[Plugin] Selection ToysRe: [Plugin] Selection Toys (1.13.0) — 3 August 2009what i can saying? thanks!
hire me @ http://www.publied.it !
Re: [Plugin] Selection Toys (1.13.0) — 3 August 2009Great work Tom!
I didn't have time to read through all the 9 pages of this thread ( ![]() I ask this because 'dynamic components',a typical SU7 feature, is part of the selection toys plugin... Re: [Plugin] Selection Toys (1.13.0) — 3 August 2009It should work, yes. The DC filters simply checks the DC meta data stored in components, and that can be read in SU6.
Re: [Plugin] Selection Toys (1.13.0) — 3 August 2009Yes it works well this version, I used it for a few days, and the grey out problem never happens again!
Thanks, Thomas su30
Re: [Plugin] Selection Toys (1.14.0) — 15 September 2009New selection tool to select a face's loops.
Re: [Plugin] Selection Toys (1.15.0) — 15 September 2009Big speed improvement for most selection functions. Noticeable when dealing with large selections.
Some functions are yet not optimized. I need some more time to ensure they work as they should. These are mostly functions related to connected geometry. Thomas Thomassen — SketchUp Monkey & Coding addict
Re: [Plugin] Selection Toys (1.15.0) — 15 September 2009Is this normal? Select Quad-face loop doesn't mean to select closed loop edges that form a quad? Or I misunderstood ?
This is what happened: BTW: I think you have an error on cursor code; Would you please take a look? ( as I know correct syntax is UI::create_cursor(cursor_path, x, y) ) Last edited by NewOne on Tue Sep 15, 2009 3:02 pm, edited 3 times in total.
Re: [Plugin] Selection Toys (1.15.0) — 15 September 2009Quad-face Loop works as expected. I tried to illustrate it with that gif animation. It selects connected faces and edges in a row.
Can you illustrate your expected result? (You're not confusing it with the new Face Loop feature I just added? The new feature is accessed from the Tools menu. See comment over the first illustration.) Thomas Thomassen — SketchUp Monkey & Coding addict
Yes I did confused that two features! ![]() ![]() Re: [Plugin] Selection Toys (1.15.0) — 15 September 2009Got any suggestions for better names?
They do have all too similar names - no wonder it leads to confusion. Maybe the new one should be named Select Edge Loops ? Thomas Thomassen — SketchUp Monkey & Coding addict
Yes, it's a better name. This one I think is a function that will be used very often, so why don't you make an icon for it instead of hiding it in Tools menu where is a little hard to find? ![]() Re: [Plugin] Selection Toys (1.15.0) — 15 September 2009Yea - I might add a toolbar for this now. Good idea.
Thinking it might be worth making a UI to choose what items to display in the menus and toolbars. This plugin has gained quite a few commands through it's lifespan. Thomas Thomassen — SketchUp Monkey & Coding addict
Re: [Plugin] Selection Toys (1.15.0) — 15 September 2009Thank you for contributing such a great tool!
Very helpful! Re: [Plugin] Selection Toys (1.0.0)Thanks.......
![]() ![]() you are great man I find "Boolean Tool" but i can not find full version please help me can you send me "boolean tool" please. Thanks,
RuturaJ Re: [Plugin] Selection Toys (1.15.0) — 15 September 2009Great tool. Thank you for sharing with the community.
After reading Daniel Tal's book I was thinking that a tool like this would be very handy. Have you given any thought to trying to select like Blenders ring/chain command. Re: [Plugin] Selection Toys (1.15.0) — 15 September 2009I've not used Blender - how does these functions work?
Re: [Plugin] Selection Toys (1.15.0) — 15 September 2009Please pardon the intrusion.
