[Plugin] Selection Toys
Re: [Plugin] Selection Toys (2.1.0) — 04 January 2010
Postby thomthom » Thu Jan 14, 2010 11:23 am
Yea - I've been thinking I should include that for plugins that consists of multiple files packaged in .zip.
PluginStore Author
PluginStore Author
Postby thomthom » Fri Jan 15, 2010 5:15 pm
Outer Edges added to selection filters and Quad-Face Loop now accepts multiple start-edges in my internal build. Got a couple of other things to finish before I release it though.
PluginStore Author
PluginStore Author
Postby bagatelo » Sat Jan 16, 2010 12:36 am
MODO from Luxology have good tools that make interesting selections. I remenber one very good. Is something like select polygon by yes/no/yes/no/yes/no, or by samples. Think about this, please.
bagatelo
Postby thomthom » Sat Jan 16, 2010 11:27 am
yes/no/yes/no/yes?
PluginStore Author
PluginStore Author
Postby bagatelo » Sat Jan 16, 2010 4:32 pm
thomthom wrote:yes/no/yes/no/yes?
Please see the imagem called "selection"...
This is plugins tools to make selections in 3dsMax, and more...:
http://www.polyboost.com/features_selection.htm
http://www.orionflame.com/
bagatelo
Bug?
Postby JClements » Sat Jan 16, 2010 7:58 pm
Hi Thom:
Selection Tools must be a labor of love! :)
Selecting Instances on same layer (both all and active) not working? See attached.
JClements
Premium Member
Premium Member
Postby thomthom » Sat Jan 16, 2010 8:10 pm
JClements wrote:Selecting Instances on same layer (both all and active) not working? See attached.
I will look into that.
(you edited you post? you mentioned about selecting from active vs all - well, I have been planning a complete new set of selection tools, where you interactively build your selection)
PluginStore Author
PluginStore Author
Postby JClements » Sat Jan 16, 2010 8:24 pm
Yeh, I edited my post because part of it didn't make sense. :shock:
Another Bug; Select Edge Loops?
If after an edge loop is selected, then using the Layers Toolbar (PC) dropdown list to move the edge to a new layer does not work. Interestly though, using Entity Info to move the selected edge to a new layer does.
[Edit]
Select Default Front and Default Back not working?
JClements
Premium Member
Premium Member
Postby thomthom » Sat Jan 16, 2010 9:18 pm
JClements wrote:Another Bug; Select Edge Loops?
If after an edge loop is selected, then using the Layers Toolbar dropdown list to move the edge to a new layer does not work. Interestly though, using Entity Info to move the selected edge to a new layer does.
hm.. will have to look at that. I never use that toolbar. PC or OSX?
JClements wrote:Select Default Front and Default Back not working?
Might be a bug there. Thought I'd fixed it earlier, but maybe it slipped through... :/
PluginStore Author
PluginStore Author
Re: Bug?
Postby thomthom » Sun Jan 17, 2010 6:33 pm
JClements wrote:Hi Thom:
Confirmed and fixed internally.
Thanks for reporting.
PluginStore Author
PluginStore Author
Postby thomthom » Sun Jan 17, 2010 6:35 pm
Can't reproduce.
PluginStore Author
PluginStore Author
Postby thomthom » Sun Jan 17, 2010 6:37 pm
Can't reproduce.
Saying that, as it works now, the edges also needs to have the same material for the Select Connected by Material to select the neighbouring face... Might have to revise this function. ...and I wonder why I haven't added one that doesn't select connected....
PluginStore Author
PluginStore Author
Postby thomthom » Sun Jan 17, 2010 6:41 pm
This is very odd. But it seems to be a Sketchup bug. I can't see anything in my code that'd do this. And as you say, the Entitiy Info works. I'll try to forward this to Google.
PluginStore Author
PluginStore Author
Postby rv1974 » Mon Jan 18, 2010 9:55 am
Hi!
What I really missinng is option to select all edges bitween "90 degrees faces" (the exact degree number should be ajustable)
rv1974
Postby thomthom » Mon Jan 18, 2010 10:02 am
Ah - took me a little while to understand this one, but being able to select edges where the angle between connected faces are larger than a given angle?
This would be something that filters an existing selection? Or make a new selection in the active space?
PluginStore Author
PluginStore Author
Postby rv1974 » Mon Jan 18, 2010 11:16 am
>...being able to select edges where the angle between connected faces are larger than a given angle?..
