[Plugin] SCF PowerToolbar (09.Sep.2010)
Re: [Plugin] SCF PowerToolbar v1
Postby CadFather » Mon Jan 05, 2009 12:55 pm
you can now find the video tutorials here as well http://www.youtube.com/user/VideoSketchup
CadFather
PluginStore Author
PluginStore Author
Postby me3mar » Mon Jan 05, 2009 2:13 pm
First of all many thanks for the power toolbar.
i'm having some troubles with half of the funktions of the toolbar, eventhoght there's no problem reports or warnings,
i just klick the button, nothing happens! by (devide and portrude) i fill the options, then klick devide, or portrude... nothing happens.
the same is happening by the following comands : Portrude, FFD (all 4), and Bevel.
any suggestions?
thanks again in advance
me3mar
me3mar
Postby CadFather » Mon Jan 05, 2009 3:22 pm
..i need more info - are you using a mac?
CadFather
PluginStore Author
PluginStore Author
Postby me3mar » Mon Jan 05, 2009 4:40 pm
i am using pc windows xp pro - Sp 3 -
ram 4 g.
quad core 2,4 GH.
sketchup 7
thank you again
me3mar
me3mar
Postby CadFather » Mon Jan 05, 2009 4:53 pm
if the system is good it should work - if you have multiple copies of the same plugins as the ones included in the powertoolbar (protrude etc) you can get into problems
start from this, making sure these are the only contents in the plugins folder (back up the old one)
if it works reintroduce the others by elimination
http://www.sketchucation.com/forums/scf/viewtopic.php?f=180&t=14770&st=0&sk=t&sd=a&start=15#p112166
CadFather
PluginStore Author
PluginStore Author
Postby me3mar » Mon Jan 05, 2009 10:13 pm
i had to move all the rubys manualy and cleanup a little, and it works fantastic!!
thanks CadFather for your help
me3mar
me3mar
Postby Fletch » Tue Jan 06, 2009 8:55 pm
Great work on those tus Cadfather! :thumb:
I realized I'm working with the 'old' protrude... didn't realize it had such great improvements - gotta go get it now 8-)
Fletch
Twilight Render
Postby numerobis » Tue Jan 06, 2009 10:57 pm
WOW!!! very cool! thank you! :D
numerobis
Postby Edson » Wed Jan 07, 2009 8:18 pm
max,
in order to install this toolbar i removed all my plugins and started moving them back carefully in order no to have double copies. in doing so i realized that another toolbar you made (ARCHILAND toolbar) has a folder called CD_ICONS, the same name of the icons folder for the powertoolbar. my question: is it ok to have both folders with the same name? will not there be some confusion between them? what should i do?
edson mahfuz, architect | porto alegre • brasil
http://www.mahfuz.arq.br
Edson
Global Moderator
Postby Edson » Wed Jan 07, 2009 9:04 pm
after all i did not manage to install it. the same error message as BTM reported appears to me.
oddly enough, why does the ARCHLAND toolbar installs without any problems and the POWERTOOLBAR does not?
individually, all the scrips run on my mac.
Edson
Global Moderator
Postby bellwells » Thu Jan 08, 2009 4:49 am
Edson wrote:max,
Edson, there will be a problem with 2 folders the same name as you'll be asked if you want to replace the old with the new, which you do NOT want to do! What I did was simply place the contents of the PowerToolbar CD_ICONS into the other CD_ICONS folder (or vice versa) by copy all and paste.
Max, thanks for another great addition to SU!!!!
Ron
bellwells
Premium Member
Premium Member
Postby CadFather » Thu Jan 08, 2009 8:44 am
hi Edson, the two plugins have different subfolders inside CD_ICONS (architect and power). you should have 1 cd_icons folder and inside it, the 2 subfolders.
i think the parsing errors reported can be easily fixed but i do not have a mac to check/fix - some kind master with a mac could look into it perhaps?
the quick other option is to disable the plugins which cause the error - if you can report the full text of the ruby console i will try later..
CadFather
PluginStore Author
PluginStore Author
Postby chango70 » Thu Jan 15, 2009 4:37 am
OMG, Cadfather, why can't Google hire you!? I am always amazed by how professionally thought out your tools (interface at least) are! Thank you. :ecstatic:
chango70
Postby CadFather » Thu Jan 15, 2009 9:24 am
thanks Chango, though without the masters we would only have a 'nice' interface... ;)
(..there's more cooking in the oven..) ;)
CadFather
PluginStore Author
PluginStore Author
Postby xrok1 » Mon Jan 26, 2009 6:24 am
i think it would be great (not that its not great already, but greater yet) if we could have just one SCF Toolbar & then pick and choose which ruby's we want in it, like a visual plugin bar that could be customized with any of the tools from your series of toolbars (mix and match).
any chance of this? ;)
“There are three classes of people: those who see. Those who see when they are shown. Those who do not see.”
xrok1
Postby pilou » Mon Feb 02, 2009 7:12 pm
Amazing and cool design! :fro:
A list here of Plugs used will be useful ;)
Speedy Galerie
Top SketchUcator
Postby driven » Sat May 09, 2009 1:19 am
has any one got this fully running on a mac??
i get this error, functionality of some of the tools
john
driven
PluginStore Author
PluginStore Author
Postby Chris Fullmer » Sat May 09, 2009 1:22 am
Tiffs don't work on the forum John. Use a file format more common to the web like jpg, or png works great.
