[Plugin] Selection Toys
Re: [Plugin] Selection Toys (2.2.0) —31 August 2010
Postby thomthom » Sun Sep 05, 2010 7:25 pm
And there are no errors at all when you start SU?
If you open Ruby Console, what output do you get when you type:
Select_Toys
load 'tt_selection_toys.rb'
TT_Lib::VERSION
PluginStore Author
PluginStore Author
Postby stonebreaker » Sun Sep 05, 2010 7:29 pm
Select_Toys
--Select_Toys
--true
TT_Lib::VERSION
--1.2.0
i use the german su8 version.^^
stonebreaker
Postby thomthom » Sun Sep 05, 2010 7:35 pm
I can make so sense why you would not have a Selection Toys menu item under tools and various Context Menu entries (which depend on what you right-click)
I was about to ask if you'd checked the Preferences for Selection Toys, but if you have not menu... I'm really stomped.
Can you post a screenshot of your Tools menu?
PluginStore Author
PluginStore Author
Postby stonebreaker » Sun Sep 05, 2010 7:42 pm
hi
now it runs...i reinstall su8 and copy the plugin seperatly in before i add my "backup-plugin" folder.^^
...for whatever reason...^^
stonebreaker
Postby thomthom » Sun Sep 05, 2010 7:44 pm
hm... I heard some people talk about not getting any startup errors in SU8. Maybe you experienced that and did not get any notification about any errors that prevented the plugin to load.
Whatever it was, I'm glad it work for you now. :)
PluginStore Author
PluginStore Author
Postby stonebreaker » Sun Sep 05, 2010 7:51 pm
btw. thx for the help. :D
i don't want to miss your really great plugin which makes work so much easier.^^
stonebreaker
Postby Dan Rathbun » Mon Sep 06, 2010 10:31 am
I see a general issue. There's is a unins000.dat and unins000.exe in his plugins folder. What plugin is this for ?
These files should be in the specificplugin subfolder, or else the installer will be overwriting these files for subsequently installed plugins, and the original plugin can no longer uninstalled with these files.
    I'm not here much anymore. But a PM will fire email notifications.
    Dan Rathbun
    PluginStore Author
    PluginStore Author
    Postby Jim » Mon Sep 06, 2010 5:13 pm
    Dan Rathbun wrote:I see a general issue. There's is a unins000.dat and unins000.exe in his plugins folder. What plugin is this for ?
    Twilight Render, I assume. I mentioned the issue on the Twilight support forum, was told it's not a problem, and didn't follow-up.
    Their installer need work anyway because when you install to a folder that is not the default - SketchUp 7 - none of the preset locations use the custom location and you need to change them manually. :x
    Jim
    Global Moderator
    Postby Dan Rathbun » Mon Sep 06, 2010 5:52 pm
    It wouldn't be a problem if the file names were say, uninsTLR.dat and uninsTLR.exe; anything but the installer's defaults.
      Dan Rathbun
      PluginStore Author
      PluginStore Author
      Postby Khai » Sun Sep 19, 2010 1:14 am
      can someone give me a step by step idiots guide on how to actually use this?
      I can get it to light an edge up orange. that's all. how do you select things with it?
      Khai
      Postby Dan Rathbun » Sun Sep 19, 2010 4:51 am
      See the first post for basic use.
      Thomas has a link to a Command Cheatsheet also in the first post.
      (ThomThom is in Norway, so it was the middle of his night when you posted... he'll answer... be patient. He's an SCF moderator, and checks in several times a day.)
        Dan Rathbun
        PluginStore Author
        PluginStore Author
        Postby Khai » Sun Sep 19, 2010 5:19 am
        Dan Rathbun wrote:See the first post for basic use.
        erm. I did?
        and I don't see how to use it. sorry.. I mean, do I select the group then...what? the most I've got is an orange outline and nothing selected. so I'm doing something wrong...
        this is what I mean by step by step and ... be patient? I asked once and waited...?
        Khai
        Postby d12dozr » Sun Sep 19, 2010 5:51 am
        Khai, what are you trying to select? What function are you trying to use?
        http://goo.gl/f7ooYh
        d12dozr
        Top SketchUcator
        Postby Khai » Sun Sep 19, 2010 5:58 am
        well I want to use it.... and I don't get any selections whatever I try.. so I thought I'd ask for help..
