SketchUcation Plugin Store
[Plugin] Boolean--OSCoolean (Oct 2010) for SU 8 free version
Re: [Plugin] Boolean--OSCoolean (Oct 2010) for SU 8 free ver
Postby lubessy » Wed Jul 18, 2012 3:32 am
COULD someone PLEASE fix this BOOLEAN PLUGIN?!?!
it's doesnt work AT ALL in sketchup 8 pro!!!
please oscoolean!!! update it for everyone whose in need of this plugin!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
lubessy
Operating system: Windows
SketchUp version: 8
License type: Pro
SketchUp use: interior design
Level of SketchUp: Advanced
Postby Dave R » Thu Jul 19, 2012 12:09 pm
Just use the native Solid Tools. :roll:
Inspecting mirrors is a job I could easily see myself doing.
Global Moderator
SketchUp version: 8
License type: Pro
SketchUp use: woodworking
Postby Jspro » Wed Aug 22, 2012 9:39 pm
Yes I really had high hopes for this plugin. It seems to load alright but it only join two components together, but would not cut a hole or do any of the other functions. I have version 8 of sketchup hoping that there will be an update so that I can use this
Jspro
Postby Dave R » Wed Aug 22, 2012 10:55 pm
Since other users have reported that the plugin works fine, perhaps your problem is due to incorrect installation? That's the usual cause of plugins not working. Would you like to continue to wait for the update you're hoping for or would you rather just get the existing version to work? If it is the latter, post screen shots of the Plugins folder and of the contents of the related folders so we can see how you've installed it.
Global Moderator
SketchUp version: 8
License type: Pro
Postby Jspro » Thu Aug 23, 2012 1:46 am
Dave thanks for all your help, the tool bars loaded correctly ,after i have intersected the to groups together ,the first command joins them together, but after that nothing seems to happen? here a pic of my plugin folder
Jspro
Postby Jspro » Thu Aug 23, 2012 2:21 am
Dave heres the screen shot of the tool bar
Jspro
Postby Jspro » Thu Aug 23, 2012 2:44 am
Hey Dave my agologizes i think ive figured it out it seems to work thanks John
Jspro
Postby dyl » Thu Aug 23, 2012 1:23 pm
I've extracted the files to the plugins folder but cant seem to find it anywhere in Sketchup. Any ideas? Have just updated to the latest free version of Sketchup 8.
Update, sorry just scrolled back through a few pages and found the solution. View/Toolbar and you can enable it there.
dyl
Postby Jspro » Tue Aug 28, 2012 12:21 am
Can you help me in trying to figure out why OSCoolean has stop working? When i have two objects that i have group togther and intersected them, the command doesnt respond? Here a copy of my sketchup plugin folder. Thanks John
Jspro
Postby Dave R » Tue Aug 28, 2012 12:46 am
Why don't you post the model that is giving the problems?
Global Moderator
SketchUp version: 8
License type: Pro
Postby Jspro » Tue Aug 28, 2012 1:04 am
This is just a simple model, that i used to see if it will work, do you think that the plugin round corners some how has affected it somehow?
Jspro
Postby Jspro » Tue Aug 28, 2012 4:25 pm
Dave have you had a chance to figure out what could be happening with my problem? thanks john
Jspro
Postby Dave R » Tue Aug 28, 2012 4:32 pm
You still haven't posted the model as I requested. You seem to be resisting being helped. I don't have more time to donate to this.
Global Moderator
SketchUp version: 8
License type: Pro
Postby Jspro » Tue Aug 28, 2012 4:48 pm
The model is posted if you cant figure it out fine! just say so, dont have an attitude about it
Jspro
Postby thomthom » Tue Aug 28, 2012 4:53 pm
Jspro wrote:The model is posted if you cant figure it out fine! just say so, dont have an attitude about it
He meant the actual .skp file - not a screenshot.
Global Moderator
SketchUp version: 8
License type: Pro
SketchUp use: architecture
Postby Dave R » Tue Aug 28, 2012 5:13 pm
The model isn't posted. A screen shot is not the model. :roll: And I don't have an attitude about it.
Global Moderator
SketchUp version: 8
License type: Pro
Postby Jspro » Tue Aug 28, 2012 5:18 pm
Well you know i did say i was new to these pugins, when were looking for help we are at a disadvantage. Not all of us are techno-wizs. Not trying to offend anyone but beng accused of resisting help seems like he is tired of doing this. I was just looking for help that is all.