Chris
All my Plugins I've written
SketchUp Team
SketchUp Team
Postby •BTM » Sat May 09, 2009 1:39 am
tiff works on the forum
...but maybe only on macs... ;)
Anyways, I had the same problem too. I no longer have the SCF powertoolbar.
•BTM
PluginStore Author
PluginStore Author
Postby Chris Fullmer » Sat May 09, 2009 1:44 am
That is very interesting. I never knew that. They do not show up on PC's. Good to know,
Chris
I've never liked the tiff format and I don't know why.
SketchUp Team
SketchUp Team
Postby •BTM » Sat May 09, 2009 2:48 am
I don't like it much either. Same, I don't know why. I like PNG the most :thumb:
•BTM
PluginStore Author
PluginStore Author
Postby modelhead » Sat May 09, 2009 3:45 am
I sat and looked at the bar a few months ago and thought it looked like a toybox. I have been playing with it like a big kid ever since then. I can't count the hours I have had good fun and adventure with it. There seem to be just endless things to explore with the power toolbar and many other tools that just keep coming from our homegrown ruby community.. Thanks for a great time!! :D
:enlight:
modelhead
Postby Sir » Sat May 09, 2009 12:41 pm
the link to your website is broken btw
Sir
Postby windrockwater » Sat Jul 04, 2009 12:44 am
The link for downloading this cool script is not working. Is there a working link available? TIA...
windrockwater
Postby CadFather » Sat Jul 04, 2009 4:39 am
Hi, link repaired.. thanks
CadFather
PluginStore Author
PluginStore Author
Postby haroldcampbell » Wed Feb 24, 2010 6:44 pm
driven wrote:has any one got this fully running on a mac??
john
Don't know if this is still an issue for anyone, but you can find a patched version that works for me.
I changed line 4921
Code: Select all
if (n1.between? (n2 - interval), (n2 + interval))
to
Code: Select all
if ( n1.between?((n2 - interval), (n2 + interval)) )
I'm running mac os x 6, SketchUp 7 (7.1.6859)
haroldcampbell
Re: Errors in [Plugin] SCF PowerToolbar v1
Postby Dan Rathbun » Tue Aug 31, 2010 5:04 am
The errors are caused by poor programming style.
If you run SU7 Mac (with Ruby 1.8.5-p0) OR run SU7 on PC AND have updated your Ruby interpreter DLL to Ruby 1.8.5 or higher, then certain "typos" are no longer permitted by the Ruby interpreter.
cd_power_extension_m.rb
Line 4921:
* move first "(" just after "between?" and before "(n2", so it replaces the space character. Like:
if n1.between?((n2 - interval), (n2 + interval))
cd_power_m.rb
* same fix as above, .. replace Line 4921
with:
cutting_windows.rb
fix Line 610:
faces_and_heights[0].pushpull (faces_and_heights[1]), false
* add parenthesis around pushpull method's argument list, ie:
faces_and_heights[0].pushpull( (faces_and_heights[1]), false )
What is happening, is that:
  • Ruby is getting confused as to what are method argument lists, and what are arguments (delimeted with parenthesis,) within the arguemnt list.
  • For best practice in later Ruby versions, all methods should have parenthesis around the whole argument list, with NO space between end of method name and the left parenthesis of it's argument list.
  • If a method has no args, speed up Ruby by passing an empty arg list, like so:
    obj.method_name()
    I'm not here much anymore. But a PM will fire email notifications.
    Dan Rathbun
    PluginStore Author
    PluginStore Author
    Postby Nosonja » Mon Sep 06, 2010 8:50 pm
    Don't work with sketchup 8.
    Nosonja
    Postby CadFather » Mon Sep 06, 2010 10:32 pm
    i'm hoping to fix the bugs soon..
    CadFather
    PluginStore Author
    PluginStore Author
    Postby tina0603 » Thu Sep 09, 2010 11:47 am
    try to replace it with haroldcampbell attachments
    tina0603
    PreviousNext
    Return to Plugins
    Users browsing this forum: JmSH, KINOMBOY, ngohung and 13 guests