        I did read the first post and sorry guys. there are no instructions there. you may see 'em but I don't..
        just boil it down for the terminally bewildered? so I select a group and say I want to select a row of faces I....? or I want to select a ring of edges I....?
        Khai
        Postby d12dozr » Sun Sep 19, 2010 7:06 am
        Quick video below, you can enable/disable context-click options from the UI Settings in the Selection Toys menu.
        HTH
        d12dozr
        Top SketchUcator
        Postby thomthom » Sun Sep 19, 2010 9:46 am
        Thanks Marcus! Great video - I should put that in the original post.
        Khai: in addition to Marcus' video that showed the menu items, you can also enable the toolbar Tools->Selection Toys->Enable Toolbar
        PluginStore Author
        PluginStore Author
        Postby d12dozr » Sun Sep 19, 2010 6:49 pm
        Glad to help, sir...its a great plugin, feel free to use the video in your top post if you think its good enough.
        http://www.youtube.com/watch?v=bemMh3gpLVI
        d12dozr
        Top SketchUcator
        Postby Khai » Tue Sep 21, 2010 6:51 pm
        thank you that really helps :)
        tho somethings not working right - selecting N-gons does not work at all... and I know there is some.. I can see them...!
        Khai
        Postby thomthom » Tue Sep 21, 2010 8:19 pm
        PluginStore Author
        PluginStore Author
        Postby Khai » Tue Sep 21, 2010 8:23 pm
        Select Ngon
        Khai
        Postby thomthom » Tue Sep 21, 2010 8:26 pm
        Select Only -> Polygons ?
        Note that Select Only and Deselect modifies your current selection - doesn't add to it.
        PluginStore Author
        PluginStore Author
        Postby Khai » Tue Sep 21, 2010 8:29 pm
        that's exactly what I'm doing.
        select the model, then Select Only -> N-Gons and nothing is selected, even tho I can see Ngon's.
        to clarify :
        Khai
        Postby pilou » Tue Sep 21, 2010 8:54 pm
        Better if you post your SKP file ;)
        Speedy Galerie
        Top SketchUcator
        Postby Khai » Tue Sep 21, 2010 8:56 pm
        Pilou wrote:Better if you post your SKP file ;)
        sorry cannot do that, it's copyrighted work that will be for sale, and it's not just the mesh in the image above.
        Khai
        Postby thomthom » Wed Sep 22, 2010 7:14 am
        Polygon and N-Gon refer to entities where the Entity Info display Polygon.
        PluginStore Author
        PluginStore Author
        Postby Khai » Wed Sep 22, 2010 8:26 am
        erm... pardon?
        ok I must be being dense... that made no sense at all?
        Khai
        Postby pilou » Wed Sep 22, 2010 8:36 am
        In fact i believe this N Gon function shown only figures who are made with the tool "Polygon" ;)
        And not geometric figures that you can see as Ngons ;)
        Speedy Galerie
        Top SketchUcator
        Postby thomthom » Wed Sep 22, 2010 8:41 am
        Pilou wrote:In fact i believe this N Gon function shown only figures who are made with the tool "Polygon" ;)
        Exactly - the selection tool doesn't look at the shape of the geometry, but filters the selection based on the types of entities SketchUp reports.
        When you select something in SU, the Entity Info window will say what type it is - all the filtering is based on these types.
        PluginStore Author
        PluginStore Author
        Postby Khai » Wed Sep 22, 2010 8:48 am
        ah. thanks for your help then.. this explains all my problems with this Ruby. we're not compatible.. but thats ok.
        Khai
        Postby N3TO » Tue Sep 28, 2010 9:05 am
        thomthom wrote:I can make so sense why you would not have a Selection Toys menu item under tools and various Context Menu entries (which depend on what you right-click)
        Hello Thomas!
        It happens with me also! You can see a screenshot here
        http://www.netcond.net/N3TO/Screenshot_toolsmenu.jpg
        I see all posts but I can't resolve the trouble.
        apologies for my bad english...
        N3TO
        Premium Member
        Premium Member
        PreviousNext
        Return to Plugins
        cron
        Users browsing this forum: pcg26 and 10 guests