Fossa is talking about Blender's loop subdivide feature. One can invoke a loop around the target geometry and, with the scroll wheel, increase or decrease the number of loops. This is usually used on narrow, elongated solids. The command first sets the initial loop at the midpoint of the target region, and then replicates/multiplies that loop as the scroll wheel is advanced or reversed. This is very similar to the Sketchup Divide command, which only works on edges. After observing by using your Selection Toys and Fredo6's Tools on Surface plugins, I am guessing it's gonna be either you or he who will finally implement this in Sketchup. The clue may be in whatever SU is doing in the Divide command. I believe there is a Blender video tutorial on loop subdivide at gryllus.net, though I haven't been there in a while. I take the slow, deliberate approach in my aimless wandering.
Re: [Plugin] Selection Toys (1.15.0) — 15 September 2009reat tool, thankyou.
would it be possible to select loops in the other direction, without faces (rings)? “There are three classes of people: those who see. Those who see when they are shown. Those who do not see.”
http://www.Twilightrender.com try it! Re: [Plugin] Selection Toys (1.15.0) — 15 September 2009I have been looking into that - but I've found it hard to reliably select - determine the path for the edges to select.
Other applications which has this feature seem to operate with quads, but not SU. Got some ideas I'll try out - but at the moment I'm working on V2.0 and I just recently managed to loose the work I did so I have to redo it all over again. Any attempts for the ring select will be after the V2.0 release. Thomas Thomassen — SketchUp Monkey & Coding addict
Re: [Plugin] Selection Toys (1.15.0) — 15 September 2009Thomthom:
I am not sure if you were responding to me or xrok1, or both?
Re: [Plugin] Selection Toys (1.15.0) — 15 September 2009I was replying to xrok1.
I'm still not 100% sure about the feature you requested. If it's subdividing geometry then it sounds like it's another plugin by its self. I think that fossa's request was similar to xrok1's - a pure selection tool. Thomas Thomassen — SketchUp Monkey & Coding addict
Re: [Plugin] Selection Toys (1.15.0) — 15 September 2009Ok.
Best wishes, mitcorb I take the slow, deliberate approach in my aimless wandering.
Re: [Plugin] Selection Toys (1.15.0) — 15 September 2009viewtopic.php?f=15&t=22523#p189527
Thomthom, Do you have a solution for this problem (like your select similar groups, but that selects consecutively named components and replaces them with just a single instance) it's a really unique need, so not sure if it's worth your time... ![]()
Re: [Plugin] Selection Toys (1.15.0) — 15 September 2009Will have a look at it over the weekend. Right now I'm off to beer and poker!
![]() Thomas Thomassen — SketchUp Monkey & Coding addict
Re: [Plugin] Selection Toys (2.0.0) — 3 November 2009Whoop whoop! BIG update!
Re: [Plugin] Selection Toys (2.0.0) — 3 November 2009Wow Bro...you've really outdone ye self. Awesome job with the UI and the new toolbar. I can't thank you enough for this plugin. I've grown heavily dependent upon it!!!
![]() 3D Artist at Clearstory 3D Imaging
Guide Tool at Winning With Sketchup Content Creator at Skapeup
Re: [Plugin] Selection Toys (2.0.0) — 3 November 2009you're hired!
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() “There are three classes of people: those who see. Those who see when they are shown. Those who do not see.”
http://www.Twilightrender.com try it! Re: [Plugin] Selection Toys (2.0.0) — 3 November 2009Glad you guys like it.
I got an idea for an improved Selection Filter tool. On screen UI - inspired by Fredo's tools. I just had to get this version 2.0 done first - making the preparations. ![]() Personally I use mostly the Edge and Face filter, occasionally Group and Component. They are all assigned to Ctrl+1 to Ctrl+4. I have found no point in adding shortcuts for the rest of the types - as I rarely use them so I never remember the shortcut. Also, there isn't enough keys on the keyboard for them all. Thats why I'm planning on adding an on-screen filter palette which pops up under the cursor for quick access. It should allow for the user to select multiple types of entities to select/deselect. Thomas Thomassen — SketchUp Monkey & Coding addict
Users browsing this forum: Google Bot, williamvj and 8 guests
