshot of the app., with the grey-out
on the right-click tools. http://picasa***.google.com/kyprusplacid/SU?authkey=yW_XtO3TIMw&feat=directlink There was nothing in the Ruby console. Not sure if I'm suppose to type something in there or not to get feedback. Nore would I know what to type. Guess this isn't much help. this is with the new update by the way. Re: [Plugin] Selection Toys (1.2.1)No worries. I saw it myself when I used the plugin quite a bit. I did some changes and after that it appeared to be gone. That's what I'll be sending you tomorrow.
Re: [Plugin] Selection Toys (1.3.1)Updated with some important bug fixes to prevent bugsplats.
A couple of extra select variations added. Thomas Thomassen — SketchUp Monkey & Coding addict
Re: [Plugin] Selection Toys (1.4.0)By request viewtopic.php?f=180&t=16665, added filters for entities with Default material.
Re: [Plugin] Selection Toys (1.4.0)Cool, thanks Thomas!
![]() All people have the right to stupidity but some abuse the privilege.
Re: [Plugin] Selection Toys (1.5.0)Added selection methods for Dynamic Components. Same as regular components, except it allows you to select by DC family.
Re: [Plugin] Selection Toys (1.5.1)Fixed an issue where the DC menu would not appear if there was only one instance of the DC variant.
Re: [Plugin] Selection Toys (1.5.1)Does your selection tools, or is it possible in general, to select an adjacent edge after selecting a single edge in an exploded curve? then the next and so on by clicking (with your 'tool' selected) arbitrarily rather than finding little edges, zooming in clicking, paning clicking etc - finally the curve is completely selected or as much of it as you want, you can use weld.
this would help with complex models and tight spaces. c
Not currently. But it's something I have on my todo list. Thomas Thomassen — SketchUp Monkey & Coding addict
Re: [Plugin] Selection Toys (1.5.1)Hey Thomas
![]() Native Selection tool of SketchUp is at the same time so powerfull and so poor. Your "Toys" increase incredibly its possibilities. I have had not to use those, concerning selection with components or groups for now but, The idea of your "Select Loop" is really amazing (and time saver)! I like it a lot ![]() But more and moreover what seems especially important to me is your "Selection Modifier" : which makes possible to make a new selection into an existing selection. Since the beginning i'm using SU, i think it's something which definitively misses as a native option !!!! Here with this work, I discover you as a masterclass rubymaker ![]() ![]() ![]() ,simon Re: [Plugin] Selection Toys (1.7.1)Reorganized the menu item for the selection filters. Now split into one Select Only->... and Deselect->....
The list of filters where getting too large, so I felt it was better to split them. Sorry to anyone who might have to reassign their hotkeys. Added support for dimension objects and images. Added support for soft and smooth edges. Added support for hidden entities. Added extended support for selecting faces; parallel, perpendicular, opposite and by area. Thomas Thomassen — SketchUp Monkey & Coding addict
Re: [Plugin] Selection Toys (1.7.1)very good job thomthom
![]() minor suggestion: consider adding a 'Deselect All' option for the Tools or Plugins menu, found this handy to assign to a keyboard shortcut to quickly get rid of the selection.
That's interesting... no Deselect All function built in to SU. I'll include it for the next release. Thanks for the tip. ![]() Thomas Thomassen — SketchUp Monkey & Coding addict
Re: [Plugin] Selection Toys (1.7.1)Its already there. edit->select none or ctrl+t by default.
Re: [Plugin] Selection Toys (1.7.1)CTRl+T deselect current selection...
Frenglish at its best !
My scripts Re: [Plugin] Selection Toys (1.7.1)heh
![]() ![]() Thomas Thomassen — SketchUp Monkey & Coding addict
Re: [Plugin] Selection Toys (1.7.1)Thanks, thomthom:
I will check this out. I take the slow, deliberate approach in my aimless wandering.
Re: [Plugin] Selection Toys (1.7.1)thanx thanx and thanx again tomtom...
I've been read this tread but thought that it wouldn't be needed .... but recently i'v recieved a file that is done by someone that really is textured badly ( i mean it is textured to groups, not faces inside them) and is using lots of similar group instead of component, ... so your job is really time concuming and worthy .... ![]() ![]() My perspective shortcuts book: https://bit.ly/30Tdbce
Re: [Plugin] Selection Toys (1.8.0)Another small update:
Re: [Plugin] Selection Toys (1.9.0)Added filters for Curves (Polylines)
Before Arcs would select Curves and Arcs and Circles - Now they select Arcs and Circles Curves will select Curves, Arcs and Circles. Question: Currently, Curves selects Arcs and Circles are a subset of Curves. But is it preferred that Curves selects only Curves - Arcs only Arcs and Circles selects only Circles? Thomas Thomassen — SketchUp Monkey & Coding addict
Re: [Plugin] Selection Toys (1.9.0)ThomThom, takk for alt.
Could you do a little favor? When you update a plugin, could you add the date of the update to the title line? I can't remember version numbers well enough to recognize and update has been issued. I usually can't remember the date ,either. But I know enough to hover the cursor over the clock on my computer screen to find out what the current date actually is. Thank you. Etaoin Shrdlu
% (THERE'S NO PLACE LIKE) G28 X0.0 Y0.0 Z0.0 M30 %