-yes
>...filters an existing selection?
-yes
rv1974
Postby juan974 » Mon Jan 18, 2010 7:28 pm
good idea rv1974, kind of : "select string edges", useful for complicated shape
juan974
Postby N3TO » Wed Jan 20, 2010 5:19 pm
Where can I download Seletcion Toys (2.1.0)???
thanks
N3TO
Premium Member
Premium Member
Postby thomthom » Wed Jan 20, 2010 5:36 pm
N3TO wrote:Where can I download Seletcion Toys (2.1.0)???
thanks
Bottom of the first post on the first page of this thread.
PluginStore Author
PluginStore Author
Postby Dan Rathbun » Tue Jan 26, 2010 8:47 am
ThomThom wrote:Selection Modifier
Selection Submenu - Currently there's two kinds of modifiers.
The explanations are a bit confusing for me... I have alot of experience in Electronic Radio Frequency / Broadcast Engineering, where Filters are a very important device. So when I think of Filters I think of them in that respect. See if you think I'm correct here:
ThomThom wrote:One filters out the type of entity you want.
This would be a 'Pass' filter?
http://en.wikipedia.org/wiki/Band-pass_filter
ThomThom wrote:The other deselects the entity you specify.
This is a 'Reject' Filter? (also sometimes called a 'Trap' or 'Notch' Filter from the way the signal looks on a Spectrum Analyser.)
http://en.wikipedia.org/wiki/Notch_filter
    I'm not here much anymore. But a PM will fire email notifications.
    Dan Rathbun
    PluginStore Author
    PluginStore Author
    Postby thomthom » Tue Jan 26, 2010 10:07 am
    I think so ... from what I understood of that definition of filters... unfamiliar territory to me.
    PluginStore Author
    PluginStore Author
    Postby DIEGO-RODRIGUEZ » Fri Mar 05, 2010 4:38 am
    hi tom.
    a question
    as I select only:
    1 - Lines with a free end (no connection with another line or entity)
    2 - lines with the two free ends (no connection with another line or entity, in its extreme ningudo)
    DIEGO-RODRIGUEZ
    Banned
    Postby arjunmax09 » Wed Mar 17, 2010 4:10 pm
    please help me.... i'm not getting all the buttons in the toolbar... only able to get faces, edges, groups and component options
    when you fail at something....you haven't really failed...you've found one way the thing will not work out
    arjunmax09
    Banned
    Postby thomthom » Wed Mar 17, 2010 4:30 pm
    arjunmax09 wrote:please help me.... i'm not getting all the buttons in the toolbar... only able to get faces, edges, groups and component options
    Tools->Selection Toys->UI Settings
    PluginStore Author
    PluginStore Author
    Postby thomthom » Wed Mar 17, 2010 4:31 pm
    DIEGO-RODRIGUEZ wrote:hi tom.
    a question
    as I select only:
    Never noticed this post.
    I'm adding it to my list.
    PluginStore Author
    PluginStore Author
    Postby DIEGO-RODRIGUEZ » Wed Mar 17, 2010 4:41 pm
    I think it would be a useful tool for working with drawings imported from autocad.
    drawings with many lines, could detect lines, what not intersect
    DIEGO-RODRIGUEZ
    Banned
    Postby thomthom » Wed Mar 17, 2010 4:59 pm
    DIEGO-RODRIGUEZ wrote:I think it would be a useful tool for working with drawings imported from autocad.
    http://www.smustard.com/script/StrayLines
    PluginStore Author
    PluginStore Author
    Postby DIEGO-RODRIGUEZ » Wed Mar 17, 2010 5:45 pm
    oooooo. :)
    excellent, thank you very much. did not know
    DIEGO-RODRIGUEZ
    Banned
    Postby arjunmax09 » Thu Mar 18, 2010 5:21 am
    well thomthom... i tried doin' it but i can't go further down the options.. see the video
    arjunmax09
    Banned
    Postby thomthom » Thu Mar 18, 2010 8:28 am
    hm...
    What version of Internet Explorer do you have?
    You haven't disabled Javascript have you?
    PluginStore Author
    PluginStore Author
    PreviousNext
    Return to Plugins
    Users browsing this forum: BrianGustavoLuiz, Einstein, MAXIMODRAGON, nektares, pitangapedro, ymab and 20 guests