Jspro
Postby TIG » Tue Aug 28, 2012 5:39 pm
So where is this model [SKP] file ?
I suspect that you have mis-installed something and the SKP will not be so helpful...
Have you tried doing this with the Ruby Console open and see if there are any messages ?
You need to help us to help you... :?
Global Moderator
SketchUp version: 8
License type: Pro
Postby Jspro » Tue Aug 28, 2012 8:34 pm
Dear TIG thanks for help, as i was saying i am new to this. Where would i find this skp file? if i knew where to find it i would sure like to send it to you. The Ruby Console had no message in it. I suspect from my lack of knowledge of the internal working of Sketchup & plugins that maby i should just be happy with sketchup the way it is. i just thought that this forum was for all ,when i sent the wrong pic of the model that should have been the clue that i am a rookie. thanks john
Jspro
Postby TIG » Tue Aug 28, 2012 8:56 pm
OK... we really do have our work cut out here... :?
At least if we are not getting error messages we know something :?
A Sketchup model is saved as a file on your computer.
That model-file have a file-type suffix '.SKP' [or .skp that's irrelevant].
So a model is often referred to a a 'SKP'...
That's the file you can attach to a post - just as you attached an image-file.
[Note that your system might be set also to make 'backup-files' [.SKB] of your model. do NOT attach that file...]
Everyone has to start somewhere, all of us were 'useless' at some point...
On a separate issue from the 'SKP'...
I note that you have '...AdditionalPluginFolders.rb' in your Plugins folder.
Why?
This is only needed by users who know what they are doing... and have additional plugins in folders other than the standard folder structure, that they also want to auto-load - e.g. if you kept some plugins on a central server... Unless you really do need that remove it from the Plugins folder...
Every .rb [and .rbs...] file in the Plugins folder will 'auto-load' [or at least try to do so] when Sketchup starts. So only have those types of files in there that you want to load and which you know are 'OK'...
Many files auto-load and then load other files in special subfolders... hence the 'Lib' folder for Fredo's scripts - these add extra functions and often the main bulk of a tool's coding...
:enlight:
Global Moderator
SketchUp version: 8
License type: Pro
Postby Jspro » Tue Aug 28, 2012 9:40 pm
Dear tig i am truley trying to find this .skp file when i type in search the drawing comes up, and i know now thats not what you want. is it some where in the c drive? ive look in sketchup folders, i dont know? the AdditionalPluginFolders.rb' was suggested by the author. would you like me to remove it?
Jspro
Postby TIG » Tue Aug 28, 2012 9:54 pm
If you are not actually 'using' the '...AdditionalPlugins' script then please remove it from the Plugins folder. It's pointless having things complicate issues unnecessarily...
On this question of the 'SKP file'...
How have you been able to open and save models thus far ???
If you have a new Sketchup model and you save it, you are prompted where to save it to.
How do you then open it later ?
That is the very SKP file you could attach to a post - although as I have said it's unlikely to offer much of a solution...
Surely you understand the basic operation of a computer ?
Have you ever used a PC before ?
Do you understand how files are made and saved as different 'types of file', so that they will open with different applications that are specific to that 'type' etc... for example a TXT file or a DOC file or a SKP file, or a PNG or JPG file, etc will ALL open with different applications [aka programs!]..
:roll:
Global Moderator
SketchUp version: 8
License type: Pro
Postby Jspro » Wed Aug 29, 2012 1:51 am
TIG, well your patience with me paid off. I removed the AdditionalPlugins than restarted win and now it works, i glad you stayed and helped. When i was downloading the plugin (Round Corner) the author had put id his referral of this (I also suggest that you install 000_AdditionalPluginFolders to have more control on errors when Sketchup loads plugins.) so i did? i dont know. Well thanks again John
Jspro
Postby blackcat1313 » Tue Sep 18, 2012 6:28 am
I just gotta say, this plugin is FANTASTIC -- I just tried it on a few simple shapes and it works great! Thanks Oscar! You plugin writers are really making this Sketchup thing work in the real world! :ecstatic:
Bill
blackcat1313
Operating system: Mac
SketchUp version: 8
License type: Free
SketchUp use: hobby
Level of SketchUp: Beginner
Postby huajiet » Thu Oct 11, 2012 5:14 pm
hi,
first of all, great plugin. it has been working fine for the first few times until recently, when the plugin stopped giving any observable response after selecting both operands.
