[Plugin] SCF PowerToolbar (09.Sep.2010)
Re: [Plugin] SCF PowerToolbar v1
Postby rongvuong » Thu Sep 09, 2010 12:08 pm
Don't work with sketchup 8.
help me?
rongvuong
Postby Humpmetwice » Thu Sep 09, 2010 2:43 pm
I get this error after installing the power toolbar. Did I do something wrong, is there something else I need?
Humpmetwice
Postby CadFather » Thu Sep 09, 2010 3:05 pm
ok, wrong lines have been changed - hope it still works.
CadFather
PluginStore Author
PluginStore Author
Postby thomthom » Thu Sep 09, 2010 3:14 pm
Could you add a Last Updated timestamp to your original post? Makes it easier to catch any updates when you browse the plugins.
PluginStore Author
PluginStore Author
Postby Humpmetwice » Thu Sep 09, 2010 3:18 pm
CadFather wrote:ok, wrong lines have been changed - hope it still works.
Is there something I can do to fix this or do I need to uninstall it? It still works but is aggravating :o !
Humpmetwice
Postby CadFather » Thu Sep 09, 2010 3:27 pm
Thom, you mean in the subject, or just the post?
@ humpmetwice, i don't think this has to do with SCF-PB - take out all your plugins then install PB, if it works then you know..
CadFather
PluginStore Author
PluginStore Author
Postby thomthom » Thu Sep 09, 2010 4:11 pm
CadFather wrote:Thom, you mean in the subject, or just the post?
At least the subject - since that appears when you browse the forum and also in Jim's index.
PluginStore Author
PluginStore Author
Re: [Plugin] SCF PowerToolbar (09.Sep.2010)
Postby CadFather » Thu Sep 09, 2010 4:15 pm
yes of course.. done.
CadFather
PluginStore Author
PluginStore Author
Postby unclex » Thu Sep 09, 2010 6:15 pm
where is the new guy?
unclex
Postby the.pjt » Tue Oct 05, 2010 6:06 pm
How do we can unpack the main file to edit it ? is it possible to unpack a code ? can you upload a unpacked version ?
the.pjt
Postby bd99 » Wed Oct 06, 2010 7:45 am
thankkkkkkkkkkkkkkkkkkkk
bd99
Postby exposal » Tue Nov 02, 2010 3:18 am
I've try on SU8.0 PRO.that's no problem.
exposal
Postby hyprc » Sat Nov 12, 2011 12:55 pm
so cool, thank U
hyprc
Postby TIG » Sat Nov 12, 2011 2:25 pm
I've edited the download page - with a warning about 'rogue files' inside the zip!
CADfather, can you please sort out this issue, which can break some other tools and cause other problems - the older files [sketchup.rb and extensions.rb] supplied in the zip should NEVER be put into the Plugins folder. In all recent versions of Sketchup newer versions of those files come pre-installed in the Tools folder, so having these duplicates just messes things up - sometimes so subtly it causes hours of searching to find what's up! :roll:
Global Moderator
Postby CadFather » Sat Nov 12, 2011 2:28 pm
sure, i'll post an update very soon
CadFather
PluginStore Author
PluginStore Author
Postby Unr Cruurni » Tue Jul 17, 2012 1:18 pm
Hay all fearless Ruby Scripters!
First I want to thank you all for the wonderfull job your doing !
now,
Using SCF powerbar with Metric Meters template is O.k?
since I'v been having trouble with the Push-Pull along normals tool.
I set 6m as a value and it Pulls 0.15m...
Thanks ! ALOT!
Unr Cruurni
Postby anderseide » Mon Oct 22, 2012 11:27 pm
Hello¨
First of all, great work!
Second, am I the only one getting trouble installing all the SCF bars(power bar, architect, draw tool, selective etc)? They all have their icons in a folder called CD_ICONS, so loading them all in the plugins folder made them overwrite each other. In the end I had to change each folder to CD_ICON1, CD_ICON2, and then change the routing in the orignial rb. file.
Am I the only one experiencing this?
Third: All my plugin toolbars load at startup except the different SCF`s. I have tried twenty times to place them and save the template, but it doesn`t work When I manually toggle them on, they`re in the right place, so I guess the template is saved, but the toolbars won`t show up without manually enabling them.
Any suggestions?
Thanks!
anderseide
Previous
Return to Plugins
Users browsing this forum: BenRitter, busradavaz, dennipeter, jsteacy, Mandreshi and 13 guests