ruby console gives me something like this:
WARNING: make_unique is a deprecated methodof Sketchup:Group
Error: #<TypeError: reference to deleted Edge>
(eval):279:in `all_connected'
(eval):279:in `Remain_Face'
(eval):279:in `collect'
(eval):331:in `Intersect_outer'
(eval):422:in `Cut'
(eval):123:in `set_current_point'
(eval):80:in `onLButtonUp'
(eval):279
could someone interpret this for me?
much thanks in advance.
huajiet
Postby nate812 » Fri Oct 12, 2012 1:01 am
Awesome! Thanks! I had to disable SketchyPhisics to allow it to work - but works great!!
nate812
Postby willyshop » Sun Nov 04, 2012 6:28 am
I'm having some trouble getting this to work. After I installed it and restarted sketchup, the new toolbar didn't show up. I went in the ruby console to load it manually, and got the following error:
Error: #<SyntaxError: (eval):27:in `load': /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/OSCoolean.rbs:1: no .<digit> floating literal anymore; put 0 before dot
RBS1.0
/Library/Application Support/Google SketchUp 8/SketchUp/Plugins/OSCoolean.rbs:1: parse error, unexpected tINTEGER
RBS1.0
(eval):27
(eval):27
willyshop
SketchUp version: 8
License type: Free
SketchUp use: engineering and mechanical design
Postby TIG » Sun Nov 04, 2012 11:53 am
Did you look under View > Toolbars [aka ToolPalettes on MAC ?] to activate its toolbar ?
Unsure about that 'error message' - the script is encrypted as RBS rather than a readable RB format...
Global Moderator
SketchUp version: 8
License type: Pro
Postby prairiemain » Thu Nov 15, 2012 11:19 am
This is an EXCELLENT tool. I don't see how anyone using Sketchup on a regular basis can live without it. I'd rank this in the top five MUST HAVE extensions.
When I first installed this and could not get it to work. I finally did get it to work and my problem was operator error :roll: I was using it wrong. You first select WHAT operation you want to perform THEN the two components you want to operate on. Works like a charm, then.
I'm usually pretty good at following directions, as per the OSCoolean videos which are short and show absolutely what you need to know, but one gets into the habit of first "selecting" then "operating" for core and plugin functions. Hopefully, this experience will teach me to be more alert.
Others have mentioned this in previous posts but I thought I would also bring it up: While using the Ruby Console to debug for why this plugin was not working, I did not see error messages but warnings about "deprecated".
Code: Select all
A hearty salute to the author of this great tool, oscarlok.
prairiemain
SketchUp version: 8
License type: Free
SketchUp use: film and stage
Postby TIG » Thu Nov 15, 2012 12:33 pm
Don't worry WARNING: make_unique is a deprecated methodof Sketchup:Group is an erroneous 'spurious' message from the API.
In fact there are many occasions when you need to make groups unique so that you only have the one instance to refer to.
The 'error' message assumes that every operation on duplicating a group makes it unique automatically [as it logically ought to be], BUT this is actually not the case!
To see this, make a simple group and then copy it using Move+Ctrl.
Select one instance and open Entity Info, it will report that there are two groups with the same definition in the model !!
Now edit the selected group, but close the edit without making any changes.
Now the selected group's Entity Info reports ONE group, the copy has been rendered unique automatically by SketchUp working behind the scenes.
The equivalent in the API code is group.make_unique - this will produce the same result [as you can't mimic an 'edit' in code any other way].
Therefore the method is NOT 'deprecated' and is needed whenever group.entities.parent.instances[1] returns true, like when a group has been copied and not edited...
It will remain that way until the SketchUp inner workings auto-uniquify copied groups, so then authors won't have to trap for duplicates in Ruby code as there'll never be any...
Global Moderator
SketchUp version: 8
License type: Pro
Need Authorised SketchUp Training by experts in various disciplines? Check out our Training details.
PreviousNext
Return to Plugins
Users browsing this forum: abelio333, Google Feedfetcher, Lenny12, lutus and 16 guests
